2017-12-22 | libvpx bbappend: follow version upgrade | Max Krummenacher | |
The append is only needed for T20 as it does not have a neon unit. The other SoC compile fine without any change. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> | |||
2016-09-29 | meta-openembedded layer bbappends | Max Krummenacher | |
Move the appends on recipe's which are not in an essential required layer into a target layer specific directory and add them only if said layer is active in build/conf/bblayers.conf. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com> |
