Note that we currently do not want to use the stable symlinks to the
eMMC for modules were older version of the Toradex Easy Installer exist.
Using the stable symlinks would require a Toradex Easy Instaler 5.3.0 or
newer.
For Verdin iMX8MP 5.3.0 is the first version and thus we can directly use
the stable symlink name pointing to the eMMC.
Related-to: TEI-750
(cherry picked from commit fad3643e14fc4412288549b833b097ec4a44bf33)
I have observed a following OE build issue with the latest
dunfell-5.x.y, as follows:
ERROR: OE-core's config sanity checker detected a potential misconfiguration.
Either fix the cause of this error or at your own risk disable the checker (see sanity.conf).
Following is the list of potential problems / advisories:
TMPDIR changed to include path filtering from the pseudo database.
It is recommended to use a clean TMPDIR with the new pseudo path filtering so TMPDIR would need to be removed to continue.
this is due to the ABI VERSION changed in OE, usually we should remove
the TMPDIR and rebuild when seeing this error, but it's not enough for
Toradex builds, since we have split DEPLOY_DIR out of TMPDIR, so we
should also check the ABI VERSION change in DEPLOY_DIR, or else it
might not comply the OE layer.
We should warn the end users about this risk, let's add a toradex
sanity check bbclass for that.
We can also add some other basic Toradex specific sanity checks, for
instance, for fitimage, the end users must inherit toradex-fitimage
rather than kernel-fitimage.
Related-to: ELB-3944
Signed-off-by: Ming Liu <ming.liu@toradex.com>
(cherry picked from commit 943f7da5a1cbbf695c3385b59e33aaea0c87904c)
This makes it possible to build a image tarball with 'autoinstall'
enabled.
Related-to: TEI-773
(cherry picked from commit 9e9859a9d3cb5a6daa2a8a7e0c98d5830021b644)
and
(cherry picked from commit b960cee9fba7f3f9a6603cd5464fcfa45df3bceb)
present
Partly back-port commit 2d9f3c3d763e2bca704da4019add973b9a2c572f from
OE upstream:
kernel-fitimage: build configuration for image tree when dtb is not present
This patch adds support for adding configuration node even
when dtb is not part of the FIT image. The conf and default
node number are therefore changed to point to kernel ID rather
than dtb ID when dtb does not exist.
to support fitImage for qemu machines which dont have a dtb node.
Related-to: TOR-1700
(cherry picked from commit 4a67680a10d7567499c15c3ffc065b5b4d05f07b)
Keep hard-copy version of license file
in sstate cache in case of NXP connection error
Related-to: ELB-3485
Signed-off-by: Denys Drozdov <denys.drozdov@toradex.com>
(cherry picked from commit b29e20964a72e01193b242aefb6cde655dda7d87)
Devicetrees and overlays have been bundled into fitimage, so we dont
have to install them to boot partition.
(cherry picked from commit d87faee758c3b37797f0dc53e4486d5f82a48173)
To support devicetree overlays, we need let fitimage_assemble handle
both ${KERNEL_DEVICETREE} and ${EXTERNAL_KERNEL_DEVICETREE} at
meanwhile, but the fitimage_assemble can only deal with one. ( when
${EXTERNAL_KERNEL_DEVICETREE} is set, it will skip
${KERNEL_DEVICETREE} )
Let's override fitimage_assemble to be able to assemble all dtb/dtbo
files in ${KERNEL_DEVICETREE} and ${EXTERNAL_KERNEL_DEVICETREE}.
(cherry picked from commit 5e1b1f1d77b50005c4342669a25beebc6e6c248e)
The major reason for doing this is because we are currently deploying
all dtbo files to ${DEPLOY_DIR_IMAGE}/devicetree, but not machine
specific ones, and they will be unnecessarily bundled into fitimage
when kernel-fitimage.bbclass is being inherited.
To fix that, we introduce a extra task do_collect_overlays to collect
machine specific overlays to ${DT_FILES_PATH} before do_compile, where
dtb compilation is being compiled in. In this way, only machine
specific overlays would be compiled and deployed.
(cherry picked from commit 3f3703403ce8451c997faee1eb1f7665bff24437)
squashed with
(cherry picked from commit 80534650f210472afbfd6f5d6d80559c708eb72e)
(cherry picked from commit 6d8f8337ff1bf0200dead6adbc2615556b6495de)
The License window will be shown in case SHOW_EULA_FILE set to "1"
(cherry picked from commit a4f005089d9c286fa33f4fb5f2e41f1a0ee614d6)
Ensure there is a popup that shows the EULA license
to be accepted once installing a tdxref image
(cherry picked from commit 9ececa26080b7abdc96dc1b4b910e735b6eafcfd)
The current wildcard setting deploys machine specific overlays with
<machine>* and thus e.g. apalis-imx8 gets additionally those specific
to apalis-imx8x.
Fix that.
Related to: ELB-3499
(cherry picked from commit dd8c0e4a0ac40381e2ed0a112105e8d9a8af4387)
If one uses our BSP layers / machines without a Toradex distro the
do_image_teziimg step fails due to missing variables.
Add weak defines of those.
(cherry picked from commit 02a227afd8b099e79280131eddbe59d05f8e2865)
This patch mainly aims to let fdt_overlays only contain devicetree
overlay names without the 'overlays' sub-directory.
Also add a sanity check for items in
TEZI_EXTERNAL_KERNEL_DEVICETREE_BOOT, if a item not existing in boot
filesystem, throw a error at build time.
A complementary patch is needed to boot script, to load devicetree
overlays from a configurable prefix.
Related-to: TOR-1537
(cherry picked from commit a2a5fb89339eff7d0f729086d04c949e9c4955ee)
We have decided to drop boot partition from EMMC/RAWNAND devices for
all Torizoncore images, in which case, we dont have to maintain a extra
image type teziimg-distro for Torizoncore, let's drop it.
This patch would not introduce any functional change to teziimg images,
just aims to drop all Torizoncore related code.
Introduce two new variables to make teziimg more extendable:
- TEZI_ROOT_NAME: the end user could choose rootfs image name, for
instance, "rootfs", "ota".
- TEZI_USE_BOOTFILES: the end user could decide if a boot partition
should be created for EMMC device.
Related-to: TOR-1334
(cherry picked from commit 048fa23d795bbaf4ab31f3f5340ce64839b0e525)
Move the code deploying dtb overlays to a prefuncs
tezi_deploy_dt_overlays of do_image_bootfs, and put all prefuncs of
do_image_bootfs, do_image_teziimg, do_image_teziimg_distro to variables
so that they could be overridden in other meta layers. For instance, an
end user might want to write his/her own image.json file according to
his/her partitions layout.
Also fix a missing double quotes.
(cherry picked from commit 29c2fb146a127e2a26d6baab641bd7ba3867c3b5)
We have machine overlay where the machine name is postfixed with the
carrier board name, e.g. colibri-imx7-aster_atmel-mxt_overlay.dts.
No longer require an '_' after the machine name to deploy also overlays
with a postfix after the machine name.
(cherry picked from commit 0e19023b9fd03f6922992c59f4ddc3a4aff9f36d)
For the colibri-imx7-emmc machine we need the overlays prefixed with
colibri-imx7.
Due to the changed machine name the machine specific overlays did
not get deployed into a image. Fix that.
(cherry picked from commit 75d703f9af475110554d1a88954998291b2ce96a)
We have separate machines for the now deprecated i.MX 8X B0 silicon
based modules.
(cherry picked from commit ec02225f82cbf9054ea1bf301967ebf1b9ea98fa)
On i.MX8 processors there was a bug in Tezi that leaked an old
u-boot environment into newly installed image. This got fixed and
can be enforced by using Tezi config format number 4.
Make use of that.
(cherry picked from commit 51927b354280c398b11b7b6bd64c1617825f17d1)
The device-tree overlays have been reworked. Reenable the build
and deployment.
This reverts commit 1914b33f70f13b5460152daaf49de7511e4990ee.
Related-to: ELB-2943
They currently do not build against the downstream kernel, drop them
if building for a downstream kernel for now.
It's useless and would be overridden by the same definition in
imx-base.inc of meta-freescale layer.
Related-to: ELB-2553
The default u-boot env file name has changed to u-boot-initial-env in
OE layer, adapt to it.
Rename destination "devicetree" with dtb overlays (on bootfs) to "overlays".
Relates-to: ELB-2807
Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com>
(cherry picked from commit 288b7e41f508e0dcde66b536953d014dd4497971)
If using upstream variants kernel itself is close to 8 MB and one can
barely keep a backup copy in the resulting 16 MB!
(cherry picked from commit aae74f006cd02717df3b047b59940196de53c105)
Iterating through the variable don't interpret quotes at and they
act as a part of variable. It leads to iterate with the wrong
filenames [1]. Removing quotes fixes overlay names.
[1]
PC $ cat overlays.txt
fdt_overlays="1 2 3"
Apalis iMX6 # env import -t ${loadaddr} overlays.txt
Apalis iMX6 # print fdt_overlays
Apalis iMX6 # for overlay_file in ${fdt_overlays}; do echo "file=${overlay_file}"; done
file="1
file=2
file=3"
Related-to: ELB-2797
Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
(cherry picked from commit b8b2e862432c0a30f41bd19efb66ec80267e7f5d)
Commit 0b33be8f "image_type_tezi.bbclass: allow inexistence of machine specific overlays"
introduces the regression bug, that prevents to gather machine-specific
dtbos.
This commit fixes the bug.
Fixed: 0b33be8f ("image_type_tezi.bbclass: allow inexistence of machine specific overlays")
(cherry picked from commit 5846cdddd88363cfa8bab0bf14d5999f20503709)
Gracefully continue should there not (yet) be any machine specific
device tree overlays.
This avoids the following build failure:
ERROR: Logfile of failure stored in: /home/user/builds/oe-core_4.0/build
/tmp/work/apalis_imx8-tdx-linux/console-tdx-image/1.0-r0/temp
/log.do_image_bootfs.4117712
Log data follows:
| DEBUG: Executing python function tezi_deploy_bootfs_files
| DEBUG: Python function tezi_deploy_bootfs_files finished
| DEBUG: Executing python function set_image_size
| DEBUG: 168906.400000 = 129928 * 1.300000
| DEBUG: 168906.400000 = max(168906.400000, 65536)[168906.400000] + 0
| DEBUG: 168907.000000 = int(168906.400000)
| DEBUG: 168907 = aligned(168907)
| DEBUG: returning 168907
| DEBUG: Python function set_image_size finished
| DEBUG: Executing shell function do_image_bootfs
| ls: cannot access 'apalis-imx8_*.dtbo': No such file or directory
| WARNING: /home/user/builds/oe-core_4.0/build/tmp/work
/run.do_image_bootfs.4117712:1 exit 2 from
'machine_dtbos=`cd $deploy_dt_dir && ls apalis-imx8_*.dtbo`'
| ERROR: Execution of '/home/user/builds/oe-core_4.0/build/tmp/work
/run.do_image_bootfs.4117712' failed with exit code 2:
ERROR: Task (/home/user/builds/oe-core_4.0/build/../layers
/meta-toradex-demos/recipes-images/images/console-tdx-image.bb
:do_image_bootfs) failed with exit code '1'
NOTE: Tasks Summary: Attempted 5813 tasks of which 5544 didn't need to
be rerun and 1 failed.
NOTE: Writing buildhistory
NOTE: Writing buildhistory took: 15 seconds
(cherry picked from commit 0b33be8fed56b44c8f0b648da20d0b6706d8e7d5)
Introduce TEZI_EXTERNAL_KERNEL_DEVICETREE and
TEZI_EXTERNAL_KERNEL_DEVICETREE_BOOT variables. First one provides the
list of overlays copied to boot partition (by default all overlays are
copied), the second one sets the list of overlays that should be loaded
during boot time (listed in ${bootfs}/overlays.txt).
TEZI_EXTERNAL_KERNEL_DEVICETREE_BOOT defaults to be empty.
Relates-to: ELB-2723
(cherry picked from commit c648af29199e2f8dedcaf6b7c3c61a2dcf6a579b)
UBOOT_BINARY_TEZI_EMMC has been defined in machine conf, drop it.
(cherry picked from commit 1f5d1d2cb0bf8711c93de21bccc6e87bea96253a)
Make sure the git hash is always 12 characters long. This avoids issues
where we can get different length git hashes between to independent
builds. This can be problematic when sstate is shared.
Related-to: TOR-810
Make sure u-boot enviroment is erased when installing
new Toradex Easy Installer image
Related-to: TEI-130
Signed-off-by: Luka Pivk <luka.pivk@toradex.com>
(cherry picked from commit 25711572bcb5a40057b53323b8b34a28f74d9b0f)
It contains a helper function kernel_configure_variable that could be
called in do_configure_append task to assign a value to a config
variable in ${B}/.config.
Change toradex-kernel-localversion.bbclass to use this function.
Handle the case where SRCREV_machine is set to AUTOREV.
As SRCREV_machine isn't set to INVALID as its default drop checking for INVALID.
fixes: f22318f toradex-kernel-localversion.bbclass: use SRCREV to set scmversion
Related-to: TOR-694
Handle the case where SRCREV is set to AUTOREV.
Related-to: TOR-694
In commit 32df2d41:
[ toradex-kernel-localversion.bbclass: use origin branch set scmversion ]
we changed to use origin branch to set scmversion, but that's not good
enough, we should stick to SRCREV which is the latest original commit
in the source.
Related-to: TOR-694
This makes 'config_format' item configurable in different layers.
For kernel-yocto, the commit hash of HEAD is different for every run of
do_patch if there is any patch in SRC_URI, this is breaking the recipes
that relying on KERNEL_VERSION which contains scmversion, so we should
let scmversion stick to the original head instead of the HEAD after
do_patch, this will make scmversion stable and hence will make
KERNEL_VERSION stable for the recipes that relying on it.
So that one sees in the Toradex Easy Installer which image is which.
(cherry picked from commit 3d072f3077b67adf293810da51ba951dc4b6c593)
And the squashed fix:
(cherry picked from commit 78d71eea7dd80066067f93445a957f8396b63c6e)
(cherry picked from commit e6e0f885bc858f16a6c49522d91e7b6dc67d2a16)
Introduce TEZI_DATE variable, it defaults to ${TDX_MATRIX_BUILD_TIME}
but could be overridden in local.conf.
It will be used to set release_date in image json files, hence it must
be excluded by IMAGE_TYPEDEP_teziimg and IMAGE_CMD_teziimg-distro to
avoid running into basehash mismatch problems.
Currently we are generating image.json files directly in
${DEPLOY_DIR_IMAGE} which is not correct, since image.json file is a
image specific file so race condition could happen when multiple image
builds write to a same image.json.
Fix it by generating image json files in ${IMGDEPLOYDIR} directory with
IMAGE_BASENAME suffix and copying them to a temporary directory
${WORKDIR}/image-json with the final json names. In this way, the json
files could be handled by sstate and they turn to be image specific.
Actually, LOCALVERSION_AUTO needs to be enabled to make the kernel
build system picking up .scmversion. So make sure LOCALVERSION_AUTO
is enabled when we generate a .scmversion file and disabled otherwise.
Fixes: 1bb212d9311a ("toradex-kernel-localversion: disable automatic localversion")
Introduce a new variable TEZI_IMAGE_NAME to allow a custom image name
for the Tezi tarball. This allows to stick with the default OpenEmbedded
image names for rootfs tarballs etc. while still following custom naming
rules for the final Tezi images.
Default to IMAGE_NAME to retain backward compatibility.
Make sure LOCALVERSION_AUTO is disabled to avoid interference with
our LOCALVERSION. This fixes building of the i.MX 8 kernel recipe.
Make sure TDX_VERSION is defined in case Toradex distro is not used.
This avoids confusing localverisons with just a dash.
The mainline recipe has the .config file ready later then our kernel
recipes. Use kernel_do_configure_append() which seems to work for both
cases.
The blank should be before the value rather than after it, or else we
risk on messing up the values by 'a b' > 'ab'.
Use OFFSET_SPL_PAYLOAD to decide if a SPL has to be deployed or not.
This allows a simple integration of machines which have an SPL (as e.g.
verdin-imx8mm has) but do aggregate the SPL and U-Boot proper into one
binary.
The list of deployed U-Boot artefacts is set in python for the 'distro'
tezi-image, but in the non 'distro' case directly in the tar command.
Unify that to put the list together in python.
Using PV is not a good idea with the new versioning, especially since
there is a timestamp in the version number. Use the DISTRO_VERSION
variable by default.
