path: root/classes/toradex-kernel-config.bbclass
2020-03-14toradex-kernel-config: add bbclassMing Liu
It contains a helper function kernel_configure_variable that could be called in do_configure_append task to assign a value to a config variable in ${B}/.config. Change toradex-kernel-localversion.bbclass to use this function. Signed-off-by: Ming Liu <ming.liu@toradex.com> (cherry picked from commit aaf2b59a0bd69c1cfea6d2fc0df30ab49e16e031)
