2014-10-30 | lxdm: remove LXDM 0.4.1 in favor of LXDM 0.5 of meta-openembeddeddaisy | Stefan Agner | |
Remove LXDM 0.4.1 receipts in favor of LXDM 0.5 from meta-openembedded. The version 0.5 also supports systemd-logind as login/session manager which allows to remove now unsupported ConsoleKit without losing functionality. | |||
2014-10-29 | lxpolkit: disable XDG autostart | Stefan Agner | |
Disable XDG autostart of lxpolkit. lxsessions starts lxpolkit automatically without the need of a extra XDG autostart file. | |||
2014-10-29 | lxsession: fix Hibernate button, gets disabled now | Stefan Agner | |
The Hibernate function doesn't exist in our kernels, using DBus and systemd-logind, the lxsession should determine whether there is Hibernate support or not. However, due to a bug in the result parsing of lxsession, this did not work properly. Add patch to fix this issue. | |||
2014-10-23 | lxrandr: don't use symlink for configure.ac | Stefan Agner | |
Do not use symlink for configure.ac since autoconf don't like both, configure.in and configure.ac in place. | |||
2014-10-22 | lxrandr: use symlink to create configure.ac | Stefan Agner | |
Solves issue when building lxrandr with persistent work directory: | mv: cannot stat '/build/linuxdev/yocto-autobuilder/yocto-worker/toradex/build/build/out-eglibc/work/armv7ahf-vfp-neon-angstrom-linux-gnueabi/lxrandr/0.1.2-r0/lxrandr-0.1.2/configure.in': No such file or directory | |||
2014-10-22 | obconf: force overwrite language files by autopoint | Stefan Agner | |
This fixes errors when a second machine is built with the same work folder: | autopoint: File config.rpath has been locally modified. | autopoint: File po/Makefile.in.in has been locally modified. | autopoint: *** Some files have been locally modified. Not overwriting them because --force has not been specified. For your convenience, you find the local modifications in the file '/tmp/gtf3UV2x/autopoint.diff'. | autopoint: *** Stop. | ERROR: autopoint failed | |||
2014-10-01 | obconf: add mirror for git | Max Krummenacher | |
2014-06-09 | lxsession: fix autoconf build | Max Krummenacher | |
2014-06-09 | lxpolkit: fix autoconf build | Max Krummenacher | |
2014-06-09 | lxmenu-data: fix gnu-gettext changes | Max Krummenacher | |
2014-06-09 | lxdm: fix autoconf build and add depends | Max Krummenacher | |
2014-06-09 | gpicview: deploy icon | Max Krummenacher | |
2014-06-09 | lxtask: add now required depends | Max Krummenacher | |
2014-06-09 | lxinput: add now required depends | Max Krummenacher | |
2014-06-09 | lxshortcut: add now required depends | Max Krummenacher | |
2014-06-09 | lxde: move base recipes from meta-toradex to meta-lxde | Max Krummenacher | |
while at it, add attional DEPENDS for lxrandr | |||
2014-04-29 | lxdm: add runtime dependency xinitdora | Stefan Agner | |
Add xinit as runtime dependency since its required by LXDM. | |||
2014-03-25 | lxappearance: update to 0.5.5 | Max Krummenacher | |
2014-03-10 | lxsession: backport of lxsession-logout | Max Krummenacher | |
0.4.9.2 segfaults when systemd's logind is installed. | |||
2014-03-10 | menu-cache: update to 0.5.1 | Max Krummenacher | |
2014-03-10 | lxappearance: update to 0.5.4 | Max Krummenacher | |
2014-03-10 | gpicview: update to 0.2.4 | Max Krummenacher | |
2013-10-15 | lxpanel: fix paths in git repodylan | Max Krummenacher | |
2013-10-15 | lxpanel: update to 0.6.1 | Max Krummenacher | |
2013-10-15 | lxtask: backport Patch that resolves -1% CPU | Max Krummenacher | |
http://lxde.git.sourceforge.net/git/gitweb.cgi?p=lxde/lxtask;a=commit;h=963dea395cc58eae940b85e242f0d84fb7d2eaa5 | |||
2013-10-15 | DEPENDS: replace ${RDEPENDS} with the explicit deps | Max Krummenacher | |
DEPENDS lists required built recipes at build time, whereas RDEPENDS does list required packages at runtime. So don't confuse the two namespaces by using one to define the other. | |||
2013-10-15 | lxsession: enable dbus | Max Krummenacher | |
2013-10-15 | lxde: use packagegroup instead of task | Max Krummenacher | |
2013-10-15 | lxpanel: add wireless-tools to dependencies | Max Krummenacher | |
2013-10-15 | Convert to new ALTERNATIVE_${PN} syntax | Max Krummenacher | |
2013-10-15 | task-lxde-extended: remove package lxsession-edit, this is now part of lxsession | Max Krummenacher | |
2013-10-15 | lxsession: update to 0.4.9.2 | Max Krummenacher | |
2013-10-15 | lxpanel: add libwnck as a dependency | Max Krummenacher | |
2013-10-15 | lxpanel: update to 0.5.12 | Max Krummenacher | |
2013-10-15 | lxinput: update to 0.3.2 | Max Krummenacher | |
2013-10-15 | lxappearance: update to 0.5.2 | Max Krummenacher | |
2013-10-15 | gpicview: update to 0.2.3 | Max Krummenacher | |
2013-10-15 | lxde-icon-theme: update to 0.5.0 | Max Krummenacher | |
2013-10-15 | add _${PN} to all DEPENDS variable definitions | Max Krummenacher | |
2013-10-15 | Add missing autoconf tests required by newer autoconf version Backported a ↵ | Max Krummenacher | |
bugfix to lxdm (lxdm used 100% CPU) | |||
2013-10-15 | Add missing dependency to openbox | Max Krummenacher | |
2013-10-15 | split layer meta-lxde from github.com/tworaz/oe-tworaz | Max Krummenacher | |
2013-08-01 | corrected indentation to not upset bitbake | Steve Phillips | |
2012-01-22 | lxde-icon-theme RDEPEND on gnome-icon-theme. Without it some applications ↵ | Peter Tworek | |
miss certain icons. | |||
2012-01-15 | Fix lxappearance crash when empty cursors are used. | Peter Tworek | |
2012-01-13 | Add task-lxde-extended. | Peter Tworek | |
2012-01-13 | Fix lxde-icon-theme and lxappearance recipes. | Peter Tworek | |
2012-01-13 | Add lxsession-edit recipe. | Peter Tworek | |
2012-01-13 | Add lxpolkit recipe. | Peter Tworek | |
