This is the 5.4.264 stable release
drivers/pci/controller/dwc/pci-imx6.c
commit 0f31993721f92 ("PCI: imx6: Install the fault
handler only on compatible match") overlaps with our
not mainlined THUMB work.
Keep both additions
sound/soc/codecs/sgtl5000.c
commit c062676528865 (ASoC: sgtl5000: Reset the
CHIP_CLK_CTRL reg on remove") with a backport of a
"fixes" commit.
commit 2b3a7a302c9804e463f2ea5b54dc3a6ad106a344 upstream.
The pcm state can be SNDRV_PCM_STATE_DISCONNECTED at disconnect
callback, and there is not an entry of SNDRV_PCM_STATE_DISCONNECTED
in snd_pcm_state_names.
This patch adds the missing entry to resolve this issue.
cat /proc/asound/card2/pcm0p/sub0/status
That results in stack traces like the following:
[ 99.702732][ T5171] Unexpected kernel BRK exception at EL1
[ 99.702774][ T5171] Internal error: BRK handler: f2005512 [#1] PREEMPT SMP
[ 99.703858][ T5171] Modules linked in: bcmdhd(E) (...)
[ 99.747425][ T5171] CPU: 3 PID: 5171 Comm: cat Tainted: G C OE 5.10.189-android13-4-00003-g4a17384380d8-ab11086999 #1
[ 99.748447][ T5171] Hardware name: Rockchip RK3588 CVTE V10 Board (DT)
[ 99.749024][ T5171] pstate: 60400005 (nZCv daif +PAN -UAO -TCO BTYPE=--)
[ 99.749616][ T5171] pc : snd_pcm_substream_proc_status_read+0x264/0x2bc
[ 99.750204][ T5171] lr : snd_pcm_substream_proc_status_read+0xa4/0x2bc
[ 99.750778][ T5171] sp : ffffffc0175abae0
[ 99.751132][ T5171] x29: ffffffc0175abb80 x28: ffffffc009a2c498
[ 99.751665][ T5171] x27: 0000000000000001 x26: ffffff810cbae6e8
[ 99.752199][ T5171] x25: 0000000000400cc0 x24: ffffffc0175abc60
[ 99.752729][ T5171] x23: 0000000000000000 x22: ffffff802f558400
[ 99.753263][ T5171] x21: ffffff81d8d8ff00 x20: ffffff81020cdc00
[ 99.753795][ T5171] x19: ffffff802d110000 x18: ffffffc014fbd058
[ 99.754326][ T5171] x17: 0000000000000000 x16: 0000000000000000
[ 99.754861][ T5171] x15: 000000000000c276 x14: ffffffff9a976fda
[ 99.755392][ T5171] x13: 0000000065689089 x12: 000000000000d72e
[ 99.755923][ T5171] x11: ffffff802d110000 x10: 00000000000000e0
[ 99.756457][ T5171] x9 : 9c431600c8385d00 x8 : 0000000000000008
[ 99.756990][ T5171] x7 : 0000000000000000 x6 : 000000000000003f
[ 99.757522][ T5171] x5 : 0000000000000040 x4 : ffffffc0175abb70
[ 99.758056][ T5171] x3 : 0000000000000001 x2 : 0000000000000001
[ 99.758588][ T5171] x1 : 0000000000000000 x0 : 0000000000000000
[ 99.759123][ T5171] Call trace:
[ 99.759404][ T5171] snd_pcm_substream_proc_status_read+0x264/0x2bc
[ 99.759958][ T5171] snd_info_seq_show+0x54/0xa4
[ 99.760370][ T5171] seq_read_iter+0x19c/0x7d4
[ 99.760770][ T5171] seq_read+0xf0/0x128
[ 99.761117][ T5171] proc_reg_read+0x100/0x1f8
[ 99.761515][ T5171] vfs_read+0xf4/0x354
[ 99.761869][ T5171] ksys_read+0x7c/0x148
[ 99.762226][ T5171] __arm64_sys_read+0x20/0x30
[ 99.762625][ T5171] el0_svc_common+0xd0/0x1e4
[ 99.763023][ T5171] el0_svc+0x28/0x98
[ 99.763358][ T5171] el0_sync_handler+0x8c/0xf0
[ 99.763759][ T5171] el0_sync+0x1b8/0x1c0
[ 99.764118][ T5171] Code: d65f03c0 b9406102 17ffffae 94191565 (d42aa240)
[ 99.764715][ T5171] ---[ end trace 1eeffa3e17c58e10 ]---
[ 99.780720][ T5171] Kernel panic - not syncing: BRK handler: Fatal exception
Signed-off-by: Jason Zhang <jason.zhang@rock-chips.com>
Cc: <stable@vger.kernel.org>
Link: https://lore.kernel.org/r/20231206013139.20506-1-jason.zhang@rock-chips.com
[ Upstream commit 29046a78a3c0a1f8fa0427f164caa222f003cf5b ]
When wm_adsp_buffer_read() fails, we should free buf->regions.
Otherwise, the callers of wm_adsp_buffer_populate() will
directly free buf on failure, which makes buf->regions a leaked
memory.
Fixes: a792af69b08f ("ASoC: wm_adsp: Refactor compress stream initialisation")
Signed-off-by: Dinghao Liu <dinghao.liu@zju.edu.cn>
Reviewed-by: Richard Fitzgerald <rf@opensource.cirrus.com>
Link: https://lore.kernel.org/r/20231204074158.12026-1-dinghao.liu@zju.edu.cn
Signed-off-by: Mark Brown <broonie@kernel.org>
commit cae2bdb579ecc9d4219c58a7d3fde1958118dc1d upstream.
ChromeOS want to support ALC257.
Add codec ID to some relation function.
Signed-off-by: Kailang Yang <kailang@realtek.com>
Link: https://lore.kernel.org/r/99a88a7dbdb045fd9d934abeb6cec15f@realtek.com
commit baaacbff64d9f34b64f294431966d035aeadb81c upstream.
This platform need to set Mic VREF to 100%.
Link: https://lore.kernel.org/r/0916af40f08a4348a3298a9a59e6967e@realtek.com
commit a337c355719c42a6c5b67e985ad753590ed844fb upstream.
It's been reported that the runtime PM on KONTRON SinglePC (PCI SSID
1734:1232) caused a stall of playback after a bunch of invocations.
(FWIW, this looks like an timing issue, and the stall happens rather
on the controller side.)
As a workaround, disable the default power-save on this platform.
Link: https://lore.kernel.org/r/20231130151321.9813-1-tiwai@suse.de
commit 713f040cd22285fcc506f40a0d259566e6758c3c upstream.
Apply the already existing quirk chain ALC294_FIXUP_ASUS_SPK to enable
the internal speaker of ASUS K6500ZC.
Signed-off-by: Chandradeep Dey <codesigning@chandradeepdey.com>
Link: https://lore.kernel.org/r/NizcVHQ--3-9@chandradeepdey.com
commit c7a60651953359f98dbf24b43e1bf561e1573ed4 upstream.
As reported recently, ALSA core info helper may cause a deadlock at
the forced device disconnection during the procfs operation.
The proc_remove() (that is called from the snd_card_disconnect()
helper) has a synchronization of the pending procfs accesses via
wait_for_completion(). Meanwhile, ALSA procfs helper takes the global
mutex_lock(&info_mutex) at both the proc_open callback and
snd_card_info_disconnect() helper. Since the proc_open can't finish
due to the mutex lock, wait_for_completion() never returns, either,
hence it deadlocks.
TASK#1 TASK#2
proc_reg_open()
takes use_pde()
snd_info_text_entry_open()
snd_info_card_disconnect()
takes mutex_lock(&info_mutex)
proc_remove()
wait_for_completion(unused_pde)
... waiting task#1 closes
=> DEADLOCK
This patch is a workaround for avoiding the deadlock scenario above.
The basic strategy is to move proc_remove() call outside the mutex
lock. proc_remove() can work gracefully without extra locking, and it
can delete the tree recursively alone. So, we call proc_remove() at
snd_info_card_disconnection() at first, then delete the rest resources
recursively within the info_mutex lock.
After the change, the function snd_info_disconnect() doesn't do
disconnection by itself any longer, but it merely clears the procfs
pointer. So rename the function to snd_info_clear_entries() for
avoiding confusion.
The similar change is applied to snd_info_free_entry(), too. Since
the proc_remove() is called only conditionally with the non-NULL
entry->p, it's skipped after the snd_info_clear_entries() call.
Reported-by: Shinhyung Kang <s47.kang@samsung.com>
Closes: https://lore.kernel.org/r/664457955.21699345385931.JavaMail.epsvc@epcpadp4
Reviewed-by: Jaroslav Kysela <perex@perex.cz>
Link: https://lore.kernel.org/r/20231109141954.4283-1-tiwai@suse.de
[ Upstream commit fbb74e56378d8306f214658e3d525a8b3f000c5a ]
We need to check for an active device as otherwise we get warnings
for some mcbsp instances for "Runtime PM usage count underflow!".
Reported-by: Andreas Kemnade <andreas@kemnade.info>
Link: https://lore.kernel.org/r/20231030052340.13415-1-tony@atomide.com
[ Upstream commit f93dc90c2e8ed664985e366aa6459ac83cdab236 ]
While AudioDSP drivers assign streams exclusively of HOST or LINK type,
nothing blocks a user to attempt to assign a COUPLED stream. As
supplied substream instance may be a stub, what is the case when
code-loading, such scenario ends with null-ptr-deref.
Signed-off-by: Cezary Rojewski <cezary.rojewski@intel.com>
Link: https://lore.kernel.org/r/20231006102857.749143-2-cezary.rojewski@intel.com
[ Upstream commit bd0f7498bc9084d8cccc5484cd004b40f314b763 ]
static void cx81801_close()
(A) struct snd_soc_dapm_context *dapm = &component->card->dapm;
(B) if (!component)
return;
(A) uses component before NULL check (B). This patch moves it after (B).
Fixes: d0fdfe34080c ("ASoC: cx20442: replace codec to component")
Reported-by: Dan Carpenter <dan.carpenter@linaro.org>
Closes: https://lore.kernel.org/r/3e608474-e99a-4866-ae98-3054a4221f09@moroto.mountain
Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com>
Link: https://lore.kernel.org/r/87ttqdq623.wl-kuninori.morimoto.gx@renesas.com
[ Upstream commit 168d97844a61db302dec76d44406e9d4d7106b8e ]
Error path in snd_skl_parse_uuids() shall free last allocated module if
its instance_id allocation fails.
Fixes: f8e066521192 ("ASoC: Intel: Skylake: Fix uuid_module memory leak in failure case")
Signed-off-by: Amadeusz Sławiński <amadeuszx.slawinski@linux.intel.com>
Link: https://lore.kernel.org/r/20231026082558.1864910-1-amadeuszx.slawinski@linux.intel.com
[ Upstream commit f88dfbf333b3661faff996bb03af2024d907b76a ]
The RT5650 should enable a power setting for button detection to avoid the wrong result.
Signed-off-by: Shuming Fan <shumingf@realtek.com>
Link: https://lore.kernel.org/r/20231013094525.715518-1-shumingf@realtek.com
[ Upstream commit aa6464edbd51af4a2f8db43df866a7642b244b5f ]
Free the "priv" pointer before returning the error code.
Fixes: 90eb6b59d311 ("ASoC: pxa-ssp: add support for an external clock in devicetree")
Signed-off-by: Dan Carpenter <dan.carpenter@linaro.org>
Link: https://lore.kernel.org/r/84ac2313-1420-471a-b2cb-3269a2e12a7c@moroto.mountain
commit 057a28ef93bdbe84326d34cdb5543afdaab49fe1 upstream.
Lenovo ThinkCentre M70q had boot up pop noise.
Disable power save will solve pop issue.
Link: https://lore.kernel.org/r/315900e2efef42fd9855eacfeb443abd@realtek.com
[ Upstream commit b19a5733de255cabba5feecabf6e900638b582d1 ]
The devm_clk_get() can return -EPROBE_DEFER error,
modify the error code to be -EINVAL is not correct, which
cause the -EPROBE_DEFER error is not correctly handled.
This patch is to fix the return error code.
Fixes: b86ef5367761 ("ASoC: fsl: Add Audio Mixer machine driver")
Signed-off-by: Shengjiu Wang <shengjiu.wang@nxp.com>
Reviewed-by: Daniel Baluta <daniel.baluta@nxp.com>
Link: https://lore.kernel.org/r/1694757731-18308-1-git-send-email-shengjiu.wang@nxp.com
[ Upstream commit aedf323b66b2b875137422ecb7d2525179759076 ]
For spdif input to report the locked rate correctly, even when no capture
is running, the HW and reference clock must be started as soon as
the dai is probed.
Fixes: 5ce5658375e6 ("ASoC: meson: add axg spdif input")
Signed-off-by: Jerome Brunet <jbrunet@baylibre.com>
Link: https://lore.kernel.org/r/20230907090504.12700-1-jbrunet@baylibre.com
commit 358040e3807754944dbddf948a23c6d914297ed7 upstream.
The update of rate_num/den and msbits were factored out to
fixup_unreferenced_params() function to be called explicitly after the
hw_refine or hw_params procedure. It's called from
snd_pcm_hw_refine_user(), but it's forgotten in the PCM compat ioctl.
This ended up with the incomplete rate_num/den and msbits parameters
when 32bit compat ioctl is used.
This patch adds the missing call in snd_pcm_ioctl_hw_params_compat().
Reported-by: Meng_Cai@novatek.com.cn
Fixes: f9a076bff053 ("ALSA: pcm: calculate non-mask/non-interval parameters always when possible")
Reviewed-by: Takashi Sakamoto <o-takashi@sakamocchi.jp>
Link: https://lore.kernel.org/r/20230829134344.31588-1-tiwai@suse.de
[ Upstream commit db4bfcba7bb8d10f00bba2a3da6b9a9c2a1d7b71 ]
Use "select" to ensure that the required kconfig symbols are set
as expected.
Drop HOSTAUDIO since it is now equivalent to UML_SOUND.
Set CONFIG_SOUND=m in ARCH=um defconfig files to maintain the
status quo of the default configs.
Allow SOUND with UML regardless of HAS_IOMEM. Otherwise there is a
kconfig warning for unmet dependencies. (This was not an issue when
SOUND was defined in arch/um/drivers/Kconfig. I have done 50 randconfig
builds and didn't find any issues.)
This fixes build errors when CONFIG_SOUND is not set:
ld: arch/um/drivers/hostaudio_kern.o: in function `hostaudio_cleanup_module':
hostaudio_kern.c:(.exit.text+0xa): undefined reference to `unregister_sound_mixer'
ld: hostaudio_kern.c:(.exit.text+0x15): undefined reference to `unregister_sound_dsp'
ld: arch/um/drivers/hostaudio_kern.o: in function `hostaudio_init_module':
hostaudio_kern.c:(.init.text+0x19): undefined reference to `register_sound_dsp'
ld: hostaudio_kern.c:(.init.text+0x31): undefined reference to `register_sound_mixer'
ld: hostaudio_kern.c:(.init.text+0x49): undefined reference to `unregister_sound_dsp'
and this kconfig warning:
WARNING: unmet direct dependencies detected for SOUND
Fixes: 1da177e4c3f4 ("Linux-2.6.12-rc2")
Fixes: d886e87cb82b ("sound: make OSS sound core optional")
Reported-by: kernel test robot <lkp@intel.com>
Closes: lore.kernel.org/r/202307141416.vxuRVpFv-lkp@intel.com
Cc: Richard Weinberger <richard@nod.at>
Cc: Anton Ivanov <anton.ivanov@cambridgegreys.com>
Cc: Johannes Berg <johannes@sipsolutions.net>
Cc: linux-um@lists.infradead.org
Cc: Tejun Heo <tj@kernel.org>
Cc: Takashi Iwai <tiwai@suse.de>
Cc: Jaroslav Kysela <perex@perex.cz>
Cc: Masahiro Yamada <masahiroy@kernel.org>
Cc: Nathan Chancellor <nathan@kernel.org>
Cc: Nick Desaulniers <ndesaulniers@google.com>
Cc: Nicolas Schier <nicolas@fjasle.eu>
Cc: linux-kbuild@vger.kernel.org
Cc: alsa-devel@alsa-project.org
Reviewed-by: Masahiro Yamada <masahiroy@kernel.org>
Signed-off-by: Richard Weinberger <richard@nod.at>
[ Upstream commit 67de40c9df94037769967ba28c7d951afb45b7fb ]
Before committing 79597c8bf64c, *rac97 always be NULL if there is
an error. When error happens, make sure *rac97 is NULL is safer.
For examble, in snd_vortex_mixer():
err = snd_ac97_mixer(pbus, &ac97, &vortex->codec);
vortex->isquad = ((vortex->codec == NULL) ?
0 : (vortex->codec->ext_id&0x80));
If error happened but vortex->codec isn't NULL, this may cause some
problems.
Move the judgement order to be clearer and better.
Fixes: 79597c8bf64c ("ALSA: ac97: Fix possible NULL dereference in snd_ac97_mixer")
Suggested-by: Christophe JAILLET <christophe.jaillet@wanadoo.fr>
Acked-by: Christophe JAILLET <christophe.jaillet@wanadoo.fr>
Signed-off-by: Su Hui <suhui@nfschina.com>
Link: https://lore.kernel.org/r/20230823025212.1000961-1-suhui@nfschina.com
[ Upstream commit 297224fc0922e7385573a30c29ffdabb67f27b7d ]
Although snd_seq_oss_midi_open() and snd_seq_oss_midi_close() can be
called concurrently from different code paths, we have no proper data
protection against races. Introduce open_mutex to each seq_oss_midi
object for avoiding the races.
Reported-by: "Gong, Sishuai" <sishuai@purdue.edu>
Closes: https://lore.kernel.org/r/7DC9AF71-F481-4ABA-955F-76C535661E33@purdue.edu
Link: https://lore.kernel.org/r/20230612125533.27461-1-tiwai@suse.de
[ Upstream commit f85739c0b2b0d98a32f5ca4fcc5501d2b76df4f6 ]
The 8K sample parameter of 12.288Mhz main system bus clock doesn't work
because the I2SC_MR.IMCKDIV must not be 0 according to the sama5d2
series datasheet(I2SC Mode Register of Register Summary).
So use the 6.144Mhz instead of 12.288Mhz to support 8K sample.
Signed-off-by: Guiting Shen <aarongt.shen@gmail.com>
Link: https://lore.kernel.org/r/20230715030620.62328-1-aarongt.shen@gmail.com
[ Upstream commit d20d35d1ad62c6cca36368c1e8f29335a068659e ]
According to the datasheet, the DMIC config should
be changed to { 0, 2 ,3 }
Signed-off-by: Edgar <ljijcj@163.com>
Link: https://lore.kernel.org/r/20230719054722.401954-1-ljijcj@163.com
[ Upstream commit f0691dc16206f21b13c464434366e2cd632b8ed7 ]
When handling an AAD interrupt, if IRQ events read failed (for example,
due to i2c "Transfer while suspended" failure, i.e. when attempting to
read it while DA7219 is suspended, which may happen due to a spurious
AAD interrupt), the events array contains garbage uninitialized values.
So instead of trying to interprete those values and doing any actions
based on them (potentially resulting in misbehavior, e.g. reporting
bogus events), refuse to handle the interrupt.
Signed-off-by: Dmytro Maluka <dmy@semihalf.com>
Link: https://lore.kernel.org/r/20230717193737.161784-3-dmy@semihalf.com
[ Upstream commit 91e292917dad64ab8d1d5ca2ab3069ad9dac6f72 ]
da7219_aad_suspend() disables jack detection, which should prevent
generating new interrupts by DA7219 while suspended. However, there is a
theoretical possibility that there is a pending interrupt generated just
before suspending DA7219 and not handled yet, so the IRQ handler may
still run after DA7219 is suspended. To prevent that, wait until the
pending IRQ handling is done.
This patch arose as an attempt to fix the following I2C failure
occurring sometimes during system suspend or resume:
[ 355.876211] i2c_designware i2c_designware.3: Transfer while suspended
[ 355.876245] WARNING: CPU: 2 PID: 3576 at drivers/i2c/busses/i2c-designware-master.c:570 i2c_dw_xfer+0x411/0x440
[ 355.876462] Call Trace:
[ 355.876468] <TASK>
[ 355.876475] ? update_load_avg+0x1b3/0x615
[ 355.876484] __i2c_transfer+0x101/0x1d8
[ 355.876494] i2c_transfer+0x74/0x10d
[ 355.876504] regmap_i2c_read+0x6a/0x9c
[ 355.876513] _regmap_raw_read+0x179/0x223
[ 355.876521] regmap_raw_read+0x1e1/0x28e
[ 355.876527] regmap_bulk_read+0x17d/0x1ba
[ 355.876532] ? __wake_up+0xed/0x1bb
[ 355.876542] da7219_aad_irq_thread+0x54/0x2c9 [snd_soc_da7219 5fb8ebb2179cf2fea29af090f3145d68ed8e2184]
[ 355.876556] irq_thread+0x13c/0x231
[ 355.876563] ? irq_forced_thread_fn+0x5f/0x5f
[ 355.876570] ? irq_thread_fn+0x4d/0x4d
[ 355.876576] kthread+0x13a/0x152
[ 355.876581] ? synchronize_irq+0xc3/0xc3
[ 355.876587] ? kthread_blkcg+0x31/0x31
[ 355.876592] ret_from_fork+0x1f/0x30
[ 355.876601] </TASK>
which indicates that the AAD IRQ handler is unexpectedly running when
DA7219 is suspended, and as a result, is trying to read data from DA7219
over I2C and is hitting the I2C driver "Transfer while suspended"
failure.
However, with this patch the above failure is still reproducible. So
this patch does not fix any real observed issue so far, but at least is
useful for confirming that the above issue is not caused by a pending
IRQ but rather looks like a DA7219 hardware issue with an IRQ
unexpectedly generated after jack detection is already disabled.
Link: https://lore.kernel.org/r/20230717193737.161784-2-dmy@semihalf.com
commit 011b559be832194f992f73d6c0d5485f5925a10b upstream.
Pointer substream is being dereferenced on the assignment of pointer card
before substream is being null checked with the macro PCM_RUNTIME_CHECK.
Although PCM_RUNTIME_CHECK calls BUG_ON, it still is useful to perform the
the pointer check before card is assigned.
Fixes: d4cfb30fce03 ("ALSA: pcm: Set per-card upper limit of PCM buffer allocations")
Signed-off-by: Colin Ian King <colin.i.king@gmail.com>
Link: https://lore.kernel.org/r/20220424205945.1372247-1-colin.i.king@gmail.com
commit 7d50b295c4af16f814ee82369c4a234df5228801 upstream.
This reverts commit 3ad796cbc36a ("ALSA: pcm: Use SG-buffer only when
direct DMA is available") also the modification commit 467fd0e82b62
("ALSA: pcm: Fix build error on m68k and others").
Poking the DMA internal helper is a layer violation, so we should
avoid that. Meanwhile the actual bug has been addressed by the
Kconfig fix in commit dbed452a078d ("dma-pool: decouple DMA_REMAP from
DMA_COHERENT_POOL"), so we can live without this hack.
Link: https://lore.kernel.org/r/20200717064130.22957-1-tiwai@suse.de
commit 467fd0e82b6265b8e6cc078a70bd7592574d5c83 upstream.
The commit 3ad796cbc36a ("ALSA: pcm: Use SG-buffer only when direct
DMA is available") introduced a check of the DMA type and this caused
a build error on m68k (and possibly some others) due to the lack of
dma_is_direct() definition. Since the check is needed only for
CONFIG_SND_DMA_SGBUF enablement (i.e. solely x86), use #ifdef instead
of IS_ENABLED() for avoiding such a build error.
Fixes: 3ad796cbc36a ("ALSA: pcm: Use SG-buffer only when direct DMA is available")
Link: https://lore.kernel.org/r/20200707111225.26826-1-tiwai@suse.de
[ Upstream commit 269f399dc19f0e5c51711c3ba3bd06e0ef6ef403 ]
Otherwise bit clock remains running writing invalid data to the DAC.
Signed-off-by: Matus Gajdos <matuszpd@gmail.com>
Acked-by: Shengjiu Wang <shengjiu.wang@gmail.com>
Cc: stable@vger.kernel.org
Link: https://lore.kernel.org/r/20230712124934.32232-1-matuszpd@gmail.com
[ Upstream commit 0b2cbce6898600aae5e87285f1c2000162d59c76 ]
On i.MX8MQ/i.MX8MN/i.MX8MM platform, the sai IP is upgraded.
There are some new registers and new bit definition. This
patch is to complete the register list.
Acked-by: Nicolin Chen <nicoleotsuka@gmail.com>
Reviewed-by: Fabio Estevam <festevam@gmail.com>
Link: https://lore.kernel.org/r/1600323079-5317-2-git-send-email-shengjiu.wang@nxp.com
Stable-dep-of: 269f399dc19f ("ASoC: fsl_sai: Disable bit clock with transmitter")
[ Upstream commit 94741eba63c23b0f1527b0ae0125e6b553bde10e ]
Current code enables TCSR.TE and RCSR.RE together, and disable
TCSR.TE and RCSR.RE together in trigger(), which only supports
one operation mode:
1. Rx synchronous with Tx: TE is last enabled and first disabled
Other operation mode need to be considered also:
2. Tx synchronous with Rx: RE is last enabled and first disabled.
3. Asynchronous mode: Tx and Rx are independent.
So the enable TCSR.TE and RCSR.RE sequence and the disable
sequence need to be refined accordingly for #2 and #3.
There is slightly against what RM recommennds with this change.
For example in Rx synchronous with Tx mode, case "aplay 1.wav;
arecord 2.wav" enable TE before RE. But it should be safe to
do so, judging by years of testing results.
Reviewed-by: Nicolin Chen <nicoleotsuka@gmail.com>
Link: https://lore.kernel.org/r/20200805063413.4610-2-shengjiu.wang@nxp.com
[ Upstream commit bd55842ed998a622ba6611fe59b3358c9f76773d ]
The PCM memory allocation helpers have a sanity check against too many
buffer allocations. However, the check is performed without a proper
lock and the allocation isn't serialized; this allows user to allocate
more memories than predefined max size.
Practically seen, this isn't really a big problem, as it's more or
less some "soft limit" as a sanity check, and it's not possible to
allocate unlimitedly. But it's still better to address this for more
consistent behavior.
The patch covers the size check in do_alloc_pages() with the
card->memory_mutex, and increases the allocated size there for
preventing the further overflow. When the actual allocation fails,
the size is decreased accordingly.
Reported-by: BassCheck <bass@buaa.edu.cn>
Reported-by: Tuo Li <islituo@gmail.com>
Link: https://lore.kernel.org/r/CADm8Tek6t0WedK+3Y6rbE5YEt19tML8BUL45N2ji4ZAz1KcN_A@mail.gmail.com
Link: https://lore.kernel.org/r/20230703112430.30634-1-tiwai@suse.de
[ Upstream commit 3ad796cbc36a7bc8bfd4de191d791b9490bc112b ]
The DMA-coherent SG-buffer is tricky to use, as it does need the
mapping. It used to work stably on x86 over years (and that's why we
had enabled SG-buffer on solely x86) with the default mmap handler and
vmap(), but our luck seems no forever success. The chance of breakage
is high when the special DMA handling is introduced in the arch side.
In this patch, we change the buffer allocation to use the SG-buffer
only when the device in question is with the direct DMA. It's a bit
hackish, but it's currently the only condition that may work (more or
less) reliably with the default mmap and vmap() for mapping the pages
that are deduced via virt_to_page().
In theory, we can apply the similar hack in the sound/core memory
allocation helper, too; but it's used by SOF for allocating SG pages
without re-mapping via vmap() or mmap, and it's fine to use it in that
way, so let's keep it and adds the workaround in PCM side.
Link: https://lore.kernel.org/r/20200615160045.2703-5-tiwai@suse.de
Stable-dep-of: bd55842ed998 ("ALSA: pcm: Fix potential data race at PCM memory allocation helpers")
[ Upstream commit d4cfb30fce03093ad944e0b44bd8f40bdad5330e ]
Currently, the available buffer allocation size for a PCM stream
depends on the preallocated size; when a buffer has been preallocated,
the max buffer size is set to that size, so that application won't
re-allocate too much memory. OTOH, when no preallocation is done,
each substream may allocate arbitrary size of buffers as long as
snd_pcm_hardware.buffer_bytes_max allows -- which can be quite high,
HD-audio sets 1GB there.
It means that the system may consume a high amount of pages for PCM
buffers, and they are pinned and never swapped out. This can lead to
OOM easily.
For avoiding such a situation, this patch adds the upper limit per
card. Each snd_pcm_lib_malloc_pages() and _free_pages() calls are
tracked and it will return an error if the total amount of buffers
goes over the defined upper limit. The default value is set to 32MB,
which should be really large enough for usual operations.
If larger buffers are needed for any specific usage, it can be
adjusted (also dynamically) via snd_pcm.max_alloc_per_card option.
Setting zero there means no chceck is performed, and again, unlimited
amount of buffers are allowed.
Link: https://lore.kernel.org/r/20200120124423.11862-1-tiwai@suse.de
interfaces.
commit 788449ae57f4273111b779bbcaad552b67f517d5 upstream.
This patch adds a USB quirk for Mythware XA001AU USB interface.
Signed-off-by: dengxiang <dengxiang@nfschina.com>
Link: https://lore.kernel.org/r/20230803024437.370069-1-dengxiang@nfschina.com
[ Upstream commit c1f848f12103920ca165758aedb1c10904e193e1 ]
When the tdm lane mask is computed, the driver currently fills the 1st lane
before moving on to the next. If the stream has less channels than the
lanes can accommodate, slots will be disabled on the last lanes.
Unfortunately, the HW distribute channels in a different way. It distribute
channels in pair on each lanes before moving on the next slots.
This difference leads to problems if a device has an interface with more
than 1 lane and with more than 2 slots per lane.
For example: a playback interface with 2 lanes and 4 slots each (total 8
slots - zero based numbering)
- Playing a 8ch stream:
- All slots activated by the driver
- channel #2 will be played on lane #1 - slot #0 following HW placement
- Playing a 4ch stream:
- Lane #1 disabled by the driver
- channel #2 will be played on lane #0 - slot #2
This behaviour is obviously not desirable.
Change the way slots are activated on the TDM lanes to follow what the HW
does and make sure each channel always get mapped to the same slot/lane.
Fixes: 1a11d88f499c ("ASoC: meson: add tdm formatter base driver")
Link: https://lore.kernel.org/r/20230809171931.1244502-1-jbrunet@baylibre.com
[ Upstream commit c163108e706909570f8aa9aa5bcf6806e2b4c98c ]
The driver forgets to call regulator_bulk_disable()
Add the missed call to fix it.
Fixes: 33ada14a26c8 ("ASoC: add rt5665 codec driver")
Signed-off-by: Zhang Shurong <zhang_shurong@foxmail.com>
Link: https://lore.kernel.org/r/tencent_A560D01E3E0A00A85A12F137E4B5205B3508@qq.com
[ Upstream commit 81302b1c7c997e8a56c1c2fc63a296ebeb0cd2d0 ]
It's reported that the recording started right after the driver probe
doesn't work properly, and it turned out that this is related with the
codec auto-suspend. Namely, after the probe phase, the usage count
goes zero, and the auto-suspend is programmed, but the codec is kept
still active until the auto-suspend expiration. When an application
(e.g. alsactl) updates the mixer values at this moment, the values are
cached but not actually written. Then, starting arecord thereafter
also results in the silence because of the missing unmute.
The root cause is the handling of "lazy update" mode; when a mixer
value is updated *after* the suspend, it should update only the cache
and exits. At the resume, the cached value is written to the device,
in turn. The problem is that the current code misinterprets the state
of auto-suspend as if it were already suspended.
Although we can add the check of the actual device state after
pm_runtime_get_if_in_use() for catching the missing state, this won't
suffice; the second call of regmap_update_bits_check() will skip
writing the register because the cache has been already updated by the
first call. So we'd need fixes in two different places.
OTOH, a simpler fix is to replace pm_runtime_get_if_in_use() with
pm_runtime_get_if_active() (with ign_usage_count=true). This change
implies that the driver takes the pm refcount if the device is still
in ACTIVE state and continues the processing. A small caveat is that
this will leave the auto-suspend timer. But, since the timer callback
itself checks the device state and aborts gracefully when it's active,
this won't be any substantial problem.
Long story short: we address the missing register-write problem just
by replacing the pm_runtime_*() call in snd_hda_keep_power_up().
Fixes: fc4f000bf8c0 ("ALSA: hda - Fix unexpected resume through regmap code path")
Reported-by: Amadeusz Sławiński <amadeuszx.slawinski@linux.intel.com>
Closes: https://lore.kernel.org/r/a7478636-af11-92ab-731c-9b13c582a70d@linux.intel.com
Suggested-by: Cezary Rojewski <cezary.rojewski@intel.com>
Link: https://lore.kernel.org/r/20230518113520.15213-1-tiwai@suse.de
snd_hdac_regmap_sync()
[ Upstream commit 1f4a08fed450db87fbb5ff5105354158bdbe1a22 ]
The variable codec->regmap is often protected by the lock
codec->regmap_lock when is accessed. However, it is accessed without
holding the lock when is accessed in snd_hdac_regmap_sync():
if (codec->regmap)
In my opinion, this may be a harmful race, because if codec->regmap is
set to NULL right after the condition is checked, a null-pointer
dereference can occur in the called function regcache_sync():
map->lock(map->lock_arg); --> Line 360 in drivers/base/regmap/regcache.c
To fix this possible null-pointer dereference caused by data race, the
mutex_lock coverage is extended to protect the if statement as well as the
function call to regcache_sync().
[ Note: the lack of the regmap_lock itself is harmless for the current
codec driver implementations, as snd_hdac_regmap_sync() is only for
PM runtime resume that is prohibited during the codec probe.
But the change makes the whole code more consistent, so it's merged
as is -- tiwai ]
Signed-off-by: Tuo Li <islituo@gmail.com>
Link: https://lore.kernel.org/r/20230703031016.1184711-1-islituo@gmail.com
[ Upstream commit 73f1c75d5e6bd8ce2a887ef493a66ad1b16ed704 ]
These models use NSIWAY amplifiers for internal speaker, but cannot put
sound outside from these amplifiers. So eapd verbs are needed to initialize
the amplifiers. They can be added during boot to get working sound out
of internal speaker.
Link: https://lore.kernel.org/r/20230703021751.2945750-1-dengxiang@nfschina.com
[ Upstream commit 8cabf83c7aa54530e699be56249fb44f9505c4f3 ]
There is no apparent reason for the massive code duplication.
Signed-off-by: Oswald Buddenhagen <oswald.buddenhagen@gmx.de>
Link: https://lore.kernel.org/r/20230510173917.3073107-3-oswald.buddenhagen@gmx.de
commit e51df4f81b02bcdd828a04de7c1eb6a92988b61e upstream.
In commit 2cb1e0259f50 ("ASoC: cs42l51: re-hook of_match_table
pointer"), 9 years ago, some random guy fixed the cs42l51 after it was
split into a core part and an I2C part to properly match based on a
Device Tree compatible string.
However, the fix in this commit is wrong: the MODULE_DEVICE_TABLE(of,
....) is in the core part of the driver, not the I2C part. Therefore,
automatic module loading based on module.alias, based on matching with
the DT compatible string, loads the core part of the driver, but not
the I2C part. And threfore, the i2c_driver is not registered, and the
codec is not known to the system, nor matched with a DT node with the
corresponding compatible string.
In order to fix that, we move the MODULE_DEVICE_TABLE(of, ...) into
the I2C part of the driver. The cs42l51_of_match[] array is also moved
as well, as it is not possible to have this definition in one file,
and the MODULE_DEVICE_TABLE(of, ...) invocation in another file, due
to how MODULE_DEVICE_TABLE works.
Thanks to this commit, the I2C part of the driver now properly
autoloads, and thanks to its dependency on the core part, the core
part gets autoloaded as well, resulting in a functional sound card
without having to manually load kernel modules.
Fixes: 2cb1e0259f50 ("ASoC: cs42l51: re-hook of_match_table pointer")
Signed-off-by: Thomas Petazzoni <thomas.petazzoni@bootlin.com>
Link: https://lore.kernel.org/r/20230713112112.778576-1-thomas.petazzoni@bootlin.com
commit f061e2be8689057cb4ec0dbffa9f03e1a23cdcb2 upstream.
The WM8904_ADC_TEST_0 register is modified as part of updating the OSR
controls but does not have a cache default, leading to errors when we try
to modify these controls in cache only mode with no prior read:
wm8904 3-001a: ASoC: error at snd_soc_component_update_bits on wm8904.3-001a for register: [0x000000c6] -16
Add a read of the register to probe() to fill the cache and avoid both the
error messages and the misconfiguration of the chip which will result.
Acked-by: Charles Keepax <ckeepax@opensource.cirrus.com>
Link: https://lore.kernel.org/r/20230723-asoc-fix-wm8904-adc-test-read-v1-1-2cdf2edd83fd@kernel.org
[ Upstream commit 0e4c2b6b0c4a4b4014d9424c27e5e79d185229c5 ]
Clear TX registers on stop to prevent the SPDIF interface from sending
last written word over and over again.
Fixes: a2388a498ad2 ("ASoC: fsl: Add S/PDIF CPU DAI driver")
Link: https://lore.kernel.org/r/20230719164729.19969-1-matuszpd@gmail.com
[ Upstream commit 89dbb335cb6a627a4067bc42caa09c8bc3326d40 ]
snd_jack_report() is supposed to be callable from an IRQ context, too,
and it's indeed used in that way from virtsnd driver. The fix for
input_dev race in commit 1b6a6fc5280e ("ALSA: jack: Access input_dev
under mutex"), however, introduced a mutex lock in snd_jack_report(),
and this resulted in a potential sleep-in-atomic.
For addressing that problem, this patch changes the relevant code to
use the object get/put and removes the mutex usage. That is,
snd_jack_report(), it takes input_get_device() and leaves with
input_put_device() for assuring the input_dev being assigned.
Although the whole mutex could be reduced, we keep it because it can
be still a protection for potential races between creation and
deletion.
Fixes: 1b6a6fc5280e ("ALSA: jack: Access input_dev under mutex")
Closes: https://lore.kernel.org/r/cf95f7fe-a748-4990-8378-000491b40329@moroto.mountain
Tested-by: Amadeusz Sławiński <amadeuszx.slawinski@linux.intel.com>
Link: https://lore.kernel.org/r/20230706155357.3470-1-tiwai@suse.de
[ Upstream commit 2f76e1d6ca524a888d29aafe29f2ad2003857971 ]
devm_kasprintf() returns a pointer to dynamically allocated memory.
Pointer could be NULL in case allocation fails. Check pointer validity.
Identified with coccinelle (kmerr.cocci script).
Signed-off-by: Claudiu Beznea <claudiu.beznea@microchip.com>
Link: https://lore.kernel.org/r/20230614121509.443926-1-claudiu.beznea@microchip.com
[ Upstream commit 79597c8bf64ca99eab385115743131d260339da5 ]
smatch error:
sound/pci/ac97/ac97_codec.c:2354 snd_ac97_mixer() error:
we previously assumed 'rac97' could be null (see line 2072)
remove redundant assignment, return error if rac97 is NULL.
Fixes: da3cec35dd3c ("ALSA: Kill snd_assert() in sound/pci/*")
Link: https://lore.kernel.org/r/20230615021732.1972194-1-suhui@nfschina.com
[ Upstream commit 60413129ee2b38a80347489270af7f6e1c1de4d0 ]
When using the codec through the generic audio graph card, there are at
least two calls of es8316_set_dai_sysclk(), with the effect of limiting
the allowed sample rates according to the MCLK/LRCK ratios supported by
the codec:
1. During audio card setup, to set the initial MCLK - see
asoc_simple_init_dai().
2. Before opening a stream, to update MCLK, according to the stream
sample rate and the multiplication factor - see
asoc_simple_hw_params().
In some cases the initial MCLK might be set to a frequency that doesn't
match any of the supported ratios, e.g. 12287999 instead of 12288000,
which is only 1 Hz below the supported clock, as that is what the
hardware reports. This creates an empty list of rate constraints, which
is further passed to snd_pcm_hw_constraint_list() via
es8316_pcm_startup(), and causes the following error on the very first
access of the sound card:
$ speaker-test -D hw:Analog,0 -F S16_LE -c 2 -t wav
Broken configuration for playback: no configurations available: Invalid argument
Setting of hwparams failed: Invalid argument
Note that all subsequent retries succeed thanks to the updated MCLK set
at point 2 above, which uses a computed frequency value instead of a
reading from the hardware registers. Normally this would have mitigated
the issue, but es8316_pcm_startup() executes before the 2nd call to
es8316_set_dai_sysclk(), hence it cannot make use of the updated
constraints.
Since es8316_pcm_hw_params() performs anyway a final validation of MCLK
against the stream sample rate and the supported MCLK/LRCK ratios, fix
the issue by ensuring that sysclk_constraints list is only set when at
least one supported sample rate is autodetected by the codec.
Fixes: b8b88b70875a ("ASoC: add es8316 codec driver")
Signed-off-by: Cristian Ciocaltea <cristian.ciocaltea@collabora.com>
Link: https://lore.kernel.org/r/20230530181140.483936-3-cristian.ciocaltea@collabora.com
[ Upstream commit 6f073429037cd79d7311cd8236311c53f5ea8f01 ]
The following error occurs when trying to restore a previously saved
ALSA mixer state (tested on a Rock 5B board):
$ alsactl --no-ucm -f /tmp/asound.state store hw:Analog
$ alsactl --no-ucm -I -f /tmp/asound.state restore hw:Analog
alsactl: set_control:1475: Cannot write control '2:0:0:ALC Capture Target Volume:0' : Invalid argument
According to ES8316 datasheet, the register at address 0x2B, which is
related to the above mixer control, contains by default the value 0xB0.
Considering the corresponding ALC target bits (ALCLVL) are 7:4, the
control is initialized with 11, which is one step above the maximum
value allowed by the driver:
ALCLVL | dB gain
0000 | -16.5
0001 | -15.0
0010 | -13.5
0111 | -6.0
1000 | -4.5
1001 | -3.0
1010 | -1.5
1111 | -1.5
The tests performed using the VU meter feature (--vumeter=TYPE) of
arecord/aplay confirm the specs are correct and there is no measured
gain if the 1011-1111 range would have been mapped to 0 dB:
dB gain | VU meter %
-6.0 | 30-31
-4.5 | 35-36
-3.0 | 42-43
-1.5 | 50-51
0.0 | 50-51
Increment the max value allowed for ALC Capture Target Volume control,
so that it matches the hardware default. Additionally, update the
related TLV to prevent an artificial extension of the dB gain range.
Link: https://lore.kernel.org/r/20230530181140.483936-2-cristian.ciocaltea@collabora.com
[ Upstream commit e384dba03e3294ce7ea69e4da558e9bf8f0e8946 ]
Add entries for Positivo laptops: CW14Q01P, K1424G, N14ZP74G to the
DMI table, so that active-high jack-detect will work properly on
these laptops.
Signed-off-by: Edson Juliano Drosdeck <edson.drosdeck@gmail.com>
Link: https://lore.kernel.org/r/20230529181911.632851-1-edson.drosdeck@gmail.com
