path: root/init
2021-06-10pid: take a reference when initializing `cad_pid`Mark Rutland
commit 0711f0d7050b9e07c44bc159bbc64ac0a1022c7f upstream. During boot, kernel_init_freeable() initializes `cad_pid` to the init task's struct pid. Later on, we may change `cad_pid` via a sysctl, and when this happens proc_do_cad_pid() will increment the refcount on the new pid via get_pid(), and will decrement the refcount on the old pid via put_pid(). As we never called get_pid() when we initialized `cad_pid`, we decrement a reference we never incremented, can therefore free the init task's struct pid early. As there can be dangling references to the struct pid, we can later encounter a use-after-free (e.g. when delivering signals). This was spotted when fuzzing v5.13-rc3 with Syzkaller, but seems to have been around since the conversion of `cad_pid` to struct pid in commit 9ec52099e4b8 ("[PATCH] replace cad_pid by a struct pid") from the pre-KASAN stone age of v2.6.19. Fix this by getting a reference to the init task's struct pid when we assign it to `cad_pid`. Full KASAN splat below. ================================================================== BUG: KASAN: use-after-free in ns_of_pid include/linux/pid.h:153 [inline] BUG: KASAN: use-after-free in task_active_pid_ns+0xc0/0xc8 kernel/pid.c:509 Read of size 4 at addr ffff23794dda0004 by task syz-executor.0/273 CPU: 1 PID: 273 Comm: syz-executor.0 Not tainted 5.12.0-00001-g9aef892b2d15 #1 Hardware name: linux,dummy-virt (DT) Call trace: ns_of_pid include/linux/pid.h:153 [inline] task_active_pid_ns+0xc0/0xc8 kernel/pid.c:509 do_notify_parent+0x308/0xe60 kernel/signal.c:1950 exit_notify kernel/exit.c:682 [inline] do_exit+0x2334/0x2bd0 kernel/exit.c:845 do_group_exit+0x108/0x2c8 kernel/exit.c:922 get_signal+0x4e4/0x2a88 kernel/signal.c:2781 do_signal arch/arm64/kernel/signal.c:882 [inline] do_notify_resume+0x300/0x970 arch/arm64/kernel/signal.c:936 work_pending+0xc/0x2dc Allocated by task 0: slab_post_alloc_hook+0x50/0x5c0 mm/slab.h:516 slab_alloc_node mm/slub.c:2907 [inline] slab_alloc mm/slub.c:2915 [inline] kmem_cache_alloc+0x1f4/0x4c0 mm/slub.c:2920 alloc_pid+0xdc/0xc00 kernel/pid.c:180 copy_process+0x2794/0x5e18 kernel/fork.c:2129 kernel_clone+0x194/0x13c8 kernel/fork.c:2500 kernel_thread+0xd4/0x110 kernel/fork.c:2552 rest_init+0x44/0x4a0 init/main.c:687 arch_call_rest_init+0x1c/0x28 start_kernel+0x520/0x554 init/main.c:1064 0x0 Freed by task 270: slab_free_hook mm/slub.c:1562 [inline] slab_free_freelist_hook+0x98/0x260 mm/slub.c:1600 slab_free mm/slub.c:3161 [inline] kmem_cache_free+0x224/0x8e0 mm/slub.c:3177 put_pid.part.4+0xe0/0x1a8 kernel/pid.c:114 put_pid+0x30/0x48 kernel/pid.c:109 proc_do_cad_pid+0x190/0x1b0 kernel/sysctl.c:1401 proc_sys_call_handler+0x338/0x4b0 fs/proc/proc_sysctl.c:591 proc_sys_write+0x34/0x48 fs/proc/proc_sysctl.c:617 call_write_iter include/linux/fs.h:1977 [inline] new_sync_write+0x3ac/0x510 fs/read_write.c:518 vfs_write fs/read_write.c:605 [inline] vfs_write+0x9c4/0x1018 fs/read_write.c:585 ksys_write+0x124/0x240 fs/read_write.c:658 __do_sys_write fs/read_write.c:670 [inline] __se_sys_write fs/read_write.c:667 [inline] __arm64_sys_write+0x78/0xb0 fs/read_write.c:667 __invoke_syscall arch/arm64/kernel/syscall.c:37 [inline] invoke_syscall arch/arm64/kernel/syscall.c:49 [inline] el0_svc_common.constprop.1+0x16c/0x388 arch/arm64/kernel/syscall.c:129 do_el0_svc+0xf8/0x150 arch/arm64/kernel/syscall.c:168 el0_svc+0x28/0x38 arch/arm64/kernel/entry-common.c:416 el0_sync_handler+0x134/0x180 arch/arm64/kernel/entry-common.c:432 el0_sync+0x154/0x180 arch/arm64/kernel/entry.S:701 The buggy address belongs to the object at ffff23794dda0000 which belongs to the cache pid of size 224 The buggy address is located 4 bytes inside of 224-byte region [ffff23794dda0000, ffff23794dda00e0) The buggy address belongs to the page: page:(____ptrval____) refcount:1 mapcount:0 mapping:0000000000000000 index:0x0 pfn:0x4dda0 head:(____ptrval____) order:1 compound_mapcount:0 flags: 0x3fffc0000010200(slab|head) raw: 03fffc0000010200 dead000000000100 dead000000000122 ffff23794d40d080 raw: 0000000000000000 0000000000190019 00000001ffffffff 0000000000000000 page dumped because: kasan: bad access detected Memory state around the buggy address: ffff23794dd9ff00: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc ffff23794dd9ff80: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc >ffff23794dda0000: fa fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb ^ ffff23794dda0080: fb fb fb fb fb fb fb fb fb fb fb fb fc fc fc fc ffff23794dda0100: fc fc fc fc fc fc fc fc 00 00 00 00 00 00 00 00 ================================================================== Link: https://lkml.kernel.org/r/20210524172230.38715-1-mark.rutland@arm.com Fixes: 9ec52099e4b8678a ("[PATCH] replace cad_pid by a struct pid") Signed-off-by: Mark Rutland <mark.rutland@arm.com> Acked-by: Christian Brauner <christian.brauner@ubuntu.com> Cc: Cedric Le Goater <clg@fr.ibm.com> Cc: Christian Brauner <christian@brauner.io> Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: Kees Cook <keescook@chromium.org Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Paul Mackerras <paulus@samba.org> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-04-10init/Kconfig: make COMPILE_TEST depend on HAS_IOMEMMasahiro Yamada
commit ea29b20a828511de3348334e529a3d046a180416 upstream. I read the commit log of the following two: - bc083a64b6c0 ("init/Kconfig: make COMPILE_TEST depend on !UML") - 334ef6ed06fa ("init/Kconfig: make COMPILE_TEST depend on !S390") Both are talking about HAS_IOMEM dependency missing in many drivers. So, 'depends on HAS_IOMEM' seems the direct, sensible solution to me. This does not change the behavior of UML. UML still cannot enable COMPILE_TEST because it does not provide HAS_IOMEM. The current dependency for S390 is too strong. Under the condition of CONFIG_PCI=y, S390 provides HAS_IOMEM, hence can enable COMPILE_TEST. I also removed the meaningless 'default n'. Link: https://lkml.kernel.org/r/20210224140809.1067582-1-masahiroy@kernel.org Signed-off-by: Masahiro Yamada <masahiroy@kernel.org> Cc: Heiko Carstens <hca@linux.ibm.com> Cc: Guenter Roeck <linux@roeck-us.net> Cc: Arnd Bergmann <arnd@kernel.org> Cc: Kees Cook <keescook@chromium.org> Cc: Daniel Borkmann <daniel@iogearbox.net> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: KP Singh <kpsingh@google.com> Cc: Nathan Chancellor <nathan@kernel.org> Cc: Nick Terrell <terrelln@fb.com> Cc: Quentin Perret <qperret@google.com> Cc: Valentin Schneider <valentin.schneider@arm.com> Cc: "Enrico Weigelt, metux IT consult" <lkml@metux.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-04-10init/Kconfig: make COMPILE_TEST depend on !S390Heiko Carstens
commit 334ef6ed06fa1a54e35296b77b693bcf6d63ee9e upstream. While allmodconfig and allyesconfig build for s390 there are also various bots running compile tests with randconfig, where PCI is disabled. This reveals that a lot of drivers should actually depend on HAS_IOMEM. Adding this to each device driver would be a never ending story, therefore just disable COMPILE_TEST for s390. The reasoning is more or less the same as described in commit bc083a64b6c0 ("init/Kconfig: make COMPILE_TEST depend on !UML"). Reported-by: kernel test robot <lkp@intel.com> Suggested-by: Arnd Bergmann <arnd@kernel.org> Signed-off-by: Heiko Carstens <hca@linux.ibm.com> Cc: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-04-10init/Kconfig: make COMPILE_TEST depend on !UMLRichard Weinberger
commit bc083a64b6c035135c0f80718f9e9192cc0867c6 upstream. UML is a bit special since it does not have iomem nor dma. That means a lot of drivers will not build if they miss a dependency on HAS_IOMEM. s390 used to have the same issues but since it gained PCI support UML is the only stranger. We are tired of patching dozens of new drivers after every merge window just to un-break allmod/yesconfig UML builds. One could argue that a decent driver has to know on what it depends and therefore a missing HAS_IOMEM dependency is a clear driver bug. But the dependency not obvious and not everyone does UML builds with COMPILE_TEST enabled when developing a device driver. A possible solution to make these builds succeed on UML would be providing stub functions for ioremap() and friends which fail upon runtime. Another one is simply disabling COMPILE_TEST for UML. Since it is the least hassle and does not force use to fake iomem support let's do the latter. Link: http://lkml.kernel.org/r/1466152995-28367-1-git-send-email-richard@nod.at Signed-off-by: Richard Weinberger <richard@nod.at> Acked-by: Arnd Bergmann <arnd@arndb.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2020-11-10printk: reduce LOG_BUF_SHIFT range for H8300John Ogness
[ Upstream commit 550c10d28d21bd82a8bb48debbb27e6ed53262f6 ] The .bss section for the h8300 is relatively small. A value of CONFIG_LOG_BUF_SHIFT that is larger than 19 will create a static printk ringbuffer that is too large. Limit the range appropriately for the H8300. Reported-by: kernel test robot <lkp@intel.com> Signed-off-by: John Ogness <john.ogness@linutronix.de> Reviewed-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Acked-by: Steven Rostedt (VMware) <rostedt@goodmis.org> Signed-off-by: Petr Mladek <pmladek@suse.com> Link: https://lore.kernel.org/r/20200812073122.25412-1-john.ogness@linutronix.de Signed-off-by: Sasha Levin <sashal@kernel.org>
2020-05-20x86: Fix early boot crash on gcc-10, third tryBorislav Petkov
commit a9a3ed1eff3601b63aea4fb462d8b3b92c7c1e7e upstream. ... or the odyssey of trying to disable the stack protector for the function which generates the stack canary value. The whole story started with Sergei reporting a boot crash with a kernel built with gcc-10: Kernel panic — not syncing: stack-protector: Kernel stack is corrupted in: start_secondary CPU: 1 PID: 0 Comm: swapper/1 Not tainted 5.6.0-rc5—00235—gfffb08b37df9 #139 Hardware name: Gigabyte Technology Co., Ltd. To be filled by O.E.M./H77M—D3H, BIOS F12 11/14/2013 Call Trace: dump_stack panic ? start_secondary __stack_chk_fail start_secondary secondary_startup_64 -—-[ end Kernel panic — not syncing: stack—protector: Kernel stack is corrupted in: start_secondary This happens because gcc-10 tail-call optimizes the last function call in start_secondary() - cpu_startup_entry() - and thus emits a stack canary check which fails because the canary value changes after the boot_init_stack_canary() call. To fix that, the initial attempt was to mark the one function which generates the stack canary with: __attribute__((optimize("-fno-stack-protector"))) ... start_secondary(void *unused) however, using the optimize attribute doesn't work cumulatively as the attribute does not add to but rather replaces previously supplied optimization options - roughly all -fxxx options. The key one among them being -fno-omit-frame-pointer and thus leading to not present frame pointer - frame pointer which the kernel needs. The next attempt to prevent compilers from tail-call optimizing the last function call cpu_startup_entry(), shy of carving out start_secondary() into a separate compilation unit and building it with -fno-stack-protector, was to add an empty asm(""). This current solution was short and sweet, and reportedly, is supported by both compilers but we didn't get very far this time: future (LTO?) optimization passes could potentially eliminate this, which leads us to the third attempt: having an actual memory barrier there which the compiler cannot ignore or move around etc. That should hold for a long time, but hey we said that about the other two solutions too so... Reported-by: Sergei Trofimovich <slyfox@gentoo.org> Signed-off-by: Borislav Petkov <bp@suse.de> Tested-by: Kalle Valo <kvalo@codeaurora.org> Cc: <stable@vger.kernel.org> Link: https://lkml.kernel.org/r/20200314164451.346497-1-slyfox@gentoo.org Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2020-05-20Stop the ad-hoc games with -Wno-maybe-initializedLinus Torvalds
commit 78a5255ffb6a1af189a83e493d916ba1c54d8c75 upstream. We have some rather random rules about when we accept the "maybe-initialized" warnings, and when we don't. For example, we consider it unreliable for gcc versions < 4.9, but also if -O3 is enabled, or if optimizing for size. And then various kernel config options disabled it, because they know that they trigger that warning by confusing gcc sufficiently (ie PROFILE_ALL_BRANCHES). And now gcc-10 seems to be introducing a lot of those warnings too, so it falls under the same heading as 4.9 did. At the same time, we have a very straightforward way to _enable_ that warning when wanted: use "W=2" to enable more warnings. So stop playing these ad-hoc games, and just disable that warning by default, with the known and straight-forward "if you want to work on the extra compiler warnings, use W=123". Would it be great to have code that is always so obvious that it never confuses the compiler whether a variable is used initialized or not? Yes, it would. In a perfect world, the compilers would be smarter, and our source code would be simpler. That's currently not the world we live in, though. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2020-05-20kbuild: compute false-positive -Wmaybe-uninitialized cases in KconfigMasahiro Yamada
commit b303c6df80c9f8f13785aa83a0471fca7e38b24d upstream. Since -Wmaybe-uninitialized was introduced by GCC 4.7, we have patched various false positives: - commit e74fc973b6e5 ("Turn off -Wmaybe-uninitialized when building with -Os") turned off this option for -Os. - commit 815eb71e7149 ("Kbuild: disable 'maybe-uninitialized' warning for CONFIG_PROFILE_ALL_BRANCHES") turned off this option for CONFIG_PROFILE_ALL_BRANCHES - commit a76bcf557ef4 ("Kbuild: enable -Wmaybe-uninitialized warning for "make W=1"") turned off this option for GCC < 4.9 Arnd provided more explanation in https://lkml.org/lkml/2017/3/14/903 I think this looks better by shifting the logic from Makefile to Kconfig. Link: https://github.com/ClangBuiltLinux/linux/issues/350 Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Nathan Chancellor <natechancellor@gmail.com> Tested-by: Nick Desaulniers <ndesaulniers@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-12-21sched/core: Add try_get_task_stack() and put_task_stack()Andy Lutomirski
commit c6c314a613cd7d03fb97713e0d642b493de42e69 upstream. There are a few places in the kernel that access stack memory belonging to a different task. Before we can start freeing task stacks before the task_struct is freed, we need a way for those code paths to pin the stack. Signed-off-by: Andy Lutomirski <luto@kernel.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Jann Horn <jann@thejh.net> Cc: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/17a434f50ad3d77000104f21666575e10a9c1fbd.1474003868.git.luto@kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: zhangyi (F) <yi.zhang@huawei.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-12-21sched/core: Allow putting thread_info into task_structAndy Lutomirski
commit c65eacbe290b8141554c71b2c94489e73ade8c8d upstream. If an arch opts in by setting CONFIG_THREAD_INFO_IN_TASK_STRUCT, then thread_info is defined as a single 'u32 flags' and is the first entry of task_struct. thread_info::task is removed (it serves no purpose if thread_info is embedded in task_struct), and thread_info::cpu gets its own slot in task_struct. This is heavily based on a patch written by Linus. Originally-from: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Andy Lutomirski <luto@kernel.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Jann Horn <jann@thejh.net> Cc: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/a0898196f0476195ca02713691a5037a14f2aac5.1473801993.git.luto@kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: zhangyi (F) <yi.zhang@huawei.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-05-16init: initialize jump labels before command line option parsingDan Williams
[ Upstream commit 6041186a32585fc7a1d0f6cfe2f138b05fdc3c82 ] When a module option, or core kernel argument, toggles a static-key it requires jump labels to be initialized early. While x86, PowerPC, and ARM64 arrange for jump_label_init() to be called before parse_args(), ARM does not. Kernel command line: rdinit=/sbin/init page_alloc.shuffle=1 panic=-1 console=ttyAMA0,115200 page_alloc.shuffle=1 ------------[ cut here ]------------ WARNING: CPU: 0 PID: 0 at ./include/linux/jump_label.h:303 page_alloc_shuffle+0x12c/0x1ac static_key_enable(): static key 'page_alloc_shuffle_key+0x0/0x4' used before call to jump_label_init() Modules linked in: CPU: 0 PID: 0 Comm: swapper Not tainted 5.1.0-rc4-next-20190410-00003-g3367c36ce744 #1 Hardware name: ARM Integrator/CP (Device Tree) [<c0011c68>] (unwind_backtrace) from [<c000ec48>] (show_stack+0x10/0x18) [<c000ec48>] (show_stack) from [<c07e9710>] (dump_stack+0x18/0x24) [<c07e9710>] (dump_stack) from [<c001bb1c>] (__warn+0xe0/0x108) [<c001bb1c>] (__warn) from [<c001bb88>] (warn_slowpath_fmt+0x44/0x6c) [<c001bb88>] (warn_slowpath_fmt) from [<c0b0c4a8>] (page_alloc_shuffle+0x12c/0x1ac) [<c0b0c4a8>] (page_alloc_shuffle) from [<c0b0c550>] (shuffle_store+0x28/0x48) [<c0b0c550>] (shuffle_store) from [<c003e6a0>] (parse_args+0x1f4/0x350) [<c003e6a0>] (parse_args) from [<c0ac3c00>] (start_kernel+0x1c0/0x488) Move the fallback call to jump_label_init() to occur before parse_args(). The redundant calls to jump_label_init() in other archs are left intact in case they have static key toggling use cases that are even earlier than option parsing. Link: http://lkml.kernel.org/r/155544804466.1032396.13418949511615676665.stgit@dwillia2-desk3.amr.corp.intel.com Signed-off-by: Dan Williams <dan.j.williams@intel.com> Reported-by: Guenter Roeck <groeck@google.com> Reviewed-by: Kees Cook <keescook@chromium.org> Cc: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Mike Rapoport <rppt@linux.ibm.com> Cc: Russell King <rmk@armlinux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2018-06-06Kbuild: change CC_OPTIMIZE_FOR_SIZE definitionArnd Bergmann
commit 877417e6ffb9578e8580abf76a71e15732473456 upstream. CC_OPTIMIZE_FOR_SIZE disables the often useful -Wmaybe-unused warning, because that causes a ridiculous amount of false positives when combined with -Os. This means a lot of warnings don't show up in testing by the developers that should see them with an 'allmodconfig' kernel that has CC_OPTIMIZE_FOR_SIZE enabled, but only later in randconfig builds that don't. This changes the Kconfig logic around CC_OPTIMIZE_FOR_SIZE to make it a 'choice' statement defaulting to CC_OPTIMIZE_FOR_PERFORMANCE that gets added for this purpose. The allmodconfig and allyesconfig kernels now default to -O2 with the maybe-unused warning enabled. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Michal Marek <mmarek@suse.com> Cc: Nathan Chancellor <natechancellor@gmail.com> Cc: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-03bpf: introduce BPF_JIT_ALWAYS_ON configAlexei Starovoitov
[ upstream commit 290af86629b25ffd1ed6232c4e9107da031705cb ] The BPF interpreter has been used as part of the spectre 2 attack CVE-2017-5715. A quote from goolge project zero blog: "At this point, it would normally be necessary to locate gadgets in the host kernel code that can be used to actually leak data by reading from an attacker-controlled location, shifting and masking the result appropriately and then using the result of that as offset to an attacker-controlled address for a load. But piecing gadgets together and figuring out which ones work in a speculation context seems annoying. So instead, we decided to use the eBPF interpreter, which is built into the host kernel - while there is no legitimate way to invoke it from inside a VM, the presence of the code in the host kernel's text section is sufficient to make it usable for the attack, just like with ordinary ROP gadgets." To make attacker job harder introduce BPF_JIT_ALWAYS_ON config option that removes interpreter from the kernel in favor of JIT-only mode. So far eBPF JIT is supported by: x64, arm64, arm32, sparc64, s390, powerpc64, mips64 The start of JITed program is randomized and code page is marked as read-only. In addition "constant blinding" can be turned on with net.core.bpf_jit_harden v2->v3: - move __bpf_prog_ret0 under ifdef (Daniel) v1->v2: - fix init order, test_bpf and cBPF (Daniel's feedback) - fix offloaded bpf (Jakub's feedback) - add 'return 0' dummy in case something can invoke prog->bpf_func - retarget bpf tree. For bpf-next the patch would need one extra hunk. It will be sent when the trees are merged back to net-next Considered doing: int bpf_jit_enable __read_mostly = BPF_EBPF_JIT_DEFAULT; but it seems better to land the patch as-is and in bpf-next remove bpf_jit_enable global variable from all JITs, consolidate in one place and remove this jit_init() function. Signed-off-by: Alexei Starovoitov <ast@kernel.org> Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-05kaiser: stack map PAGE_SIZE at THREAD_SIZE-PAGE_SIZEHugh Dickins
Kaiser only needs to map one page of the stack; and kernel/fork.c did not build on powerpc (no __PAGE_KERNEL). It's all cleaner if linux/kaiser.h provides kaiser_map_thread_stack() and kaiser_unmap_thread_stack() wrappers around asm/kaiser.h's kaiser_add_mapping() and kaiser_remove_mapping(). And use linux/kaiser.h in init/main.c to avoid the #ifdefs there. Signed-off-by: Hugh Dickins <hughd@google.com> Acked-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-05KAISER: Kernel Address IsolationRichard Fellner
This patch introduces our implementation of KAISER (Kernel Address Isolation to have Side-channels Efficiently Removed), a kernel isolation technique to close hardware side channels on kernel address information. More information about the patch can be found on: https://github.com/IAIK/KAISER From: Richard Fellner <richard.fellner@student.tugraz.at> From: Daniel Gruss <daniel.gruss@iaik.tugraz.at> X-Subject: [RFC, PATCH] x86_64: KAISER - do not map kernel in user mode Date: Thu, 4 May 2017 14:26:50 +0200 Link: http://marc.info/?l=linux-kernel&m=149390087310405&w=2 Kaiser-4.10-SHA1: c4b1831d44c6144d3762ccc72f0c4e71a0c713e5 To: <linux-kernel@vger.kernel.org> To: <kernel-hardening@lists.openwall.com> Cc: <clementine.maurice@iaik.tugraz.at> Cc: <moritz.lipp@iaik.tugraz.at> Cc: Michael Schwarz <michael.schwarz@iaik.tugraz.at> Cc: Richard Fellner <richard.fellner@student.tugraz.at> Cc: Ingo Molnar <mingo@kernel.org> Cc: <kirill.shutemov@linux.intel.com> Cc: <anders.fogh@gdata-adan.de> After several recent works [1,2,3] KASLR on x86_64 was basically considered dead by many researchers. We have been working on an efficient but effective fix for this problem and found that not mapping the kernel space when running in user mode is the solution to this problem [4] (the corresponding paper [5] will be presented at ESSoS17). With this RFC patch we allow anybody to configure their kernel with the flag CONFIG_KAISER to add our defense mechanism. If there are any questions we would love to answer them. We also appreciate any comments! Cheers, Daniel (+ the KAISER team from Graz University of Technology) [1] http://www.ieee-security.org/TC/SP2013/papers/4977a191.pdf [2] https://www.blackhat.com/docs/us-16/materials/us-16-Fogh-Using-Undocumented-CPU-Behaviour-To-See-Into-Kernel-Mode-And-Break-KASLR-In-The-Process.pdf [3] https://www.blackhat.com/docs/us-16/materials/us-16-Jang-Breaking-Kernel-Address-Space-Layout-Randomization-KASLR-With-Intel-TSX.pdf [4] https://github.com/IAIK/KAISER [5] https://gruss.cc/files/kaiser.pdf [patch based also on https://raw.githubusercontent.com/IAIK/KAISER/master/KAISER/0001-KAISER-Kernel-Address-Isolation.patch] Signed-off-by: Richard Fellner <richard.fellner@student.tugraz.at> Signed-off-by: Moritz Lipp <moritz.lipp@iaik.tugraz.at> Signed-off-by: Daniel Gruss <daniel.gruss@iaik.tugraz.at> Signed-off-by: Michael Schwarz <michael.schwarz@iaik.tugraz.at> Acked-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-12-12kernel: remove stop_machine() Kconfig dependencyChris Wilson
Currently the full stop_machine() routine is only enabled on SMP if module unloading is enabled, or if the CPUs are hotpluggable. This leads to configurations where stop_machine() is broken as it will then only run the callback on the local CPU with irqs disabled, and not stop the other CPUs or run the callback on them. For example, this breaks MTRR setup on x86 in certain configs since ea8596bb2d8d379 ("kprobes/x86: Remove unused text_poke_smp() and text_poke_smp_batch() functions") as the MTRR is only established on the boot CPU. This patch removes the Kconfig option for STOP_MACHINE and uses the SMP and HOTPLUG_CPU config options to compile the correct stop_machine() for the architecture, removing the false dependency on MODULE_UNLOAD in the process. Link: https://lkml.org/lkml/2014/10/8/124 References: https://bugs.freedesktop.org/show_bug.cgi?id=84794 Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> Acked-by: Ingo Molnar <mingo@kernel.org> Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Cc: Pranith Kumar <bobby.prani@gmail.com> Cc: Michal Hocko <mhocko@suse.cz> Cc: Vladimir Davydov <vdavydov@parallels.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: H. Peter Anvin <hpa@linux.intel.com> Cc: Tejun Heo <tj@kernel.org> Cc: Iulia Manda <iulia.manda21@gmail.com> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Chuck Ebbert <cebbert.lkml@gmail.com> Cc: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-11sys_membarrier(): system-wide memory barrier (generic, x86)Mathieu Desnoyers
Here is an implementation of a new system call, sys_membarrier(), which executes a memory barrier on all threads running on the system. It is implemented by calling synchronize_sched(). It can be used to distribute the cost of user-space memory barriers asymmetrically by transforming pairs of memory barriers into pairs consisting of sys_membarrier() and a compiler barrier. For synchronization primitives that distinguish between read-side and write-side (e.g. userspace RCU [1], rwlocks), the read-side can be accelerated significantly by moving the bulk of the memory barrier overhead to the write-side. The existing applications of which I am aware that would be improved by this system call are as follows: * Through Userspace RCU library (http://urcu.so) - DNS server (Knot DNS) https://www.knot-dns.cz/ - Network sniffer (http://netsniff-ng.org/) - Distributed object storage (https://sheepdog.github.io/sheepdog/) - User-space tracing (http://lttng.org) - Network storage system (https://www.gluster.org/) - Virtual routers (https://events.linuxfoundation.org/sites/events/files/slides/DPDK_RCU_0MQ.pdf) - Financial software (https://lkml.org/lkml/2015/3/23/189) Those projects use RCU in userspace to increase read-side speed and scalability compared to locking. Especially in the case of RCU used by libraries, sys_membarrier can speed up the read-side by moving the bulk of the memory barrier cost to synchronize_rcu(). * Direct users of sys_membarrier - core dotnet garbage collector (https://github.com/dotnet/coreclr/issues/198) Microsoft core dotnet GC developers are planning to use the mprotect() side-effect of issuing memory barriers through IPIs as a way to implement Windows FlushProcessWriteBuffers() on Linux. They are referring to sys_membarrier in their github thread, specifically stating that sys_membarrier() is what they are looking for. To explain the benefit of this scheme, let's introduce two example threads: Thread A (non-frequent, e.g. executing liburcu synchronize_rcu()) Thread B (frequent, e.g. executing liburcu rcu_read_lock()/rcu_read_unlock()) In a scheme where all smp_mb() in thread A are ordering memory accesses with respect to smp_mb() present in Thread B, we can change each smp_mb() within Thread A into calls to sys_membarrier() and each smp_mb() within Thread B into compiler barriers "barrier()". Before the change, we had, for each smp_mb() pairs: Thread A Thread B previous mem accesses previous mem accesses smp_mb() smp_mb() following mem accesses following mem accesses After the change, these pairs become: Thread A Thread B prev mem accesses prev mem accesses sys_membarrier() barrier() follow mem accesses follow mem accesses As we can see, there are two possible scenarios: either Thread B memory accesses do not happen concurrently with Thread A accesses (1), or they do (2). 1) Non-concurrent Thread A vs Thread B accesses: Thread A Thread B prev mem accesses sys_membarrier() follow mem accesses prev mem accesses barrier() follow mem accesses In this case, thread B accesses will be weakly ordered. This is OK, because at that point, thread A is not particularly interested in ordering them with respect to its own accesses. 2) Concurrent Thread A vs Thread B accesses Thread A Thread B prev mem accesses prev mem accesses sys_membarrier() barrier() follow mem accesses follow mem accesses In this case, thread B accesses, which are ensured to be in program order thanks to the compiler barrier, will be "upgraded" to full smp_mb() by synchronize_sched(). * Benchmarks On Intel Xeon E5405 (8 cores) (one thread is calling sys_membarrier, the other 7 threads are busy looping) 1000 non-expedited sys_membarrier calls in 33s =3D 33 milliseconds/call. * User-space user of this system call: Userspace RCU library Both the signal-based and the sys_membarrier userspace RCU schemes permit us to remove the memory barrier from the userspace RCU rcu_read_lock() and rcu_read_unlock() primitives, thus significantly accelerating them. These memory barriers are replaced by compiler barriers on the read-side, and all matching memory barriers on the write-side are turned into an invocation of a memory barrier on all active threads in the process. By letting the kernel perform this synchronization rather than dumbly sending a signal to every process threads (as we currently do), we diminish the number of unnecessary wake ups and only issue the memory barriers on active threads. Non-running threads do not need to execute such barrier anyway, because these are implied by the scheduler context switches. Results in liburcu: Operations in 10s, 6 readers, 2 writers: memory barriers in reader: 1701557485 reads, 2202847 writes signal-based scheme: 9830061167 reads, 6700 writes sys_membarrier: 9952759104 reads, 425 writes sys_membarrier (dyn. check): 7970328887 reads, 425 writes The dynamic sys_membarrier availability check adds some overhead to the read-side compared to the signal-based scheme, but besides that, sys_membarrier slightly outperforms the signal-based scheme. However, this non-expedited sys_membarrier implementation has a much slower grace period than signal and memory barrier schemes. Besides diminishing the number of wake-ups, one major advantage of the membarrier system call over the signal-based scheme is that it does not need to reserve a signal. This plays much more nicely with libraries, and with processes injected into for tracing purposes, for which we cannot expect that signals will be unused by the application. An expedited version of this system call can be added later on to speed up the grace period. Its implementation will likely depend on reading the cpu_curr()->mm without holding each CPU's rq lock. This patch adds the system call to x86 and to asm-generic. [1] http://urcu.so membarrier(2) man page: MEMBARRIER(2) Linux Programmer's Manual MEMBARRIER(2) NAME membarrier - issue memory barriers on a set of threads SYNOPSIS #include <linux/membarrier.h> int membarrier(int cmd, int flags); DESCRIPTION The cmd argument is one of the following: MEMBARRIER_CMD_QUERY Query the set of supported commands. It returns a bitmask of supported commands. MEMBARRIER_CMD_SHARED Execute a memory barrier on all threads running on the system. Upon return from system call, the caller thread is ensured that all running threads have passed through a state where all memory accesses to user-space addresses match program order between entry to and return from the system call (non-running threads are de facto in such a state). This covers threads from all pro=E2=80=90 cesses running on the system. This command returns 0. The flags argument needs to be 0. For future extensions. All memory accesses performed in program order from each targeted thread is guaranteed to be ordered with respect to sys_membarrier(). If we use the semantic "barrier()" to represent a compiler barrier forcing memory accesses to be performed in program order across the barrier, and smp_mb() to represent explicit memory barriers forcing full memory ordering across the barrier, we have the following ordering table for each pair of barrier(), sys_membarrier() and smp_mb(): The pair ordering is detailed as (O: ordered, X: not ordered): barrier() smp_mb() sys_membarrier() barrier() X X O smp_mb() X O O sys_membarrier() O O O RETURN VALUE On success, these system calls return zero. On error, -1 is returned, and errno is set appropriately. For a given command, with flags argument set to 0, this system call is guaranteed to always return the same value until reboot. ERRORS ENOSYS System call is not implemented. EINVAL Invalid arguments. Linux 2015-04-15 MEMBARRIER(2) Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Reviewed-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Nicholas Miell <nmiell@comcast.net> Cc: Ingo Molnar <mingo@redhat.com> Cc: Alan Cox <gnomes@lxorguk.ukuu.org.uk> Cc: Lai Jiangshan <laijs@cn.fujitsu.com> Cc: Stephen Hemminger <stephen@networkplumber.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: David Howells <dhowells@redhat.com> Cc: Pranith Kumar <bobby.prani@gmail.com> Cc: Michael Kerrisk <mtk.manpages@gmail.com> Cc: Shuah Khan <shuahkh@osg.samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-10kexec: split kexec_load syscall from kexec core codeDave Young
There are two kexec load syscalls, kexec_load another and kexec_file_load. kexec_file_load has been splited as kernel/kexec_file.c. In this patch I split kexec_load syscall code to kernel/kexec.c. And add a new kconfig option KEXEC_CORE, so we can disable kexec_load and use kexec_file_load only, or vice verse. The original requirement is from Ted Ts'o, he want kexec kernel signature being checked with CONFIG_KEXEC_VERIFY_SIG enabled. But kexec-tools use kexec_load syscall can bypass the checking. Vivek Goyal proposed to create a common kconfig option so user can compile in only one syscall for loading kexec kernel. KEXEC/KEXEC_FILE selects KEXEC_CORE so that old config files still work. Because there's general code need CONFIG_KEXEC_CORE, so I updated all the architecture Kconfig with a new option KEXEC_CORE, and let KEXEC selects KEXEC_CORE in arch Kconfig. Also updated general kernel code with to kexec_load syscall. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Dave Young <dyoung@redhat.com> Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: Vivek Goyal <vgoyal@redhat.com> Cc: Petr Tesarik <ptesarik@suse.cz> Cc: Theodore Ts'o <tytso@mit.edu> Cc: Josh Boyer <jwboyer@fedoraproject.org> Cc: David Howells <dhowells@redhat.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-10kmod: use system_unbound_wq instead of khelperFrederic Weisbecker
We need to launch the usermodehelper kernel threads with the widest affinity and this is partly why we use khelper. This workqueue has unbound properties and thus a wide affinity inherited by all its children. Now khelper also has special properties that we aren't much interested in: ordered and singlethread. There is really no need about ordering as all we do is creating kernel threads. This can be done concurrently. And singlethread is a useless limitation as well. The workqueue engine already proposes generic unbound workqueues that don't share these useless properties and handle well parallel jobs. The only worrysome specific is their affinity to the node of the current CPU. It's fine for creating the usermodehelper kernel threads but those inherit this affinity for longer jobs such as requesting modules. This patch proposes to use these node affine unbound workqueues assuming that a node is sufficient to handle several parallel usermodehelper requests. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Rik van Riel <riel@redhat.com> Reviewed-by: Oleg Nesterov <oleg@redhat.com> Cc: Christoph Lameter <cl@linux.com> Cc: Tejun Heo <tj@kernel.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-08Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security Pull security subsystem updates from James Morris: "Highlights: - PKCS#7 support added to support signed kexec, also utilized for module signing. See comments in 3f1e1bea. ** NOTE: this requires linking against the OpenSSL library, which must be installed, e.g. the openssl-devel on Fedora ** - Smack - add IPv6 host labeling; ignore labels on kernel threads - support smack labeling mounts which use binary mount data - SELinux: - add ioctl whitelisting (see http://kernsec.org/files/lss2015/vanderstoep.pdf) - fix mprotect PROT_EXEC regression caused by mm change - Seccomp: - add ptrace options for suspend/resume" * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (57 commits) PKCS#7: Add OIDs for sha224, sha284 and sha512 hash algos and use them Documentation/Changes: Now need OpenSSL devel packages for module signing scripts: add extract-cert and sign-file to .gitignore modsign: Handle signing key in source tree modsign: Use if_changed rule for extracting cert from module signing key Move certificate handling to its own directory sign-file: Fix warning about BIO_reset() return value PKCS#7: Add MODULE_LICENSE() to test module Smack - Fix build error with bringup unconfigured sign-file: Document dependency on OpenSSL devel libraries PKCS#7: Appropriately restrict authenticated attributes and content type KEYS: Add a name for PKEY_ID_PKCS7 PKCS#7: Improve and export the X.509 ASN.1 time object decoder modsign: Use extract-cert to process CONFIG_SYSTEM_TRUSTED_KEYS extract-cert: Cope with multiple X.509 certificates in a single file sign-file: Generate CMS message as signature instead of PKCS#7 PKCS#7: Support CMS messages also [RFC5652] X.509: Change recorded SKID & AKID to not include Subject or Issuer PKCS#7: Check content type and versions MAINTAINERS: The keyrings mailing list has moved ...
2015-09-05Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs updates from Al Viro: "In this one: - d_move fixes (Eric Biederman) - UFS fixes (me; locking is mostly sane now, a bunch of bugs in error handling ought to be fixed) - switch of sb_writers to percpu rwsem (Oleg Nesterov) - superblock scalability (Josef Bacik and Dave Chinner) - swapon(2) race fix (Hugh Dickins)" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (65 commits) vfs: Test for and handle paths that are unreachable from their mnt_root dcache: Reduce the scope of i_lock in d_splice_alias dcache: Handle escaped paths in prepend_path mm: fix potential data race in SyS_swapon inode: don't softlockup when evicting inodes inode: rename i_wb_list to i_io_list sync: serialise per-superblock sync operations inode: convert inode_sb_list_lock to per-sb inode: add hlist_fake to avoid the inode hash lock in evict writeback: plug writeback at a high level change sb_writers to use percpu_rw_semaphore shift percpu_counter_destroy() into destroy_super_work() percpu-rwsem: kill CONFIG_PERCPU_RWSEM percpu-rwsem: introduce percpu_rwsem_release() and percpu_rwsem_acquire() percpu-rwsem: introduce percpu_down_read_trylock() document rwsem_release() in sb_wait_write() fix the broken lockdep logic in __sb_start_write() introduce __sb_writers_{acquired,release}() helpers ufs_inode_get{frag,block}(): get rid of 'phys' argument ufs_getfrag_block(): tidy up a bit ...
2015-09-05Merge branch 'akpm' (patches from Andrew)Linus Torvalds
Merge patch-bomb from Andrew Morton: - a few misc things - Andy's "ambient capabilities" - fs/nofity updates - the ocfs2 queue - kernel/watchdog.c updates and feature work. - some of MM. Includes Andrea's userfaultfd feature. [ Hadn't noticed that userfaultfd was 'default y' when applying the patches, so that got fixed in this merge instead. We do _not_ mark new features that nobody uses yet 'default y' - Linus ] * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (118 commits) mm/hugetlb.c: make vma_has_reserves() return bool mm/madvise.c: make madvise_behaviour_valid() return bool mm/memory.c: make tlb_next_batch() return bool mm/dmapool.c: change is_page_busy() return from int to bool mm: remove struct node_active_region mremap: simplify the "overlap" check in mremap_to() mremap: don't do uneccesary checks if new_len == old_len mremap: don't do mm_populate(new_addr) on failure mm: move ->mremap() from file_operations to vm_operations_struct mremap: don't leak new_vma if f_op->mremap() fails mm/hugetlb.c: make vma_shareable() return bool mm: make GUP handle pfn mapping unless FOLL_GET is requested mm: fix status code which move_pages() returns for zero page mm: memcontrol: bring back the VM_BUG_ON() in mem_cgroup_swapout() genalloc: add support of multiple gen_pools per device genalloc: add name arg to gen_pool_get() and devm_gen_pool_create() mm/memblock: WARN_ON when nid differs from overlap region Documentation/features/vm: add feature description and arch support status for batched TLB flush after unmap mm: defer flush of writable TLB entries mm: send one IPI per CPU to TLB flush all entries after unmapping pages ...
2015-09-04mm: send one IPI per CPU to TLB flush all entries after unmapping pagesMel Gorman
An IPI is sent to flush remote TLBs when a page is unmapped that was potentially accesssed by other CPUs. There are many circumstances where this happens but the obvious one is kswapd reclaiming pages belonging to a running process as kswapd and the task are likely running on separate CPUs. On small machines, this is not a significant problem but as machine gets larger with more cores and more memory, the cost of these IPIs can be high. This patch uses a simple structure that tracks CPUs that potentially have TLB entries for pages being unmapped. When the unmapping is complete, the full TLB is flushed on the assumption that a refill cost is lower than flushing individual entries. Architectures wishing to do this must give the following guarantee. If a clean page is unmapped and not immediately flushed, the architecture must guarantee that a write to that linear address from a CPU with a cached TLB entry will trap a page fault. This is essentially what the kernel already depends on but the window is much larger with this patch applied and is worth highlighting. The architecture should consider whether the cost of the full TLB flush is higher than sending an IPI to flush each individual entry. An additional architecture helper called flush_tlb_local is required. It's a trivial wrapper with some accounting in the x86 case. The impact of this patch depends on the workload as measuring any benefit requires both mapped pages co-located on the LRU and memory pressure. The case with the biggest impact is multiple processes reading mapped pages taken from the vm-scalability test suite. The test case uses NR_CPU readers of mapped files that consume 10*RAM. Linear mapped reader on a 4-node machine with 64G RAM and 48 CPUs 4.2.0-rc1 4.2.0-rc1 vanilla flushfull-v7 Ops lru-file-mmap-read-elapsed 159.62 ( 0.00%) 120.68 ( 24.40%) Ops lru-file-mmap-read-time_range 30.59 ( 0.00%) 2.80 ( 90.85%) Ops lru-file-mmap-read-time_stddv 6.70 ( 0.00%) 0.64 ( 90.38%) 4.2.0-rc1 4.2.0-rc1 vanilla flushfull-v7 User 581.00 611.43 System 5804.93 4111.76 Elapsed 161.03 122.12 This is showing that the readers completed 24.40% faster with 29% less system CPU time. From vmstats, it is known that the vanilla kernel was interrupted roughly 900K times per second during the steady phase of the test and the patched kernel was interrupts 180K times per second. The impact is lower on a single socket machine. 4.2.0-rc1 4.2.0-rc1 vanilla flushfull-v7 Ops lru-file-mmap-read-elapsed 25.33 ( 0.00%) 20.38 ( 19.54%) Ops lru-file-mmap-read-time_range 0.91 ( 0.00%) 1.44 (-58.24%) Ops lru-file-mmap-read-time_stddv 0.28 ( 0.00%) 0.47 (-65.34%) 4.2.0-rc1 4.2.0-rc1 vanilla flushfull-v7 User 58.09 57.64 System 111.82 76.56 Elapsed 27.29 22.55 It's still a noticeable improvement with vmstat showing interrupts went from roughly 500K per second to 45K per second. The patch will have no impact on workloads with no memory pressure or have relatively few mapped pages. It will have an unpredictable impact on the workload running on the CPU being flushed as it'll depend on how many TLB entries need to be refilled and how long that takes. Worst case, the TLB will be completely cleared of active entries when the target PFNs were not resident at all. [sasha.levin@oracle.com: trace tlb flush after disabling preemption in try_to_unmap_flush] Signed-off-by: Mel Gorman <mgorman@suse.de> Reviewed-by: Rik van Riel <riel@redhat.com> Cc: Dave Hansen <dave.hansen@intel.com> Acked-by: Ingo Molnar <mingo@kernel.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Cc: Michal Hocko <mhocko@suse.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-04userfaultfd: buildsystem activationAndrea Arcangeli
This allows to select the userfaultfd during configuration to build it. Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Acked-by: Pavel Emelyanov <xemul@parallels.com> Cc: Sanidhya Kashyap <sanidhya.gatech@gmail.com> Cc: zhang.zhanghailiang@huawei.com Cc: "Kirill A. Shutemov" <kirill@shutemov.name> Cc: Andres Lagar-Cavilla <andreslc@google.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Paolo Bonzini <pbonzini@redhat.com> Cc: Rik van Riel <riel@redhat.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Hugh Dickins <hughd@google.com> Cc: Peter Feiner <pfeiner@google.com> Cc: "Dr. David Alan Gilbert" <dgilbert@redhat.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: "Huangpeng (Peter)" <peter.huangpeng@huawei.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-02Merge branch 'for-4.3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup Pull cgroup updates from Tejun Heo: - a new PIDs controller is added. It turns out that PIDs are actually an independent resource from kmem due to the limited PID space. - more core preparations for the v2 interface. Once cpu side interface is settled, it should be ready for lifting the devel mask. for-4.3-unified-base was temporarily branched so that other trees (block) can pull cgroup core changes that blkcg changes depend on. - a non-critical idr_preload usage bug fix. * 'for-4.3' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup: cgroup: pids: fix invalid get/put usage cgroup: introduce cgroup_subsys->legacy_name cgroup: don't print subsystems for the default hierarchy cgroup: make cftype->private a unsigned long cgroup: export cgrp_dfl_root cgroup: define controller file conventions cgroup: fix idr_preload usage cgroup: add documentation for the PIDs controller cgroup: implement the PIDs subsystem cgroup: allow a cgroup subsystem to reject a fork
2015-08-15percpu-rwsem: kill CONFIG_PERCPU_RWSEMOleg Nesterov
Remove CONFIG_PERCPU_RWSEM, the next patch adds the unconditional user of percpu_rw_semaphore. Signed-off-by: Oleg Nesterov <oleg@redhat.com>
2015-08-14Move certificate handling to its own directoryDavid Howells
Move certificate handling out of the kernel/ directory and into a certs/ directory to get all the weird stuff in one place and move the generated signing keys into this directory. Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: David Woodhouse <David.Woodhouse@intel.com>
2015-08-12sign-file: Document dependency on OpenSSL devel librariesDavid Howells
The revised sign-file program is no longer a script that wraps the openssl program, but now rather a program that makes use of OpenSSL's crypto library. This means that to build the sign-file program, the kernel build process now has a dependency on the OpenSSL development packages in addition to OpenSSL itself. Document this in Kconfig and in module-signing.txt. Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: David Woodhouse <David.Woodhouse@intel.com>
2015-08-12Merge branch 'for-mingo' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/paulmck/linux-rcu into core/rcu Pull RCU changes from Paul E. McKenney: - The combination of tree geometry-initialization simplifications and OS-jitter-reduction changes to expedited grace periods. These two are stacked due to the large number of conflicts that would otherwise result. [ With one addition, a temporary commit to silence a lockdep false positive. Additional changes to the expedited grace-period primitives (queued for 4.4) remove the cause of this false positive, and therefore include a revert of this temporary commit. ] - Documentation updates. - Torture-test updates. - Miscellaneous fixes. Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-08-07modsign: Add explicit CONFIG_SYSTEM_TRUSTED_KEYS optionDavid Woodhouse
Let the user explicitly provide a file containing trusted keys, instead of just automatically finding files matching *.x509 in the build tree and trusting whatever we find. This really ought to be an *explicit* configuration, and the build rules for dealing with the files were fairly painful too. Fix applied from James Morris that removes an '=' from a macro definition in kernel/Makefile as this is a feature that only exists from GNU make 3.82 onwards. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: David Howells <dhowells@redhat.com>
2015-08-07modsign: Use single PEM file for autogenerated keyDavid Woodhouse
The current rule for generating signing_key.priv and signing_key.x509 is a classic example of a bad rule which has a tendency to break parallel make. When invoked to create *either* target, it generates the other target as a side-effect that make didn't predict. So let's switch to using a single file signing_key.pem which contains both key and certificate. That matches what we do in the case of an external key specified by CONFIG_MODULE_SIG_KEY anyway, so it's also slightly cleaner. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: David Howells <dhowells@redhat.com>
2015-08-07modsign: Extract signing cert from CONFIG_MODULE_SIG_KEY if neededDavid Woodhouse
Where an external PEM file or PKCS#11 URI is given, we can get the cert from it for ourselves instead of making the user drop signing_key.x509 in place for us. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: David Howells <dhowells@redhat.com>
2015-08-07modsign: Allow external signing key to be specifiedDavid Woodhouse
2015-08-07MODSIGN: Extract the blob PKCS#7 signature verifier from module signingDavid Howells
Extract the function that drives the PKCS#7 signature verification given a data blob and a PKCS#7 blob out from the module signing code and lump it with the system keyring code as it's generic. This makes it independent of module config options and opens it to use by the firmware loader. Signed-off-by: David Howells <dhowells@redhat.com> Cc: Luis R. Rodriguez <mcgrof@suse.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Ming Lei <ming.lei@canonical.com> Cc: Seth Forshee <seth.forshee@canonical.com> Cc: Kyle McMartin <kyle@kernel.org>
2015-08-07MODSIGN: Use PKCS#7 messages as module signaturesDavid Howells
Move to using PKCS#7 messages as module signatures because: (1) We have to be able to support the use of X.509 certificates that don't have a subjKeyId set. We're currently relying on this to look up the X.509 certificate in the trusted keyring list. (2) PKCS#7 message signed information blocks have a field that supplies the data required to match with the X.509 certificate that signed it. (3) The PKCS#7 certificate carries fields that specify the digest algorithm used to generate the signature in a standardised way and the X.509 certificates specify the public key algorithm in a standardised way - so we don't need our own methods of specifying these. (4) We now have PKCS#7 message support in the kernel for signed kexec purposes and we can make use of this. To make this work, the old sign-file script has been replaced with a program that needs compiling in a previous patch. The rules to build it are added here. Signed-off-by: David Howells <dhowells@redhat.com> Tested-by: Vivek Goyal <vgoyal@redhat.com>
2015-08-07fs, file table: reinit files_stat.max_files after deferred memory initialisationMel Gorman
Dave Hansen reported the following; My laptop has been behaving strangely with 4.2-rc2. Once I log in to my X session, I start getting all kinds of strange errors from applications and see this in my dmesg: VFS: file-max limit 8192 reached The problem is that the file-max is calculated before memory is fully initialised and miscalculates how much memory the kernel is using. This patch recalculates file-max after deferred memory initialisation. Note that using memory hotplug infrastructure would not have avoided this problem as the value is not recalculated after memory hot-add. 4.1: files_stat.max_files = 6582781 4.2-rc2: files_stat.max_files = 8192 4.2-rc2 patched: files_stat.max_files = 6562467 Small differences with the patch applied and 4.1 but not enough to matter. Signed-off-by: Mel Gorman <mgorman@suse.de> Reported-by: Dave Hansen <dave.hansen@intel.com> Cc: Nicolai Stange <nicstange@gmail.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Alex Ng <alexng@microsoft.com> Cc: Fengguang Wu <fengguang.wu@intel.com> Cc: Peter Zijlstra (Intel) <peterz@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-07-22rcu: Hide RCU_NOCB_CPU behind RCU_EXPERTPaul E. McKenney
This commit prevents Kconfig from asking the user about RCU_NOCB_CPU unless the user really wants to be asked. Reported-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Cc: Thomas Gleixner <tglx@linutronix.de>
2015-07-14cgroup: implement the PIDs subsystemAleksa Sarai
Adds a new single-purpose PIDs subsystem to limit the number of tasks that can be forked inside a cgroup. Essentially this is an implementation of RLIMIT_NPROC that applies to a cgroup rather than a process tree. However, it should be noted that organisational operations (adding and removing tasks from a PIDs hierarchy) will *not* be prevented. Rather, the number of tasks in the hierarchy cannot exceed the limit through forking. This is due to the fact that, in the unified hierarchy, attach cannot fail (and it is not possible for a task to overcome its PIDs cgroup policy limit by attaching to a child cgroup -- even if migrating mid-fork it must be able to fork in the parent first). PIDs are fundamentally a global resource, and it is possible to reach PID exhaustion inside a cgroup without hitting any reasonable kmemcg policy. Once you've hit PID exhaustion, you're only in a marginally better state than OOM. This subsystem allows PID exhaustion inside a cgroup to be prevented. Signed-off-by: Aleksa Sarai <cyphar@cyphar.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2015-07-06rcu: Drop RCU_USER_QS in favor of NO_HZ_FULLPaul E. McKenney
The RCU_USER_QS Kconfig parameter is now just a synonym for NO_HZ_FULL, so this commit eliminates RCU_USER_QS, replacing all uses with NO_HZ_FULL. Reported-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Frederic Weisbecker <fweisbec@gmail.com>
2015-07-04Merge branch 'sched-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull scheduler fixes from Ingo Molnar: "Debug info and other statistics fixes and related enhancements" * 'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: sched/numa: Fix numa balancing stats in /proc/pid/sched sched/numa: Show numa_group ID in /proc/sched_debug task listings sched/debug: Move print_cfs_rq() declaration to kernel/sched/sched.h sched/stat: Expose /proc/pid/schedstat if CONFIG_SCHED_INFO=y sched/stat: Simplify the sched_info accounting dependency
2015-07-04Merge branch 'core-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull max log buf size increase from Ingo Molnar: "Ran into this limit recently, so increase it by an order of magnitude" * 'core-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: printk: Increase maximum CONFIG_LOG_BUF_SHIFT from 21 to 25
2015-07-04sched/stat: Simplify the sched_info accounting dependencyNaveen N. Rao
Both CONFIG_SCHEDSTATS=y and CONFIG_TASK_DELAY_ACCT=y track task sched_info, which results in ugly #if clauses. Simplify the code by introducing a synthethic CONFIG_SCHED_INFO switch, selected by both. Signed-off-by: Naveen N. Rao <naveen.n.rao@linux.vnet.ibm.com> Cc: Balbir Singh <bsingharora@gmail.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: a.p.zijlstra@chello.nl Cc: ricklind@us.ibm.com Link: http://lkml.kernel.org/r/8d19eef800811a94b0f91bcbeb27430a884d7433.1435255405.git.naveen.n.rao@linux.vnet.ibm.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-07-01Merge branch 'akpm' (patches from Andrew)Linus Torvalds
Merge third patchbomb from Andrew Morton: - the rest of MM - scripts/gdb updates - ipc/ updates - lib/ updates - MAINTAINERS updates - various other misc things * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (67 commits) genalloc: rename of_get_named_gen_pool() to of_gen_pool_get() genalloc: rename dev_get_gen_pool() to gen_pool_get() x86: opt into HAVE_COPY_THREAD_TLS, for both 32-bit and 64-bit MAINTAINERS: add zpool MAINTAINERS: BCACHE: Kent Overstreet has changed email address MAINTAINERS: move Jens Osterkamp to CREDITS MAINTAINERS: remove unused nbd.h pattern MAINTAINERS: update brcm gpio filename pattern MAINTAINERS: update brcm dts pattern MAINTAINERS: update sound soc intel patterns MAINTAINERS: remove website for paride MAINTAINERS: update Emulex ocrdma email addresses bcache: use kvfree() in various places libcxgbi: use kvfree() in cxgbi_free_big_mem() target: use kvfree() in session alloc and free IB/ehca: use kvfree() in ipz_queue_{cd}tor() drm/nouveau/gem: use kvfree() in u_free() drm: use kvfree() in drm_free_large() cxgb4: use kvfree() in t4_free_mem() cxgb3: use kvfree() in cxgb_free_mem() ...
2015-07-01Merge tag 'modules-next-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux Pull module updates from Rusty Russell: "Main excitement here is Peter Zijlstra's lockless rbtree optimization to speed module address lookup. He found some abusers of the module lock doing that too. A little bit of parameter work here too; including Dan Streetman's breaking up the big param mutex so writing a parameter can load another module (yeah, really). Unfortunately that broke the usual suspects, !CONFIG_MODULES and !CONFIG_SYSFS, so those fixes were appended too" * tag 'modules-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: (26 commits) modules: only use mod->param_lock if CONFIG_MODULES param: fix module param locks when !CONFIG_SYSFS. rcu: merge fix for Convert ACCESS_ONCE() to READ_ONCE() and WRITE_ONCE() module: add per-module param_lock module: make perm const params: suppress unused variable error, warn once just in case code changes. modules: clarify CONFIG_MODULE_COMPRESS help, suggest 'N'. kernel/module.c: avoid ifdefs for sig_enforce declaration kernel/workqueue.c: remove ifdefs over wq_power_efficient kernel/params.c: export param_ops_bool_enable_only kernel/params.c: generalize bool_enable_only kernel/module.c: use generic module param operaters for sig_enforce kernel/params: constify struct kernel_param_ops uses sysfs: tightened sysfs permission checks module: Rework module_addr_{min,max} module: Use __module_address() for module_address_lookup() module: Make the mod_tree stuff conditional on PERF_EVENTS || TRACING module: Optimize __module_address() using a latched RB-tree rbtree: Implement generic latch_tree seqlock: Introduce raw_read_seqcount_latch() ...
2015-07-01printk: Increase maximum CONFIG_LOG_BUF_SHIFT from 21 to 25Ingo Molnar
So I tried to some kernel debugging that produced a ton of kernel messages on a big box, and wanted to save them all: but CONFIG_LOG_BUF_SHIFT maxes out at 21 (2 MB). Increase it to 25 (32 MB). This does not affect any existing config or defaults. Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-kernel@vger.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-06-30mm: meminit: finish initialisation of struct pages before basic setupMel Gorman
Waiman Long reported that 24TB machines hit OOM during basic setup when struct page initialisation was deferred. One approach is to initialise memory on demand but it interferes with page allocator paths. This patch creates dedicated threads to initialise memory before basic setup. It then blocks on a rw_semaphore until completion as a wait_queue and counter is overkill. This may be slower to boot but it's simplier overall and also gets rid of a section mangling which existed so kswapd could do the initialisation. [akpm@linux-foundation.org: include rwsem.h, use DECLARE_RWSEM, fix comment, remove unneeded cast] Signed-off-by: Mel Gorman <mgorman@suse.de> Cc: Waiman Long <waiman.long@hp.com Cc: Nathan Zimmer <nzimmer@sgi.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Scott Norton <scott.norton@hp.com> Tested-by: Daniel J Blueman <daniel@numascale.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-26Merge branch 'for-4.2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup Pull cgroup updates from Tejun Heo: - threadgroup_lock got reorganized so that its users can pick the actual locking mechanism to use. Its only user - cgroups - is updated to use a percpu_rwsem instead of per-process rwsem. This makes things a bit lighter on hot paths and allows cgroups to perform and fail multi-task (a process) migrations atomically. Multi-task migrations are used in several places including the unified hierarchy. - Delegation rule and documentation added to unified hierarchy. This will likely be the last interface update from the cgroup core side for unified hierarchy before lifting the devel mask. - Some groundwork for the pids controller which is scheduled to be merged in the coming devel cycle. * 'for-4.2' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup: cgroup: add delegation section to unified hierarchy documentation cgroup: require write perm on common ancestor when moving processes on the default hierarchy cgroup: separate out cgroup_procs_write_permission() from __cgroup_procs_write() kernfs: make kernfs_get_inode() public MAINTAINERS: add a cgroup core co-maintainer cgroup: fix uninitialised iterator in for_each_subsys_which cgroup: replace explicit ss_mask checking with for_each_subsys_which cgroup: use bitmask to filter for_each_subsys cgroup: add seq_file forward declaration for struct cftype cgroup: simplify threadgroup locking sched, cgroup: replace signal_struct->group_rwsem with a global percpu_rwsem sched, cgroup: reorganize threadgroup locking cgroup: switch to unsigned long for bitmasks cgroup: reorganize include/linux/cgroup.h cgroup: separate out include/linux/cgroup-defs.h cgroup: fix some comment typos
2015-06-26Merge tag 'driver-core-4.2-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core updates from Greg KH: "Here is the driver core / firmware changes for 4.2-rc1. A number of small changes all over the place in the driver core, and in the firmware subsystem. Nothing really major, full details in the shortlog. Some of it is a bit of churn, given that the platform driver probing changes was found to not work well, so they were reverted. All of these have been in linux-next for a while with no reported issues" * tag 'driver-core-4.2-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (31 commits) Revert "base/platform: Only insert MEM and IO resources" Revert "base/platform: Continue on insert_resource() error" Revert "of/platform: Use platform_device interface" Revert "base/platform: Remove code duplication" firmware: add missing kfree for work on async call fs: sysfs: don't pass count == 0 to bin file readers base:dd - Fix for typo in comment to function driver_deferred_probe_trigger(). base/platform: Remove code duplication of/platform: Use platform_device interface base/platform: Continue on insert_resource() error base/platform: Only insert MEM and IO resources firmware: use const for remaining firmware names firmware: fix possible use after free on name on asynchronous request firmware: check for file truncation on direct firmware loading firmware: fix __getname() missing failure check drivers: of/base: move of_init to driver_init drivers/base: cacheinfo: fix annoying typo when DT nodes are absent sysfs: disambiguate between "error code" and "failure" in comments driver-core: fix build for !CONFIG_MODULES driver-core: make __device_attach() static ...
2015-06-26Merge branch 'akpm' (patches from Andrew)Linus Torvalds
Merge second patchbomb from Andrew Morton: - most of the rest of MM - lots of misc things - procfs updates - printk feature work - updates to get_maintainer, MAINTAINERS, checkpatch - lib/ updates * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (96 commits) exit,stats: /* obey this comment */ coredump: add __printf attribute to cn_*printf functions coredump: use from_kuid/kgid when formatting corename fs/reiserfs: remove unneeded cast NILFS2: support NFSv2 export fs/befs/btree.c: remove unneeded initializations fs/minix: remove unneeded cast init/do_mounts.c: add create_dev() failure log kasan: remove duplicate definition of the macro KASAN_FREE_PAGE fs/efs: femove unneeded cast checkpatch: emit "NOTE: <types>" message only once after multiple files checkpatch: emit an error when there's a diff in a changelog checkpatch: validate MODULE_LICENSE content checkpatch: add multi-line handling for PREFER_ETHER_ADDR_COPY checkpatch: suggest using eth_zero_addr() and eth_broadcast_addr() checkpatch: fix processing of MEMSET issues checkpatch: suggest using ether_addr_equal*() checkpatch: avoid NOT_UNIFIED_DIFF errors on cover-letter.patch files checkpatch: remove local from codespell path checkpatch: add --showfile to allow input via pipe to show filenames ...
2015-06-25init/do_mounts.c: add create_dev() failure logVishnu Pratap Singh
If create_dev() function fails to create the root mount device (/dev/root), then it goes to panic as root device not found but there is no printk in this case. So I have added the log in case it fails to create the root device. It will help in debugging. [akpm@linux-foundation.org: simplify printk(), use pr_emerg(), display errno] Signed-off-by: Vishnu Pratap Singh <vishnu.ps@samsung.com> Acked-by: Pavel Machek <pavel@ucw.cz> Cc: Paul Gortmaker <paul.gortmaker@windriver.com> Cc: Mike Snitzer <snitzer@redhat.com> Cc: Dan Ehrenberg <dehrenberg@chromium.org> Cc: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
