Add drivers for e-con Systems AR0521 and AR1335 camera modules.
Related to: PMS-387
toradex_5.4-2.1.x-imx
Update 5.4-2.1.x-imx to v5.4.74 from [1].
[1] https://github.com/Freescale/linux-fslc
This is the 5.4.76 stable release
- drivers/tty/serial/fsl_lpuart.c:
Fix merge conflict of upstream patches [86875e1d6426] and [8febdfb5973d],
which contradicted with patch [cde0cb39c0e8e] from NXP.
Signed-off-by: Andrey Zhizhikin <andrey.zhizhikin@leica-geosystems.com>
commit d6e36668598154820177bfd78c1621d8e6c580a2 upstream.
After commit d12544fb2aa9 ("PM: runtime: Remove link state checks in
rpm_get/put_supplier()") nothing prevents the consumer device's
runtime PM from acquiring additional references to the supplier
device after pm_runtime_clean_up_links() has run (or even while it
is running), so calling this function from __device_release_driver()
may be pointless (or even harmful).
Moreover, it ignores stateless device links, so the runtime PM
handling of managed and stateless device links is inconsistent
because of it, so better get rid of it entirely.
Fixes: d12544fb2aa9 ("PM: runtime: Remove link state checks in rpm_get/put_supplier()")
Cc: 5.1+ <stable@vger.kernel.org> # 5.1+
Tested-by: Xiang Chen <chenxiang66@hisilicon.com>
Reviewed-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
commit e0e398e204634db8fb71bd89cf2f6e3e5bd09b51 upstream.
While removing a device link, drop the supplier device's runtime PM
usage counter as many times as needed to drop all of the runtime PM
references to it from the consumer in addition to dropping the
consumer's link count.
Fixes: baa8809f6097 ("PM / runtime: Optimize the use of device links")
commit f8f6ae5d077a9bdaf5cbf2ac960a5d1a04b47482 upstream.
The purpose of io_remap_pfn_range() is to map IO memory, such as a
memory mapped IO exposed through a PCI BAR. IO devices do not
understand encryption, so this memory must always be decrypted.
Automatically call pgprot_decrypted() as part of the generic
implementation.
This fixes a bug where enabling AMD SME causes subsystems, such as RDMA,
using io_remap_pfn_range() to expose BAR pages to user space to fail.
The CPU will encrypt access to those BAR pages instead of passing
unencrypted IO directly to the device.
Places not mapping IO should use remap_pfn_range().
Fixes: aca20d546214 ("x86/mm: Add support to make use of Secure Memory Encryption")
Signed-off-by: Jason Gunthorpe <jgg@nvidia.com>
Cc: Tom Lendacky <thomas.lendacky@amd.com>
Cc: Andrey Ryabinin <aryabinin@virtuozzo.com>
Cc: Brijesh Singh <brijesh.singh@amd.com>
Cc: Jonathan Corbet <corbet@lwn.net>
Cc: Dmitry Vyukov <dvyukov@google.com>
Cc: "Dave Young" <dyoung@redhat.com>
Cc: Alexander Potapenko <glider@google.com>
Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Cc: Larry Woodman <lwoodman@redhat.com>
Cc: Matt Fleming <matt@codeblueprint.co.uk>
Cc: "Michael S. Tsirkin" <mst@redhat.com>
Cc: Toshimitsu Kani <toshi.kani@hpe.com>
Cc: <stable@vger.kernel.org>
Link: https://lkml.kernel.org/r/0-v1-025d64bdf6c4+e-amd_sme_fix_jgg@nvidia.com
commit ffedeeb780dc554eff3d3b16e6a462a26a41d7ec upstream.
Introduce new C macros for annotations of functions and data in
assembly. There is a long-standing mess in macros like ENTRY, END,
ENDPROC and similar. They are used in different manners and sometimes
incorrectly.
So introduce macros with clear use to annotate assembly as follows:
a) Support macros for the ones below
SYM_T_FUNC -- type used by assembler to mark functions
SYM_T_OBJECT -- type used by assembler to mark data
SYM_T_NONE -- type used by assembler to mark entries of unknown type
They are defined as STT_FUNC, STT_OBJECT, and STT_NOTYPE
respectively. According to the gas manual, this is the most portable
way. I am not sure about other assemblers, so this can be switched
back to %function and %object if this turns into a problem.
Architectures can also override them by something like ", @function"
if they need.
SYM_A_ALIGN, SYM_A_NONE -- align the symbol?
SYM_L_GLOBAL, SYM_L_WEAK, SYM_L_LOCAL -- linkage of symbols
b) Mostly internal annotations, used by the ones below
SYM_ENTRY -- use only if you have to (for non-paired symbols)
SYM_START -- use only if you have to (for paired symbols)
SYM_END -- use only if you have to (for paired symbols)
c) Annotations for code
SYM_INNER_LABEL_ALIGN -- only for labels in the middle of code
SYM_INNER_LABEL -- only for labels in the middle of code
SYM_FUNC_START_LOCAL_ALIAS -- use where there are two local names for
one function
SYM_FUNC_START_ALIAS -- use where there are two global names for one
function
SYM_FUNC_END_ALIAS -- the end of LOCAL_ALIASed or ALIASed function
SYM_FUNC_START -- use for global functions
SYM_FUNC_START_NOALIGN -- use for global functions, w/o alignment
SYM_FUNC_START_LOCAL -- use for local functions
SYM_FUNC_START_LOCAL_NOALIGN -- use for local functions, w/o
alignment
SYM_FUNC_START_WEAK -- use for weak functions
SYM_FUNC_START_WEAK_NOALIGN -- use for weak functions, w/o alignment
SYM_FUNC_END -- the end of SYM_FUNC_START_LOCAL, SYM_FUNC_START,
SYM_FUNC_START_WEAK, ...
For functions with special (non-C) calling conventions:
SYM_CODE_START -- use for non-C (special) functions
SYM_CODE_START_NOALIGN -- use for non-C (special) functions, w/o
alignment
SYM_CODE_START_LOCAL -- use for local non-C (special) functions
SYM_CODE_START_LOCAL_NOALIGN -- use for local non-C (special)
SYM_CODE_END -- the end of SYM_CODE_START_LOCAL or SYM_CODE_START
d) For data
SYM_DATA_START -- global data symbol
SYM_DATA_START_LOCAL -- local data symbol
SYM_DATA_END -- the end of the SYM_DATA_START symbol
SYM_DATA_END_LABEL -- the labeled end of SYM_DATA_START symbol
SYM_DATA -- start+end wrapper around simple global data
SYM_DATA_LOCAL -- start+end wrapper around simple local data
The macros allow to pair starts and ends of functions and mark functions
correctly in the output ELF objects.
All users of the old macros in x86 are converted to use these in further
patches.
Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
Cc: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
Cc: Juergen Gross <jgross@suse.com>
Cc: Len Brown <len.brown@intel.com>
Cc: linux-doc@vger.kernel.org
Cc: linux-pm@vger.kernel.org
Cc: Mark Rutland <mark.rutland@arm.com>
Cc: Pavel Machek <pavel@ucw.cz>
Cc: Will Deacon <will@kernel.org>
Cc: x86-ml <x86@kernel.org>
Cc: xen-devel@lists.xenproject.org
Link: https://lkml.kernel.org/r/20191011115108.12392-2-jslaby@suse.cz
Cc: Jian Cai <jiancai@google.com>
This is the 5.4.75 stable release
- drivers/i2c/busses/i2c-imx.c:
Drop NXP changes, which are covered by commit [2c58d5e0c754c] from
upstream.
- drivers/net/can/flexcan.c:
Keep NXP implementation, patch [ca10989632d88] from upstream is covered
in the NXP tree.
- drivers/usb/host/xhci.h:
Fix merge fuzz for upstream commit [2600a131e1f61]
commit 879bc2d27904354b98ca295b6168718e045c4aa2 upstream.
When starting a HP machine with HIL driver but without an HIL keyboard
or HIL mouse attached, it may happen that data written to the HIL loop
gets stuck (e.g. because the transaction queue is full). Usually one
will then have to reboot the machine because all you see is and endless
output of:
Transaction add failed: transaction already queued?
In the higher layers hp_sdc_enqueue_transaction() is called to queued up
a HIL packet. This function returns an error code, and this patch adds
the necessary checks for this return code and disables the HIL driver if
further packets can't be sent.
Tested on a HP 730 and a HP 715/64 machine.
Signed-off-by: Helge Deller <deller@gmx.de>
commit 8c39076c276be0b31982e44654e2c2357473258a upstream.
RFC 7862 introduced a new flag that either client or server is
allowed to set: EXCHGID4_FLAG_SUPP_FENCE_OPS.
Client needs to update its bitmask to allow for this flag value.
v2: changed minor version argument to unsigned int
Signed-off-by: Olga Kornievskaia <kolga@netapp.com>
CC: <stable@vger.kernel.org>
Signed-off-by: Anna Schumaker <Anna.Schumaker@Netapp.com>
commit 1465af12e254a68706e110846f59cf0f09683184 upstream.
Commit 259ee7754b67 ("btrfs: tree-checker: Add ROOT_ITEM check")
introduced btrfs root item size check, however btrfs root item has two
versions, the legacy one which just ends before generation_v2 member, is
smaller than current btrfs root item size.
This caused btrfs kernel to reject valid but old tree root leaves.
Fix this problem by also allowing legacy root item, since kernel can
already handle them pretty well and upgrade to newer root item format
when needed.
Reported-by: Martin Steigerwald <martin@lichtvoll.de>
Fixes: 259ee7754b67 ("btrfs: tree-checker: Add ROOT_ITEM check")
CC: stable@vger.kernel.org # 5.4+
Tested-By: Martin Steigerwald <martin@lichtvoll.de>
Reviewed-by: Josef Bacik <josef@toxicpanda.com>
Signed-off-by: Qu Wenruo <wqu@suse.com>
Reviewed-by: David Sterba <dsterba@suse.com>
Signed-off-by: David Sterba <dsterba@suse.com>
tSwapSourceStart
[ Upstream commit 6bbe2a90a0bb4af8dd99c3565e907fe9b5e7fd88 ]
The patch addresses the compliance test failures while running
TD.PD.CP.E3, TD.PD.CP.E4, TD.PD.CP.E5 of the "Deterministic PD
Compliance MOI" test plan published in https://www.usb.org/usbc.
For a product to be Type-C compliant, it's expected that these tests
are run on usb.org certified Type-C compliance tester as mentioned in
The purpose of the tests TD.PD.CP.E3, TD.PD.CP.E4, TD.PD.CP.E5 is to
verify the PR_SWAP response of the device. While doing so, the test
asserts that Source Capabilities message is NOT received from the test
device within tSwapSourceStart min (20 ms) from the time the last bit
of GoodCRC corresponding to the RS_RDY message sent by the UUT was
sent. If it does then the test fails.
This is in line with the requirements from the USB Power Delivery
Specification Revision 3.0, Version 1.2:
"6.6.8.1 SwapSourceStartTimer
The SwapSourceStartTimer Shall be used by the new Source, after a
Power Role Swap or Fast Role Swap, to ensure that it does not send
Source_Capabilities Message before the new Sink is ready to receive
the
Source_Capabilities Message. The new Source Shall Not send the
Source_Capabilities Message earlier than tSwapSourceStart after the
last bit of the EOP of GoodCRC Message sent in response to the PS_RDY
Message sent by the new Source indicating that its power supply is
ready."
The patch makes sure that TCPM does not send the Source_Capabilities
Message within tSwapSourceStart(20ms) by transitioning into
SRC_STARTUP only after tSwapSourceStart(20ms).
Signed-off-by: Badhri Jagan Sridharan <badhri@google.com>
Reviewed-by: Guenter Roeck <linux@roeck-us.net>
Reviewed-by: Heikki Krogerus <heikki.krogerus@linux.intel.com>
Link: https://lore.kernel.org/r/20200817183828.1895015-1-badhri@google.com
[ Upstream commit b305dfe2e93434b12d438434461b709641f62af4 ]
The default RGB quantization range for BT.2020 is full range (just as for
all the other RGB pixel encodings), not limited range.
Update the V4L2_MAP_QUANTIZATION_DEFAULT macro and documentation
accordingly.
Also mention that HSV is always full range and cannot be limited range.
When RGB BT2020 was introduced in V4L2 it was not clear whether it should
be limited or full range, but full range is the right (and consistent)
choice.
Signed-off-by: Hans Verkuil <hverkuil-cisco@xs4all.nl>
Signed-off-by: Mauro Carvalho Chehab <mchehab+huawei@kernel.org>
commit 54c9de89895e0a36047fcc4ae754ea5b8655fb9d upstream.
In order to avoid tight event channel related IRQ loops add a new
framework of "late EOI" handling: the IRQ the event channel is bound
to will be masked until the event has been handled and the related
driver is capable to handle another event. The driver is responsible
for unmasking the event channel via the new function xen_irq_lateeoi().
This is similar to binding an event channel to a threaded IRQ, but
without having to structure the driver accordingly.
In order to support a future special handling in case a rogue guest
is sending lots of unsolicited events, add a flag to xen_irq_lateeoi()
which can be set by the caller to indicate the event was a spurious
one.
This is part of XSA-332.
Cc: stable@vger.kernel.org
Reported-by: Julien Grall <julien@xen.org>
Signed-off-by: Juergen Gross <jgross@suse.com>
Reviewed-by: Jan Beulich <jbeulich@suse.com>
Reviewed-by: Stefano Stabellini <sstabellini@kernel.org>
Reviewed-by: Wei Liu <wl@xen.org>
This is the 5.4.74 stable release
commit 6b61d49a55796dbbc479eeb4465e59fd656c719c upstream.
Commit 8234f6734c5d ("PM-runtime: Switch autosuspend over to using
hrtimers") switched PM runtime autosuspend to use hrtimers and all
related time accounting in ns, but missed to update the timer_expires
data type in struct dev_pm_info to u64.
This causes the timer_expires value to be truncated on 32-bit
architectures when assignment is done from u64 values:
rpm_suspend()
|- dev->power.timer_expires = expires;
Fix it by changing the timer_expires type to u64.
Fixes: 8234f6734c5d ("PM-runtime: Switch autosuspend over to using hrtimers")
Signed-off-by: Grygorii Strashko <grygorii.strashko@ti.com>
Acked-by: Pavel Machek <pavel@ucw.cz>
Acked-by: Vincent Guittot <vincent.guittot@linaro.org>
Cc: 5.0+ <stable@vger.kernel.org> # 5.0+
[ rjw: Subject and changelog edits ]
commit c9ca43d42ed8d5fd635d327a664ed1d8579eb2af upstream.
For QUP IP versions 2.5 and above the oversampling rate is
halved from 32 to 16.
Commit ce734600545f ("tty: serial: qcom_geni_serial: Update
the oversampling rate") is pushed to handle this scenario.
But the existing logic is failing to classify QUP Version 3.0
into the correct group ( 2.5 and above).
As result Serial Engine clocks are not configured properly for
baud rate and garbage data is sampled to FIFOs from the line.
So, fix the logic to detect QUP with versions 2.5 and above.
Fixes: ce734600545f ("tty: serial: qcom_geni_serial: Update the oversampling rate")
Cc: stable <stable@vger.kernel.org>
Signed-off-by: Paras Sharma <parashar@codeaurora.org>
Reviewed-by: Akash Asthana <akashast@codeaurora.org>
Link: https://lore.kernel.org/r/1601445926-23673-1-git-send-email-parashar@codeaurora.org
commit 1c9c02bb22684f6949d2e7ddc0a3ff364fd5a6fc upstream.
Update logic for broken test. Use a more common logging style.
It appears the logic in this function is broken for the
consecutive tests of
if (prog_status & 0x3)
else if (prog_status & 0x2)
else (prog_status & 0x1)
Likely the first test should be
if ((prog_status & 0x3) == 0x3)
Found by inspection of include files using printk.
Fixes: eb3db27507f7 ("[MTD] LPDDR PFOW definition")
Reported-by: Joe Perches <joe@perches.com>
Signed-off-by: Gustavo A. R. Silva <gustavo@embeddedor.com>
Acked-by: Miquel Raynal <miquel.raynal@bootlin.com>
Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com>
Link: https://lore.kernel.org/linux-mtd/3fb0e29f5b601db8be2938a01d974b00c8788501.1588016644.git.gustavo@embeddedor.com
commit 1aef5b4391f0c75c0a1523706a7b0311846ee12f upstream.
This should be "current" not "skb".
Fixes: c6b5fb8690fa ("bpf: add documentation for eBPF helpers (42-50)")
Signed-off-by: Song Liu <songliubraving@fb.com>
Signed-off-by: Alexei Starovoitov <ast@kernel.org>
Link: https://lore.kernel.org/bpf/20200910203314.70018-1-songliubraving@fb.com
nft_flow_rule_create
commit 31cc578ae2de19c748af06d859019dced68e325d upstream.
This patch fixes the issue due to:
BUG: KASAN: slab-out-of-bounds in nft_flow_rule_create+0x622/0x6a2
net/netfilter/nf_tables_offload.c:40
Read of size 8 at addr ffff888103910b58 by task syz-executor227/16244
The error happens when expr->ops is accessed early on before performing the boundary check and after nft_expr_next() moves the expr to go out-of-bounds.
This patch checks the boundary condition before expr->ops that fixes the slab-out-of-bounds Read issue.
Add nft_expr_more() and use it to fix this problem.
Signed-off-by: Saeed Mirzamohammadi <saeed.mirzamohammadi@oracle.com>
This is the 5.4.73 stable release
- arch/arm/boot/dts/imx6sl.dtsi:
Commit [a1767c90194e2] in NXP tree is now covered with commit [5c4c2f437cead]
from upstream.
- drivers/gpu/drm/mxsfb/mxsfb_drv.c:
Resolve merge hunk for patch [ed8b90d303cf0] from upstream
- drivers/media/i2c/ov5640.c:
Patch [aa4bb8b8838ff] in NXP tree is now covered by patches [79ec0578c7e0a]
and [b2f8546056b35] from upstream. Changes from NXP patch [99aa4c8c18984] are
covered in upstream version as well.
- drivers/net/ethernet/freescale/fec_main.c:
Fix merge fuzz for patch [9e70485b40c83] from upstream.
- drivers/usb/cdns3/gadget.c:
Keep NXP version of the file, upstream version is not compatible.
- drivers/usb/dwc3/core.c:
- drivers/usb/dwc3/core.h:
Fix merge fuzz of patch [08045050c6bd2] together wth NXP patch [b30e41dc1e494]
- sound/soc/fsl/fsl_sai.c:
- sound/soc/fsl/fsl_sai.h:
Commit [2ea70e51eb72a] in NXP tree is now covered with commit [1ad7f52fe6683]
from upstream.
[ Upstream commit e8ee6c8cb61b676f1a2d6b942329e98224bd8ee9 ]
DW DMA IP-core provides a way to synthesize the DMA controller with
channels having different parameters like maximum burst-length,
multi-block support, maximum data width, etc. Those parameters both
explicitly and implicitly affect the channels performance. Since DMA slave
devices might be very demanding to the DMA performance, let's provide a
functionality for the slaves to be assigned with DW DMA channels, which
performance according to the platform engineer fulfill their requirements.
After this patch is applied it can be done by passing the mask of suitable
DMA-channels either directly in the dw_dma_slave structure instance or as
a fifth cell of the DMA DT-property. If mask is zero or not provided, then
there is no limitation on the channels allocation.
For instance Baikal-T1 SoC is equipped with a DW DMAC engine, which first
two channels are synthesized with max burst length of 16, while the rest
of the channels have been created with max-burst-len=4. It would seem that
the first two channels must be faster than the others and should be more
preferable for the time-critical DMA slave devices. In practice it turned
out that the situation is quite the opposite. The channels with
max-burst-len=4 demonstrated a better performance than the channels with
max-burst-len=16 even when they both had been initialized with the same
settings. The performance drop of the first two DMA-channels made them
unsuitable for the DW APB SSI slave device. No matter what settings they
are configured with, full-duplex SPI transfers occasionally experience the
Rx FIFO overflow. It means that the DMA-engine doesn't keep up with
incoming data pace even though the SPI-bus is enabled with speed of 25MHz
while the DW DMA controller is clocked with 50MHz signal. There is no such
problem has been noticed for the channels synthesized with
max-burst-len=4.
Signed-off-by: Serge Semin <Sergey.Semin@baikalelectronics.ru>
Link: https://lore.kernel.org/r/20200731200826.9292-6-Sergey.Semin@baikalelectronics.ru
Signed-off-by: Vinod Koul <vkoul@kernel.org>
[ Upstream commit 7f6e4312e15a5c370e84eaa685879b6bdcc717e4 ]
Protect against potential stack overflow that might happen when bpf2bpf
calls get combined with tailcalls. Limit the caller's stack depth for
such case down to 256 so that the worst case scenario would result in 8k
stack size (32 which is tailcall limit * 256 = 8k).
Suggested-by: Alexei Starovoitov <ast@kernel.org>
Signed-off-by: Maciej Fijalkowski <maciej.fijalkowski@intel.com>
[ Upstream commit 7010645ba7256992818b518163f46bd4cdf8002a ]
trace-cmd report doesn't show events from target subsystem because
scsi_command_size() leaks through event format string:
[target:target_sequencer_start] function scsi_command_size not defined
[target:target_cmd_complete] function scsi_command_size not defined
Addition of scsi_command_size() to plugin_scsi.c in trace-cmd doesn't
help because an expression is used inside TP_printk(). trace-cmd event
parser doesn't understand minus sign inside [ ]:
Error: expected ']' but read '-'
Rather than duplicating kernel code in plugin_scsi.c, provide a dedicated
field for CONTROL byte.
Link: https://lore.kernel.org/r/20200929125957.83069-1-r.bolshakov@yadro.com
Reviewed-by: Mike Christie <michael.christie@oracle.com>
Signed-off-by: Roman Bolshakov <r.bolshakov@yadro.com>
[ Upstream commit f3d301c1f2f5676465cdf3259737ea19cc82731f ]
perf_event.h has macros that define the field offsets in the
data_src bitmask in perf records. The SNOOPX and REMOTE offsets
were both 37. These are distinct fields, and the bitfield layout
in perf_mem_data_src confirms that SNOOPX should be at offset 38.
Fixes: 52839e653b5629bd ("perf tools: Add support for printing new mem_info encodings")
Signed-off-by: Al Grant <al.grant@foss.arm.com>
Reviewed-by: Andi Kleen <ak@linux.intel.com>
Link: https://lkml.kernel.org/r/4ac9f5cc-4388-b34a-9999-418a4099415d@foss.arm.com
[ Upstream commit 12856e7acde4702b7c3238c15fcba86ff6aa507f ]
For VFs, the Memory Space Enable bit in the Command Register is
hard-wired to 0.
Add a new bit to signify devices where the Command Register Memory
Space Enable bit does not control the device's response to MMIO
accesses.
Fixes: abafbc551fdd ("vfio-pci: Invalidate mmaps and block MMIO access on disabled memory")
Signed-off-by: Matthew Rosato <mjrosato@linux.ibm.com>
Acked-by: Bjorn Helgaas <bhelgaas@google.com>
Signed-off-by: Alex Williamson <alex.williamson@redhat.com>
[ Upstream commit 8fb156c9ee2db94f7127c930c89917634a1a9f56 ]
The implementation of split_page_owner() prefers a count rather than the
old order of the page. When we support a variable size THP, we won't
have the order at this point, but we will have the number of pages.
So change the interface to what the caller and callee would prefer.
Signed-off-by: Matthew Wilcox (Oracle) <willy@infradead.org>
Reviewed-by: SeongJae Park <sjpark@amazon.de>
Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
Cc: Huang Ying <ying.huang@intel.com>
Link: https://lkml.kernel.org/r/20200908195539.25896-4-willy@infradead.org
[ Upstream commit a4947e84f23474803b62a2759b5808147e4e15f9 ]
The various array_size functions use SIZE_MAX define, but missed limits.h
causes to failure to compile code that needs overflow.h.
In file included from drivers/infiniband/core/uverbs_std_types_device.c:6:
./include/linux/overflow.h: In function 'array_size':
./include/linux/overflow.h:258:10: error: 'SIZE_MAX' undeclared (first use in this function)
258 | return SIZE_MAX;
Fixes: 610b15c50e86 ("overflow.h: Add allocation size calculation helpers")
Link: https://lore.kernel.org/r/20200913102928.134985-1-leon@kernel.org
Signed-off-by: Leon Romanovsky <leonro@nvidia.com>
[ Upstream commit 61690d01db32eb1f94adc9ac2b8bb741d34e4671 ]
The original function returns unsigned long and 0 on failure.
Fixes: 4a35339958f1 ("RDMA/umem: Add API to find best driver supported page size in an MR")
Link: https://lore.kernel.org/r/0-v1-982a13cc5c6d+501ae-fix_best_pgsz_stub_jgg@nvidia.com
Reviewed-by: Gal Pressman <galpress@amazon.com>
Acked-by: Shiraz Saleem <shiraz.saleem@intel.com>
[ Upstream commit 67197a4f28d28d0b073ab0427b03cb2ee5382578 ]
Currently __set_oom_adj loops through all processes in the system to keep
oom_score_adj and oom_score_adj_min in sync between processes sharing
their mm. This is done for any task with more that one mm_users, which
includes processes with multiple threads (sharing mm and signals).
However for such processes the loop is unnecessary because their signal
structure is shared as well.
Android updates oom_score_adj whenever a tasks changes its role
(background/foreground/...) or binds to/unbinds from a service, making it
more/less important. Such operation can happen frequently. We noticed
that updates to oom_score_adj became more expensive and after further
investigation found out that the patch mentioned in "Fixes" introduced a
regression. Using Pixel 4 with a typical Android workload, write time to
oom_score_adj increased from ~3.57us to ~362us. Moreover this regression
linearly depends on the number of multi-threaded processes running on the
system.
Mark the mm with a new MMF_MULTIPROCESS flag bit when task is created with
(CLONE_VM && !CLONE_THREAD && !CLONE_VFORK). Change __set_oom_adj to use
MMF_MULTIPROCESS instead of mm_users to decide whether oom_score_adj
update should be synchronized between multiple processes. To prevent
races between clone() and __set_oom_adj(), when oom_score_adj of the
process being cloned might be modified from userspace, we use
oom_adj_mutex. Its scope is changed to global.
The combination of (CLONE_VM && !CLONE_THREAD) is rarely used except for
the case of vfork(). To prevent performance regressions of vfork(), we
skip taking oom_adj_mutex and setting MMF_MULTIPROCESS when CLONE_VFORK is
specified. Clearing the MMF_MULTIPROCESS flag (when the last process
sharing the mm exits) is left out of this patch to keep it simple and
because it is believed that this threading model is rare. Should there
ever be a need for optimizing that case as well, it can be done by hooking
into the exit path, likely following the mm_update_next_owner pattern.
With the combination of (CLONE_VM && !CLONE_THREAD && !CLONE_VFORK) being
quite rare, the regression is gone after the change is applied.
[surenb@google.com: v3]
Link: https://lkml.kernel.org/r/20200902012558.2335613-1-surenb@google.com
Fixes: 44a70adec910 ("mm, oom_adj: make sure processes sharing mm have same view of oom_score_adj")
Reported-by: Tim Murray <timmurray@google.com>
Suggested-by: Michal Hocko <mhocko@kernel.org>
Signed-off-by: Suren Baghdasaryan <surenb@google.com>
Acked-by: Christian Brauner <christian.brauner@ubuntu.com>
Acked-by: Oleg Nesterov <oleg@redhat.com>
Cc: Eugene Syromiatnikov <esyr@redhat.com>
Cc: Christian Kellner <christian@kellner.me>
Cc: Adrian Reber <areber@redhat.com>
Cc: Shakeel Butt <shakeelb@google.com>
Cc: Aleksa Sarai <cyphar@cyphar.com>
Cc: Alexey Dobriyan <adobriyan@gmail.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Alexey Gladkov <gladkov.alexey@gmail.com>
Cc: Michel Lespinasse <walken@google.com>
Cc: Daniel Jordan <daniel.m.jordan@oracle.com>
Cc: Andrei Vagin <avagin@gmail.com>
Cc: Bernd Edlinger <bernd.edlinger@hotmail.de>
Cc: John Johansen <john.johansen@canonical.com>
Cc: Yafang Shao <laoar.shao@gmail.com>
Link: https://lkml.kernel.org/r/20200824153036.3201505-1-surenb@google.com
Debugged-by: Minchan Kim <minchan@kernel.org>
[ Upstream commit 0d9826bc18ce356e8909919ad681ad65d0a6061e ]
Dump vlan tag and proto for the usual vlan offload case if the
NF_LOG_MACDECODE flag is set on. Without this information the logging is
misleading as there is no reference to the VLAN header.
[12716.993704] test: IN=veth0 OUT= MACSRC=86:6c:92:ea:d6:73 MACDST=0e:3b:eb:86:73:76 VPROTO=8100 VID=10 MACPROTO=0800 SRC=192.168.10.2 DST=172.217.168.163 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=2548 DF PROTO=TCP SPT=55848 DPT=80 WINDOW=501 RES=0x00 ACK FIN URGP=0
[12721.157643] test: IN=veth0 OUT= MACSRC=86:6c:92:ea:d6:73 MACDST=0e:3b:eb:86:73:76 VPROTO=8100 VID=10 MACPROTO=0806 ARP HTYPE=1 PTYPE=0x0800 OPCODE=2 MACSRC=86:6c:92:ea:d6:73 IPSRC=192.168.10.2 MACDST=0e:3b:eb:86:73:76 IPDST=192.168.10.1
Fixes: 83e96d443b37 ("netfilter: log: split family specific code to nf_log_{ip,ip6,common}.c files")
commit a6e7d0a4bdb02a7a3ffe0b44aaa8842b7efdd056 upstream.
In case HDA controller becomes active, but codec is runtime suspended,
jack detection is not successful and no interrupt is raised. This has
been observed with multiple Realtek codecs and HDA controllers from
different vendors. Bug does not occur if both codec and controller are
active, or both are in suspend. Bug can be easily hit on desktop systems
with no built-in speaker.
The problem can be fixed by powering up the codec once after every
controller runtime resume. Even if codec goes back to suspend later, the
jack detection will continue to work. Add a flag to 'hda_codec' to
describe codecs that require this flow from the controller driver.
Modify __azx_runtime_resume() to use pm_request_resume() to make the
intent clearer.
Mark all Realtek codecs with the new forced_resume flag.
BugLink: https://bugzilla.kernel.org/show_bug.cgi?id=209379
Cc: Kailang Yang <kailang@realtek.com>
Co-developed-by: Kai-Heng Feng <kai.heng.feng@canonical.com>
Signed-off-by: Kai-Heng Feng <kai.heng.feng@canonical.com>
Signed-off-by: Kai Vehmanen <kai.vehmanen@linux.intel.com>
Link: https://lore.kernel.org/r/20201012102704.794423-1-kai.vehmanen@linux.intel.com
[ Upstream commit 02a1b175b0e92d9e0fa5df3957ade8d733ceb6a0 ]
Documentation/networking/ip-sysctl.txt:46 says:
ip_forward_use_pmtu - BOOLEAN
By default we don't trust protocol path MTUs while forwarding
because they could be easily forged and can lead to unwanted
fragmentation by the router.
You only need to enable this if you have user-space software
which tries to discover path mtus by itself and depends on the
kernel honoring this information. This is normally not the case.
Default: 0 (disabled)
Possible values:
0 - disabled
1 - enabled
Which makes it pretty clear that setting it to 1 is a potential
security/safety/DoS issue, and yet it is entirely reasonable to want
forwarded traffic to honour explicitly administrator configured
route mtus (instead of defaulting to device mtu).
Indeed, I can't think of a single reason why you wouldn't want to.
Since you configured a route mtu you probably know better...
It is pretty common to have a higher device mtu to allow receiving
large (jumbo) frames, while having some routes via that interface
(potentially including the default route to the internet) specify
a lower mtu.
Note that ipv6 forwarding uses device mtu unless the route is locked
(in which case it will use the route mtu).
This approach is not usable for IPv4 where an 'mtu lock' on a route
also has the side effect of disabling TCP path mtu discovery via
disabling the IPv4 DF (don't frag) bit on all outgoing frames.
I'm not aware of a way to lock a route from an IPv6 RA, so that also
potentially seems wrong.
Signed-off-by: Maciej Żenczykowski <maze@google.com>
Cc: Eric Dumazet <edumazet@google.com>
Cc: Willem de Bruijn <willemb@google.com>
Cc: Lorenzo Colitti <lorenzo@google.com>
Cc: Sunmeet Gill (Sunny) <sgill@quicinc.com>
Cc: Vinay Paradkar <vparadka@qti.qualcomm.com>
Cc: Tyler Wear <twear@quicinc.com>
Cc: David Ahern <dsahern@kernel.org>
Reviewed-by: Eric Dumazet <edumazet@google.com>
The pca9450 provides an I2C level translator which can be enabled in
the CONFIG2 register. Provide a way to configure that from platform data
or device tree.
Related-to: ELB-3132
This is the 5.4.72 stable release
commit 8746f135bb01872ff412d408ea1aa9ebd328c1f5 upstream.
E0 is not allowed with Level 4:
BLUETOOTH CORE SPECIFICATION Version 5.2 | Vol 3, Part C page 1319:
'128-bit equivalent strength for link and encryption keys
required using FIPS approved algorithms (E0 not allowed,
SAFER+ not allowed, and P-192 not allowed; encryption key
not shortened'
SC enabled:
> HCI Event: Read Remote Extended Features (0x23) plen 13
Status: Success (0x00)
Handle: 256
Page: 1/2
Features: 0x0b 0x00 0x00 0x00 0x00 0x00 0x00 0x00
Secure Simple Pairing (Host Support)
LE Supported (Host)
Secure Connections (Host Support)
> HCI Event: Encryption Change (0x08) plen 4
Handle: 256
Encryption: Enabled with AES-CCM (0x02)
SC disabled:
Handle: 256
Page: 1/2
Features: 0x03 0x00 0x00 0x00 0x00 0x00 0x00 0x00
LE Supported (Host)
Handle: 256
Encryption: Enabled with E0 (0x01)
[May 8 20:23] Bluetooth: hci0: Invalid security: expect AES but E0 was used
< HCI Command: Disconnect (0x01|0x0006) plen 3
Handle: 256
Reason: Authentication Failure (0x05)
Signed-off-by: Luiz Augusto von Dentz <luiz.von.dentz@intel.com>
Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
Cc: Hans-Christian Noren Egtvedt <hegtvedt@cisco.com>
commit 339ddaa626995bc6218972ca241471f3717cc5f4 upstream.
Starting with the upgrade to v5.8-rc3, I've noticed I wasn't able to
connect to my Bluetooth headset properly anymore. While connecting to
the device would eventually succeed, bluetoothd seemed to be confused
about the current connection state where the state was flapping hence
and forth. Bisecting this issue led to commit 3ca44c16b0dc (Bluetooth:
Consolidate encryption handling in hci_encrypt_cfm, 2020-05-19), which
refactored `hci_encrypt_cfm` to also handle updating the connection
state.
The commit in question changed the code to call `hci_connect_cfm` inside
`hci_encrypt_cfm` and to change the connection state. But with the
conversion, we now only update the connection state if a status was set
already. In fact, the reverse should be true: the status should be
updated if no status is yet set. So let's fix the isuse by reversing the
condition.
Fixes: 3ca44c16b0dc ("Bluetooth: Consolidate encryption handling in hci_encrypt_cfm")
Signed-off-by: Patrick Steinhardt <ps@pks.im>
Acked-by: Luiz Augusto von Dentz <luiz.von.dentz@intel.com>
commit 3ca44c16b0dcc764b641ee4ac226909f5c421aa3 upstream.
This makes hci_encrypt_cfm calls hci_connect_cfm in case the connection
state is BT_CONFIG so callers don't have to check the state.
commit f19425641cb2572a33cb074d5e30283720bd4d22 upstream.
Only sockets will have the chan->data set to an actual sk, channels
like A2MP would have its own data which would likely cause a crash when
calling sk_filter, in order to fix this a new callback has been
introduced so channels can implement their own filtering if necessary.
This is the 5.4.71 stable release
The current driver does not handle/use the combined BUCK123_DVS register.
So do not use the voltage setpoints for buck1, buck2 and buck3 from
that register but rather take the values from the per buck converter
registers PCA9450_BUCKxOUT_DVSy.
Fixes buck1, buck2 and buck3 to be at their reset defaults of 850 mV
independent of what is commanded from software if the PMIC is not yet
configured accordingly in the bootloader.
commit e49d8c22f1261c43a986a7fdbf677ac309682a07 upstream.
All TC actions call tcf_idr_insert() for new action at the end
of their ->init(), so we can actually move it to a central place
in tcf_action_init_1().
And once the action is inserted into the global IDR, other parallel
process could free it immediately as its refcnt is still 1, so we can
not fail after this, we need to move it after the goto action
validation to avoid handling the failure case after insertion.
This is found during code review, is not directly triggered by syzbot.
And this prepares for the next patch.
Cc: Vlad Buslov <vladbu@mellanox.com>
Cc: Jamal Hadi Salim <jhs@mojatatu.com>
Cc: Jiri Pirko <jiri@resnulli.us>
by khugepaged
commit 4aab2be0983031a05cb4a19696c9da5749523426 upstream.
When memory is hotplug added or removed the min_free_kbytes should be
recalculated based on what is expected by khugepaged. Currently after
hotplug, min_free_kbytes will be set to a lower default and higher
default set when THP enabled is lost.
This change restores min_free_kbytes as expected for THP consumers.
[vijayb@linux.microsoft.com: v5]
Link: https://lkml.kernel.org/r/1601398153-5517-1-git-send-email-vijayb@linux.microsoft.com
Fixes: f000565adb77 ("thp: set recommended min free kbytes")
Signed-off-by: Vijay Balakrishna <vijayb@linux.microsoft.com>
Reviewed-by: Pavel Tatashin <pasha.tatashin@soleen.com>
Cc: Allen Pais <apais@microsoft.com>
Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com>
Cc: Song Liu <songliubraving@fb.com>
Link: https://lkml.kernel.org/r/1600305709-2319-2-git-send-email-vijayb@linux.microsoft.com
Link: https://lkml.kernel.org/r/1600204258-13683-1-git-send-email-vijayb@linux.microsoft.com
[ Upstream commit 50b2412b7e7862c5af0cbf4b10d93bc5c712d021 ]
Upon command completion timeout, driver simulates a forced command
completion. In a rare case where real interrupt for that command arrives
simultaneously, it might release the command entry while the forced
handler might still access it.
Fix that by adding an entry refcount, to track current amount of allowed
handlers. Command entry to be released only when this refcount is
decremented to zero.
Command refcount is always initialized to one. For callback commands,
command completion handler is the symmetric flow to decrement it. For
non-callback commands, it is wait_func().
Before ringing the doorbell, increment the refcount for the real completion
handler. Once the real completion handler is called, it will decrement it.
For callback commands, once the delayed work is scheduled, increment the
refcount. Upon callback command completion handler, we will try to cancel
the timeout callback. In case of success, we need to decrement the callback
refcount as it will never run.
In addition, gather the entry index free and the entry free into a one
flow for all command types release.
Fixes: e126ba97dba9 ("mlx5: Add driver for Mellanox Connect-IB adapters")
Signed-off-by: Eran Ben Elisha <eranbe@mellanox.com>
Reviewed-by: Moshe Shemesh <moshe@mellanox.com>
Signed-off-by: Saeed Mahameed <saeedm@nvidia.com>
[ Upstream commit 91a46c6d1b4fcbfa4773df9421b8ad3e58088101 ]
XFRMA_REPLAY_ESN_VAL was not cloned completely from the old to the new.
Migrate this attribute during XFRMA_MSG_MIGRATE
v1->v2:
- move curleft cloning to a separate patch
Fixes: af2f464e326e ("xfrm: Assign esn pointers when cloning a state")
Signed-off-by: Antony Antony <antony.antony@secunet.com>
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
commit c381b07941adc2274ce552daf86c94701c5e265a upstream.
The original problem was from nvme-over-tcp code, who mistakenly uses
kernel_sendpage() to send pages allocated by __get_free_pages() without
__GFP_COMP flag. Such pages don't have refcount (page_count is 0) on
tail pages, sending them by kernel_sendpage() may trigger a kernel panic
from a corrupted kernel heap, because these pages are incorrectly freed
in network stack as page_count 0 pages.
This patch introduces a helper sendpage_ok(), it returns true if the
checking page,
- is not slab page: PageSlab(page) is false.
- has page refcount: page_count(page) is not zero
All drivers who want to send page to remote end by kernel_sendpage()
may use this helper to check whether the page is OK. If the helper does
not return true, the driver should try other non sendpage method (e.g.
sock_no_sendpage()) to handle the page.
Signed-off-by: Coly Li <colyli@suse.de>
Cc: Chaitanya Kulkarni <chaitanya.kulkarni@wdc.com>
Cc: Hannes Reinecke <hare@suse.de>
Cc: Jan Kara <jack@suse.com>
Cc: Mikhail Skorzhinskii <mskorzhinskiy@solarflare.com>
Cc: Philipp Reisner <philipp.reisner@linbit.com>
Cc: Sagi Grimberg <sagi@grimberg.me>
Cc: Vlastimil Babka <vbabka@suse.com>
commit 65c204398928f9c79f1a29912b410439f7052635 upstream.
Systems with memory or disk constraints often reduce the kernel footprint
by configuring LD_DEAD_CODE_DATA_ELIMINATION. However, this can result in
removal of any BTF information.
Use the KEEP() macro to preserve the BTF data as done with other important
sections, while still allowing for smaller kernels.
Fixes: 90ceddcb4950 ("bpf: Support llvm-objcopy for vmlinux BTF")
Signed-off-by: Tony Ambardar <Tony.Ambardar@gmail.com>
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
Acked-by: John Fastabend <john.fastabend@gmail.com>
Acked-by: Andrii Nakryiko <andriin@fb.com>
Link: https://lore.kernel.org/bpf/a635b5d3e2da044e7b51ec1315e8910fbce0083f.1600417359.git.Tony.Ambardar@gmail.com
commit 6735b4632def0640dbdf4eb9f99816aca18c4f16 upstream.
syzbot has reported an issue in the framebuffer layer, where a malicious
user may overflow our built-in font data buffers.
In order to perform a reliable range check, subsystems need to know
`FONTDATAMAX` for each built-in font. Unfortunately, our font descriptor,
`struct console_font` does not contain `FONTDATAMAX`, and is part of the
UAPI, making it infeasible to modify it.
For user-provided fonts, the framebuffer layer resolves this issue by
reserving four extra words at the beginning of data buffers. Later,
whenever a function needs to access them, it simply uses the following
macros:
Recently we have gathered all the above macros to <linux/font.h>. Let us
do the same thing for built-in fonts, prepend four extra words (including
`FONTDATAMAX`) to their data buffers, so that subsystems can use these
macros for all fonts, no matter built-in or user-provided.
This patch depends on patch "fbdev, newport_con: Move FONT_EXTRA_WORDS
macros into linux/font.h".
Link: https://syzkaller.appspot.com/bug?id=08b8be45afea11888776f897895aef9ad1c3ecfd
Signed-off-by: Peilin Ye <yepeilin.cs@gmail.com>
Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Link: https://patchwork.freedesktop.org/patch/msgid/ef18af00c35fb3cc826048a5f70924ed6ddce95b.1600953813.git.yepeilin.cs@gmail.com
commit bb0890b4cd7f8203e3aa99c6d0f062d6acdaad27 upstream.
drivers/video/console/newport_con.c is borrowing FONT_EXTRA_WORDS macros
from drivers/video/fbdev/core/fbcon.h. To keep things simple, move all
definitions into <linux/font.h>.
Since newport_con now uses four extra words, initialize the fourth word in
newport_set_font() properly.
Link: https://patchwork.freedesktop.org/patch/msgid/7fb8bc9b0abc676ada6b7ac0e0bd443499357267.1600953813.git.yepeilin.cs@gmail.com
