In order to use the auxiliar ADC inputs of STMPE811 devices we need
to add resources for the ADC block. Also move the ADC macros from
the touchscreen driver to the general header file. We will need them
for the ADC driver in future.
The voltage table for the SM2 regulator on TPS658643 was wrong. However,
since the requested voltage of 1.8V was at the right place, the system
worked fine nonetheless.
The port used for KEY_BACK does not support wakeup (no wake PIN). Remove
the wake flag, this prevents unbalanced irq warning messages.
After suspend, mode filter might be called with empty yres. This leads
to division by zero when checking aspect ratio. Return as invalid mode
when yres is zero.
When enabling SATA clocks, the PCIE clocks are enabled as well since
those are the parent clocks. In order to enable this parent clocks,
the PCIE regulator avdd_plle needs to be enabled. The resume path used
to freeze because the PCIE PLL did not lock.
Setting the resolution to 1088p (as of now), since
there are flickers observed for 1080p and also
the encoder is not compatible with alignement of
the RM surfaces of 1080p. 1088p is a stop-gap solution
until the issues with 1080p are resolved.
Bug 1369083
Change-Id: I3e73076451e7671d90603c6496ad14733591edeb
Signed-off-by: Bryan Wu <pengw@nvidia.com>
Reviewed-on: http://git-master/r/309543
Tested-by: Vikram Fugro <vfugro@nvidia.com>
Reviewed-by: Kaustubh Purandare <kpurandare@nvidia.com>
Reviewed-by: Winnie Hsu <whsu@nvidia.com>
Reviewed-by: Matthew Pedro <mapedro@nvidia.com>
Bug 1369083
Change-Id: I1a81bcb62e8f6bb654ffbebba09661187ab4b512
Reviewed-on: http://git-master/r/309536
The tweaks are only specific to r16-r2 branch
and will not go into mainline.
- Pass nvmap memory handle to the user through
the mmap'd buffer allocated by videobuf2 client.
- Allow the "user" nvmap client to access the
nvmap memory handle of "videobuf2-dma-nvmap" client.
Re-arranging the copyright message in nvmap_dev.c
for Automatic validation to pass.
Bug 1369083
Change-Id: Ia27d172253860e79557911c2e848bc9084d662d4
Signed-off-by: Vikram Fugro <vfugro@nvidia.com>
Reviewed-on: http://git-master/r/309494
Reviewed-by: Krishna Reddy <vdumpa@nvidia.com>
This reverts commit dd9a841da571a41d43f1eeaac1785b2adb1d80f3.
The config changes (for V4L2) can be done manually as per need
basis for V4L2, followed by compiling the kernel.
Change-Id: I9174bce0f3da2974ab703b238dfb8fb3bbf607c5
Reviewed-on: http://git-master/r/327607
- Disables TEGRA_CAMERA
- Enables SOC_CAMERA and OV5640 sensor support
Bug 1369083
Change-Id: I073c226e9f04a6f4f4699051f624a755dceb36cb
Reviewed-on: http://git-master/r/309491
When hotpluging hdmi the read of edid often fails.
Add up to 4 retries with a 500ms delay before giving up.
Bug 1369083
Change-Id: I1522b688e0681e52592c0f26a8e335937372836a
Reviewed-on: http://git-master/r/279989
Tested-by: Matthew Pedro <mapedro@nvidia.com>
Add support for dual cameras from both CSI-A and CSI-B:
- move all the CSI settings into video buffer struct
- queue the video buffer struct to a dedicated queue
- process one video buffer struct from the queue at one time
Bug 1369083
Change-Id: Ie64d69282ab991b66e97327e288a2bacde088bd6
Reviewed-on: http://git-master/r/246269
(cherry picked from commit 228b0c2d9ae3fa1121f88836626d654ae0fc4ff0)
Reviewed-on: http://git-master/r/279987
soc_camera_link supports passing power on/off control callback to
soc_camera stack. So the power control can be handled by soc_camera
stack instead of our Tegra V4L2 host driver.
Also pass other platform_data fields via soc_camera_link instead of
a hacking nvhost_device_data struct.
Bug 1240806
Bug 1369083
Change-Id: I443a7d28196cc8292805da70d2d5ff1c3cd50a5d
Reviewed-on: http://git-master/r/246267
(cherry picked from commit 9083d270bf93b583cd5bf5151a52ea250f8541a3)
Reviewed-on: http://git-master/r/279986
Bug 1369083
Change-Id: I43acb0d1dd6ca182291895d294a8458bfc99da05
Reviewed-on: http://git-master/r/279985
Reviewed-by: Allen Martin <amartin@nvidia.com>
Use right buffer flag NVMAP_HANDLE_WRITE_COMBINE to allocate buffer,
which can be shared by VI/CSI and CPU. Don't use NVMAP_HEAP_SYSMEM.
It is validated to old T20 silicon and can't support big buffers. By
default, our nvmap_alloc() will use IOVMM to allocate buffers.
nvmap_pin() gives us IOVA for hardware engines like VI/CSI module
with IOMMU enabled in kernel. nvmap_mmap() gives us VA for CPU
read/write operations. So we need to convert VA address to physical
address of the buffer and map that buffer to user space processor's
memory space "page by page".
Bug 1369083
Change-Id: I4629eebe206c7640adf63551968fd89260dd0082
Reviewed-on: http://git-master/r/279984
- tweak offset registers
- add test mode to output color bars
- use BGGR RAW format
Bug 1369083
Change-Id: I61352c018f8ca099ff3d39158a67052a1e185eec
Reviewed-on: http://git-master/r/279983
Reworked driver in order to properly support default watchdog api
such as triggering by writing a character and disable by sending
a magic character. Renamed ENABLE_ON_PROBE to ENABLE_HEARTBEAT
which triggers the watchdog using the interrupt service routine.
Initialisation of the framebuffer console on DVI-D aka HDMI always
failed on monitors which report the vertical front porch to be 1
in their EDID.
The fix now changes also the modedb and not only the list of
videomodes with a compatible timing.
This was particularly bad on Apalis T30 where this is activated
by default. On Colibri T30 this was observed when enabling it using the
fbcon=map:1 boot argument.
fix Coverity issue
Coverity id : 13692
Bug 1046331
Bug 1049868
Change-Id: Iefa6d076d4622368534710630b89b9a15d166378
Signed-off-by: Deepak Nibade <dnibade@nvidia.com>
Reviewed-on: http://git-master/r/165864
(cherry picked from commit db33c3f3f2447a52a40f4fd001fec9a2932ee4c8)
Reviewed-on: http://git-master/r/244637
Reviewed-by: Shreshtha Sahu <ssahu@nvidia.com>
Tested-by: Shreshtha Sahu <ssahu@nvidia.com>
Reviewed-by: Kiran Adduri <kadduri@nvidia.com>
Reviewed-by: Erik Lilliebjerg <elilliebjerg@nvidia.com>
GVS: Gerrit_Virtual_Submit
I211 with a blank iNVM uses a different PCI ID. Hack the driver to load
despite i211 data sheet claiming tools only, not for driver.
Please note that the existing driver hacks concerning NVM validation
skipping and Ethernet MAC address assignment equally apply.
Tested on initial samples of Apalis T30 1GB V1.0A.
According to Realtek, the firmware provides
power optimizations. The driver works without
the firmware. Plus, there are scenarios where
the firmware is not available, which makes the
driver wait at request_firmware call (i.e.,
60 sec wait).
Bug 1236060
Bug 991551
Change-Id: Ifcaa4b2dd48c4111ded33cf2bade7dc1f6422821
Signed-off-by: Mursalin Akon <makon@nvidia.com>
Reviewed-on: http://git-master/r/258353
Re-work input selection to apply to a live camera stream.
While at it default to automatic input selection and make this option
available via IOCTL as input value 2 as well.
While at it disable the automatic I2C module loading for now as due to
our currently redundant soc-camera-pdrv registration via board specific
platform data the adv7180 driver is always automatically loaded upon
modprobe tegra_v4l2_camera invocation.
export access to the 'Local Shared OS and T_Crit Limit'
register.
Hack to avoid 24 Hz mode in X resulting in no display at all. This has
been encountered using e.g. a Samsung SyncMaster F2380 if connected by
HDMI.
root@apalis-t30:~# xrandr
Screen 0: minimum 256 x 128, current 1920 x 1080, maximum 2048 x 2048
LVDS-1 connected 1920x1080+0+0 (normal left inverted right x axis y axis) 0mm x 0mm
1920x1080 58.6*+
HDMI-1 connected 1920x1080+0+0 (normal left inverted right x axis y axis) 160mm x 90mm
1920x1080 60.0 + 24.0*
1680x1050 59.9
1280x1024 75.0 60.0
1440x900 75.0 59.9
1280x960 60.0
1280x800 59.9
1152x864 75.0
1280x720 60.0 50.0
1024x768 75.0 70.1 60.0
832x624 74.6
800x600 72.2 75.0 60.3 56.2
720x576 50.0
720x480 59.9
640x480 75.0 72.8 66.7 59.9
720x400 70.1
Previously only 64-lead and 40-lead models were identified. This patch
adds 48-lead and 32-lead device identification as well.
Please note that due to missing parameter negotiation functions one
might get the following message with a subsequent crash:
WARNING: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Could
not get parameters on device '/dev/video0'
This can be avoided by explicitly specifying the format as follows:
gst-launch v4l2src ! deinterlace tff=1 method=4 ! 'video/x-raw-yuv,
width=(int)720, height=(int)576, format=(fourcc)I420' !
nv_omx_videomixer ! nv_gl_eglimagesink
Powering on, improved interlacing.
Move paddr to correct ifdef to enable CONFIG_NVMAP_PAGE_POOLS=n
compilation.
Change-Id: I543d9d95fc14395200647e09480f25d9bc001e00
This reverts commit 080c3135b58aa700851991fb672e6c33cf16d9d9.
Fix issue with nvhost_client_device_init being issued more than once.
Revise Ethernet MAC address assignment: should now handle up to two
instances of custom user MACs (2nd one with a 0x100000 offset). This
way customer does not have to worry about NVM on a secondary Ethernet
on the carrier board and still gets a valid official MAC address from
us (e.g. analogous to how we did it on our Protea carrier board).
bug report courtesy of Mikhail Shevchuk
Fix the following build issue introduced by commit
5cfcbc23d116927a7ae8d5b67baeacf2905b21f9 if neither
CONFIG_MACH_APALIS_T30 nor CONFIG_MACH_COLIBRI_T30 is defined as in
case of e.g. the Colibri T20:
drivers/mmc/host/sdhci-tegra.c:951:2:
error: expected expression before '.' token
The Dell 5800 appears to be a simple rebrand of the Novatel E362.
Signed-off-by: Dan Williams <dcbw@redhat.com>
Cc: stable <stable@vger.kernel.org>
