2013-02-14Linux 3.4.31v3.4.31Greg Kroah-Hartman
2013-02-14be2net: Fix to trim skb for padded vlan packets to workaround an ASIC BugSomnath Kotur
commit 93040ae5cc8dcc893eca4a4366dc8415af278edf upstream. Fixed spelling error in a comment as pointed out by DaveM. Also refactored existing code a bit to provide placeholders for another ASIC Bug workaround that will be checked-in soon after this. Signed-off-by: Somnath Kotur <somnath.kotur@emulex.com> Signed-off-by: David S. Miller <davem@davemloft.net> Cc: Jacek Luczak <difrost.kernel@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-14tg3: Fix crc errors on jumbo frame receiveNithin Nayak Sujir
[ Upstream commit daf3ec688e057f6060fb9bb0819feac7a8bbf45c ] TG3_PHY_AUXCTL_SMDSP_ENABLE/DISABLE macros do a blind write to the phy auxiliary control register and overwrite the EXT_PKT_LEN (bit 14) resulting in intermittent crc errors on jumbo frames with some link partners. Change the code to do a read/modify/write. Signed-off-by: Nithin Nayak Sujir <nsujir@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-14tg3: Avoid null pointer dereference in tg3_interrupt in netconsole modeNithin Nayak Sujir
[ Upstream commit 9c13cb8bb477a83b9a3c9e5a5478a4e21294a760 ] When netconsole is enabled, logging messages generated during tg3_open can result in a null pointer dereference for the uninitialized tg3 status block. Use the irq_sync flag to disable polling in the early stages. irq_sync is cleared when the driver is enabling interrupts after all initialization is completed. Signed-off-by: Nithin Nayak Sujir <nsujir@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-14bridge: Pull ip header into skb->data before looking into ip header.Sarveshwar Bandi
[ Upstream commit 6caab7b0544e83e6c160b5e80f5a4a7dd69545c7 ] If lower layer driver leaves the ip header in the skb fragment, it needs to be first pulled into skb->data before inspecting ip header length or ip version number. Signed-off-by: Sarveshwar Bandi <sarveshwar.bandi@emulex.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-14tcp: fix for zero packets_in_flight was too broadIlpo Järvinen
[ Upstream commit 6731d2095bd4aef18027c72ef845ab1087c3ba63 ] There are transients during normal FRTO procedure during which the packets_in_flight can go to zero between write_queue state updates and firing the resulting segments out. As FRTO processing occurs during that window the check must be more precise to not match "spuriously" :-). More specificly, e.g., when packets_in_flight is zero but FLAG_DATA_ACKED is true the problematic branch that set cwnd into zero would not be taken and new segments might be sent out later. Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Tested-by: Eric Dumazet <edumazet@google.com> Acked-by: Neal Cardwell <ncardwell@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-14tcp: frto should not set snd_cwnd to 0Eric Dumazet
[ Upstream commit 2e5f421211ff76c17130b4597bc06df4eeead24f ] Commit 9dc274151a548 (tcp: fix ABC in tcp_slow_start()) uncovered a bug in FRTO code : tcp_process_frto() is setting snd_cwnd to 0 if the number of in flight packets is 0. As Neal pointed out, if no packet is in flight we lost our chance to disambiguate whether a loss timeout was spurious. We should assume it was a proper loss. Reported-by: Pasi Kärkkäinen <pasik@iki.fi> Signed-off-by: Neal Cardwell <ncardwell@google.com> Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Cc: Yuchung Cheng <ycheng@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-14netback: correct netbk_tx_err to handle wrap around.Ian Campbell
[ Upstream commit b9149729ebdcfce63f853aa54a404c6a8f6ebbf3 ] Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Acked-by: Jan Beulich <JBeulich@suse.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-14xen/netback: free already allocated memory on failure in xen_netbk_get_requestsIan Campbell
[ Upstream commit 4cc7c1cb7b11b6f3515bd9075527576a1eecc4aa ] Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-14xen/netback: don't leak pages on failure in xen_netbk_tx_check_gop.Matthew Daley
[ Upstream commit 7d5145d8eb2b9791533ffe4dc003b129b9696c48 ] Signed-off-by: Matthew Daley <mattjd@gmail.com> Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Acked-by: Ian Campbell <ian.campbell@citrix.com> Acked-by: Jan Beulich <JBeulich@suse.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-14xen/netback: shutdown the ring if it contains garbage.Ian Campbell
[ Upstream commit 48856286b64e4b66ec62b94e504d0b29c1ade664 ] A buggy or malicious frontend should not be able to confuse netback. If we spot anything which is not as it should be then shutdown the device and don't try to continue with the ring in a potentially hostile state. Well behaved and non-hostile frontends will not be penalised. As well as making the existing checks for such errors fatal also add a new check that ensures that there isn't an insane number of requests on the ring (i.e. more than would fit in the ring). If the ring contains garbage then previously is was possible to loop over this insane number, getting an error each time and therefore not generating any more pending requests and therefore not exiting the loop in xen_netbk_tx_build_gops for an externded period. Also turn various netdev_dbg calls which no precipitate a fatal error into netdev_err, they are rate limited because the device is shutdown afterwards. This fixes at least one known DoS/softlockup of the backend domain. Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Acked-by: Jan Beulich <JBeulich@suse.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-14net: sctp: sctp_endpoint_free: zero out secret key dataDaniel Borkmann
[ Upstream commit b5c37fe6e24eec194bb29d22fdd55d73bcc709bf ] On sctp_endpoint_destroy, previously used sensitive keying material should be zeroed out before the memory is returned, as we already do with e.g. auth keys when released. Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Acked-by: Vlad Yasevich <vyasevic@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-14net: sctp: sctp_setsockopt_auth_key: use kzfree instead of kfreeDaniel Borkmann
[ Upstream commit 6ba542a291a5e558603ac51cda9bded347ce7627 ] In sctp_setsockopt_auth_key, we create a temporary copy of the user passed shared auth key for the endpoint or association and after internal setup, we free it right away. Since it's sensitive data, we should zero out the key before returning the memory back to the allocator. Thus, use kzfree instead of kfree, just as we do in sctp_auth_key_put(). Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-14sctp: refactor sctp_outq_teardown to insure proper re-initalizationNeil Horman
[ Upstream commit 2f94aabd9f6c925d77aecb3ff020f1cc12ed8f86 ] Jamie Parsons reported a problem recently, in which the re-initalization of an association (The duplicate init case), resulted in a loss of receive window space. He tracked down the root cause to sctp_outq_teardown, which discarded all the data on an outq during a re-initalization of the corresponding association, but never reset the outq->outstanding_data field to zero. I wrote, and he tested this fix, which does a proper full re-initalization of the outq, fixing this problem, and hopefully future proofing us from simmilar issues down the road. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Reported-by: Jamie Parsons <Jamie.Parsons@metaswitch.com> Tested-by: Jamie Parsons <Jamie.Parsons@metaswitch.com> CC: Jamie Parsons <Jamie.Parsons@metaswitch.com> CC: Vlad Yasevich <vyasevich@gmail.com> CC: "David S. Miller" <davem@davemloft.net> CC: netdev@vger.kernel.org Acked-by: Vlad Yasevich <vyasevich@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-14atm/iphase: rename fregt_t -> ffreg_tHeiko Carstens
[ Upstream commit ab54ee80aa7585f9666ff4dd665441d7ce41f1e8 ] We have conflicting type qualifiers for "freg_t" in s390's ptrace.h and the iphase atm device driver, which causes the compile error below. Unfortunately the s390 typedef can't be renamed, since it's a user visible api, nor can I change the include order in s390 code to avoid the conflict. So simply rename the iphase typedef to a new name. Fixes this compile error: In file included from drivers/atm/iphase.c:66:0: drivers/atm/iphase.h:639:25: error: conflicting type qualifiers for 'freg_t' In file included from next/arch/s390/include/asm/ptrace.h:9:0, from next/arch/s390/include/asm/lowcore.h:12, from next/arch/s390/include/asm/thread_info.h:30, from include/linux/thread_info.h:54, from include/linux/preempt.h:9, from include/linux/spinlock.h:50, from include/linux/seqlock.h:29, from include/linux/time.h:5, from include/linux/stat.h:18, from include/linux/module.h:10, from drivers/atm/iphase.c:43: next/arch/s390/include/uapi/asm/ptrace.h:197:3: note: previous declaration of 'freg_t' was here Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Acked-by: chas williams - CONTRACTOR <chas@cmf.nrl.navy.mil> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-14packet: fix leakage of tx_ring memoryPhil Sutter
[ Upstream commit 9665d5d62487e8e7b1f546c00e11107155384b9a ] When releasing a packet socket, the routine packet_set_ring() is reused to free rings instead of allocating them. But when calling it for the first time, it fills req->tp_block_nr with the value of rb->pg_vec_len which in the second invocation makes it bail out since req->tp_block_nr is greater zero but req->tp_block_size is zero. This patch solves the problem by passing a zeroed auto-variable to packet_set_ring() upon each invocation from packet_release(). As far as I can tell, this issue exists even since 69e3c75 (net: TX_RING and packet mmap), i.e. the original inclusion of TX ring support into af_packet, but applies only to sockets with both RX and TX ring allocated, which is probably why this was unnoticed all the time. Signed-off-by: Phil Sutter <phil.sutter@viprinet.com> Cc: Johann Baudy <johann.baudy@gnu-log.net> Cc: Daniel Borkmann <dborkman@redhat.com> Acked-by: Daniel Borkmann <dborkman@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-14via-rhine: Fix bugs in NAPI support.David S. Miller
[ Upstream commit 559bcac35facfed49ab4f408e162971612dcfdf3 ] 1) rhine_tx() should use dev_kfree_skb() not dev_kfree_skb_irq() 2) rhine_slow_event_task's NAPI triggering logic is racey, it should just hit the interrupt mask register. This is the same as commit 7dbb491878a2c51d372a8890fa45a8ff80358af1 ("r8169: avoid NAPI scheduling delay.") made to fix the same problem in the r8169 driver. From Francois Romieu. Reported-by: Jamie Gloudon <jamie.gloudon@gmail.com> Tested-by: Jamie Gloudon <jamie.gloudon@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-14ipv6: do not create neighbor entries for local deliveryMarcelo Ricardo Leitner
[ Upstream commit bd30e947207e2ea0ff2c08f5b4a03025ddce48d3 ] They will be created at output, if ever needed. This avoids creating empty neighbor entries when TPROXYing/Forwarding packets for addresses that are not even directly reachable. Note that IPv4 already handles it this way. No neighbor entries are created for local input. Tested by myself and customer. Signed-off-by: Jiri Pirko <jiri@resnulli.us> Signed-off-by: Marcelo Ricardo Leitner <mleitner@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-14pktgen: correctly handle failures when adding a deviceCong Wang
[ Upstream commit 604dfd6efc9b79bce432f2394791708d8e8f6efc ] The return value of pktgen_add_device() is not checked, so even if we fail to add some device, for example, non-exist one, we still see "OK:...". This patch fixes it. After this patch, I got: # echo "add_device non-exist" > /proc/net/pktgen/kpktgend_0 -bash: echo: write error: No such device # cat /proc/net/pktgen/kpktgend_0 Running: Stopped: Result: ERROR: can not add device non-exist # echo "add_device eth0" > /proc/net/pktgen/kpktgend_0 # cat /proc/net/pktgen/kpktgend_0 Running: Stopped: eth0 Result: OK: add_device=eth0 (Candidate for -stable) Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Cong Wang <amwang@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-14net: loopback: fix a dst refcounting issueEric Dumazet
[ Upstream commit 794ed393b707f01858f5ebe2ae5eabaf89d00022 ] Ben Greear reported crashes in ip_rcv_finish() on a stress test involving many macvlans. We tracked the bug to a dst use after free. ip_rcv_finish() was calling dst->input() and got garbage for dst->input value. It appears the bug is in loopback driver, lacking a skb_dst_force() before calling netif_rx(). As a result, a non refcounted dst, normally protected by a RCU read_lock section, was escaping this section and could be freed before the packet being processed. [<ffffffff813a3c4d>] loopback_xmit+0x64/0x83 [<ffffffff81477364>] dev_hard_start_xmit+0x26c/0x35e [<ffffffff8147771a>] dev_queue_xmit+0x2c4/0x37c [<ffffffff81477456>] ? dev_hard_start_xmit+0x35e/0x35e [<ffffffff8148cfa6>] ? eth_header+0x28/0xb6 [<ffffffff81480f09>] neigh_resolve_output+0x176/0x1a7 [<ffffffff814ad835>] ip_finish_output2+0x297/0x30d [<ffffffff814ad6d5>] ? ip_finish_output2+0x137/0x30d [<ffffffff814ad90e>] ip_finish_output+0x63/0x68 [<ffffffff814ae412>] ip_output+0x61/0x67 [<ffffffff814ab904>] dst_output+0x17/0x1b [<ffffffff814adb6d>] ip_local_out+0x1e/0x23 [<ffffffff814ae1c4>] ip_queue_xmit+0x315/0x353 [<ffffffff814adeaf>] ? ip_send_unicast_reply+0x2cc/0x2cc [<ffffffff814c018f>] tcp_transmit_skb+0x7ca/0x80b [<ffffffff814c3571>] tcp_connect+0x53c/0x587 [<ffffffff810c2f0c>] ? getnstimeofday+0x44/0x7d [<ffffffff810c2f56>] ? ktime_get_real+0x11/0x3e [<ffffffff814c6f9b>] tcp_v4_connect+0x3c2/0x431 [<ffffffff814d6913>] __inet_stream_connect+0x84/0x287 [<ffffffff814d6b38>] ? inet_stream_connect+0x22/0x49 [<ffffffff8108d695>] ? _local_bh_enable_ip+0x84/0x9f [<ffffffff8108d6c8>] ? local_bh_enable+0xd/0x11 [<ffffffff8146763c>] ? lock_sock_nested+0x6e/0x79 [<ffffffff814d6b38>] ? inet_stream_connect+0x22/0x49 [<ffffffff814d6b49>] inet_stream_connect+0x33/0x49 [<ffffffff814632c6>] sys_connect+0x75/0x98 This bug was introduced in linux-2.6.35, in commit 7fee226ad2397b (net: add a noref bit on skb dst) skb_dst_force() is enforced in dev_queue_xmit() for devices having a qdisc. Reported-by: Ben Greear <greearb@candelatech.com> Signed-off-by: Eric Dumazet <edumazet@google.com> Tested-by: Ben Greear <greearb@candelatech.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-14r8169: remove the obsolete and incorrect AMD workaroundTimo Teräs
[ Upstream commit 5d0feaff230c0abfe4a112e6f09f096ed99e0b2d ] This was introduced in commit 6dccd16 "r8169: merge with version 6.001.00 of Realtek's r8169 driver". I did not find the version 6.001.00 online, but in 6.002.00 or any later r8169 from Realtek this hunk is no longer present. Also commit 05af214 "r8169: fix Ethernet Hangup for RTL8110SC rev d" claims to have fixed this issue otherwise. The magic compare mask of 0xfffe000 is dubious as it masks parts of the Reserved part, and parts of the VLAN tag. But this does not make much sense as the VLAN tag parts are perfectly valid there. In matter of fact this seems to be triggered with any VLAN tagged packet as RxVlanTag bit is matched. I would suspect 0xfffe0000 was intended to test reserved part only. Finally, this hunk is evil as it can cause more packets to be handled than what was NAPI quota causing net/core/dev.c: net_rx_action(): WARN_ON_ONCE(work > weight) to trigger, and mess up the NAPI state causing device to hang. As result, any system using VLANs and having high receive traffic (so that NAPI poll budget limits rtl_rx) would result in device hang. Signed-off-by: Timo Teräs <timo.teras@iki.fi> Acked-by: Francois Romieu <romieu@fr.zoreil.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-14netxen: fix off by one bug in netxen_release_tx_buffer()Eric Dumazet
[ Upstream commit a05948f296ce103989b28a2606e47d2e287c3c89 ] Christoph Paasch found netxen could trigger a BUG in its dismantle phase, in netxen_release_tx_buffer(), using full size TSO packets. cmd_buf->frag_count includes the skb->data part, so the loop must start at index 1 instead of 0, or else we can make an out of bound access to cmd_buff->frag_array[MAX_SKB_FRAGS + 2] Christoph provided the fixes in netxen_map_tx_skb() function. In case of a dma mapping error, its better to clear the dma fields so that we don't try to unmap them again in netxen_release_tx_buffer() Reported-by: Christoph Paasch <christoph.paasch@uclouvain.be> Signed-off-by: Eric Dumazet <edumazet@google.com> Tested-by: Christoph Paasch <christoph.paasch@uclouvain.be> Cc: Sony Chacko <sony.chacko@qlogic.com> Cc: Rajesh Borundia <rajesh.borundia@qlogic.com> Signed-off-by: Christoph Paasch <christoph.paasch@uclouvain.be> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-14isdn/gigaset: fix zero size border case in debug dumpTilman Schmidt
[ Upstream commit d721a1752ba544df8d7d36959038b26bc92bdf80 ] If subtracting 12 from l leaves zero we'd do a zero size allocation, leading to an oops later when we try to set the NUL terminator. Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Tilman Schmidt <tilman@imap.cc> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-14net/mlx4_core: Set number of msix vectors under SRIOV mode to firmware defaultsOr Gerlitz
[ Upstream commit ca4c7b35f75492de7fbf5ee95be07481c348caee ] The lines if (mlx4_is_mfunc(dev)) { nreq = 2; } else { which hard code the number of requested msi-x vectors under multi-function mode to two can be removed completely, since the firmware sets num_eqs and reserved_eqs appropriately Thus, the code line: nreq = min_t(int, dev->caps.num_eqs - dev->caps.reserved_eqs, nreq); is by itself sufficient and correct for all cases. Currently, for mfunc mode num_eqs = 32 and reserved_eqs = 28, hence four vectors will be enabled. This triples (one vector is used for the async events and commands EQ) the horse power provided for processing of incoming packets on netdev RSS scheme, IO initiators/targets commands processing flows, etc. Reviewed-by: Jack Morgenstein <jackm@dev.mellanox.co.il> Signed-off-by: Amir Vadai <amirv@mellanox.com> Signed-off-by: Or Gerlitz <ogerlitz@mellanox.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-14net/mlx4_en: Fix bridged vSwitch configuration for non SRIOV modeYan Burman
[ Upstream commit 213815a1e6ae70b9648483b110bc5081795f99e8 ] Commit 5b4c4d36860e "mlx4_en: Allow communication between functions on same host" introduced a regression under which a bridge acting as vSwitch whose uplink is an mlx4 Ethernet device become non-operative in native (non sriov) mode. This happens since broadcast ARP requests sent by VMs were loopback-ed by the HW and hence the bridge learned VM source MACs on both the VM and the uplink ports. The fix is to place the DMAC in the send WQE only under SRIOV/eSwitch configuration or when the device is in selftest. Reviewed-by: Or Gerlitz <ogerlitz@mellanox.com> Signed-off-by: Yan Burman <yanb@mellanox.com> Signed-off-by: Amir Vadai <amirv@mellanox.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-14net: calxedaxgmac: throw away overrun framesRob Herring
[ Upstream commit d6fb3be544b46a7611a3373fcaa62b5b0be01888 ] The xgmac driver assumes 1 frame per descriptor. If a frame larger than the descriptor's buffer size is received, the frame will spill over into the next descriptor. So check for received frames that span more than one descriptor and discard them. This prevents a crash if we receive erroneous large packets. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Cc: netdev@vger.kernel.org Cc: linux-kernel@vger.kernel.org Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-14ipv6: fix header length calculation in ip6_append_data()Romain KUNTZ
[ Upstream commit 7efdba5bd9a2f3e2059beeb45c9fa55eefe1bced ] Commit 299b0767 (ipv6: Fix IPsec slowpath fragmentation problem) has introduced a error in the header length calculation that provokes corrupted packets when non-fragmentable extensions headers (Destination Option or Routing Header Type 2) are used. rt->rt6i_nfheader_len is the length of the non-fragmentable extension header, and it should be substracted to rt->dst.header_len, and not to exthdrlen, as it was done before commit 299b0767. This patch reverts to the original and correct behavior. It has been successfully tested with and without IPsec on packets that include non-fragmentable extensions headers. Signed-off-by: Romain Kuntz <r.kuntz@ipflavors.com> Acked-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-14MAINTAINERS: Stephen Hemminger email changeStephen Hemminger
[ Upstream commit adbbf69d1a54abf424e91875746a610dcc80017d ] I changed my email because the vyatta.com mail server is now redirected to brocade.com; and the Brocade mail system is not friendly to Linux desktop users. Signed-off-by: Stephen Hemminger <stephen@networkplumber.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-14ipv6: fix the noflags test in addrconf_get_prefix_routeRomain Kuntz
[ Upstream commit 85da53bf1c336bb07ac038fb951403ab0478d2c5 ] The tests on the flags in addrconf_get_prefix_route() does no make much sense: the 'noflags' parameter contains the set of flags that must not match with the route flags, so the test must be done against 'noflags', and not against 'flags'. Signed-off-by: Romain Kuntz <r.kuntz@ipflavors.com> Acked-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-14net: prevent setting ttl=0 via IP_TTLCong Wang
[ Upstream commit c9be4a5c49cf51cc70a993f004c5bb30067a65ce ] A regression is introduced by the following commit: commit 4d52cfbef6266092d535237ba5a4b981458ab171 Author: Eric Dumazet <eric.dumazet@gmail.com> Date: Tue Jun 2 00:42:16 2009 -0700 net: ipv4/ip_sockglue.c cleanups Pure cleanups but it is not a pure cleanup... - if (val != -1 && (val < 1 || val>255)) + if (val != -1 && (val < 0 || val > 255)) Since there is no reason provided to allow ttl=0, change it back. Reported-by: nitin padalia <padalia.nitin@gmail.com> Cc: nitin padalia <padalia.nitin@gmail.com> Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-14samsung-laptop: Disable on EFI hardwareMatt Fleming
commit e0094244e41c4d0c7ad69920681972fc45d8ce34 upstream. It has been reported that running this driver on some Samsung laptops with EFI can cause those machines to become bricked as detailed in the following report, https://bugs.launchpad.net/ubuntu-cdimage/+bug/1040557 There have also been reports of this driver causing Machine Check Exceptions on recent EFI-enabled Samsung laptops, https://bugzilla.kernel.org/show_bug.cgi?id=47121 So disable it if booting from EFI since this driver relies on grovelling around in the BIOS memory map which isn't going to work. Signed-off-by: Matt Fleming <matt.fleming@intel.com> Cc: Corentin Chary <corentincj@iksaif.net> Cc: Matthew Garrett <mjg59@srcf.ucam.org> Cc: Colin Ian King <colin.king@canonical.com> Cc: Steve Langasek <steve.langasek@canonical.com> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-14efi: Make 'efi_enabled' a function to query EFI facilitiesMatt Fleming
commit 83e68189745ad931c2afd45d8ee3303929233e7f upstream. Originally 'efi_enabled' indicated whether a kernel was booted from EFI firmware. Over time its semantics have changed, and it now indicates whether or not we are booted on an EFI machine with bit-native firmware, e.g. 64-bit kernel with 64-bit firmware. The immediate motivation for this patch is the bug report at, https://bugs.launchpad.net/ubuntu-cdimage/+bug/1040557 which details how running a platform driver on an EFI machine that is designed to run under BIOS can cause the machine to become bricked. Also, the following report, https://bugzilla.kernel.org/show_bug.cgi?id=47121 details how running said driver can also cause Machine Check Exceptions. Drivers need a new means of detecting whether they're running on an EFI machine, as sadly the expression, if (!efi_enabled) hasn't been a sufficient condition for quite some time. Users actually want to query 'efi_enabled' for different reasons - what they really want access to is the list of available EFI facilities. For instance, the x86 reboot code needs to know whether it can invoke the ResetSystem() function provided by the EFI runtime services, while the ACPI OSL code wants to know whether the EFI config tables were mapped successfully. There are also checks in some of the platform driver code to simply see if they're running on an EFI machine (which would make it a bad idea to do BIOS-y things). This patch is a prereq for the samsung-laptop fix patch. Signed-off-by: Matt Fleming <matt.fleming@intel.com> Cc: David Airlie <airlied@linux.ie> Cc: Corentin Chary <corentincj@iksaif.net> Cc: Matthew Garrett <mjg59@srcf.ucam.org> Cc: Dave Jiang <dave.jiang@intel.com> Cc: Olof Johansson <olof@lixom.net> Cc: Peter Jones <pjones@redhat.com> Cc: Colin Ian King <colin.king@canonical.com> Cc: Steve Langasek <steve.langasek@canonical.com> Cc: Tony Luck <tony.luck@intel.com> Cc: Konrad Rzeszutek Wilk <konrad@kernel.org> Cc: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-14Bluetooth: Fix handling of unexpected SMP PDUsJohan Hedberg
commit 8cf9fa1240229cbdd888236c0c43fcbad680cf00 upstream. The conn->smp_chan pointer can be NULL if SMP PDUs arrive at unexpected moments. To avoid NULL pointer dereferences the code should be checking for this and disconnect if an unexpected SMP PDU arrives. This patch fixes the issue by adding a check for conn->smp_chan for all other PDUs except pairing request and security request (which are are the first PDUs to come to initialize the SMP context). Signed-off-by: Johan Hedberg <johan.hedberg@intel.com> Acked-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Gustavo Padovan <gustavo.padovan@collabora.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-14kernel/resource.c: fix stack overflow in __reserve_region_with_split()T Makphaibulchoke
commit 4965f5667f36a95b41cda6638875bc992bd7d18b upstream. Using a recursive call add a non-conflicting region in __reserve_region_with_split() could result in a stack overflow in the case that the recursive calls are too deep. Convert the recursive calls to an iterative loop to avoid the problem. Tested on a machine containing 135 regions. The kernel no longer panicked with stack overflow. Also tested with code arbitrarily adding regions with no conflict, embedding two consecutive conflicts and embedding two non-consecutive conflicts. Signed-off-by: T Makphaibulchoke <tmac@hp.com> Reviewed-by: Ram Pai <linuxram@us.ibm.com> Cc: Paul Gortmaker <paul.gortmaker@gmail.com> Cc: Wei Yang <weiyang@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-14virtio_console: Don't access uninitialized data.Sjur Brændeland
commit aded024a12b32fc1ed9a80639681daae2d07ec25 upstream. Don't access uninitialized work-queue when removing device. The work queue is initialized only if the device multi-queue. So don't call cancel_work unless this is a multi-queue device. This fixes the following panic: Kernel panic - not syncing: BUG! Call Trace: 62031b28: [<6026085d>] panic+0x16b/0x2d3 62031b30: [<6004ef5e>] flush_work+0x0/0x1d7 62031b60: [<602606f2>] panic+0x0/0x2d3 62031b68: [<600333b0>] memcpy+0x0/0x140 62031b80: [<6002d58a>] unblock_signals+0x0/0x84 62031ba0: [<602609c5>] printk+0x0/0xa0 62031bd8: [<60264e51>] __mutex_unlock_slowpath+0x13d/0x148 62031c10: [<6004ef5e>] flush_work+0x0/0x1d7 62031c18: [<60050234>] try_to_grab_pending+0x0/0x17e 62031c38: [<6004e984>] get_work_gcwq+0x71/0x8f 62031c48: [<60050539>] __cancel_work_timer+0x5b/0x115 62031c78: [<628acc85>] unplug_port+0x0/0x191 [virtio_console] 62031c98: [<6005061c>] cancel_work_sync+0x12/0x14 62031ca8: [<628ace96>] virtcons_remove+0x80/0x15c [virtio_console] 62031ce8: [<628191de>] virtio_dev_remove+0x1e/0x7e [virtio] 62031d08: [<601cf242>] __device_release_driver+0x75/0xe4 62031d28: [<601cf2dd>] device_release_driver+0x2c/0x40 62031d48: [<601ce0dd>] driver_unbind+0x7d/0xc6 62031d88: [<601cd5d9>] drv_attr_store+0x27/0x29 62031d98: [<60115f61>] sysfs_write_file+0x100/0x14d 62031df8: [<600b737d>] vfs_write+0xcb/0x184 62031e08: [<600b58b8>] filp_close+0x88/0x94 62031e38: [<600b7686>] sys_write+0x59/0x88 62031e88: [<6001ced1>] handle_syscall+0x5d/0x80 62031ea8: [<60030a74>] userspace+0x405/0x531 62031f08: [<600d32cc>] sys_dup+0x0/0x5e 62031f28: [<601b11d6>] strcpy+0x0/0x18 62031f38: [<600be46c>] do_execve+0x10/0x12 62031f48: [<600184c7>] run_init_process+0x43/0x45 62031fd8: [<60019a91>] new_thread_handler+0xba/0xbc Signed-off-by: Sjur Brændeland <sjur.brandeland@stericsson.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-14rtlwifi: Fix scheduling while atomic bugLarry Finger
commit a5ffbe0a1993a27072742ef7db6cf9839956fce9 upstream. Kernel commits 41affd5 and 6539306 changed the locking in rtl_lps_leave() from a spinlock to a mutex by doing the calls indirectly from a work queue to reduce the time that interrupts were disabled. This change was fine for most systems; however a scheduling while atomic bug was reported in https://bugzilla.redhat.com/show_bug.cgi?id=903881. The backtrace indicates that routine rtl_is_special(), which calls rtl_lps_leave() in three places was entered in atomic context. These direct calls are replaced by putting a request on the appropriate work queue. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Reported-and-tested-by: Nathaniel Doherty <ntdoherty@gmail.com> Cc: Nathaniel Doherty <ntdoherty@gmail.com> Cc: Stanislaw Gruszka <sgruszka@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-14rtlwifi: Fix the usage of the wrong variable in usb.cLarry Finger
commit 0a06ad8e3a1cb5311b7dbafde45410aa1bce9d40 upstream. In routine _rtl_rx_pre_process(), skb_dequeue() is called to get an skb; however, the wrong variable name is used in subsequent calls. Reported-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Cc: Guenter Roeck <linux@roeck-us.net> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-11Linux 3.4.30v3.4.30Greg Kroah-Hartman
2013-02-11usb: Prevent dead ports when xhci is not enabledDavid Moore
commit 58b2939b4d5a030eaec469d29812ab8477ee7e76 upstream. When the xHCI driver is not available, actively switch the ports to EHCI mode since some BIOSes leave them in xHCI mode where they would otherwise appear dead. This was discovered on a Dell Optiplex 7010, but it's possible other systems could be affected. This should be backported to kernels as old as 3.0, that contain the commit 69e848c2090aebba5698a1620604c7dccb448684 "Intel xhci: Support EHCI/xHCI port switching." Signed-off-by: David Moore <david.moore@gmail.com> Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-11USB: XHCI: fix memory leak of URB-private dataAlan Stern
commit 48c3375c5f69b1c2ef3d1051a0009cb9bce0ce24 upstream. This patch (as1640) fixes a memory leak in xhci-hcd. The urb_priv data structure isn't always deallocated in the handle_tx_event() routine for non-control transfers. The patch adds a kfree() call so that all paths end up freeing the memory properly. This patch should be backported to kernels as old as 2.6.36, that contain the commit 8e51adccd4c4b9ffcd509d7f2afce0a906139f75 "USB: xHCI: Introduce urb_priv structure" Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Reported-and-tested-by: Martin Mokrejs <mmokrejs@fold.natur.cuni.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-11xhci: Fix TD size for isochronous URBs.Sarah Sharp
commit f18f8ed2a9adc41c2d9294b85b6af115829d2af1 upstream. To calculate the TD size for a particular TRB in an isoc TD, we need know the endpoint's max packet size. Isochronous endpoints also encode the number of additional service opportunities in their wMaxPacketSize field. The TD size calculation did not mask off those bits before using the field. This resulted in incorrect TD size information for isochronous TRBs when an URB frame buffer crossed a 64KB boundary. For example: - an isoc endpoint has 2 additional service opportunites and a max packet size of 1020 bytes - a frame transfer buffer contains 3060 bytes - one frame buffer crosses a 64KB boundary, and must be split into one 1276 byte TRB, and one 1784 byte TRB. The TD size is is the number of packets that remain to be transferred for a TD after processing all the max packet sized packets in the current TRB and all previous TRBs. For this TD, the number of packets to be transferred is (3060 / 1020), or 3. The first TRB contains 1276 bytes, which means it contains one full packet, and a 256 byte remainder. After processing all the max packet-sized packets in the first TRB, the host will have 2 packets left to transfer. The old code would calculate the TD size for the first TRB as: total packet count = DIV_ROUND_UP (TD length / endpoint wMaxPacketSize) total packet count - (first TRB length / endpoint wMaxPacketSize) The math should have been: total packet count = DIV_ROUND_UP (3060 / 1020) = 3 3 - (1276 / 1020) = 2 Since the old code didn't mask off the additional service interval bits from the wMaxPacketSize field, the math ended up as total packet count = DIV_ROUND_UP (3060 / 5116) = 1 1 - (1276 / 5116) = 1 Fix this by masking off the number of additional service opportunities in the wMaxPacketSize field. This patch should be backported to stable kernels as old as 3.0, that contain the commit 4da6e6f247a2601ab9f1e63424e4d944ed4124f3 "xhci 1.0: Update TD size field format." It may not apply well to kernels older than 3.2 because of commit 29cc88979a8818cd8c5019426e945aed118b400e "USB: use usb_endpoint_maxp() instead of le16_to_cpu()". Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-11xhci: Fix isoc TD encoding.Sarah Sharp
commit 760973d2a74b93eb1697981f7448f0e62767cfc4 upstream. An isochronous TD is comprised of one isochronous TRB chained to zero or more normal TRBs. Only the isoc TRB has the TBC and TLBPC fields. The normal TRBs must set those fields to zeroes. The code was setting the TBC and TLBPC fields for both isoc and normal TRBs. Fix this. This should be backported to stable kernels as old as 3.0, that contain the commit b61d378f2da41c748aba6ca19d77e1e1c02bcea5 " xhci 1.0: Set transfer burst last packet count field." Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-11drivers: xhci: fix incorrect bit testNickolai Zeldovich
commit ba7b5c22d33136a5612ca5ef8d31564dcc501126 upstream. Fix incorrect bit test that originally showed up in 4ee823b83bc9851743fab756c76b27d6a1e2472b "USB/xHCI: Support device-initiated USB 3.0 resume." Use '&' instead of '&&'. This should be backported to kernels as old as 3.4. Signed-off-by: Nickolai Zeldovich <nickolai@csail.mit.edu> Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-11USB: storage: optimize to match the Huawei USB storage devices and support ↵fangxiaozhi
new switch command commit 200e0d994d9d1919b28c87f1a5fb99a8e13b8a0f upstream. 1. Optimize the match rules with new macro for Huawei USB storage devices, to avoid to load USB storage driver for the modem interface with Huawei devices. 2. Add to support new switch command for new Huawei USB dongles. Signed-off-by: fangxiaozhi <huananhu@huawei.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-11USB: storage: Define a new macro for USB storage match rulesfangxiaozhi
commit 07c7be3d87e5cdaf5f94c271c516456364ef286c upstream. 1. Define a new macro for USB storage match rules: matching with Vendor ID and interface descriptors. Signed-off-by: fangxiaozhi <huananhu@huawei.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-11usb: Using correct way to clear usb3.0 device's remote wakeup feature.Lan Tianyu
commit 54a3ac0c9e5b7213daa358ce74d154352657353a upstream. Usb3.0 device defines function remote wakeup which is only for interface recipient rather than device recipient. This is different with usb2.0 device's remote wakeup feature which is defined for device recipient. According usb3.0 spec 9.4.5, the function remote wakeup can be modified by the SetFeature() requests using the FUNCTION_SUSPEND feature selector. This patch is to use correct way to disable usb3.0 device's function remote wakeup after suspend error and resuming. This should be backported to kernels as old as 3.4, that contain the commit 623bef9e03a60adc623b09673297ca7a1cdfb367 "USB/xhci: Enable remote wakeup for USB3 devices." Signed-off-by: Lan Tianyu <tianyu.lan@intel.com> Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-11USB: EHCI: fix bug in scheduling periodic split transfersAlan Stern
commit 3e619d04159be54b3daa0b7036b0ce9e067f4b5d upstream. This patch (as1654) fixes a very old bug in ehci-hcd, connected with scheduling of periodic split transfers. The calculations for full/low-speed bus usage are all carried out after the correction for bit-stuffing has been applied, but the values in the max_tt_usecs array assume it hasn't been. The array should allow for allocation of up to 90% of the bus capacity, which is 900 us, not 780 us. The symptom caused by this bug is that any isochronous transfer to a full-speed device with a maxpacket size larger than about 980 bytes is always rejected with a -ENOSPC error. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-11USB: EHCI: fix timer bug affecting port resumeAlan Stern
commit ee74290b7853db9d5fd64db70e5c175241c59fba upstream. This patch (as1652) fixes a long-standing bug in ehci-hcd. The driver relies on status polls to know when to stop port-resume signalling. It uses the root-hub status timer to schedule these status polls. But when the driver for the root hub is resumed, the timer is rescheduled to go off immediately -- before the port is ready. When this happens the timer does not get re-enabled, which prevents the port resume from finishing until some other event occurs. The symptom is that when a new device is plugged in, it doesn't get recognized or enumerated until lsusb is run or something else happens. The solution is to re-enable the root-hub status timer after every status poll while a port resume is in progress. This bug hasn't surfaced before now because we never used to try to suspend the root hub in the middle of a port resume (except by coincidence). Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Reported-and-tested-by: Norbert Preining <preining@logic.at> Tested-by: Ming Lei <ming.lei@canonical.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-11USB: qcserial: add Telit Gobi QDL deviceDaniele Palmas
commit 78796ae17eacedcdcaaeb03ba73d2e532a4c8f83 upstream. Add VID and PID for Telit Gobi QDL device Signed-off-by: Daniele Palmas <dnlplm@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-11USB: option: add Changhong CH690Bjørn Mork
commit d4fa681541aa7bf8570d03426dd7ba663a71c467 upstream. New device with 3 serial interfaces: If#= 0 Alt= 0 #EPs= 3 Cls=ff(vend) Sub=ff Prot=ff If#= 1 Alt= 0 #EPs= 2 Cls=ff(vend) Sub=ff Prot=ff If#= 2 Alt= 0 #EPs= 2 Cls=ff(vend) Sub=ff Prot=ff If#= 3 Alt= 0 #EPs= 2 Cls=08(stor) Sub=06 Prot=50 Signed-off-by: Bjørn Mork <bjorn@mork.no> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
