2015-04-03Linux 3.18.11v3.18.11Sasha Levin
2015-03-28target/pscsi: Fix NULL pointer dereference in get_device_typeNicholas Bellinger
[ Upstream commit 215a8fe4198f607f34ecdbc9969dae783d8b5a61 ] This patch fixes a NULL pointer dereference OOPs with pSCSI backends within target_core_stat.c code. The bug is caused by a configfs attr read if no pscsi_dev_virt->pdv_sd has been configured. Reported-by: Olaf Hering <olaf@aepfle.de> Cc: <stable@vger.kernel.org> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-03-28iscsi-target: Avoid early conn_logout_comp for iser connectionsNicholas Bellinger
[ Upstream commit f068fbc82e7696d67b1bb8189306865bedf368b6 ] This patch fixes a iser specific logout bug where early complete() of conn->conn_logout_comp in iscsit_close_connection() was causing isert_wait4logout() to complete too soon, triggering a use after free NULL pointer dereference of iscsi_conn memory. The complete() was originally added for traditional iscsi-target when a ISCSI_LOGOUT_OP failed in iscsi_target_rx_opcode(), but given iser-target does not wait in logout failure, this special case needs to be avoided. Reported-by: Sagi Grimberg <sagig@mellanox.com> Cc: Sagi Grimberg <sagig@mellanox.com> Cc: Slava Shwartsman <valyushash@gmail.com> Cc: <stable@vger.kernel.org> # v3.10+ Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-03-28target: Fix virtual LUN=0 target_configure_device failure OOPsNicholas Bellinger
[ Upstream commit 5f7da044f8bc1cfb21c962edf34bd5699a76e7ae ] This patch fixes a NULL pointer dereference triggered by a late target_configure_device() -> alloc_workqueue() failure that results in target_free_device() being called with DF_CONFIGURED already set, which subsequently OOPses in destroy_workqueue() code. Currently this only happens at modprobe target_core_mod time when core_dev_setup_virtual_lun0() -> target_configure_device() fails, and the explicit target_free_device() gets called. To address this bug originally introduced by commit 0fd97ccf45, go ahead and move DF_CONFIGURED to end of target_configure_device() code to handle this special failure case. Reported-by: Claudio Fleiner <cmf@daterainc.com> Cc: Claudio Fleiner <cmf@daterainc.com> Cc: Christoph Hellwig <hch@lst.de> Cc: <stable@vger.kernel.org> # v3.7+ Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-03-28target: Fix reference leak in target_get_sess_cmd() error pathBart Van Assche
[ Upstream commit 7544e597343e2166daba3f32e4708533aa53c233 ] This patch fixes a se_cmd->cmd_kref leak buf when se_sess->sess_tearing_down is true within target_get_sess_cmd() submission path code. This se_cmd reference leak can occur during active session shutdown when ack_kref=1 is passed by target_submit_cmd_[map_sgls,tmr]() callers. Signed-off-by: Bart Van Assche <bart.vanassche@sandisk.com> Cc: <stable@vger.kernel.org> # 3.6+ Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-03-28ARM: dts: am43xx-clocks: Fix ehrpwm tbclk data on am43xxVignesh R
[ Upstream commit 7d53d25578486d65bd7cd242bc7816b40e55e62b ] ehrpwm tbclk is wrongly modelled as deriving from dpll_per_m2_ck. The TRM says tbclk is derived from SYSCLKOUT. SYSCLKOUT nothing but the functional clock of pwmss (l4ls_gclk). Fix this by changing source of ehrpwmx_tbclk to l4ls_gclk. Fixes: 4da1c67719f61 ("add tbclk data for ehrpwm") Signed-off-by: Vignesh R <vigneshr@ti.com> Acked-by: Tero Kristo <t-kristo@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-03-28ARM: dts: am33xx-clocks: Fix ehrpwm tbclk data on am33xxVignesh R
[ Upstream commit 6e22616eba7e25fac5aa6cb6563471afa1815ec2 ] ehrpwm tbclk is wrongly modelled as deriving from dpll_per_m2_ck. The TRM says tbclk is derived from SYSCLKOUT. SYSCLKOUT nothing but the functional clock of pwmss (l4ls_gclk). Fix this by changing source of ehrpwmx_tbclk to l4ls_gclk. Fixes: 9e100ebafb91: ("Fix ehrpwm tbclk data") Signed-off-by: Vignesh R <vigneshr@ti.com> Acked-by: Tero Kristo <t-kristo@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-03-28ARM: dts: DRA7x: Fix the bypass clock source for dpll_iva and othersRavikumar Kattekola
[ Upstream commit d2192ea09858a8535b056fcede1a41d824e0b3d8 ] Fixes: ee6c750761 (ARM: dts: dra7 clock data) On DRA7x, For DPLL_IVA, the ref clock(CLKINP) is connected to sys_clk1 and the bypass input(CLKINPULOW) is connected to iva_dpll_hs_clk_div clock. But the bypass input is not directly routed to bypass clkout instead both CLKINP and CLKINPULOW are connected to bypass clkout via a mux. This mux is controlled by the bit - CM_CLKSEL_DPLL_IVA[23]:DPLL_BYP_CLKSEL and it's POR value is zero which selects the CLKINP as bypass clkout. which means iva_dpll_hs_clk_div is not the bypass clock for dpll_iva_ck Fix this by adding another mux clock as parent in bypass mode. This design is common to most of the PLLs and the rest have only one bypass clock. Below is a list of the DPLLs that need this fix: DPLL_IVA, DPLL_DDR, DPLL_DSP, DPLL_EVE, DPLL_GMAC, DPLL_PER, DPLL_USB and DPLL_CORE Signed-off-by: Ravikumar Kattekola <rk@ti.com> Acked-by: Tero Kristo <t-kristo@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-03-28ARM: at91: pm: fix at91rm9200 standbyAlexandre Belloni
[ Upstream commit 84e871660bebfddb9a62ebd6f19d02536e782f0a ] at91rm9200 standby and suspend to ram has been broken since 00482a4078f4. It is wrongly using AT91_BASE_SYS which is a physical address and actually doesn't correspond to any register on at91rm9200. Use the correct at91_ramc_base[0] instead. Fixes: 00482a4078f4 (ARM: at91: implement the standby function for pm/cpuidle) Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-03-28ARM: imx6qdl-sabresd: set swbst_reg as vbus's parent regPeter Chen
[ Upstream commit 40f737791d4dab26bf23a6331609c604142228bd ] USB vbus 5V is from PMIC SWBST, so set swbst_reg as vbus's parent reg, it fixed a bug that the voltage of vbus is incorrect due to swbst_reg is disabled after boots up. Cc: stable@vger.kernel.org Signed-off-by: Peter Chen <peter.chen@freescale.com> Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-03-28x86: numachip: Fix 16-bit APIC ID truncationDaniel J Blueman
[ Upstream commit 00e7977dd1bbd46e336d7ef907d0fb6b6a4c294f ] Prevent 16-bit APIC IDs being truncated by using correct mask. This fixes booting large systems, where the wrong core would receive the startup and init IPIs, causing hanging. Signed-off-by: Daniel J Blueman <daniel@numascale.com> Cc: Steffen Persvold <sp@numascale.com> Cc: Bjorn Helgaas <bhelgaas@google.com> Link: http://lkml.kernel.org/r/1415089784-28779-1-git-send-email-daniel@numascale.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-03-28x86/vdso: Fix the build on GCC5Jiri Slaby
[ Upstream commit e893286918d2cde3a94850d8f7101cd1039e0c62 ] On gcc5 the kernel does not link: ld: .eh_frame_hdr table[4] FDE at 0000000000000648 overlaps table[5] FDE at 0000000000000670. Because prior GCC versions always emitted NOPs on ALIGN directives, but gcc5 started omitting them. .LSTARTFDEDLSI1 says: /* HACK: The dwarf2 unwind routines will subtract 1 from the return address to get an address in the middle of the presumed call instruction. Since we didn't get here via a call, we need to include the nop before the real start to make up for it. */ .long .LSTART_sigreturn-1-. /* PC-relative start address */ But commit 69d0627a7f6e ("x86 vDSO: reorder vdso32 code") from 2.6.25 replaced .org __kernel_vsyscall+32,0x90 by ALIGN right before __kernel_sigreturn. Of course, ALIGN need not generate any NOP in there. Esp. gcc5 collapses vclock_gettime.o and int80.o together with no generated NOPs as "ALIGN". So fix this by adding to that point at least a single NOP and make the function ALIGN possibly with more NOPs then. Kudos for reporting and diagnosing should go to Richard. Reported-by: Richard Biener <rguenther@suse.de> Signed-off-by: Jiri Slaby <jslaby@suse.cz> Acked-by: Andy Lutomirski <luto@amacapital.net> Cc: <stable@vger.kernel.org> Cc: Borislav Petkov <bp@alien8.de> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/1425543211-12542-1-git-send-email-jslaby@suse.cz Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-03-28kvm: move advertising of KVM_CAP_IRQFD to common codePaolo Bonzini
[ Upstream commit dc9be0fac70a2ad86e31a81372bb0bdfb6945353 ] POWER supports irqfds but forgot to advertise them. Some userspace does not check for the capability, but others check it---thus they work on x86 and s390 but not POWER. To avoid that other architectures in the future make the same mistake, let common code handle KVM_CAP_IRQFD the same way as KVM_CAP_IRQFD_RESAMPLE. Reported-and-tested-by: Greg Kurz <gkurz@linux.vnet.ibm.com> Cc: stable@vger.kernel.org Fixes: 297e21053a52f060944e9f0de4c64fad9bcd72fc Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-03-28x86/fpu: Drop_fpu() should not assume that tsk equals currentOleg Nesterov
[ Upstream commit f4c3686386393c120710dd34df2a74183ab805fd ] drop_fpu() does clear_used_math() and usually this is correct because tsk == current. However switch_fpu_finish()->restore_fpu_checking() is called before __switch_to() updates the "current_task" variable. If it fails, we will wrongly clear the PF_USED_MATH flag of the previous task. So use clear_stopped_child_used_math() instead. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Borislav Petkov <bp@suse.de> Reviewed-by: Rik van Riel <riel@redhat.com> Cc: <stable@vger.kernel.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Borislav Petkov <bp@alien8.de> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Pekka Riikonen <priikone@iki.fi> Cc: Quentin Casasnovas <quentin.casasnovas@oracle.com> Cc: Suresh Siddha <sbsiddha@gmail.com> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/20150309171041.GB11388@redhat.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-03-28x86/fpu: Avoid math_state_restore() without used_math() in ↵Oleg Nesterov
__restore_xstate_sig() [ Upstream commit a7c80ebcac3068b1c3cb27d538d29558c30010c8 ] math_state_restore() assumes it is called with irqs disabled, but this is not true if the caller is __restore_xstate_sig(). This means that if ia32_fxstate == T and __copy_from_user() fails, __restore_xstate_sig() returns with irqs disabled too. This triggers: BUG: sleeping function called from invalid context at kernel/locking/rwsem.c:41 dump_stack ___might_sleep ? _raw_spin_unlock_irqrestore __might_sleep down_read ? _raw_spin_unlock_irqrestore print_vma_addr signal_fault sys32_rt_sigreturn Change __restore_xstate_sig() to call set_used_math() unconditionally. This avoids enabling and disabling interrupts in math_state_restore(). If copy_from_user() fails, we can simply do fpu_finit() by hand. [ Note: this is only the first step. math_state_restore() should not check used_math(), it should set this flag. While init_fpu() should simply die. ] Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Borislav Petkov <bp@suse.de> Cc: <stable@vger.kernel.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Borislav Petkov <bp@alien8.de> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Pekka Riikonen <priikone@iki.fi> Cc: Quentin Casasnovas <quentin.casasnovas@oracle.com> Cc: Rik van Riel <riel@redhat.com> Cc: Suresh Siddha <sbsiddha@gmail.com> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/20150307153844.GB25954@redhat.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-03-28crypto: aesni - fix memory usage in GCM decryptionStephan Mueller
[ Upstream commit ccfe8c3f7e52ae83155cb038753f4c75b774ca8a ] The kernel crypto API logic requires the caller to provide the length of (ciphertext || authentication tag) as cryptlen for the AEAD decryption operation. Thus, the cipher implementation must calculate the size of the plaintext output itself and cannot simply use cryptlen. The RFC4106 GCM decryption operation tries to overwrite cryptlen memory in req->dst. As the destination buffer for decryption only needs to hold the plaintext memory but cryptlen references the input buffer holding (ciphertext || authentication tag), the assumption of the destination buffer length in RFC4106 GCM operation leads to a too large size. This patch simply uses the already calculated plaintext size. In addition, this patch fixes the offset calculation of the AAD buffer pointer: as mentioned before, cryptlen already includes the size of the tag. Thus, the tag does not need to be added. With the addition, the AAD will be written beyond the already allocated buffer. Note, this fixes a kernel crash that can be triggered from user space via AF_ALG(aead) -- simply use the libkcapi test application from [1] and update it to use rfc4106-gcm-aes. Using [1], the changes were tested using CAVS vectors to demonstrate that the crypto operation still delivers the right results. [1] http://www.chronox.de/libkcapi.html CC: Tadeusz Struk <tadeusz.struk@intel.com> Cc: stable@vger.kernel.org Signed-off-by: Stephan Mueller <smueller@chronox.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-03-28crypto: arm/aes update NEON AES module to latest OpenSSL versionArd Biesheuvel
[ Upstream commit 001eabfd54c0cbf9d7d16264ddc8cc0bee67e3ed ] This updates the bit sliced AES module to the latest version in the upstream OpenSSL repository (e620e5ae37bc). This is needed to fix a bug in the XTS decryption path, where data chunked in a certain way could trigger the ciphertext stealing code, which is not supposed to be active in the kernel build (The kernel implementation of XTS only supports round multiples of the AES block size of 16 bytes, whereas the conformant OpenSSL implementation of XTS supports inputs of arbitrary size by applying ciphertext stealing). This is fixed in the upstream version by adding the missing #ifndef XTS_CHAIN_TWEAK around the offending instructions. The upstream code also contains the change applied by Russell to build the code unconditionally, i.e., even if __LINUX_ARM_ARCH__ < 7, but implemented slightly differently. Cc: stable@vger.kernel.org Fixes: e4e7f10bfc40 ("ARM: add support for bit sliced AES using NEON instructions") Reported-by: Adrian Kotelba <adrian.kotelba@gmail.com> Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org> Tested-by: Milan Broz <gmazyland@gmail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-03-28pagemap: do not leak physical addresses to non-privileged userspaceKirill A. Shutemov
[ Upstream commit ab676b7d6fbf4b294bf198fb27ade5b0e865c7ce ] As pointed by recent post[1] on exploiting DRAM physical imperfection, /proc/PID/pagemap exposes sensitive information which can be used to do attacks. This disallows anybody without CAP_SYS_ADMIN to read the pagemap. [1] http://googleprojectzero.blogspot.com/2015/03/exploiting-dram-rowhammer-bug-to-gain.html [ Eventually we might want to do anything more finegrained, but for now this is the simple model. - Linus ] Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Acked-by: Konstantin Khlebnikov <khlebnikov@openvz.org> Acked-by: Andy Lutomirski <luto@amacapital.net> Cc: Pavel Emelyanov <xemul@parallels.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Mark Seaborn <mseaborn@chromium.org> Cc: stable@vger.kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-03-28irqchip: armada-370-xp: Fix chained per-cpu interruptsMaxime Ripard
[ Upstream commit 5724be8464dceac047c1eaddaa3651cea0ec16ca ] On the Cortex-A9-based Armada SoCs, the MPIC is not the primary interrupt controller. Yet, it still has to handle some per-cpu interrupt. To do so, it is chained with the GIC using a per-cpu interrupt. However, the current code only call irq_set_chained_handler, which is called and enable that interrupt only on the boot CPU, which means that the parent per-CPU interrupt is never unmasked on the secondary CPUs, preventing the per-CPU interrupt to actually work as expected. This was not seen until now since the only MPIC PPI users were the Marvell timers that were not working, but not used either since the system use the ARM TWD by default, and the ethernet controllers, that are faking there interrupts as SPI, and don't really expect to have interrupts on the secondary cores anyway. Add a CPU notifier that will enable the PPI on the secondary cores when they are brought up. Cc: <stable@vger.kernel.org> # 3.15+ Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Acked-by: Gregory CLEMENT <gregory.clement@free-electrons.com> Link: https://lkml.kernel.org/r/1425378443-28822-1-git-send-email-maxime.ripard@free-electrons.com Signed-off-by: Jason Cooper <jason@lakedaemon.net> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-03-28PCI: Don't read past the end of sysfs "driver_override" bufferSasha Levin
[ Upstream commit 4efe874aace57dba967624ce1c48322da2447b75 ] When printing the driver_override parameter when it is 4095 and 4094 bytes long, the printing code would access invalid memory because we need count+1 bytes for printing. Fixes: 782a985d7af2 ("PCI: Introduce new device binding path using pci_dev.driver_override") Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Acked-by: Alex Williamson <alex.williamson@redhat.com> CC: stable@vger.kernel.org # v3.16+ CC: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> CC: Alexander Graf <agraf@suse.de> CC: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-03-28libsas: Fix Kernel Crash in smp_execute_taskJames Bottomley
[ Upstream commit 6302ce4d80aa82b3fdb5c5cd68e7268037091b47 ] This crash was reported: [ 366.947370] sd 3:0:1:0: [sdb] Spinning up disk.... [ 368.804046] BUG: unable to handle kernel NULL pointer dereference at (null) [ 368.804072] IP: [<ffffffff81358457>] __mutex_lock_common.isra.7+0x9c/0x15b [ 368.804098] PGD 0 [ 368.804114] Oops: 0002 [#1] SMP [ 368.804143] CPU 1 [ 368.804151] Modules linked in: sg netconsole s3g(PO) uinput joydev hid_multitouch usbhid hid snd_hda_codec_via cpufreq_userspace cpufreq_powersave cpufreq_stats uhci_hcd cpufreq_conservative snd_hda_intel snd_hda_codec snd_hwdep snd_pcm sdhci_pci snd_page_alloc sdhci snd_timer snd psmouse evdev serio_raw pcspkr soundcore xhci_hcd shpchp s3g_drm(O) mvsas mmc_core ahci libahci drm i2c_core acpi_cpufreq mperf video processor button thermal_sys dm_dmirror exfat_fs exfat_core dm_zcache dm_mod padlock_aes aes_generic padlock_sha iscsi_target_mod target_core_mod configfs sswipe libsas libata scsi_transport_sas picdev via_cputemp hwmon_vid fuse parport_pc ppdev lp parport autofs4 ext4 crc16 mbcache jbd2 sd_mod crc_t10dif usb_storage scsi_mod ehci_hcd usbcore usb_common [ 368.804749] [ 368.804764] Pid: 392, comm: kworker/u:3 Tainted: P W O 3.4.87-logicube-ng.22 #1 To be filled by O.E.M. To be filled by O.E.M./EPIA-M920 [ 368.804802] RIP: 0010:[<ffffffff81358457>] [<ffffffff81358457>] __mutex_lock_common.isra.7+0x9c/0x15b [ 368.804827] RSP: 0018:ffff880117001cc0 EFLAGS: 00010246 [ 368.804842] RAX: 0000000000000000 RBX: ffff8801185030d0 RCX: ffff88008edcb420 [ 368.804857] RDX: 0000000000000000 RSI: 0000000000000002 RDI: ffff8801185030d4 [ 368.804873] RBP: ffff8801181531c0 R08: 0000000000000020 R09: 00000000fffffffe [ 368.804885] R10: 0000000000000000 R11: 0000000000000000 R12: ffff8801185030d4 [ 368.804899] R13: 0000000000000002 R14: ffff880117001fd8 R15: ffff8801185030d8 [ 368.804916] FS: 0000000000000000(0000) GS:ffff88011fc80000(0000) knlGS:0000000000000000 [ 368.804931] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b [ 368.804946] CR2: 0000000000000000 CR3: 000000000160b000 CR4: 00000000000006e0 [ 368.804962] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 [ 368.804978] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 [ 368.804995] Process kworker/u:3 (pid: 392, threadinfo ffff880117000000, task ffff8801181531c0) [ 368.805009] Stack: [ 368.805017] ffff8801185030d8 0000000000000000 ffffffff8161ddf0 ffffffff81056f7c [ 368.805062] 000000000000b503 ffff8801185030d0 ffff880118503000 0000000000000000 [ 368.805100] ffff8801185030d0 ffff8801188b8000 ffff88008edcb420 ffffffff813583ac [ 368.805135] Call Trace: [ 368.805153] [<ffffffff81056f7c>] ? up+0xb/0x33 [ 368.805168] [<ffffffff813583ac>] ? mutex_lock+0x16/0x25 [ 368.805194] [<ffffffffa018c414>] ? smp_execute_task+0x4e/0x222 [libsas] [ 368.805217] [<ffffffffa018ce1c>] ? sas_find_bcast_dev+0x3c/0x15d [libsas] [ 368.805240] [<ffffffffa018ce4f>] ? sas_find_bcast_dev+0x6f/0x15d [libsas] [ 368.805264] [<ffffffffa018e989>] ? sas_ex_revalidate_domain+0x37/0x2ec [libsas] [ 368.805280] [<ffffffff81355a2a>] ? printk+0x43/0x48 [ 368.805296] [<ffffffff81359a65>] ? _raw_spin_unlock_irqrestore+0xc/0xd [ 368.805318] [<ffffffffa018b767>] ? sas_revalidate_domain+0x85/0xb6 [libsas] [ 368.805336] [<ffffffff8104e5d9>] ? process_one_work+0x151/0x27c [ 368.805351] [<ffffffff8104f6cd>] ? worker_thread+0xbb/0x152 [ 368.805366] [<ffffffff8104f612>] ? manage_workers.isra.29+0x163/0x163 [ 368.805382] [<ffffffff81052c4e>] ? kthread+0x79/0x81 [ 368.805399] [<ffffffff8135fea4>] ? kernel_thread_helper+0x4/0x10 [ 368.805416] [<ffffffff81052bd5>] ? kthread_flush_work_fn+0x9/0x9 [ 368.805431] [<ffffffff8135fea0>] ? gs_change+0x13/0x13 [ 368.805442] Code: 83 7d 30 63 7e 04 f3 90 eb ab 4c 8d 63 04 4c 8d 7b 08 4c 89 e7 e8 fa 15 00 00 48 8b 43 10 4c 89 3c 24 48 89 63 10 48 89 44 24 08 <48> 89 20 83 c8 ff 48 89 6c 24 10 87 03 ff c8 74 35 4d 89 ee 41 [ 368.805851] RIP [<ffffffff81358457>] __mutex_lock_common.isra.7+0x9c/0x15b [ 368.805877] RSP <ffff880117001cc0> [ 368.805886] CR2: 0000000000000000 [ 368.805899] ---[ end trace b720682065d8f4cc ]--- It's directly caused by 89d3cf6 [SCSI] libsas: add mutex for SMP task execution, but shows a deeper cause: expander functions expect to be able to cast to and treat domain devices as expanders. The correct fix is to only do expander discover when we know we've got an expander device to avoid wrongly casting a non-expander device. Reported-by: Praveen Murali <pmurali@logicube.com> Tested-by: Praveen Murali <pmurali@logicube.com> Cc: stable@vger.kernel.org Signed-off-by: James Bottomley <JBottomley@Parallels.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-03-28gadgetfs: use-after-free in ->aio_read()Al Viro
[ Upstream commit f01d35a15fa04162a58b95970fc01fa70ec9dacd ] AIO_PREAD requests call ->aio_read() with iovec on caller's stack, so if we are going to access it asynchronously, we'd better get ourselves a copy - the one on kernel stack of aio_run_iocb() won't be there anymore. function/f_fs.c take care of doing that, legacy/inode.c doesn't... Cc: stable@vger.kernel.org Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-03-28xen-pciback: limit guest control of command registerJan Beulich
[ Upstream commit af6fc858a35b90e89ea7a7ee58e66628c55c776b ] Otherwise the guest can abuse that control to cause e.g. PCIe Unsupported Request responses by disabling memory and/or I/O decoding and subsequently causing (CPU side) accesses to the respective address ranges, which (depending on system configuration) may be fatal to the host. Note that to alter any of the bits collected together as PCI_COMMAND_GUEST permissive mode is now required to be enabled globally or on the specific device. This is CVE-2015-2150 / XSA-120. Signed-off-by: Jan Beulich <jbeulich@suse.com> Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: <stable@vger.kernel.org> Signed-off-by: David Vrabel <david.vrabel@citrix.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-03-28xen/events: avoid NULL pointer dereference in dom0 on large machinesJuergen Gross
[ Upstream commit 85e40b0539b24518c8bdf63e2605c8522377d00f ] Using the pvops kernel a NULL pointer dereference was detected on a large machine (144 processors) when booting as dom0 in evtchn_fifo_unmask() during assignment of a pirq. The event channel in question was the first to need a new entry in event_array[] in events_fifo.c. Unfortunately xen_irq_info_pirq_setup() is called with evtchn being 0 for a new pirq and the real event channel number is assigned to the pirq only during __startup_pirq(). It is mandatory to call xen_evtchn_port_setup() after assigning the event channel number to the pirq to make sure all memory needed for the event channel is allocated. Signed-off-by: Juergen Gross <jgross@suse.com> Cc: <stable@vger.kernel.org> # 3.14+ Signed-off-by: David Vrabel <david.vrabel@citrix.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-03-28drivers/rtc/rtc-s3c.c: add .needs_src_clk to s3c6410 RTC dataJavier Martinez Canillas
[ Upstream commit 8792f7772f4f40ffc68bad5f28311205584b734d ] Commit df9e26d093d3 ("rtc: s3c: add support for RTC of Exynos3250 SoC") added an "rtc_src" DT property to specify the clock used as a source to the S3C real-time clock. Not all SoCs needs this so commit eaf3a659086e ("drivers/rtc/rtc-s3c.c: fix initialization failure without rtc source clock") changed to check the struct s3c_rtc_data .needs_src_clk to conditionally grab the clock. But that commit didn't update the data for each IP version so the RTC broke on the boards that needs a source clock. This is the case of at least Exynos5250 and Exynos5440 which uses the s3c6410 RTC IP block. This commit fixes the S3C rtc on the Exynos5250 Snow and Exynos5420 Peach Pit and Pi Chromebooks. Signed-off-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk> Cc: Marek Szyprowski <m.szyprowski@samsung.com> Cc: Chanwoo Choi <cw00.choi@samsung.com> Cc: Doug Anderson <dianders@chromium.org> Cc: Olof Johansson <olof@lixom.net> Cc: Kevin Hilman <khilman@linaro.org> Cc: Tyler Baker <tyler.baker@linaro.org> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-03-28drm: Don't assign fbs for universal cursor support to filesChris Wilson
[ Upstream commit 9a6f5130143c17b91e0a3cbf5cc2d8c1e5a80a63 ] The internal framebuffers we create to remap legacy cursor ioctls to plane operations for the universal plane support shouldn't be linke to the file like normal userspace framebuffers. This bug goes back to the original universal cursor plane support introduced in commit 161d0dc1dccb17ff7a38f462c7c0d4ef8bcc5662 Author: Matt Roper <matthew.d.roper@intel.com> Date: Tue Jun 10 08:28:10 2014 -0700 drm: Support legacy cursor ioctls via universal planes when possible (v4) The isn't too disastrous since fbs are small, we only create one when the cursor bo gets changed and ultimately they'll be reaped when the window server restarts. Conceptually we'd want to just pass NULL for file_priv when creating it, but the driver needs the file to lookup the underlying buffer object for cursor id. Instead let's move the file_priv linking out of add_framebuffer_internal() into the addfb ioctl implementation, which is the only place it is needed. And also rename the function for a more accurate since it only creates the fb, but doesn't add it anywhere. Signed-off-by: Daniel Vetter <daniel.vetter@intel.com> (fix & commit msg) Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> (provider of lipstick) Reviewed-by: Matt Roper <matthew.d.roper@intel.com> Cc: Ville Syrjälä <ville.syrjala@linux.intel.com> Cc: Matt Roper <matthew.d.roper@intel.com> Cc: Rob Clark <robdclark@gmail.com> Cc: stable@vger.kernel.org Signed-off-by: Dave Airlie <airlied@redhat.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-03-28drm/vmwgfx: Fix a couple of lock dependency violationsThomas Hellstrom
[ Upstream commit 5151adb37a5918957f4c33a8d8e7629c0fb00563 ] Experimental lockdep annotation added to the TTM lock has unveiled a couple of lock dependency violations in the vmwgfx driver. In both cases it turns out that the device_private::reservation_sem is not needed so the offending code is moved out of that lock. Cc: <stable@vger.kernel.org> Acked-by: Sinclair Yeh <syeh@vmware.com> Signed-off-by: Thomas Hellstrom <thellstrom@vmware.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-03-28drm/vmwgfx: Reorder device takedown somewhatThomas Hellstrom
[ Upstream commit 3458390b9f0ba784481d23134798faee27b5f16f ] To take down the MOB and GMR memory types, the driver may have to issue fence objects and thus make sure that the fence manager is taken down after those memory types. Reorder device init accordingly. Cc: <stable@vger.kernel.org> Signed-off-by: Thomas Hellstrom <thellstrom@vmware.com> Reviewed-by: Sinclair Yeh <syeh@vmware.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-03-28Revert "i2c: core: Dispose OF IRQ mapping at client removal time"Jakub Kicinski
[ Upstream commit a49445727014216703a3c28ccee4cef36d41571e ] This reverts commit e4df3a0b6228 ("i2c: core: Dispose OF IRQ mapping at client removal time") Calling irq_dispose_mapping() will destroy the mapping and disassociate the IRQ from the IRQ chip to which it belongs. Keeping it is OK, because existent mappings are reused properly. Also, this commit breaks drivers using devm* for IRQ management on OF-based systems because devm* cleanup happens in device code, after bus's remove() method returns. Signed-off-by: Jakub Kicinski <kubakici@wp.pl> Reported-by: Sébastien Szymanski <sebastien.szymanski@armadeus.com> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Acked-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> [wsa: updated the commit message with findings fromt the other bug report] Signed-off-by: Wolfram Sang <wsa@the-dreams.de> Cc: stable@kernel.org Fixes: e4df3a0b6228 Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-03-28nilfs2: fix deadlock of segment constructor during recoveryRyusuke Konishi
[ Upstream commit 283ee1482f349d6c0c09dfb725db5880afc56813 ] According to a report from Yuxuan Shui, nilfs2 in kernel 3.19 got stuck during recovery at mount time. The code path that caused the deadlock was as follows: nilfs_fill_super() load_nilfs() nilfs_salvage_orphan_logs() * Do roll-forwarding, attach segment constructor for recovery, and kick it. nilfs_segctor_thread() nilfs_segctor_thread_construct() * A lock is held with nilfs_transaction_lock() nilfs_segctor_do_construct() nilfs_segctor_drop_written_files() iput() iput_final() write_inode_now() writeback_single_inode() __writeback_single_inode() do_writepages() nilfs_writepage() nilfs_construct_dsync_segment() nilfs_transaction_lock() --> deadlock This can happen if commit 7ef3ff2fea8b ("nilfs2: fix deadlock of segment constructor over I_SYNC flag") is applied and roll-forward recovery was performed at mount time. The roll-forward recovery can happen if datasync write is done and the file system crashes immediately after that. For instance, we can reproduce the issue with the following steps: < nilfs2 is mounted on /nilfs (device: /dev/sdb1) > # dd if=/dev/zero of=/nilfs/test bs=4k count=1 && sync # dd if=/dev/zero of=/nilfs/test conv=notrunc oflag=dsync bs=4k count=1 && reboot -nfh < the system will immediately reboot > # mount -t nilfs2 /dev/sdb1 /nilfs The deadlock occurs because iput() can run segment constructor through writeback_single_inode() if MS_ACTIVE flag is not set on sb->s_flags. The above commit changed segment constructor so that it calls iput() asynchronously for inodes with i_nlink == 0, but that change was imperfect. This fixes the another deadlock by deferring iput() in segment constructor even for the case that mount is not finished, that is, for the case that MS_ACTIVE flag is not set. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Reported-by: Yuxuan Shui <yshuiv7@gmail.com> Tested-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-03-28regulator: core: Fix enable GPIO reference countingDoug Anderson
[ Upstream commit 29d62ec5f87fbeec8413e2215ddad12e7f972e4c ] Normally _regulator_do_enable() isn't called on an already-enabled rdev. That's because the main caller, _regulator_enable() always calls _regulator_is_enabled() and only calls _regulator_do_enable() if the rdev was not already enabled. However, there is one caller of _regulator_do_enable() that doesn't check: regulator_suspend_finish(). While we might want to make regulator_suspend_finish() behave more like _regulator_enable(), it's probably also a good idea to make _regulator_do_enable() robust if it is called on an already enabled rdev. At the moment, _regulator_do_enable() is _not_ robust for already enabled rdevs if we're using an ena_pin. Each time _regulator_do_enable() is called for an rdev using an ena_pin the reference count of the ena_pin is incremented even if the rdev was already enabled. This is not as intended because the ena_pin is for something else: for keeping track of how many active rdevs there are sharing the same ena_pin. Here's how the reference counting works here: * Each time _regulator_enable() is called we increment rdev->use_count, so _regulator_enable() calls need to be balanced with _regulator_disable() calls. * There is no explicit reference counting in _regulator_do_enable() which is normally just a warapper around rdev->desc->ops->enable() with code for supporting delays. It's not expected that the "ops->enable()" call do reference counting. * Since regulator_ena_gpio_ctrl() does have reference counting (handling the sharing of the pin amongst multiple rdevs), we shouldn't call it if the current rdev is already enabled. Note that as part of this we cleanup (remove) the initting of ena_gpio_state in regulator_register(). In _regulator_do_enable(), _regulator_do_disable() and _regulator_is_enabled() is is clear that ena_gpio_state should be the state of whether this particular rdev has requested the GPIO be enabled. regulator_register() was initting it as the actual state of the pin. Fixes: 967cfb18c0e3 ("regulator: core: manage enable GPIO list") Signed-off-by: Doug Anderson <dianders@chromium.org> Signed-off-by: Mark Brown <broonie@kernel.org> Cc: stable@vger.kernel.org Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-03-28regulator: Only enable disabled regulators on resumeJavier Martinez Canillas
[ Upstream commit 0548bf4f5ad6fc3bd93c4940fa48078b34609682 ] The _regulator_do_enable() call ought to be a no-op when called on an already-enabled regulator. However, as an optimization _regulator_enable() doesn't call _regulator_do_enable() on an already enabled regulator. That means we never test the case of calling _regulator_do_enable() during normal usage and there may be hidden bugs or warnings. We have seen warnings issued by the tps65090 driver and bugs when using the GPIO enable pin. Let's match the same optimization that _regulator_enable() in regulator_suspend_finish(). That may speed up suspend/resume and also avoids exposing hidden bugs. [Use much clearer commit message from Doug Anderson] Signed-off-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk> Signed-off-by: Mark Brown <broonie@kernel.org> Cc: stable@vger.kernel.org Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-03-28regulator: rk808: Set the enable time for LDOsDoug Anderson
[ Upstream commit 28249b0c2fa361cdac450a6f40242ed45408a24f ] The LDOs are documented in the rk808 datasheet to have a soft start time of 400us. Add that to the driver. If this time takes longer on a certain board the device tree should be able to override with "regulator-enable-ramp-delay". This fixes some dw_mmc probing problems (together with other patches posted to the mmc maiing lists) on rk3288. Signed-off-by: Doug Anderson <dianders@chromium.org> Signed-off-by: Mark Brown <broonie@kernel.org> Cc: stable@vger.kernel.org Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-03-28bnx2x: Force fundamental reset for EEH recoveryBrian King
[ Upstream commit da293700568ed3d96fcf062ac15d7d7c41377f11 ] EEH recovery for bnx2x based adapters is not reliable on all Power systems using the default hot reset, which can result in an unrecoverable EEH error. Forcing the use of fundamental reset during EEH recovery fixes this. Cc: stable<stable@vger.kernel.org> Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-03-28mtd: nand: pxa3xx: Fix PIO FIFO drainingMaxime Ripard
[ Upstream commit 8dad0386b97c4bd6edd56752ca7f2e735fe5beb4 ] The NDDB register holds the data that are needed by the read and write commands. However, during a read PIO access, the datasheet specifies that after each 32 bytes read in that register, when BCH is enabled, we have to make sure that the RDDREQ bit is set in the NDSR register. This fixes an issue that was seen on the Armada 385, and presumably other mvebu SoCs, when a read on a newly erased page would end up in the driver reporting a timeout from the NAND. Cc: <stable@vger.kernel.org> # v3.14 Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Reviewed-by: Boris Brezillon <boris.brezillon@free-electrons.com> Acked-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com> Signed-off-by: Brian Norris <computersforpeace@gmail.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-03-28ALSA: hda - Treat stereo-to-mono mix properlyTakashi Iwai
[ Upstream commit cc261738add93947d138d2fabad9f4dbed4e5c00 ] The commit [ef403edb7558: ALSA: hda - Don't access stereo amps for mono channel widgets] fixed the handling of mono widgets in general, but it still misses an exceptional case: namely, a mono mixer widget taking a single stereo input. In this case, it has stereo volumes although it's a mono widget, and thus we have to take care of both left and right input channels, as stated in HD-audio spec ("7.1.3 Widget Interconnection Rules"). This patch covers this missing piece by adding proper checks of stereo amps in both the generic parser and the proc output codes. Reported-by: Raymond Yau <superquad.vortex2@gmail.com> Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-03-28ALSA: hda - Fix regression of HD-audio controller fallback modesTakashi Iwai
[ Upstream commit a1f3f1ca66bd12c339b17a0c2ef93a093f90a277 ] The commit [63e51fd708f5: ALSA: hda - Don't take unresponsive D3 transition too serious] introduced a conditional fallback behavior to the HD-audio controller depending on the flag set. However, it introduced a silly bug, too, that the flag was evaluated in a reverse way. This resulted in a regression of HD-audio controller driver where it can't go to the fallback mode at communication errors. Unfortunately (or fortunately?) this didn't come up until recently because the affected code path is an error handling that happens only on an unstable hardware chip. Most of recent chips work stably, thus they didn't hit this problem. Now, we've got a regression report with a VIA chip, and this seems indeed requiring the fallback to the polling mode, and finally the bug was revealed. The fix is a oneliner to remove the wrong logical NOT in the check. (Lesson learned - be careful about double negation.) The bug should be backported to stable, but the patch won't be applicable to 3.13 or earlier because of the code splits. The stable fix patches for earlier kernels will be posted later manually. Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=94021 Fixes: 63e51fd708f5 ('ALSA: hda - Don't take unresponsive D3 transition too serious') Cc: <stable@vger.kernel.org> # v3.14+ Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-03-28ALSA: hda - Add workaround for MacBook Air 5,2 built-in micTakashi Iwai
[ Upstream commit 2ddee91abe9cc34ddb6294ee14702b46ae07d460 ] MacBook Air 5,2 has the same problem as MacBook Pro 8,1 where the built-in mic records only the right channel. Apply the same workaround as MBP8,1 to spread the mono channel via a Cirrus codec vendor-specific COEF setup. Reported-and-tested-by: Vasil Zlatanov <vasil.zlatanov@gmail.com> Cc: <stable@vger.kernel.org> # 3.9+ Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-03-28ALSA: hda - Set single_adc_amp flag for CS420x codecsTakashi Iwai
[ Upstream commit bad994f5b4ab57eec8d56c180edca00505c3eeb2 ] CS420x codecs seem to deal only the single amps of ADC nodes even though the nodes receive multiple inputs. This leads to the inconsistent amp value after S3/S4 resume, for example. The fix is just to set codec->single_adc_amp flag. Then the driver handles these ADC amps as if single connections. Reported-and-tested-by: Vasil Zlatanov <vasil.zlatanov@gmail.com> Cc: <stable@vger.kernel.org> # 3.9+ Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-03-28ALSA: hda - Don't access stereo amps for mono channel widgetsTakashi Iwai
[ Upstream commit ef403edb75580a3ec5d155f5de82155f0419c621 ] The current HDA generic parser initializes / modifies the amp values always in stereo, but this seems causing the problem on ALC3229 codec that has a few mono channel widgets: namely, these mono widgets react to actions for both channels equally. In the driver code, we do care the mono channel and create a control only for the left channel (as defined in HD-audio spec) for such a node. When the control is updated, only the left channel value is changed. However, in the resume, the right channel value is also restored from the initial value we took as stereo, and this overwrites the left channel value. This ends up being the silent output as the right channel has been never touched and remains muted. This patch covers the places where unconditional stereo amp accesses are done and converts to the conditional accesses. Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=94581 Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-03-28ALSA: hda - Fix built-in mic on Compaq Presario CQ60Takashi Iwai
[ Upstream commit ddb6ca75b5671b8fbf1909bc588c449ee74b34f9 ] Compaq Presario CQ60 laptop with CX20561 gives a wrong pin for the built-in mic NID 0x17 instead of NID 0x1d, and it results in the non-working mic. This patch just remaps the pin correctly via fixup. Bugzilla: https://bugzilla.opensuse.org/show_bug.cgi?id=920604 Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-03-28ALSA: control: Add sanity checks for user ctl id name stringTakashi Iwai
[ Upstream commit be3bb8236db2d0fcd705062ae2e2a9d75131222f ] There was no check about the id string of user control elements, so we accepted even a control element with an empty string, which is obviously bogus. This patch adds more sanity checks of id strings. Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-03-28ALSA: snd-usb: add quirks for Roland UA-22Daniel Mack
[ Upstream commit fcdcd1dec6d2c7b718385ec743ae5a9a233edad4 ] The device complies to the UAC1 standard but hides that fact with proprietary descriptors. The autodetect quirk for Roland devices catches the audio interface but misses the MIDI part, so a specific quirk is needed. Signed-off-by: Daniel Mack <daniel@zonque.org> Reported-by: Rafa Lafuente <rafalafuente@gmail.com> Tested-by: Raphaël Doursenaud <raphael@doursenaud.fr> Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-03-28spi: pl022: Fix race in giveback() leading to driver lock-upAlexander Sverdlin
[ Upstream commit cd6fa8d2ca53cac3226fdcffcf763be390abae32 ] Commit fd316941c ("spi/pl022: disable port when unused") introduced a race, which leads to possible driver lock up (easily reproducible on SMP). The problem happens in giveback() function where the completion of the transfer is signalled to SPI subsystem and then the HW SPI controller is disabled. Another transfer might be setup in between, which brings driver in locked-up state. Exact event sequence on SMP: core0 core1 => pump_transfers() /* message->state == STATE_DONE */ => giveback() => spi_finalize_current_message() => pl022_unprepare_transfer_hardware() => pl022_transfer_one_message => flush() => do_interrupt_dma_transfer() => set_up_next_transfer() /* Enable SSP, turn on interrupts */ writew((readw(SSP_CR1(pl022->virtbase)) | SSP_CR1_MASK_SSE), SSP_CR1(pl022->virtbase)); ... => pl022_interrupt_handler() => readwriter() /* disable the SPI/SSP operation */ => writew((readw(SSP_CR1(pl022->virtbase)) & (~SSP_CR1_MASK_SSE)), SSP_CR1(pl022->virtbase)); Lockup! SPI controller is disabled and the data will never be received. Whole SPI subsystem is waiting for transfer ACK and blocked. So, only signal transfer completion after disabling the controller. Fixes: fd316941c (spi/pl022: disable port when unused) Signed-off-by: Alexander Sverdlin <alexander.sverdlin@nokia.com> Signed-off-by: Mark Brown <broonie@kernel.org> Cc: stable@vger.kernel.org Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-03-28spi: dw-mid: avoid potential NULL dereferenceAndy Shevchenko
[ Upstream commit c9dafb27c84412fe4b17c3b94cc4ffeef5df1833 ] When DMA descriptor allocation fails we should not try to assign any fields in the bad descriptor. The patch adds the necessary checks for that. Fixes: 7063c0d942a1 (spi/dw_spi: add DMA support) Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Mark Brown <broonie@kernel.org> Cc: stable@vger.kernel.org Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-03-28spi: atmel: Fix interrupt setup for PDC transfersTorsten Fleischer
[ Upstream commit 76e1d14b316d6f501ebc001e7a5d86b24ce5b615 ] Additionally to the current DMA transfer the PDC allows to set up a next DMA transfer. This is useful for larger SPI transfers. The driver currently waits for ENDRX as end of the transfer. But ENDRX is set when the current DMA transfer is done (RCR = 0), i.e. it doesn't include the next DMA transfer. Thus a subsequent SPI transfer could be started although there is currently a transfer in progress. This can cause invalid accesses to the SPI slave devices and to SPI transfer errors. This issue has been observed on a hardware with a M25P128 SPI NOR flash. So instead of ENDRX we should wait for RXBUFF. This flag is set if there is no more DMA transfer in progress (RCR = RNCR = 0). Signed-off-by: Torsten Fleischer <torfl6749@gmail.com> Signed-off-by: Mark Brown <broonie@kernel.org> Cc: stable@vger.kernel.org Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-03-28tpm/tpm_i2c_stm_st33: Add status check when reading data on the FIFOChristophe Ricard
[ Upstream commit c4eadfafb91d5501095c55ffadaa1168743f39d3 ] Add a return value check when reading data from the FIFO register. Cc: <stable@vger.kernel.org> Reviewed-by: Jason Gunthorpe <jason.gunthorpe@obsidianresearch.com> Signed-off-by: Christophe Ricard <christophe-h.ricard@st.com> Reviewed-by: Peter Huewe <peterhuewe@gmx.de> Signed-off-by: Peter Huewe <peterhuewe@gmx.de> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-03-28tpm/ibmvtpm: Additional LE support for tpm_ibmvtpm_sendjmlatten@linux.vnet.ibm.com
[ Upstream commit 62dfd912ab3b5405b6fe72d0135c37e9648071f1 ] Problem: When IMA and VTPM are both enabled in kernel config, kernel hangs during bootup on LE OS. Why?: IMA calls tpm_pcr_read() which results in tpm_ibmvtpm_send and tpm_ibmtpm_recv getting called. A trace showed that tpm_ibmtpm_recv was hanging. Resolution: tpm_ibmtpm_recv was hanging because tpm_ibmvtpm_send was sending CRQ message that probably did not make much sense to phype because of Endianness. The fix below sends correctly converted CRQ for LE. This was not caught before because it seems IMA is not enabled by default in kernel config and IMA exercises this particular code path in vtpm. Tested with IMA and VTPM enabled in kernel config and VTPM enabled on both a BE OS and a LE OS ppc64 lpar. This exercised CRQ and TPM command code paths in vtpm. Patch is against Peter's tpmdd tree on github which included Vicky's previous vtpm le patches. Signed-off-by: Joy Latten <jmlatten@linux.vnet.ibm.com> Cc: <stable@vger.kernel.org> # eb71f8a5e33f: "Added Little Endian support to vtpm module" Cc: <stable@vger.kernel.org> Reviewed-by: Ashley Lai <ashley@ahsleylai.com> Signed-off-by: Peter Huewe <peterhuewe@gmx.de> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-03-28cpuset: Fix cpuset sched_relax_domain_levelJason Low
[ Upstream commit 283cb41f426b723a0255702b761b0fc5d1b53a81 ] The cpuset.sched_relax_domain_level can control how far we do immediate load balancing on a system. However, it was found on recent kernels that echo'ing a value into cpuset.sched_relax_domain_level did not reduce any immediate load balancing. The reason this occurred was because the update_domain_attr_tree() traversal did not update for the "top_cpuset". This resulted in nothing being changed when modifying the sched_relax_domain_level parameter. This patch is able to address that problem by having update_domain_attr_tree() allow updates for the root in the cpuset traversal. Fixes: fc560a26acce ("cpuset: replace cpuset->stack_list with cpuset_for_each_descendant_pre()") Cc: <stable@vger.kernel.org> # 3.9+ Signed-off-by: Jason Low <jason.low2@hp.com> Signed-off-by: Zefan Li <lizefan@huawei.com> Signed-off-by: Tejun Heo <tj@kernel.org> Tested-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-03-28cpuset: fix a warning when clearing configured masks in old hierarchyZefan Li
[ Upstream commit 79063bffc81f82689bd90e16da1b49408f3bf095 ] When we clear cpuset.cpus, cpuset.effective_cpus won't be cleared: # mount -t cgroup -o cpuset xxx /mnt # mkdir /mnt/tmp # echo 0 > /mnt/tmp/cpuset.cpus # echo > /mnt/tmp/cpuset.cpus # cat cpuset.cpus # cat cpuset.effective_cpus 0-15 And a kernel warning in update_cpumasks_hier() is triggered: ------------[ cut here ]------------ WARNING: CPU: 0 PID: 4028 at kernel/cpuset.c:894 update_cpumasks_hier+0x471/0x650() Cc: <stable@vger.kernel.org> # 3.17+ Signed-off-by: Zefan Li <lizefan@huawei.com> Signed-off-by: Tejun Heo <tj@kernel.org> Tested-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
