If poweroff takes a bit more time (e.g. due to I2C call), it is
quite likely that another timer interrupt fires. Timer interrupt
get broadcasted through the timer interrupt callback
tick_handle_oneshot_broadcast. This code broadcasts the timer
interrupt to all CPU's in tick_broadcast_oneshot_mask. The only
function which removes CPU from this mask is
tick_shutdown_broadcast_oneshot which ultimately get called by
_cpu_down (in kernel/cpu.c). The function disable_nonboot_cpus
makes sure that the CPU's get properly taken down and _cpu_down
gets called. With that no more broadcasts are sent to CPU's which
are no longer online.
Use the PMIC repower capabilities to reboot the module. Register
arm_pm_restart to trigger a cold reboot using the PMIC.
The Colibri iMX7 uses the SNVS_PMIC_ON_REQ signal (connected to the
PMIC's PMIC_ON_EXTIN GPIO) to power off the module. The SNVS RTC
driver provides a poweroff callback which causes that signal to
go low. However, the current PMIC driver registers a poweroff
callback earlier and therefor the kernel uses the PMIC poweroff
instead of the SNVS RTC poweroff callback.
Disable SNVS power key functionality by default for Colibri i.MX 7
modules. The SNVS power key uses the ONOFF signal, which is directly
controlled by reset and therefor not really a power key available
to the user.
Follow commit 286098c029bda740822e68ba6ac2ba0b2fe7c5d3
GPIO number 0 *is* legal and must be accepted.
Set .ena_gpio to -ENODEV on regulators having no GPIO in preparation
of a code change to accept GPIO 0 in the config.
Both drivers, FB_MXS and IPUv3 use functionality from mxc_dispdrv.c.
Allow for a configuartion which builds only FB_MXS.
Allow for a build targeting iMX 7 devices without relying on configuration
from i.MX6 and friends.
Add workaround for M4 NMI issue.
Set the Ethernet PHY reference clock to be generated externaly from
the i.MX 7 by default (Colibri i.MX 7 V1.1 sample batch)
The i.MX 7 can provide a reference clock to the PHY or use a reference clock
from an external circuit.
If the device-tree node with compatible "fsl,imx7d-fec" has a clock named
enet_out then provide the clock from the i.MX 7, if such a clock is missing
use a clock provided from an external circuit.
Without MCLK the sgtl5000 does not answer I2C reads.
So defere probing to later if no sgtl5000 is found.
The PIXDATA flags of the display_flags enum are controller centric,
e.g. NEGEDGE means the controller shall drive the data signals on
pixelclocks negative edge. However, the drivers flag is display
centric: Sample the data on negative (falling) edge.
Therefore, change the if statement to check for the POSEDGE flag
(which is typically not set):
Drive on positive edge => sample on negative edge
Add device tree node for resistive touch screen controller AD7879.
Add device tree support to the I2C variant of AD7879 (AD7879-1). This
allows to specify the touchscreen controller as a I2C client node.
Most of the options available as platform data are also available as
device tree nodes.
The measurements read from the controller which are temporarly stored
in conversion_data, are interpreted wrong. The first measurement X+
contains the Y position, and the second measurement Y+ the X position
(see also Table 11 Register Table in the data sheet).
The problem is already known, the change 6680884a4420 ("Input: ad7879
- add option to correct xy axis") introduced a swap option. However,
the meaning of this boolean was inverted since the underlaying values
were already swapped. With this change, swap_xy = true actually swaps
the two axis.
Add TCM and OCRAM specifications required by the PM code,
otherwise booting Linux will fail in imx7d_pm_init.
Also add mcctest, mcctty and rpmsg nodes required to enable
rpmsg based communciation examples between the two cores.
The USB charger functionality depends on functions provided by
CONFIG_POWER_SUPPLY but this dependency is not forced through Kconfig.
Don't compile the functionality in when CONFIG_POWER_SUPPLY is not set.
This fixes linker errors of not found symbols.
power_supply_changed
power_supply_register
power_supply_unregister
If IPG clock of the GPC block is missing, we won't be able to get
the IPG bus clock later on. Return with an error if the IPG clock
is missing.
[exit with error on missing IPG clock]
By configure runtime PM prior we enable the use of it, we close the gap
for strange and unhandled conditions. Moreover it makes us rely on the
driver core, after finalized ->probe(), to request an inactive device
to become runtime PM idle/suspended, which earlier potentially could
happen already at pm_runtime_set_autosuspend_delay().
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
(cherry picked from commit 77903c01d8c6c5d2544085ba074aceadc1191d21)
Enable output driver of Ethernet reference clock.
Do not include MXC V4L2 capture drivers for now, they cause
compile time errors:
| ERROR: "foreground_sdc_deselect" [drivers/media/platform/mxc/capture/mxc_v4l2_capture.ko] undefined!
| ERROR: "bg_overlay_sdc_deselect" [drivers/media/platform/mxc/capture/mxc_v4l2_capture.ko] undefined!
| ERROR: "bg_overlay_sdc_select" [drivers/media/platform/mxc/capture/mxc_v4l2_capture.ko] undefined!
| ERROR: "foreground_sdc_select" [drivers/media/platform/mxc/capture/mxc_v4l2_capture.ko] undefined!
MX7D_PAD_UART2_TX_DATA__UART2_DTE_RX was missing the daisychain register
address and value resulting in a non working RX path.
This adds support for Ricoh RN5T567 PMIC used on Colibri iMX7. The
driver should get unified with rn5t618 driver.
This adds a driver for the watchdog timer available in Ricoh RN5T618
PMIC. The device supports a programmable expiration time of 1, 8, 32
or 128 seconds.
Signed-off-by: Beniamino Galvani <b.galvani@gmail.com>
Reviewed-by: Guenter Roeck <linux@roeck-us.net>
Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
(cherry picked from commit 22b1c841e31510c3124c88a13b8a7ada14e2e2d1)
Ricoh RN5T618 is a power management IC which integrates 3 step-down
DCDC converters, 7 low-dropout regulators, a Li-ion battery charger,
fuel gauge, ADC, GPIOs and a watchdog timer.
This commit adds a MFD core driver to support the I2C communication
with the device.
Signed-off-by: Lee Jones <lee.jones@linaro.org>
(cherry picked from commit 9bb9e29c78f8d8ee310987fd58a2b908a4ce0c40)
This adds the device tree bindings documentation for Ricoh RN5T618.
Reviewed-by: Mark Brown <broonie@linaro.org>
(cherry picked from commit a654f81640caa0bb648b0e45b792ba846c9bb02d)
This driver supports the 3 DCDC and 7 LDO regulators available on
Ricoh RN5T618 PMIC.
Signed-off-by: Mark Brown <broonie@kernel.org>
(cherry picked from commit 811b700630ff328c52ddf17d653ffdcb0ba87d30)
drivers/regulator/Kconfig
drivers/regulator/Makefile
This reverts commit 87b3f4287b8a9d31ad4d732fac769d97dcf7469a.
Has been fixed upstream differently
3241216e250430a27b30eaf7f7df3e5e006acfb5
According to the datasheet the SPI clock (for read) must not exceed
1 / 55ns for i.MX6Q/D and 1 / 43ns for i.MX6DL/S.
Reflect that correctly in the device tree.
The backport of the extcon subsystem also brought a new field in
the of node structure. Set it correctly or code using it will
think the node comes from ACPI, not from a device-tree.
Fixes gpio-leds which otherwise would not find the gpios from the
device tree.
Synchronize with imx6dl-colibri-eval-v3.dts.
Compile USB device classes such as WDM and CDC ACM as modules.
Enable FTDI USB-to-serial adapter chips and serial console which
allows to use USB serial device drivers as a serial console at
boot time. Compile USB driver for GSM and CDMA modems (Option and
others) as a module.
If the UART is in DTE mode, the signals DCD and RI are inputs. In
this case, the control bits in UCR3_DCD and UCR3_RI control the
interrupt of those two inputs. The two bits are 1 on reset, hence
leading to an interrupt if one of those signal changes... However,
as of now the interrupt handler does not handle these interrupts,
leading to a interrupt strom.
Solve the issue by explicitly disabling the two interrupts during
initialization.
The invalid value of #address-cells in the imx6 pcie host controller node
causes of_irq_parse_raw() to incorrectly advance through an interrupt-map
table of more than one interrupt. We also take the opportunity to drop the
unused #size-cells here.
This patch resolves this issue and allows proper interrupt mapping for an
imx6 pcie host connected to a P2P bridge when using legacy interrupts.
Signed-off-by: Tim Harvey <tharvey@gateworks.com>
Cc: Jason Gunthorpe <jgunthorpe@obsidianresearch.com>
Cc: Jingoo Han <jg1.han@samsung.com>
Cc: Lucas Stach <l.stach@pengutronix.de>
Cc: Mark Rutland <mark.rutland@arm.com>
Cc: linux-samsung-soc <linux-samsung-soc@vger.kernel.org>
Cc: Richard Zhu <r65037@freescale.com>
Cc: Sascha Hauer <kernel@pengutronix.de>
Cc: Stephen Warren <swarren@wwwdotorg.org>
Cc: Bjorn Helgaas <bhelgaas@google.com>
Cc: Simon Horman <horms@verge.net.au>
Cc: Thierry Reding <thierry.reding@gmail.com>
Cc: Ben Dooks <ben-linux@fluff.org>
Cc: linux-tegra <linux-tegra@vger.kernel.org>
Cc: Kukjin Kim <kgene.kim@samsung.com>
Cc: Shawn Guo <shawn.guo@linaro.org>
Cc: Grant Likely <grant.likely@linaro.org>
The Apalis evaluation board needs to set the link speed to 2.5 GT/s
(GEN1). The default link speed setting is 5 GT/s (GEN2). 0x98 is the
Link Control 2 PCIe Capability Register of the PEX8605 PCIe switch.
The switch supports link speed auto negotiation, but falsely sets the
link speed to 5 GT/s.
This stream-lines the drive strength pad settings across both the MMC
and the SD slots.
This adds explicit okay status' to adv7180 and max9526 nodes to be more
in-line with the Evaluation board device-tree.
Please note that this does not have any functional effect as by default
any node is enabled anyway.
This fixes the Ethernet PHY reset and interrupt handling.
Clarify exact Apalis iMX6Q/D module type and Ixora carrier board in
model node.
While at it also make sure the compatible node fits into 80 char length
lines.
This fixes PCIe EP device self-initialisation in case only a regular
reset EP GPIO is used as PERST# which is e.g. the case on our Ixora
carrier board by always waiting 20 milliseconds after releasing PERST#.
