Signed-off-by: Rolf Eike Beer <eb@emlix.com>
Causes build failures with gcc 8.
u
This fixes breakage to iproute2 build with recent kernel headers
caused by:
commit a263653ed798216c0069922d7b5237ca49436007
Author: Pablo Neira Ayuso <pablo@netfilter.org>
Date: Wed Jun 17 10:28:27 2015 -0500
netfilter: don't pull include/linux/netfilter.h from netns headers
The issue is that definitions in linux/in.h overlap with those
in netinet/in.h. This patch solves this by introducing the same
mechanism as was used to solve the same problem with linux/in6.h
Signed-off-by: Stephen Hemminger <stephen@networkplumber.org>
(cherry picked from commit 279c6c7fa64f5763e6b9f05e7ab3840092e702e7)
Resolve conflicts between glibc definition of IPV6 socket options
and those defined in Linux headers. Looks like earlier efforts to
solve this did not cover all the definitions.
It resolves warnings during iproute2 build.
Please consider for stable as well.
Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
(cherry picked from commit 6d08acd2d32e3e877579315dc3202d7a5f336d98)
Solution:
- Synchronize linux's `include/uapi/linux/in6.h'
with glibc's `inet/netinet/in.h'.
- Synchronize glibc's `inet/netinet/in.h with linux's
`include/uapi/linux/in6.h'.
- Allow including the headers in either other.
- First header included defines the structures and macros.
Details:
The kernel promises not to break the UAPI ABI so I don't
see why we can't just have the two userspace headers
coordinate?
If you include the kernel headers first you get those,
and if you include the glibc headers first you get those,
and the following patch arranges a coordination and
synchronization between the two.
Let's handle `include/uapi/linux/in6.h' from linux,
and `inet/netinet/in.h' from glibc and ensure they compile
in any order and preserve the required ABI.
These two patches pass the following compile tests:
cat >> test1.c <<EOF
int main (void) {
return 0;
EOF
gcc -c test1.c
cat >> test2.c <<EOF
int main (void) {
return 0;
EOF
gcc -c test2.c
One wrinkle is that the kernel has a different name for one of
the members in ipv6_mreq. In the kernel patch we create a macro
to cover the uses of the old name, and while that's not entirely
clean it's one of the best solutions (aside from an anonymous
union which has other issues).
I've reviewed the code and it looks to me like the ABI is
assured and everything matches on both sides.
Notes:
- You want netinet/in.h to include bits/in.h as early as possible,
but it needs in_addr so define in_addr early.
- You want bits/in.h included as early as possible so you can use
the linux specific code to define __USE_KERNEL_DEFS based on
the _UAPI_* macro definition and use those to cull in.h.
- glibc was missing IPPROTO_MH, added here.
Compile tested and inspected.
Reported-by: Thomas Backlund <tmb@mageia.org>
Cc: Thomas Backlund <tmb@mageia.org>
Cc: libc-alpha@sourceware.org
Cc: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
Tested-by: Cong Wang <amwang@redhat.com>
Signed-off-by: Carlos O'Donell <carlos@redhat.com>
Signed-off-by: Cong Wang <amwang@redhat.com>
(cherry picked from commit cfd280c91253cc28e4919e349fa7a813b63e71e8)
Previously, lvds-drive-strength was located in a wrong node and
there was no control of the 5th lane.
The current reset-gpio support triggers an interrupt storm on platforms
using the maxtouch with level based interrupt. The Motorola Droid 4,
which I used for some of the tests is not affected, since it uses a edge
based interrupt.
This change avoids the interrupt storm by enabling the device while its
interrupt is disabled. Afterwards we wait 100ms. This is important for
two reasons: The device is unresponsive for some time (~22ms for
mxt224E) and the CHG (interrupt) line is not working properly for 100ms.
We don't need to wait for any following interrupts, since the following
mxt_initialize() checks for bootloader mode anyways.
This fixes a boot issue on GE PPD (watchdog kills device due to
interrupt storm) and does not cause regression on Motorola Droid 4.
Fixes: f657b00df22e ("Input: atmel_mxt_ts - add support for reset line")
Signed-off-by: Sebastian Reichel <sebastian.reichel@collabora.co.uk>
Reviewed-by: Pavel Machek <pavel@ucw.cz>
(cherry picked from commit ca1cd36cef00260db6b35b32d863e0c580c0488d)
Align with mainline Atmel MXT driver.
Provide support for controlling reset pin. If this is not driven
correctly the device will be held in reset and will not respond.
Acked-by: Rob Herring <robh@kernel.org>
(cherry picked from commit f657b00df22e231da217ca0162a75db452475e8f)
Switch mxt_data and interrupt to resource managed allocation methods,
which cleans up the driver slightly and prepares for adding
reset GPIO support.
(cherry picked from commit 8cc8446b9b62ef954b630ed30e53bd1553e916a6)
When using the 'object' sysfs attribute, T100 is not displayed in
the output.
Signed-off-by: Maxime Roussin-Bélanger <maxime.roussinbelanger@gmail.com>
(cherry picked from commit 089b50d95948f691589cca4d81f1f8761747dbaa)
If a function declares a variable to access a structure element,
use it consistently.
(cherry picked from commit d7ddf15414dd598b9b875664e6b7aebe6c988f5d)
This reverts commit 22a2065b9a3fa6ad458e3100b66c4acaa05f2466.
Before SIOCGMIIREG was only able to access page 0 registers.
/build/krm/oe-core_master/build/tmp-glibc/work-shared/apalis-tk1/kernel-source/drivers/video/tegra/host/bus_client.c: In function 'nvhost_channelctl':
/build/krm/oe-core_master/build/tmp-glibc/work-shared/apalis-tk1/kernel-source/drivers/video/tegra/host/bus_client.c:894:11: error: 'snprintf' output may be truncated before the last format character [-Werror=format-truncation=]
"%s_%s", dev_name(&pdata->pdev->dev), name);
/build/krm/oe-core_master/build/tmp-glibc/work-shared/apalis-tk1/kernel-source/drivers/video/tegra/host/bus_client.c:893:3: note: 'snprintf' output 2 or more bytes (assuming 33) into a destination of size 32
snprintf(set_name, sizeof(set_name),
Building kernels before linux-4.7 with gcc-8 results in many build failures
when gcc triggers a check that was meant to catch broken compilers:
/tmp/ccCGMQmS.s:648: Error: .err encountered
According to the discussion in the gcc bugzilla, a local "register
asm()" variable is still supposed to be the correct way to force an
inline assembly to use a particular register, but marking it 'const'
lets the compiler do optimizations that break that, i.e the compiler is
free to treat the variable as either 'const' or 'register' in that case.
Upstream commit 9f73bd8bb445 ("ARM: uaccess: remove put_user() code
duplication") fixed this problem in linux-4.8 as part of a larger change,
but seems a little too big to be backported to 4.4.
Let's take the simplest fix and change only the one broken line in the
same way as newer kernels.
Suggested-by: Bernd Edlinger <bernd.edlinger@hotmail.de>
Link: https://gcc.gnu.org/bugzilla/show_bug.cgi?id=85745
Link: https://gcc.gnu.org/bugzilla/show_bug.cgi?id=86673
(cherry picked from commit 0ca85fc310e8c24cba10ed241a0188795e177683)
/tmp/ccmcXtfu.s: Assembler messages:
/tmp/ccmcXtfu.s:1441: Error: .err encountered
arch/arm/include/asm/uaccess.h
gcc-7 has an "optimization" pass that completely screws up, and
generates the code expansion for the (impossible) case of calling
ilog2() with a zero constant, even when the code gcc compiles does not
actually have a zero constant.
And we try to generate a compile-time error for anybody doing ilog2() on
a constant where that doesn't make sense (be it zero or negative). So
now gcc7 will fail the build due to our sanity checking, because it
created that constant-zero case that didn't actually exist in the source
code.
There's a whole long discussion on the kernel mailing about how to work
around this gcc bug. The gcc people themselevs have discussed their
"feature" in
https://gcc.gnu.org/bugzilla/show_bug.cgi?id=72785
but it's all water under the bridge, because while it looked at one
point like it would be solved by the time gcc7 was released, that was
not to be.
So now we have to deal with this compiler braindamage.
And the only simple approach seems to be to just delete the code that
tries to warn about bad uses of ilog2().
So now "ilog2()" will just return 0 not just for the value 1, but for
any non-positive value too.
It's not like I can recall anybody having ever actually tried to use
this function on any invalid value, but maybe the sanity check just
meant that such code never made it out in public.
Reported-by: Laura Abbott <labbott@redhat.com>
Cc: John Stultz <john.stultz@linaro.org>,
Cc: Ard Biesheuvel <ard.biesheuvel@linaro.org>
(cherry picked from commit 474c90156c8dcc2fa815e6716cc9394d7930cb9c)
tools/include/linux/log2.h
File does not exist in the 3.1 kernel, change dropped.
This helps with the move to GCC 8.
| include/linux/log2.h:22:1: error: ignoring attribute 'noreturn' because it conflicts with attribute 'const' [-Werror=attributes]
| int ____ilog2_NaN(void);
In fw version 1.2 K20 CANINTF_TX now indicates TX in progress,
not TX completed.
Parameter fw_ignore disables fw version check.
Parameter fw_reload forces k20 firmware reflash via EzPort.
This adds a driver which simulates a i2c bus with an attached EDID
memory. The memory content is read from the device tree.
This allows to simulate EDID data which may differ from an attached
display.
Hardcoded value was used before. This allows setting
drive strength values in the devicetree.
Build SELinux support in kernel, but keep it disabled.
While the PCIe reset implementation seems to work it currently resets
multiple times due to not differentiating which PCIe port needs
resetting. Improve this by doing specific reset per port only.
Kernel hangs if camera capture errors are not handled to allow for a way
out of the the capture thread.
Signed-off-by: Gerard Salvatella <gerard.salvatella@toradex.com>
This commit adds support for the 2nd CSI Camera Module 5MP OV5640 with
SCCB_ID of 0x3d connected to Apalis TK1 Mezzanine V2.0A on X7 aka
CSI_3_CSI-2/4x.
Port retains dual function capability.
Peripheral mode supports only USB 2.0.
Now device trees for revision <1.2 and 1.2 use the same rcv-sel
on i2c3 (in NVIDIA's documentation known as i2c4).
Disable Tegra SE crypto dev as done in NVIDIA L4T R21.7.
Similar to commit a7e55a39cdd1 ("CRYPTO: disable crypto dev fot t124").
Currently building fails as follows due to an erroneous + sign in front
of an #endif in arch/arm/mm/fsr-3level.c:
In file included from /home/user/linux-3.10/arch/arm/mm/fault.c:554:0:
/home/user/linux-3.10/arch/arm/mm/fsr-3level.c:68:0:
error: unterminated #else
make[2]: *** [/home/user/linux-3.10/scripts/Makefile.build:308:
arch/arm/mm/fault.o] Error 1
This fixes commit de3110548b04 ("arm: Invalidate BTB on prefetch abort
outside of user mapping on Cortex A8, A9, A12 and A17").
Merge NVIDIA's latest Linux for Tegra aka L4T R21.7 Linux kernel changes
from git://nv-tegra.nvidia.com/linux-3.10.git commit:
e78bb38b883c42edf81766a1d557aed74458e08f
Conflicts involved missing 24-bit LVDS support and a single whitespace
aka tab difference in drivers/video/tegra/dc/sor.c.
** Not yet queued for inclusion in mainline **
In order to avoid aliasing attacks against the branch predictor,
some implementations require to invalidate the BTB when switching
from one user context to another.
For this, we reuse the existing implementation for Cortex-A8, and
apply it to A9, A12 and A17.
Change-Id: Ibbd99465a5dcf5eda6a29dd23a55f9b21b280e65
Reviewed-on: https://git-master.nvidia.com/r/1704129
GVS: Gerrit_Virtual_Submit
Reviewed-by: Bibek Basu <bbasu@nvidia.com>
Tested-by: Bibek Basu <bbasu@nvidia.com>
Data can be speculatively loaded from memory and stay in cache even
when bound check fails. This can lead to unintended information
disclosure via side-channel analysis.
To mitigate this problem, insert speculation barrier.
bug 2039126
CVE-2017-5753
Change-Id: Ifc618c00cee497e6d84cac01a9b73fcecbe8f260
Signed-off-by: David Gilhooley <dgilhooley@nvidia.com>
Signed-off-by: James Huang <jamehuang@nvidia.com>
Reviewed-on: https://git-master.nvidia.com/r/1650036
(cherry picked from commit 164f8684deb5b15a53c60a60c7d9b8e3bf5af5be)
Signed-off-by: Jeetesh Burman <jburman@nvidia.com>
Reviewed-on: https://git-master.nvidia.com/r/1682714
Reviewed-on: https://git-master.nvidia.com/r/1698611
To mitigate this problem insert a speculation barrier.
bug 2039126
CVE-2017-5753
Change-Id: Ib6c4b2f99b85af3119cce3882fe35ab47509c76f
Signed-off-by: Alex Waterman <alexw@nvidia.com>
Reviewed-on: https://git-master.nvidia.com/r/1640500
Reviewed-on: https://git-master.nvidia.com/r/1650050
(cherry picked from commit f293fa670fd2f4fbe170f1e372e9aa237283c67a)
Reviewed-on: https://git-master.nvidia.com/r/1682715
Reviewed-on: https://git-master.nvidia.com/r/1698610
In order to prevent aliasing attacks on the branch predictor,
invalidate the icache on Cortex-A15, which has the side effect
of invalidating the BTB. This requires ACTLR[0] to be set to 1
(secure operation).
Change-Id: I4bb8e3ec05853d739bebd8fb3c61657e252808c0
Reviewed-on: https://git-master.nvidia.com/r/1698400
A9, A12 and A17
invalidate the BTB on CPUs that are known to be affected when taking
a prefetch abort on a address that is outside of a user task limit.
__ACCESS_CP15 and __ACCESS_CP15_64 added from below link:
https://patchwork.kernel.org/patch/9234399/
Change-Id: Ib8c9807f5e787437e66b83ea0305d75cce4bbbdf
Reviewed-on: https://git-master.nvidia.com/r/1698399
Cortex-A15 require to invalidate the BTB when switching
from one user context to another. The only way to do so on this
CPU is to perform an ICIALLU, having set ACTLR[0] to 1 from secure
mode.
Change-Id: Ib0083803d75a4399b8225193349a4b490d1776a1
Reviewed-on: https://git-master.nvidia.com/r/1698398
Commit f84a56f73ddd upstream.
Document the rationale and usage of the new array_index_nospec() helper.
Change-Id: I4b804638bbe9811b82d34cd58314cbb1738d7d25
Signed-off-by: Mark Rutland <mark.rutland@arm.com>
Cc: Jonathan Corbet <corbet@lwn.net>
Cc: gregkh@linuxfoundation.org
Cc: kernel-hardening@lists.openwall.com
Cc: torvalds@linux-foundation.org
Cc: alan@linux.intel.com
Link: https://lkml.kernel.org/r/151727413645.33451.15878817161436755393.stgit@dwillia2-desk3.amr.corp.intel.com
Reviewed-on: https://git-master.nvidia.com/r/1698397
Commit f3804203306e upstream.
array_index_nospec() is proposed as a generic mechanism to mitigate
against Spectre-variant-1 attacks, i.e. an attack that bypasses boundary
checks via speculative execution. The array_index_nospec()
implementation is expected to be safe for current generation CPUs across
multiple architectures (ARM, x86).
Based on an original implementation by Linus Torvalds, tweaked to remove
speculative flows by Alexei Starovoitov, and tweaked again by Linus to
introduce an x86 assembly implementation for the mask generation.
Change-Id: I859161a289215b20bd25ef4006115c0268b30b83
Co-developed-by: Linus Torvalds <torvalds@linux-foundation.org>
Co-developed-by: Alexei Starovoitov <ast@kernel.org>
Suggested-by: Cyril Novikov <cnovikov@lynx.com>
Cc: Russell King <linux@armlinux.org.uk>
Link: https://lkml.kernel.org/r/151727414229.33451.18411580953862676575.stgit@dwillia2-desk3.amr.corp.intel.com
Reviewed-on: https://git-master.nvidia.com/r/1698396
Plugging a Logitech DJ receiver with KASAN activated raises a bunch of
out-of-bound readings.
The fields are allocated up to MAX_USAGE, meaning that potentially, we do
not have enough fields to fit the incoming values.
Add checks and silence KASAN.
Bug 1823317
Bug 1935735
Change-Id: Ib3ba92572acbdd4c9ec265e54a45f92606107700
Signed-off-by: Benjamin Tissoires <benjamin.tissoires@redhat.com>
Signed-off-by: Gagan Grover <ggrover@nvidia.com>
Signed-off-by: Amulya Yarlagadda <ayarlagadda@nvidia.com>
Reviewed-on: http://git-master/r/1259928
(cherry picked from commit fbc389a39540e177bfa4d49b9214dfe408ef2d4a)
Reviewed-on: https://git-master.nvidia.com/r/1690285
Reviewed-by: Winnie Hsu <whsu@nvidia.com>
There's a race on CPU unplug where we free the swevent hash array
while it can still have events on. This will result in a
use-after-free which is BAD.
Simply do not free the hash array on unplug. This leaves the thing
around and no use-after-free takes place.
When the last swevent dies, we do a for_each_possible_cpu() iteration
anyway to clean these up, at which time we'll free it, so no leakage
will occur.
Bug 1823317
But 1935735
Change-Id: I309528873f8576f96663afbe51ce2739934df16c
Reported-by: Sasha Levin <sasha.levin@oracle.com>
Tested-by: Sasha Levin <sasha.levin@oracle.com>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Jiri Olsa <jolsa@redhat.com>
Cc: Stephane Eranian <eranian@google.com>
Cc: Vince Weaver <vincent.weaver@maine.edu>
Reviewed-on: http://git-master/r/1259934
(cherry picked from commit 5ea640855404df656d94bfa3990d8eba2b5f90f9)
Reviewed-on: https://git-master.nvidia.com/r/1690284
There is a use-after-free possibility in __ext4_journal_stop() in the
case that we free the handle in the first jbd2_journal_stop() because
we're referencing handle->h_err afterwards. This was introduced in
9705acd63b125dee8b15c705216d7186daea4625 and it is wrong. Fix it by
storing the handle->h_err value beforehand and avoid referencing
potentially freed handle.
Bug 1823317
Change-Id: Ib6fe50ed8013943d5fc3459eb499ecda5533c6ef
Fixes: 9705acd63b125dee8b15c705216d7186daea4625
Signed-off-by: Lukas Czerner <lczerner@redhat.com>
Reviewed-by: Andreas Dilger <adilger@dilger.ca>
Cc: stable@vger.kernel.org
Reviewed-on: http://git-master/r/1259975
(cherry picked from commit 3c15c37dc613cb75339f8e0d546ab30643e65b84)
Reviewed-on: https://git-master.nvidia.com/r/1690287
If /proc/<PID>/environ gets read before the envp[] array is fully set up
in create_{aout,elf,elf_fdpic,flat}_tables(), we might end up trying to
read more bytes than are actually written, as env_start will already be
set but env_end will still be zero, making the range calculation
underflow, allowing to read beyond the end of what has been written.
Fix this as it is done for /proc/<PID>/cmdline by testing env_end for
zero. It is, apparently, intentionally set last in create_*_tables().
This bug was found by the PaX size_overflow plugin that detected the
arithmetic underflow of 'this_len = env_end - (env_start + src)' when
env_end is still zero.
The expected consequence is that userland trying to access
/proc/<PID>/environ of a not yet fully set up process may get
inconsistent data as we're in the middle of copying in the environment
variables.
Bug 1823317
Bug 1935735
Change-Id: I38356eb68ffd1294f1f1250fb328bd01a3b37158
Fixes: https://forums.grsecurity.net/viewtopic.php?f=3&t=4363
Fixes: https://bugzilla.kernel.org/show_bug.cgi?id=116461
Signed-off-by: Mathias Krause <minipli@googlemail.com>
Cc: Emese Revfy <re.emese@gmail.com>
Cc: Pax Team <pageexec@freemail.hu>
Cc: Mateusz Guzik <mguzik@redhat.com>
Cc: Alexey Dobriyan <adobriyan@gmail.com>
Cc: Cyrill Gorcunov <gorcunov@openvz.org>
Cc: Jarod Wilson <jarod@redhat.com>
Reviewed-on: http://git-master/r/1259930
(cherry picked from commit 78d40f25b8e090782ca6b0c6051020557d373c92)
Reviewed-on: https://git-master.nvidia.com/r/1690302
Line discipline drivers may mistakenly misuse ldisc-related fields
when initializing. For example, a failure to initialize tty->receive_room
in the N_GIGASET_M101 line discipline was recently found and fixed [1].
Now, the N_X25 line discipline has been discovered accessing the previous
line discipline's already-freed private data [2].
Harden the ldisc interface against misuse by initializing revelant
tty fields before instancing the new line discipline.
[1]
commit fd98e9419d8d622a4de91f76b306af6aa627aa9c
Author: Tilman Schmidt <tilman@imap.cc>
Date: Tue Jul 14 00:37:13 2015 +0200
isdn/gigaset: reset tty->receive_room when attaching ser_gigaset
[2] Report from Sasha Levin <sasha.levin@oracle.com>
[ 634.336761] ==================================================================
[ 634.338226] BUG: KASAN: use-after-free in x25_asy_open_tty+0x13d/0x490 at addr ffff8800a743efd0
[ 634.339558] Read of size 4 by task syzkaller_execu/8981
[ 634.340359] =============================================================================
[ 634.341598] BUG kmalloc-512 (Not tainted): kasan: bad access detected
[ 634.405018] Call Trace:
[ 634.405277] dump_stack (lib/dump_stack.c:52)
[ 634.405775] print_trailer (mm/slub.c:655)
[ 634.406361] object_err (mm/slub.c:662)
[ 634.406824] kasan_report_error (mm/kasan/report.c:138 mm/kasan/report.c:236)
[ 634.409581] __asan_report_load4_noabort (mm/kasan/report.c:279)
[ 634.411355] x25_asy_open_tty (drivers/net/wan/x25_asy.c:559 (discriminator 1))
[ 634.413997] tty_ldisc_open.isra.2 (drivers/tty/tty_ldisc.c:447)
[ 634.414549] tty_set_ldisc (drivers/tty/tty_ldisc.c:567)
[ 634.415057] tty_ioctl (drivers/tty/tty_io.c:2646 drivers/tty/tty_io.c:2879)
[ 634.423524] do_vfs_ioctl (fs/ioctl.c:43 fs/ioctl.c:607)
[ 634.427491] SyS_ioctl (fs/ioctl.c:622 fs/ioctl.c:613)
[ 634.427945] entry_SYSCALL_64_fastpath (arch/x86/entry/entry_64.S:188)
Bug 1823317
Bug 1935735
Change-Id: Ica54faa9334c587594cc19bc9da007340fda672d
Cc: Tilman Schmidt <tilman@imap.cc>
Cc: Sasha Levin <sasha.levin@oracle.com>
Signed-off-by: Peter Hurley <peter@hurleysoftware.com>
Reviewed-on: http://git-master/r/1259925
(cherry picked from commit 2b1401855a2bdd31556a93feba50dd0dc0bb70e8)
Reviewed-on: https://git-master.nvidia.com/r/1690300
Tested-by: Amulya Yarlagadda <ayarlagadda@nvidia.com>
The format specifier %p can leak kernel addresses
while not valuing the kptr_restrict system
settings.The fix is designed to use %pK instead
of %p, which also evaluates whether
kptr_restrict is set.
Bug 1823317
Bug 1935735
Change-Id: I19dc309e7f5341663add987f5d0b47ee32e1be50
Reviewed-on: http://git-master/r/1260110
(cherry picked from commit d018ef6518a7527562bedae1eab86838cfcc0570)
Reviewed-on: https://git-master.nvidia.com/r/1690299
There is a double fetch problem in audit_log_single_execve_arg()
where we first check the execve(2) argumnets for any "bad" characters
which would require hex encoding and then re-fetch the arguments for
logging in the audit record[1]. Of course this leaves a window of
opportunity for an unsavory application to munge with the data.
This patch reworks things by only fetching the argument data once[2]
into a buffer where it is scanned and logged into the audit
records(s). In addition to fixing the double fetch, this patch
improves on the original code in a few other ways: better handling
of large arguments which require encoding, stricter record length
checking, and some performance improvements (completely unverified,
but we got rid of some strlen() calls, that's got to be a good
thing).
As part of the development of this patch, I've also created a basic
regression test for the audit-testsuite, the test can be tracked on
GitHub at the following link:
* https://github.com/linux-audit/audit-testsuite/issues/25
[1] If you pay careful attention, there is actually a triple fetch
problem due to a strnlen_user() call at the top of the function.
[2] This is a tiny white lie, we do make a call to strnlen_user()
prior to fetching the argument data. I don't like it, but due to the
way the audit record is structured we really have no choice unless we
copy the entire argument at once (which would require a rather
wasteful allocation). The good news is that with this patch the
kernel no longer relies on this strnlen_user() value for anything
beyond recording it in the log, we also update it with a trustworthy
value whenever possible.
Bug 1823317
Bug 1935735
Change-Id: I500834e1e699cb43d207333fa91292673de54933
Reported-by: Pengfei Wang <wpengfeinudt@gmail.com>
Cc: <stable@vger.kernel.org>
Signed-off-by: Paul Moore <paul@paul-moore.com>
Reviewed-on: http://git-master/r/1261377
(cherry picked from commit 1cc418b165a23b352e06aa5ab66a2d1e1a942a98)
Reviewed-on: https://git-master.nvidia.com/r/1690297
