2017-11-29tegra: align graphics drivers with android binariesApalis-TK1_LXDE-Image_2.7b5-20171201Dominik Sliwa
Some functionality used by android binary drivers were missing. Signed-off-by: Dominik Sliwa <dominik.sliwa@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-11-29mfd: apalis-tk1: 0.11 fw supportDominik Sliwa
2017-11-29mmc: Allow forward compatibility for eMMCRomain Izard
As stated by the eMMC 5.0 specification, a chip should not be rejected only because of the revision stated in the EXT_CSD_REV field of the EXT_CSD register. Remove the control on this value, the control of the CSD_STRUCTURE field should be sufficient to reject future incompatible changes. Signed-off-by: Romain Izard <romain.izard.pro@gmail.com> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> (cherry picked from commit 03a59437ef6b6ad7fb0165cb9b96c08d6bf057fc)
2017-11-29Merge tag 'tegra-l4t-r21.6' into toradex_tk1_l4t_r21.6Marcel Ziswiler
Merge NVIDIA's latest Linux for Tegra aka L4T R21.6 Linux kernel changes from git://nv-tegra.nvidia.com/linux-3.10.git commit: b271e8fa67a6d9c4600274a25636cfe00fdd1b68 Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Dominik Sliwa <dominik.sliwa@toradex.com>
2017-11-29Revert "spi-tegra114: Warning when clock rate switch fails"Marcel Ziswiler
This reverts commit 8fdf8dc5afdb02625084356ebd7c0d1c7494a00e. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Dominik Sliwa <dominik.sliwa@toradex.com>
2017-11-29Revert "mmc: Allow forward compatibility for eMMC"Marcel Ziswiler
This reverts commit 0293e897d740cc7991c82567aab5dee0e66294fd. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Dominik Sliwa <dominik.sliwa@toradex.com>
2017-11-29media: ov5640: major driver cleanuptoradex_tk1_l4t_r21.5Peter Gielda
Signed-off-by: Peter Gielda <pgielda@antmicro.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-10-17ARM: tegra: apalis-tk1: use high vil/vih receivers for ddcDominik Sliwa
DDC/EDID detection was failing on Apalis TK1 V1.2A on Ixora. Signed-off-by: Dominik Sliwa <dominik.sliwa@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-10-06mfd: apalis-tk1-k20: clean-up and fix support for 0.10 k20 fwApalis-TK1_LXDE-Image_2.7b4-20171007Dominik Sliwa
2017-10-05ARM: tegra: apalis-tk1: annotate and fix gpio configurationMarcel Ziswiler
2017-10-05mfd: apalis-tk1-k20: support for 0.10 k20 fwDominik Sliwa
2017-10-05ARM: tegra: apalis-tk1: move hdmi ddc config to dtDominik Sliwa
We moved HDMI DDC configuration to the device-tree. If DDC config is missing from the device-tree we default to v1.2 config. Signed-off-by: Dominik Sliwa <dominik.sliwa@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-10-03ARM: tegra: apalis-tk1: support v1.2 hardware revisionMarcel Ziswiler
Support the V1.2 hardware revision with the following pin muxing changes: Ddc_scl_pv4 and ddc_sda_pv5 previously used as Apalis GPIO3 and GPIO4 are now used as DDC pins. Gen2_i2c_scl_pt5 and gen2_i2c_sda_pt6 previously used as DDC pins are now used as USB power enable signals. Usb_vbus_en0_pn4 and usb_vbus_en1_pn5 previously used as USB power enable signals are now used as GPIO3 and GPIO4. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Dominik Sliwa <dominik.sliwa@toradex.com>
2017-10-03ARM: dts: tegra124: update model and compatibility nodesMarcel Ziswiler
Update model and compatibility nodes to be more in-line with mainline. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Dominik Sliwa <dominik.sliwa@toradex.com>
2017-10-03pinctrl: tegra: clean-upMarcel Ziswiler
Cosmetic clean-up to bring it more in-line with mainline driver in order to be able to easily assess whether it is all kosher. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Dominik Sliwa <dominik.sliwa@toradex.com>
2017-10-03Bluetooth: Properly check L2CAP config option output buffer lengthtegra-l4t-r21.6Ben Seri
Validate the output buffer length for L2CAP config requests and responses to avoid overflowing the stack buffer used for building the option blocks. Bug 1989825 Change-Id: Id158ece2176c4ac339a7232dfde8c47ce2241122 Cc: stable@vger.kernel.org Signed-off-by: Ben Seri <ben@armis.com> Signed-off-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Bibek Basu <bbasu@nvidia.com> Reviewed-on: https://git-master.nvidia.com/r/1558952 (cherry picked from commit c005032a3ffe77437f6ebc704af377fc9bc46279) Reviewed-on: https://git-master.nvidia.com/r/1570529 Reviewed-by: Matthew Pedro <mapedro@nvidia.com> Reviewed-by: Winnie Hsu <whsu@nvidia.com> Tested-by: Winnie Hsu <whsu@nvidia.com>
2017-09-27ARM: tegra: Select appropriate DMA options for LPAEPaul Kocialkowski
This automatically selects options for zone DMA and 64 bit DMA addresses when LPAE is enabled on ARM Tegra platforms. These options are required for proper operation with LPAE enabled. The ZONE_DMA option is required to ensure that drivers that allocate DMA memory get buffers from the first 4 GiB. This is necessary because a lot of the controllers only support addressing 32 bits. As for ARCH_DMA_ADDR_T_64BIT, there are situations where devices that do support addresses of more than 32 bits (such as the display controller or the GPU) can run without translating addresses through an IOMMU on a device with more than 4 GiB of system memory. Note that both of these options are stop-gap solutions required only until the IOMMU can be properly integrated with the DMA mapping API and drivers use that properly and consistently. Signed-off-by: Paul Kocialkowski <contact@paulk.fr> [treding@nvidia.com: specify rationale for options] Signed-off-by: Thierry Reding <treding@nvidia.com> (backported from commit 6aa26c5d66595494e810c791602d87a572c78808)
2017-09-20dp.c: fix compilation with gcc 7Max Krummenacher
With gcc 7 the following compile time error occurs: | drivers/video/tegra/dc/dp.c:1178:12: error: the omitted middle operand in ?: will always be 'true', suggest explicit middle operand [-Werror=parentheses] | cr_done ? : ({ret = -EINVAL; goto fail; }); | ^ | drivers/video/tegra/dc/dp.c:1186:12: error: the omitted middle operand in ?: will always be 'true', suggest explicit middle operand [-Werror=parentheses] | lt_done ? : ({ret = -EINVAL; goto fail; }); | ^ Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-09-20tegra11_soctherm.c: fix compilation with gcc 7Max Krummenacher
With gcc 7 the following compile time error occurs: | arch/arm/mach-tegra/tegra11_soctherm.c:2978:40: error: the omitted middle operand in ?: will always be 'true', suggest explicit middle operand [-Werror=parentheses] | s->sensor_enable = s->sensor_enable ?: therm->zone_enable; | ^ Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-09-20dsi.c: fix compilation with gcc 7Max Krummenacher
With gcc 7 the following compile time error occurs: | drivers/video/tegra/dc/dsi.c:766:34: error: '*' in boolean context, suggest '&&' instead [-Werror=int-in-bool-context] | drivers/video/tegra/dc/dsi.c:757:1: | (platform_t_phy_ps) ? ( \ | ~~~~~~~~~~~~~~~~~~~ | kernel-source/drivers/video/tegra/dc/dsi.c:766:34: | dsi->info.phy_timing.t_tlpx_ns * 1000, | drivers/video/tegra/dc/dsi.c:757:2: note: in definition of macro 'SELECT_T_PHY' | (platform_t_phy_ps) ? ( \ | ^~~~~~~~~~~~~~~~~ Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-09-20powergate-t12x.c: fix compilation with gcc 7Max Krummenacher
With gcc 7 the following compile time error occurs: | arch/arm/mach-tegra/powergate-t12x.c:814:10: error: statement will never be executed [-Werror=switch-unreachable] | return true; | ^~~~ Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-09-20tegra_udc.c: fix compilation with gcc 7Max Krummenacher
With gcc 7 the following compile time error occurs: | .../drivers/usb/gadget/tegra_udc.c:2565:17: error: 'out' directive writing 3 bytes into a region of size between 2 and 11 [-Werror=format-overflow=] | sprintf(name, "ep%dout", i); | ^~~~~~~~~ | .../drivers/usb/gadget/tegra_udc.c:2565:3: note: 'sprintf' output between 7 and 16 bytes into a destination of size 14 | sprintf(name, "ep%dout", i); | ^~~~~~~~~~~~~~~~~~~~~~~~~~~ The last end point will never be greater than 32 but the compiler can not find this out from the code. Work around this by passing a format specifier to interpreat i as a signed char. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-09-20apalis-tk1: activate pwm pin muxing for pwm3Marcel Ziswiler
Activate PWM pin muxing for Apalis PWM3. Note that the same PWM3 is already active on pu6 being Apalis BKL1_PWM as well. Therefore exporting that one for raw sysfs access will fail and one has to revert to using the pwm backlight. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Dominik Sliwa <dominik.sliwa@toradex.com>
2017-09-20apalis-tk1: enable large physical address extension lpaeMarcel Ziswiler
Enable support for the Large Physical Address Extension aka LPAE. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Dominik Sliwa <dominik.sliwa@toradex.com>
2017-09-20mfd: apalis-tk1: fix NULL pointer dereferenceDominik Sliwa
2017-09-20spi: tegra: fix warning when using controller-dataDominik Sliwa
Tegra spi driver was using devm_kzalloc before dev was bound. Signed-off-by: Dominik Sliwa <dominik.sliwa@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-09-20apalis-tk1: fix pcie reset for reliable gigabit ethernet operationMarcel Ziswiler
It turns out that the current PCIe reset implementation is not quite working reliably due to some Intel i210 errata. Fix this by making sure the i210's +V3.3_ETH rail is properly disabled during its reset sequence. Also further improve on the bringing up the PCIe switch as found on the Apalis Evaluation board. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Dominik Sliwa <dominik.sliwa@toradex.com>
2017-09-20apalis-tk1: update defconfig for wifiDominik Sliwa
2017-09-20ARM: dts: tegra124: fix m41t0 rtc compatible stringBhuvanchandra DV
Toradex Carrier boards use the ST M41T0 RTC (not M41T00). The RTC is almost the same, but the M41T0 needs some special handling in case the oscillator fails. Now that support for this difference is available, using the new compatible string to make use of it. Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-09-20rtc: ds1307: support m41t0 variantBhuvanchandra DV
The m41t0 variant is very similar to the already supported m41t00 variant, with the notable exception of the oscillator fail bit. The data sheet notes: If the oscillator fail (OF) bit is internally set to a '1,' this indicates that the oscillator has either stopped, or was stopped for some period of time and can be used to judge the validity of the clock and date data. The bit will get cleared with a regular write of the system time, so no changes are needed to clear it. Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com> (backported from commit 8566f70c8a90f3914b06e934852596ba94aaa381)
2017-07-26gpu: nvgpu: Remove IOCTL FREE_OBJ_CTXDebarshi Dutta
We have never used the IOCTL FREE_OBJ_CTX. Using it leads to context being only partially available, and can lead to use-after-free. Bug 1885775 Change-Id: I9d2b632ab79760f8186d02e0f35861b3a6aae649 Signed-off-by: Debarshi Dutta <ddutta@nvidia.com> Reviewed-on: https://git-master.nvidia.com/r/1506479 Reviewed-by: Automatic_Commit_Validation_User GVS: Gerrit_Virtual_Submit Reviewed-by: Bibek Basu <bbasu@nvidia.com>
2017-07-26video: tegra: nvmap: fix nvmap create handle vulnerabilityKrishna Reddy
Handle the race condition between malicious fd close and copy_to_user error, which can create use after free condition. This is fixed by deferring the fd install, which eliminates the race that leads to use after free condition. Fixing Google Bug 32160775. Bug 1835857 Change-Id: I337807e4360661beced8f9e1155c47b66607b8df Signed-off-by: Krishna Reddy <vdumpa@nvidia.com> Reviewed-on: http://git-master/r/1248391 Reviewed-on: https://git-master.nvidia.com/r/1512958 GVS: Gerrit_Virtual_Submit Reviewed-by: Bibek Basu <bbasu@nvidia.com> Tested-by: Bibek Basu <bbasu@nvidia.com>
2017-06-30apalis-tk1: snapd squashfs configurationApalis-TK1_LXDE-Image_2.7b3-20170630Marcel Ziswiler
Prepare for snapd integration. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Dominik Sliwa <dominik.sliwa@toradex.com>
2017-06-30apalis-tk1: improve spi2 clocking aka for k20Marcel Ziswiler
Change SPI2 clock parent to clk_m being 12 MHz which is anyway the maximum frequency the K20 micro controller's SPI peripheral can be run. This further allows for the EzPort to be run at exactly 2 MHz which is the maximum allowed as well. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Dominik Sliwa <dominik.sliwa@toradex.com>
2017-06-30apalis-tk1: add multitouch hid supportStefan Agner
Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com> (cherry picked from commit 15e73283a975a1b899d7f6807aa882ef885573dd) Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Dominik Sliwa <dominik.sliwa@toradex.com>
2017-06-30apalis-tk1-k20: can and spi improvementsDominik Sliwa
This patch includes CAN driver and improvements in SPI communications for Apalis TK1 k20 based MFD. Requires firmware version 0.9. Signed-off-by: Dominik Sliwa <dominik.sliwa@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-06-30video: tegra: sor: set drive current for lane4WayneWWW
Drive current for LANE4 was not set if configured as 24bpp LVDS out. Fix it by programming proper drive current register if using 24bpp out. https://devtalk.nvidia.com/default/topic/1003030 Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Dominik Sliwa <dominik.sliwa@toradex.com>
2017-06-29video: tegra: dsi: Set max limit for reading panelPavan Kunapuli
In the debugfs support for reading panel registers, max payload needs to be limited to the buff array size to avoid stack corruption. Bug 1873360 Change-Id: Ibee7bd81027d2669297942c09b905f1dd3bb09ee Signed-off-by: Pavan Kunapuli <pkunapuli@nvidia.com> Signed-off-by: sakets <sakets@nvidia.com> Reviewed-on: https://git-master/r/1507653 Reviewed-by: Automatic_Commit_Validation_User GVS: Gerrit_Virtual_Submit Reviewed-by: Bibek Basu <bbasu@nvidia.com>
2017-06-21video: tegra: nvmap: fix information leak in pin/unpinSri Krishna chowdary
When the NVMAP_IOC_PIN_MULT_32 and NVMAP_IOC_UNPIN_MULT_32 are called it is possible that the op.addr is not initialized. This can cause write to some random address thus causing corruption. This patch fixes Google Bug 31668540 bug 1832092 Change-Id: I4d12d1a6c777131ba1fa2a753ea640861f8e82a6 Signed-off-by: Sri Krishna chowdary <schowdary@nvidia.com> Reviewed-on: http://git-master/r/1314406 (cherry picked from commit da0c43534bb61e2e0849e297d389517d5e4ed168) Reviewed-on: http://git-master/r/1504673 GVS: Gerrit_Virtual_Submit Reviewed-by: Bibek Basu <bbasu@nvidia.com> Tested-by: Bibek Basu <bbasu@nvidia.com> Reviewed-by: Winnie Hsu <whsu@nvidia.com>
2017-06-20media: tegra: nvavp: Fix UAF issue.Jitendra Kumar
Use locking to protect generated fd, so that it can't be freed before channel open completes. Also add null value checks in release call. CVE-2016-8449 (A-31798848) Bug 1830023 Bug 1849492 Change-Id: Ie6e2b29c7132fdfdff6b0bfa75440bd43afffd5f Signed-off-by: Gagan Grover <ggrover@nvidia.com> Reviewed-on: http://git-master/r/1285817 (cherry picked from commit 2ff0fdedfd65f269359d6540df4662e958681aa7) Reviewed-on: http://git-master/r/1299505 (cherry picked from commit ea1af2ce5a746bda36205357c9e0adaf527026bb) Reviewed-on: http://git-master/r/1489467 (cherry picked from commit 89559abb25f82dc333eafa26391be0a50d6e9e0a) Reviewed-on: http://git-master/r/1504674 Reviewed-by: Automatic_Commit_Validation_User GVS: Gerrit_Virtual_Submit Tested-by: Bibek Basu <bbasu@nvidia.com> Reviewed-by: Bibek Basu <bbasu@nvidia.com> Reviewed-by: Winnie Hsu <whsu@nvidia.com>
2017-06-16gpu: nvgpu: Fix pgsz_idx used in gk20a_vm_alloc_space()Alex Waterman
Use the correct page size index for pgsz_idx in gk20a_vm_alloc_space(). Previously the page size itself was used, not the page size index. Bug 1837624 Change-Id: I652f5af5321c1c49dc8eb170d3f92f00c23d2b6f Signed-off-by: Alex Waterman <alexw@nvidia.com> (cherry picked from commit fd13e0e1c4e397335c24497a0f92c85934d6185f) Reviewed-on: http://git-master/r/1503371 Reviewed-by: Terje Bergstrom <tbergstrom@nvidia.com> Reviewed-by: Winnie Hsu <whsu@nvidia.com>
2017-06-09video: tegra: nvmap: Fix NULL pointer dereferenceSri Krishna chowdary
Consider the following case: 1. NVMAP_IOC_CREATE on IOVMM gives a valid fd to user space 2. user space does not call NVMAP_IOC_ALLOC. 3. user space calls a client driver IOCTL which calls dma_buf_map_attachment 4. call to dma_buf_map_attachment propagates till__nvmap_sg_table which has heap_pgalloc as true and tries to access pages[] which has all NULL. 5. Similarly, a dma_buf_kmap() can result in __nvmap_kmap() being called which again results in NULL dereference if pages[] is accessed. A valid __nvmap_sg_table should occur only when h->alloc is true. So, add check for it. bug 1838597 bug 1883708 Change-Id: I400d9d8a94ff1003db207fc9c252b9256d796f60 Signed-off-by: Sri Krishna chowdary <schowdary@nvidia.com> Signed-off-by: Debarshi Dutta <ddutta@nvidia.com> (cherry picked from commit 8244d104b7635cb0b26b651b6851498b9a84d7d6) Reviewed-on: http://git-master/r/1489579 Reviewed-by: Automatic_Commit_Validation_User GVS: Gerrit_Virtual_Submit Reviewed-by: Bibek Basu <bbasu@nvidia.com> Tested-by: Bibek Basu <bbasu@nvidia.com>
2017-05-26video: tegra: nvmap: Fix security issue in NVMAP_IOC_PARAMGagan Grover
Initialized the uninitialized variables and handled return status from nvmap_get_handle_param. Bug 1884311 Bug 1820242 Change-Id: I2390c859d2b2af39eaff44749ca64e60920fe944 Signed-off-by: Gagan Grover <ggrover@nvidia.com> Reviewed-on: http://git-master/r/1259560 Reviewed-on: http://git-master/r/1489707 GVS: Gerrit_Virtual_Submit Tested-by: Sumit Gupta <sumitg@nvidia.com> Reviewed-by: Bibek Basu <bbasu@nvidia.com>
2017-05-25video: tegra: nvmap: Fix OOB vulnerabilitySagar Kadamati
Check all pages' parameters before reserve pages. Bug 1883463 Bug 1831426 Bug 200247013 Manual port: http://git-psac/r/9287 (cherry picked from commit 61a05b52b8a17593e2817076b9bf59efdd9268ad) Change-Id: I2f47c385ff8f4a9ca6bf37ee41749bd684ca1a20 Signed-off-by: Xia Yang <xiay@nvidia.com> Signed-off-by: Sagar Kadamati <skadamati@nvidia.com> Reviewed-on: http://git-master/r/1273326 Reviewed-on: http://git-master/r/1488769 GVS: Gerrit_Virtual_Submit Tested-by: Sumit Gupta <sumitg@nvidia.com> Reviewed-by: Bibek Basu <bbasu@nvidia.com>
2017-05-22gpu: nvgpu: fix crash in gk20a_channel_releaseAingara Paramakuru
gk20a_channel_release() should bail if filp->private_data is NULL. This can happen as a result of gk20a_channel_release() being called when __gk20a_channel_open() fails in NVHOST_IOCTL_CHANNEL_OPEN. Bug 200014898 Change-Id: I32cc957aca46fcd4265a8052ac5be355b644b9f7 Signed-off-by: Aingara Paramakuru <aparamakuru@nvidia.com> Reviewed-on: http://git-master/r/496138 (cherry picked from commit cb0db6618c42ab4c33574f09f212ab1ee9a0438a) Reviewed-on: http://git-master/r/1258588 Reviewed-by: Winnie Hsu <whsu@nvidia.com> Tested-by: Winnie Hsu <whsu@nvidia.com>
2017-05-16tegra: camera: Fix UAF security issueFrank Chen
Fix UAF (use-after-free) security issue in camera.pcl driver Bug 1832830 Change-Id: Ie0f8a58a7bb9d1b4949e0f68d25d6da108f06e76 Signed-off-by: Frank Chen <frankc@nvidia.com> Reviewed-on: http://git-master/r/1271371 Reviewed-by: Automatic_Commit_Validation_User GVS: Gerrit_Virtual_Submit Reviewed-by: Jihoon Bang <jbang@nvidia.com> Reviewed-by: Winnie Hsu <whsu@nvidia.com>
2017-05-16tegra: camera race condition vulnerabilityMark Salyzyn
- Add mutex_lock(cam_desc.d_mutex) around ioctl access functions. - Check cam->cdev in PCLLK_IOCTL_DEV_DEL ioctl. (Back ported from Nexus N9 project) Bug 1832830 Signed-off-by: <tiangangpi@gmail.com> Signed-off-by: Xiaya Hu <xiaya@nvidia.com> Signed-off-by: Mark Salyzyn <salyzyn@google.com> Bug: 28026625 Change-Id: I81fbab628fb6516afa2cf5d3e0adf333aa2eb003 Reviewed-on: http://git-master/r/1271370 Reviewed-by: Automatic_Commit_Validation_User GVS: Gerrit_Virtual_Submit Reviewed-by: Frank Chen <frankc@nvidia.com> Tested-by: Frank Chen <frankc@nvidia.com> Reviewed-by: Jihoon Bang <jbang@nvidia.com> Reviewed-by: Winnie Hsu <whsu@nvidia.com>
2017-05-16camera: tegra: Fix security vulnerabilityAmey Asgaonkar
Check a few input params to make sure there is no potential for a heap overflow in the driver. (Back ported from Nexus N9 project) Bug 1757475 (nvidia) Bug 1832830 (nvidia) Bug 28193342 (google) Change-Id: I979fa38c5f453cfad7070f0340ec04adde5bac13 Signed-off-by: Amey Asgaonkar <aasgaonkar@nvidia.com> Reviewed-on: http://git-master/r/1271369 Reviewed-by: Automatic_Commit_Validation_User GVS: Gerrit_Virtual_Submit Reviewed-by: Frank Chen <frankc@nvidia.com> Tested-by: Frank Chen <frankc@nvidia.com> Reviewed-by: Jihoon Bang <jbang@nvidia.com> Reviewed-by: Winnie Hsu <whsu@nvidia.com>
2017-05-16tegra: camera: validate PCLLK_IOCTL_SEQ_XX paramsGreg Hackmann
The driver expects the userspace-provided table to be terminated with addr == CAMERA_TABLE_END. Reject tables that aren't. (back ported from Nexus N9 project) Bug 1832830 Change-Id: Id1e168e02fbf323d094fe8c36c6e4bd90cceee4f Signed-off-by: Greg Hackmann <ghackmann@google.com> Reviewed-on: http://git-master/r/1271368 Reviewed-by: Automatic_Commit_Validation_User GVS: Gerrit_Virtual_Submit Reviewed-by: Frank Chen <frankc@nvidia.com> Tested-by: Frank Chen <frankc@nvidia.com> Reviewed-by: Jihoon Bang <jbang@nvidia.com> Reviewed-by: Winnie Hsu <whsu@nvidia.com>
2017-05-16media: tegra: camera: sanity-check ioctl parameterGreg Hackmann
Several places in the camera stack can hit integer overflows or cause bad allocations if userspace passes in a bogus sizeofvalue parameter. Protect against this by using appropriately-sized integer types, adding range checks, replacing array-allocation calls with kcalloc(), and checking for allocations returning ZERO_SIZE_PTR. For one specific ioctl (PCLLK_IOCTL_UPDATE) sizeofvalue = 0 is fine, since when that happens the subdrivers won't actually touch the returned allocation. In fact the existing userspace camera driver makes calls like these and expects them to succeed! Handle this special case by adding a __camera_get_params variant that optionally treats zero-sized inputs as valid. (back ported from Nexus N9 project) Bug 1832830 Change-Id: Ie3250d8a4b814de5820fa0190b4cbd1af3ca4b3f Reported-by: Jianqiang Zhao <zhaojianqiang1@gmail.com> Signed-off-by: Greg Hackmann <ghackmann@google.com> Reviewed-on: http://git-master/r/1271367 Reviewed-by: Automatic_Commit_Validation_User GVS: Gerrit_Virtual_Submit Reviewed-by: Frank Chen <frankc@nvidia.com> Tested-by: Frank Chen <frankc@nvidia.com> Reviewed-by: Jihoon Bang <jbang@nvidia.com> Reviewed-by: Winnie Hsu <whsu@nvidia.com>
