Support for PKCS#1 v1.5 was deprecated in SHA 1001202 and fully removed
in SHA fe199e3, however, cert_tool is still able to generate
certificates in that form. This patch fully removes the ability for
cert_tool to generate these certificates.
Additionally, this patch also fixes a bug where the issuing certificate
was a RSA and the issued certificate was EcDSA. In this case, the issued
certificate would be signed using PKCS#1 v1.5 instead of RSAPSS per
PKCS#1 v2.1, preventing TF-A from verifying the image signatures. Now
that PKCS#1 v1.5 support is removed, all certificates that are signed
with RSA now use the more modern padding scheme.
Change-Id: Id87d7d915be594a1876a73080528d968e65c4e9a
Signed-off-by: Justin Chadwell <justin.chadwell@arm.com>
cert_tool is now able to accept a command line option for specifying the
key size. It now supports the following options: 1024, 2048 (default),
3072 and 4096. This is also modifiable by TFA using the build flag
KEY_SIZE.
Change-Id: Ifadecf84ade3763249ee8cc7123a8178f606f0e5
Meson is the internal code name for the SoC family. The correct name for
the platform should be Amlogic. Change the name of the platform
directory.
Signed-off-by: Carlo Caione <ccaione@baylibre.com>
Change-Id: Icc140e1ea137f12117acbf64c7dcb1a8b66b345d
The valgrind checks for cert_create have not been run in a long while -
as such there are a few memory leaks present. This patch fixes a few of
the major ones reported by valgrind. However, a few do remain.
Change-Id: Iab002fb2b0090043287d43fb54a4d18928c2ed85
This change adds nmake compatible Makefile.msvc file for
building (nmake /FMakefile.msvc) fiptool on the Windows.
Change-Id: Iccd1fe8da072edd09eb04b8622f27b3c4693b281
Signed-off-by: Girish Pathak <girish.pathak@arm.com>
GXL platforms need to have a specific header at the beginning of bl31
image to be able to boot. This adds a tool to create that and calls it at
build time.
Signed-off-by: Remi Pommarel <repk@triplefau.lt>
Add R-Car D3 SoC platform specifics. Driver, PFC, QoS, DDR init code
will be added separately.
Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com>
It is quite unlikely that this number will ever change and, if it
does need to change, we should have a good reason to do so. It
seems that this comment is now redundant.
Change-Id: I409c764080748e338e9bc5606bbdcc475213fb6e
Signed-off-by: Paul Beesley <paul.beesley@arm.com>
Change-Id: Iea72ef9ba16325cbce07eea1a975d2a96eede274
Commit 033648652f ("Make TF UUID RFC 4122 compliant") changed the scanf
parsing string to handle endianness correctly.
However that changed the number of items sscanf handles, without
adjusting the sanity check just below.
Increase the expected return value from 11 to 16 to let fiptool handle
UUIDs given as blob parameters correctly again.
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
This tool packages Secure Partitions and Resource Descriptor blobs into
a simple file that can be loaded by SPM.
Change-Id: If3800064f30bdc3d7fc6a15ffbb3007ef632bcaa
Signed-off-by: Antonio Nino Diaz <antonio.ninodiaz@arm.com>
All identifiers, regardless of use, that start with two underscores are
reserved. This means they can't be used in header guards.
The style that this project is now to use the full name of the file in
capital letters followed by 'H'. For example, for a file called
"uart_example.h", the header guard is UART_EXAMPLE_H.
The exceptions are files that are imported from other projects:
- CryptoCell driver
- dt-bindings folders
- zlib headers
Change-Id: I50561bf6c88b491ec440d0c8385c74650f3c106e
Add support for Armada 3700 and COMPHY porting layer
Move doimage utility from toos/doimage to tools/marvell/doimage.
This is done for supporting mode Marvell tools in the future.
Signed-off-by: Konstantin Porotchkin <kostap@marvell.com>
Add MMC support for STM32MP1
Reference code:
rar_gen3: IPL and Secure Monitor Rev1.0.22
https://github.com/renesas-rcar/arm-trusted-firmware [rcar_gen3]
Author: Takuya Sakata <takuya.sakata.wz@bp.renesas.com>
Date: Thu Aug 30 21:26:41 2018 +0900
Update IPL and Secure Monitor Rev1.0.22
General Information:
This port has been tested on the Salvator-X Soc_id r8a7795 revision
ES1.1 (uses an SPD).
Build Tested:
ATFW_OPT="LSI=H3 RCAR_DRAM_SPLIT=1 RCAR_LOSSY_ENABLE=1"
MBEDTLS_DIR=$mbedtls
$ make clean bl2 bl31 rcar PLAT=rcar ${ATFW_OPT} SPD=opteed
Other dependencies:
* mbed_tls:
git@github.com:ARMmbed/mbedtls.git [devel]
Merge: 68dbc94 f34a4c1
Author: Simon Butcher <simon.butcher@arm.com>
Date: Thu Aug 30 00:57:28 2018 +0100
* optee_os:
https://github.com/BayLibre/optee_os
Until it gets merged into OP-TEE, the port requires Renesas' Trusted
Environment with a modification to support power management.
Author: Jorge Ramirez-Ortiz <jramirez@baylibre.com>
Date: Thu Aug 30 16:49:49 2018 +0200
plat-rcar: cpu-suspend: handle the power level
Signed-off-by: Jorge Ramirez-Ortiz <jramirez@baylibre.com>
* u-boot:
The port has beent tested using mainline uboot.
Author: Fabio Estevam <festevam@gmail.com>
Date: Tue Sep 4 10:23:12 2018 -0300
*linux:
The port has beent tested using mainline kernel.
Author: Linus Torvalds <torvalds@linux-foundation.org>
Date: Sun Sep 16 11:52:37 2018 -0700
Linux 4.19-rc4
Overview
BOOTROM starts the cpu at EL3; In this port BL2 will therefore be entered
at this exception level (the Renesas' ATF reference tree [1] resets into
EL1 before entering BL2 - see its bl2.ld.S)
BL2 initializes DDR (and i2c to talk to the PMIC on some platforms)
before determining the boot reason (cold or warm).
During suspend all CPUs are switched off and the DDR is put in
backup mode (some kind of self-refresh mode). This means that BL2 is
always entered in a cold boot scenario.
Once BL2 boots, it determines the boot reason, writes it to shared
memory (BOOT_KIND_BASE) together with the BL31 parameters
(PARAMS_BASE) and jumps to BL31.
To all effects, BL31 is as if it is being entered in reset mode since
it still needs to initialize the rest of the cores; this is the reason
behind using direct shared memory access to BOOT_KIND_BASE and
PARAMS_BASE instead of using registers to get to those locations (see
el3_common_macros.S and bl31_entrypoint.S for the RESET_TO_BL31 use
case).
Depending on the boot reason BL31 initializes the rest of the cores:
in case of suspend, it uses a MBOX memory region to recover the
program counters.
[1] https://github.com/renesas-rcar/arm-trusted-firmware
Tests
* cpuidle
enable kernel's cpuidle arm_idle driver and boot
* system suspend
$ cat suspend.sh
#!/bin/bash
i2cset -f -y 7 0x30 0x20 0x0F
read -p "Switch off SW23 and press return " foo
echo mem > /sys/power/state
* cpu hotplug:
$ cat offline.sh
#!/bin/bash
nbr=$1
echo 0 > /sys/devices/system/cpu/cpu$nbr/online
printf "ONLINE: " && cat /sys/devices/system/cpu/online
printf "OFFLINE: " && cat /sys/devices/system/cpu/offline
$ cat online.sh
#!/bin/bash
nbr=$1
echo 1 > /sys/devices/system/cpu/cpu$nbr/online
Signed-off-by: ldts <jramirez@baylibre.com>
Signed-off-by: Yann Gautier <yann.gautier@st.com>
tools: Make invocation of host compiler correct
doimage: get rid of non null terminated strings by strncpy
HOSTCC should be used in any of the tools inside the tools/ directory
instead of CC. That way it is possible to override both values from the
command line when building the Trusted Firmware and the tools at the
same time. Also, use HOSTCCFLAGS instead of CFLAGS.
Also, instead of printing the strings CC and LD in the console during
the compilation of the tools, HOSTCC and HOSTLD have to be used for
clarity. This is how it is done in other projects like U-Boot or Linux.
Change-Id: Icd6f74c31eb74cdd1c353583399ab19e173e293e
As these rules depend on non-existing headers as well (likely copy &
pasted from fiptool), they never matched, and the built-in rules were
used. That led to random breakages when e.g. CPPFLAGS was suddenly
evaluated and contained invalid options.
For the stm32image, this reveals that we were relying on the built-in
rules by passing -D_GNU_SOURCE via CPPFLAGS, rather than using CFLAGS as
used in the local rule. Fix that as well.
Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com>
A compatibility script has been provided for about 2 years. Users should
have migrated to fiptool by now so remove the compat script.
Change-Id: I643e0c40a9e3fb428bad3be04a82cb431aad74dc
Signed-off-by: dp-arm <dimitris.papastamos@arm.com>
Signed-off-by: Matteo Croce <mcroce@redhat.com>
Missing ")" in fprintf causing build break in secure boot mode.
Change-Id: Ice555571683b68bb0d81479e9fc8abc4296809ac
Add example keys for building trusted flash images using
doimage tools.
Similar files can be generated using openssl or mbedtls.
Marvell platform make files are using trusted boot
configurations from this example etst vector.
Change-Id: I38a2e295171bee4c14005ce6f020b352c683496e
This tools adds a specific header to ST TF-A binary.
This header is used by STM32MP1 ROM code to check the bootloader.
Signed-off-by: Lionel Debieve <lionel.debieve@st.com>
Marvell support for Armada 8K SoC family
Add Marvell "doimage" utility support.
The "doimage" utility allows to create flash images compatible
with Marvell BootROM image format. Additionally this tool
allows the flash image parsing and verification.
Change-Id: Ie8d7ccd0cc2978684e7eecb695f375395fc749ee
Previously build_msg.o is built by CC. It causes FTBFS when CC
is not equal to HOSTCC.
Signed-off-by: Ying-Chun Liu (PaulLiu) <paulliu@debian.org>
Print_help was used in different contexts and returning no
error in that function was hiding the error when incorrect
options were used.
Change-Id: Ic3f71748be7ff8440c9d54810b986e9f177f4439
Signed-off-by: Roberto Vargas <roberto.vargas@arm.com>
RFC4122 defines that fields are stored in network order (big endian),
but TF-A stores them in machine order (little endian by default in TF-A).
We cannot change the future UUIDs that are already generated, but we can store
all the bytes using arrays and modify fiptool to generate the UUIDs with
the correct byte order.
Change-Id: I97be2d3168d91f4dee7ccfafc533ea55ff33e46f
This patch implements support for adding dynamic configurations for
BL31 (soc_fw_config), BL32 (tos_fw_config) and BL33 (nt_fw_config). The
necessary cert tool support and changes to default chain of trust are made
for these configs.
Change-Id: I25f266277b5b5501a196d2f2f79639d838794518
Signed-off-by: Soby Mathew <soby.mathew@arm.com>
Fix memory leaks in fiptool
Free desc->image->buffer before freeing desc->image. We make sure that
the desc->image is non-null before attempting this.
Change-Id: I35c5674629a41d7cf1a78b7b41ca4b930d0fb688
Signed-off-by: Jonathan Wright <jonathan.wright@arm.com>
Spurious whitespace existed in the BINARY shell variable which meant
the cert_tool executable was not being removed on 'make realclean'.
Change-Id: Ibfd2fd17889514f6613e33c6df58d53b9232ec14
Since we use "?=" to set PLATFORM_ROOT, it is better to change the
name to be more special, or else it may be overridden by some
environment variables, such as in some CI build environments.
Signed-off-by: Heyi Guo <heyi.guo@linaro.org>
This patch updates the `fiptool` and `cert_create` for the
`hw_config` and `tb_fw_config` dynamic configuration files.
The necessary UUIDs and OIDs are assigned to these files and
the `cert_create` is updated to generate appropriate hashes
and include them in the "Trusted Boot FW Certificate". The
`fiptool` is updated to allow the configs to be specified
via cmdline and included in the generated FIP.
Change-Id: I940e751a49621ae681d14e162aa1f5697eb0cb15
Commit 880b9e8b4c99ad99eee14079d5a6162733ef4931 (Add padding at the end
of the last entry) added code using toc_entry pointer, whose memory is
already freed via variable buf. This causes enormous padding on openSUSE.
Free the memory buffer only after padding is done.
Signed-off-by: Andreas Färber <afaerber@suse.de>
This patch adds padding bytes at the end of the last image in the
fip to be able to transfer by DMA the last image.
Change-Id: I8c6f07dee389cb3d1dc919936d9d52841d7e5723
Signed-off-by: Dimitris Papastamos <dimitris.papastamos@arm.com>
Signed-off-by: David Cunado <david.cunado@arm.com>
This option enables the user to select the secure hash algorithm
to be used for generating the hash. It supports the following
options:
- sha256 (default)
- sha384
- sha512
Change-Id: Icb093cec1b5715e248c3d1c3749a2479a7ab4b89
Signed-off-by: Qixiang Xu <qixiang.xu@arm.com>
Updates are required to enable the fiptool utility to be built on a
Windows platform. This change modifies the source files to enable
building with Visual Studio (detected via preprocessor settings).
The primary changes are:
1. Provide an implementation of the getopt_long function. This does
not exist in the Visual Studio CRT libraries because Windows
commands normally use '/' not '-' as an option indicator.
2. Redirect some function names to match those supported by the
Visual Studio libraries (when building with Visual Studio).
2. Modify a structure name (stat) to match that provided
by the Visual Studio libraries (_stat).
Note - this change does not provide makefile updates. It only modifies
the sources to enable the fiptool to be built from a Visual
Studio project. In normal use the presence of FIPTOOL.EXE is
enough to satisfy the make requirements. A makefile change may
be derived from the Visual Studio command line information at
some point in the future.
Change-Id: I3ade77ea140246af3c030920b3f97c070087f111
Signed-off-by: Evan Lloyd <evan.lloyd@arm.com>
In order to compile the source of Fiptool using Visual Studio a number
of adjustments are required to the source. This commit modifies the
source with changes that will be required, but makes no functional
modification. The intent is to allow confirmation that the GCC build
is unaffected.
Change-Id: I4055bd941c646dd0a1aa2e24b940a1db3bf629ce
michpappas/tf-issues#521_cert_tool_does_not_build_with_openssl_v1.1
cert_tool: update for compatibility with OpenSSL v1.1
Commit a8eb286adaa73e86305317b9cae15d41c57de8e7 introduced the
following error when creating ECDSA certificates.
ERROR: Error creating key 'Trusted World key'
Makefile:634: recipe for target 'certificates' failed
make: *** [certificates] Error 1
this patch adds the function to create PKCS#1 v1.5.
Change-Id: Ief96d55969d5e9877aeb528c6bb503b560563537
This patch fixes incompatibility issues that prevent building the cert_tool
with OpenSSL >= v1.1.0. The changes introduced are still backwards
compatible with OpenSSL v1.0.2.
Fixes arm-software/trusted-fw#521
Signed-off-by: Michalis Pappas <mpappas@fastmail.fm>
Using the OIDs defined in tbbr_oids.h is the recommended way to build
the cert_create tool. This patch hence sets default value of the build
flag USE_TBBR_DEFS to 1 in the Makefile in `tools/cert_create` folder
when cert_create is built from this folder.
Fixes ARM-software/tf-issues#482
Change-Id: Id1d224826b3417770bccbefa1b68d9bdb3b567f0
This patch enables choice of RSA version at run time to be used for
generating signatures by the cert_tool. The RSA PSS as defined in
PKCS#1 v2.1 becomes the default version and this patch enables to specify
the RSA PKCS#1 v1.5 algorithm to `cert_create` through the command line
-a option. Also, the build option `KEY_ALG` can be used to pass this
option from the build system. Please note that RSA PSS is mandated
by Trusted Board Boot requirements (TBBR) and legacy RSA support is
being added for compatibility reasons.
Fixes ARM-Software/tf-issues#499
Change-Id: Ifaa3f2f7c9b43f3d7b3effe2cde76bf6745a5d73
Co-Authored-By: Eleanor Bonnici <Eleanor.bonnici@arm.com>
Unix does not distinguish binary and text modes.
On Windows the 'b' flag (e.g. "rb" instead of "r") is used to
indicate that files should be opened in binary mode.
This has no impact on Unix, but is needed on Windows to avoid
end-of-line issues.
Change-Id: I69424c55735d5d563d36c50bedd6357b8e05137e
Since Trusted OS firmware may have extra images, need to
assign new uuid and image id for them.
The TBBR chain of trust has been extended to add support
for the new images within the existing Trusted OS firmware
content certificate.
Change-Id: I678dac7ba1137e85c5779b05e0c4331134c10e06
Signed-off-by: Summer Qin <summer.qin@arm.com>
Fix order of #includes
