Change-Id: I18a4327e41fc090dcea9a647f7673182ca0ed1d9
Signed-off-by: dp-arm <dimitris.papastamos@arm.com>
Change-Id: I62c1a636eb0d9f73fa3a6356e32b5a44f268d421
Additionally, remove the -o option for the create command
as it is not supported.
Change-Id: I27993a6fc5e3b0b9710e2ec5322e4296bc87d0df
fiptool: fix Segmentation fault when only --verbose option is given
Fix the following bug:
$ tools/fiptool/fiptool -v
Segmentation fault (core dumped)
The `toc_entry` and `image` data structures had a cyclic
relationship. This patch removes the explicit dependencies and introduces
functions to link them via the UUID.
This change highlights the intent of the code better and makes it more
flexible for future enhancements.
Change-Id: I0c3dd7bfda2a631a3827c8ba4831849c500affe9
fiptool: Invoke command specific usage function
Instead of always calling the top level usage function when an
error is detected, call the command-specific usage function.
For example running `fiptool create` will produce the same output
as `fiptool help create`. This is more convenient for the user
when they make a mistake.
Change-Id: I60178ab89d47adf93cdfe6d8b5d5f778a5ea3bca
This feature allows one to quickly verify that the expected
image is contained in the FIP without extracting the image and
running sha256sum(1) on it.
The sha256 digest is only shown when the verbose flag is used.
This change requires libssl-dev to be installed in order to build
Trusted Firmware. Previously, libssl-dev was optionally needed only
to support Trusted Board Boot configurations.
Fixes ARM-Software/tf-issues#124
Change-Id: Ifb1408d17f483d482bb270a589ee74add25ec5a6
It should be 'fiptool' instead of 'fiptfool'.
Change-Id: I84ce1b6aaae5b8b33e5781bfe4f9e9cf462edb03
The output is shown only when built with V=1.
Change-Id: I17fef10df6f127f07956a78b478ff3cadba4bd61
Replace fip_create with fiptool
fiptool provides a more consistent and intuitive interface compared to
the fip_create program. It serves as a better base to build on more
features in the future.
fiptool supports various subcommands. Below are the currently
supported subcommands:
1) info - List the images contained in a FIP file.
2) create - Create a new FIP file with the given images.
3) update - Update an existing FIP with the given images.
4) unpack - Extract a selected set or all the images from a FIP file.
5) remove - Remove images from a FIP file. This is a new command that
was not present in fip_create.
To create a new FIP file, replace "fip_create" with "fiptool create".
To update a FIP file, replace "fip_create" with "fiptool update".
To dump the contents of a FIP file, replace "fip_create --dump" with
"fiptool info".
A compatibility script that emulates the basic functionality of
fip_create is provided. Existing scripts might or might not work with
the compatibility script. Users are strongly encouraged to migrate to
fiptool.
Fixes ARM-Software/tf-issues#87
Fixes ARM-Software/tf-issues#108
Fixes ARM-Software/tf-issues#361
Change-Id: I7ee4da7ac60179cc83cf46af890fd8bc61a53330
With the introduction of commit `96103d5a`, the Certificate
Generation tool is not able to generate FWU certificate and
while doing so it does segmentation fault.
This happens because it is now required to pass non-volatile
counter values to the `cert_create` tool from the command line
for creating the trusted firmware certificates.
But in case of creating FWU certificate these counter values are not
being passed to the tool and as a consequence the `cert_create` tool
try to use the NULL argument and errors out with Segmentation fault.
This patch fixes this issue by providing a check before using the
command line argument passed in the case of `EXT_TYPE_NVCOUNTER`
certificate extension.
Change-Id: Ie17d0c1502b52aaa8500f3659c2da2448ab0347a
* Move stdlib header files from include/stdlib to include/lib/stdlib for
consistency with other library headers.
* Fix checkpatch paths to continue excluding stdlib files.
* Create stdlib.mk to define the stdlib source files and include directories.
* Include stdlib.mk from the top level Makefile.
* Update stdlib header path in the fip_create Makefile.
* Update porting-guide.md with the new paths.
Change-Id: Ia92c2dc572e9efb54a783e306b5ceb2ce24d27fa
Change-Id: I0d298eea9eaf47121c87637c7395e5d9868aa272
fip_create: add support for image unpacking
Make improvements for host environment portability
This patch adds support for image unpacking to the FIP packaging
tool. Command line option '-u,--unpack' may be used to unpack the
contents of an existing FIP file into the working directory. The
tool uses default hardcoded filenames for the unpacked images. If
the files already exist, they can be overwritten by specifying the
option '-f,--force'.
Change-Id: I360b11d9c5403e8c0a7a9cac32c1d90ebb228063
In some build environments executable programs have a specific file
extension. The value of BIN_EXT is appended to the relevant tool file
names to allow for this.
The value of BIN_EXT is set, where appropriate, by the build environment
specific make helper (to .exe for Windows build environments).
.gitignore is updated to hide the new (.exe) files.
Change-Id: Icc32f64b750e425265075ad4e0dea18129640b86
Replace some "recursively expanded" make variables with "simply
expanded" variables (i.e. replace = with :=). This has no functional
impact but is more consistent and theoretically more efficient.
Change-Id: Iaf33d7c8ad48464ae0d39923515d1e7f230c95c1
Some build environments do not support symbolic links. This patch
removes the symlinks previously used to build fip_create and instead
copies the relevant header files.
The original motivation for using symlinks was to avoid Trusted Firmware
library headers conflicting with headers in the compiler standard
include path. Copying the header files instead has the same effect.
Like other build artefacts, the copied files are listed in .gitignore.
The distclean targets have also been updated to remove the copies.
Change-Id: Ie8b67bcb133f7f1d660ae93b857950aa15e42b1e
Add make helper files to select the appropriate settings for the build
environment. Selection is made in make_helpers/build_env.mk, which
selects other files to include using generic build environment settings.
The Trusted Firmware Makefile and supporting tool Makefiles are updated
to include build_env.mk instead of unix.mk.
NOTE: This change does not fully enable builds in other build
environments. It facilitates this without compromising the
existing build environments.
Change-Id: Ic4064ffe6ce158bbd16d7cc9f27dd4655a3580f6
Macros are inserted to replace direct invocations of commands that are
problematic on some build environments. (e.g. Some environments expect
\ in paths instead of /.)
The changes take into account mismatched command mappings across
environments.
The new helper file unix.mk retains existing makefile behaviour on unix
like build environments by providing the following macro definitions:
SHELL_COPY cp -f
SHELL_COPY_TREE cp -rf
SHELL_DELETE rm -f
SHELL_DELETE_ALL rm -rf
MAKE_PREREQ_DIR mkdir -p (As make target)
SHELL_REMOVE_DIR rm -rf
Change-Id: I1b5ca5e1208e78230b15284c4af00c1c006cffcb
Update the cert_create Makefile to list realclean as .PHONY
(like clean)
Change-Id: I9dc8a61a11574a044372e0952b5b12b74e133747
As an initial stage of making Trusted Firmware build environment more
portable, we remove most uses of the $(shell ) function and replace them
with more portable make function based solutions.
Note that the setting of BUILD_STRING still uses $(shell ) since it's
not possible to reimplement this as a make function. Avoiding invocation
of this on incompatible host platforms will be implemented separately.
Change-Id: I768e2f9a265c78814a4adf2edee4cc46cda0f5b8
This patch adds non-volatile counter support to the Certificate
Generation tool. The TBBR Chain of Trust definition in the tool
has been extended to include the counters as certificate extensions.
The counter values can be specified in the command line.
The following default counter values are specified in the build
system:
* Trusted FW Non-Volatile counter = 0
* Non-Trusted FW Non-Volatile counter = 0
These values can be overridden by the platform at build time.
Change-Id: I7ea10ee78d72748d181df4ee78a7169b3ef2720c
This patch introduces the following improvements:
* Global variables in fip_create.c declared static.
* Flags to signal the requested actions (do_dump, do_pack) made
global.
* The ToC is printed at the end of the main funcion, after the FIP
has been created/updated, not in the parse_cmdline() function.
* Short format added to the command line options (-d,--dump;
-h,--help).
* Help message updated.
Change-Id: I5f08273c76f1de45fe597e290bee4b60aa404df9
cert_create: update help message
The help message printed by the cert_create tool using the command
line option -h (or --help) does not correctly list all the available
command line options.
This patch reworks the print_help() function to print the help
messages in a data driven approach. For each command line option
registered, an optional help message can be specified, which will
be printed by print_help().
Help messages for the TBBR options (certificates, keys and images)
are also provided.
Fix a small bug in the short options string passed to getopt_long:
the ':' was missing in the '-a' option (this option must take an
argument).
Fixes ARM-software/tf-issues#337
Change-Id: I9d08c2dfd349022808fcc884724f677eefdc1452
Apply TBBR naming convention to the fip_create options
The fip_create tool specifies images in the command line using the
ARM TF naming convention (--bl2, --bl31, etc), while the cert_create
tool uses the TBBR convention (--tb-fw, --soc-fw, etc). This double
convention is confusing and should be aligned.
This patch updates the fip_create command line options to follow the
TBBR naming convention. Usage examples in the User Guide have been
also updated.
NOTE: users that build the FIP by calling the fip_create tool directly
from the command line must update the command line options in their
scripts. Users that build the FIP by invoking the main ARM TF Makefile
should not notice any difference.
Change-Id: I84d602630a2585e558d927b50dfde4dd2112496f
By default ARM TF is built with the '-pedantic' compiler flag, which
helps detecting violations of the C standard. However, the mbed TLS
library and its associated authentication module in TF used to fail
building with this compiler flag. As a workaround, the mbed TLS
authentication module makefile used to set the 'DISABLE_PEDANTIC'
TF build flag.
The compiler errors flagged by '-pedantic' in the mbed TLS library
have been fixed between versions 1.3.9 and 2.2.0 and the library now
properly builds with this compiler flag.
This patch fixes the remaining compiler errors in the mbed TLS
authentication module in TF and unsets the 'DISABLE_PEDANTIC' TF
build flag. This means that TF is now always built with '-pedantic'.
In particular, this patch:
* Removes the final semi-colon in REGISTER_COT() macro.
This semi-colon was causing the following error message:
drivers/auth/tbbr/tbbr_cot.c:544:23: error: ISO C does not allow
extra ';' outside of a function [-Werror=pedantic]
This has been fixed both in the mbed TLS authentication module
as well as in the certificate generation tool. Note that the latter
code didn't need fixing since it is not built with '-pedantic' but
the change has been propagated for consistency.
Also fixed the REGISTER_KEYS() and REGISTER_EXTENSIONS() macros,
which were suffering from the same issue.
* Fixes a pointer type.
It was causing the following error message:
drivers/auth/mbedtls/mbedtls_crypto.c: In function 'verify_hash':
drivers/auth/mbedtls/mbedtls_crypto.c:177:42: error: pointer of
type 'void *' used in arithmetic [-Werror=pointer-arith]
Change-Id: I7b7a04ef711efd65e17b5be26990d1a0d940257d
This patch removes the dash character from the image name, to
follow the image terminology in the Trusted Firmware Wiki page:
https://github.com/ARM-software/arm-trusted-firmware/wiki
Changes apply to output messages, comments and documentation.
non-ARM platform files have been left unmodified.
Change-Id: Ic2a99be4ed929d52afbeb27ac765ceffce46ed76
This patch replaces all references to the SCP Firmware (BL0, BL30,
BL3-0, bl30) with the image terminology detailed in the TF wiki
(https://github.com/ARM-software/arm-trusted-firmware/wiki):
BL0 --> SCP_BL1
BL30, BL3-0 --> SCP_BL2
bl30 --> scp_bl2
This change affects code, documentation, build system, tools and
platform ports that load SCP firmware. ARM plaforms have been
updated to the new porting API.
IMPORTANT: build option to specify the SCP FW image has changed:
BL30 --> SCP_BL2
IMPORTANT: This patch breaks compatibility for platforms that use BL2
to load SCP firmware. Affected platforms must be updated as follows:
BL30_IMAGE_ID --> SCP_BL2_IMAGE_ID
BL30_BASE --> SCP_BL2_BASE
bl2_plat_get_bl30_meminfo() --> bl2_plat_get_scp_bl2_meminfo()
bl2_plat_handle_bl30() --> bl2_plat_handle_scp_bl2()
Change-Id: I24c4c1a4f0e4b9f17c9e4929da815c4069549e58
This patch applies the TBBR naming convention to the certificates
and the corresponding extensions defined by the CoT:
* Certificate UUID names
* Certificate identifier names
* OID names
Changes apply to:
* Generic code (variables and defines)
* The default certificate identifiers provided in the generic
code
* Build system
* ARM platforms port
* cert_create tool internal definitions
* fip_create and cert_create tools command line options
* Documentation
IMPORTANT: this change breaks the compatibility with platforms
that use TBBR. The platform will need to adapt the identifiers
and OIDs to the TBBR naming convention introduced by this patch:
Certificate UUIDs:
UUID_TRUSTED_BOOT_FIRMWARE_BL2_CERT --> UUID_TRUSTED_BOOT_FW_CERT
UUID_SCP_FIRMWARE_BL30_KEY_CERT --> UUID_SCP_FW_KEY_CERT
UUID_SCP_FIRMWARE_BL30_CERT --> UUID_SCP_FW_CONTENT_CERT
UUID_EL3_RUNTIME_FIRMWARE_BL31_KEY_CERT --> UUID_SOC_FW_KEY_CERT
UUID_EL3_RUNTIME_FIRMWARE_BL31_CERT --> UUID_SOC_FW_CONTENT_CERT
UUID_SECURE_PAYLOAD_BL32_KEY_CERT --> UUID_TRUSTED_OS_FW_KEY_CERT
UUID_SECURE_PAYLOAD_BL32_CERT --> UUID_TRUSTED_OS_FW_CONTENT_CERT
UUID_NON_TRUSTED_FIRMWARE_BL33_KEY_CERT --> UUID_NON_TRUSTED_FW_KEY_CERT
UUID_NON_TRUSTED_FIRMWARE_BL33_CERT --> UUID_NON_TRUSTED_FW_CONTENT_CERT
Certificate identifiers:
BL2_CERT_ID --> TRUSTED_BOOT_FW_CERT_ID
BL30_KEY_CERT_ID --> SCP_FW_KEY_CERT_ID
BL30_CERT_ID --> SCP_FW_CONTENT_CERT_ID
BL31_KEY_CERT_ID --> SOC_FW_KEY_CERT_ID
BL31_CERT_ID --> SOC_FW_CONTENT_CERT_ID
BL32_KEY_CERT_ID --> TRUSTED_OS_FW_KEY_CERT_ID
BL32_CERT_ID --> TRUSTED_OS_FW_CONTENT_CERT_ID
BL33_KEY_CERT_ID --> NON_TRUSTED_FW_KEY_CERT_ID
BL33_CERT_ID --> NON_TRUSTED_FW_CONTENT_CERT_ID
OIDs:
TZ_FW_NVCOUNTER_OID --> TRUSTED_FW_NVCOUNTER_OID
NTZ_FW_NVCOUNTER_OID --> NON_TRUSTED_FW_NVCOUNTER_OID
BL2_HASH_OID --> TRUSTED_BOOT_FW_HASH_OID
TZ_WORLD_PK_OID --> TRUSTED_WORLD_PK_OID
NTZ_WORLD_PK_OID --> NON_TRUSTED_WORLD_PK_OID
BL30_CONTENT_CERT_PK_OID --> SCP_FW_CONTENT_CERT_PK_OID
BL30_HASH_OID --> SCP_FW_HASH_OID
BL31_CONTENT_CERT_PK_OID --> SOC_FW_CONTENT_CERT_PK_OID
BL31_HASH_OID --> SOC_AP_FW_HASH_OID
BL32_CONTENT_CERT_PK_OID --> TRUSTED_OS_FW_CONTENT_CERT_PK_OID
BL32_HASH_OID --> TRUSTED_OS_FW_HASH_OID
BL33_CONTENT_CERT_PK_OID --> NON_TRUSTED_FW_CONTENT_CERT_PK_OID
BL33_HASH_OID --> NON_TRUSTED_WORLD_BOOTLOADER_HASH_OID
BL2U_HASH_OID --> AP_FWU_CFG_HASH_OID
SCP_BL2U_HASH_OID --> SCP_FWU_CFG_HASH_OID
NS_BL2U_HASH_OID --> FWU_HASH_OID
Change-Id: I1e047ae046299ca913911c39ac3a6e123bd41079
Firmware Update (FWU) introduces a new set of images called
SCP_BL2U, BL2U and NS_BL2U, which can be packed in a FWU FIP file.
This patch introduces new UUIDs for the Firmware Update images
and extends the 'fip'create' tool so that these new images can be
packed in a FIP file.
Change-Id: I7c60211b4f3cc265411efb131e6d3c624768f522
Firmware Update requires an X509v3 certificate which contains
hashes for SCP_BL2U, BL2U and NS_BL2U images as extensions.
This patch extends the Chain of Trust definition in the
'cert_create' tool to include the Firmware Update certificate
and the required extensions (including command line options).
A new field in the extension structure will be used to indicate
that the extension is optional. In the case of an image hash
extension, this field will tell the tool that the hash should
be included in the certificate, but filled with zeros.
Change-Id: I1f77a66b018826b71745910771f38d9cf6050388
This patch introduces a new API that allows to specify command
line options in the Chain of Trust description. These command line
options may be used to specify parameters related to the CoT (i.e.
keys or certificates), instead of keeping a hardcoded list of
options in main.c.
Change-Id: I282b0b01cb9add557b26bddc238a28253ce05e44
The certificate generation tool currently checks if all command
line options required to create all certificates in the CoT have
been specified. This prevents using the tool to create individual
certificates when the whole CoT is not required.
This patch improves the checking function so only those options
required by the certificates specified in the command line are
verified.
Change-Id: I2c426a8e2e2dec85b15f2d98fd4ba949c1aed385
This patch reworks the certificate generation tool to follow a data
driven approach. The user may specify at build time the certificates,
keys and extensions defined in the CoT, register them using the
appropiate macros and the tool will take care of creating the
certificates corresponding to the CoT specified.
Change-Id: I29950b39343c3e1b71718fce0e77dcf2a9a0be2f
Some Linux distributions include an OpenSSL library which has been
built without ECDSA support. Trying to build the certificate
generation tool on those distributions will result in a build error.
This patch fixes that issue by including ECDSA support only if
OpenSSL has been built with ECDSA. In that case, the OpenSSL
configuration file does not define the OPENSSL_NO_EC macro. The tool
will build successfully, although the resulting binary will not
support ECDSA keys.
Change-Id: I4627d1abd19eef7ad3251997d8218599187eb902
This patch extends the 'cert_create' tool to support ECDSA keys
to sign the certificates. The '--key-alg' command line option
can be used to specify the key algorithm when invoking the tool.
Available options are:
* 'rsa': create RSA-2048 keys (default option)
* 'ecdsa': create ECDSA-SECP256R1 keys
The TF Makefile has been updated to allow the platform to specify
the key algorithm by declaring the 'KEY_ALG' variable in the
platform makefile.
The behaviour regarding key management has changed. After applying
this patch, the tool will try first to open the keys from disk. If
one key does not exist or no key is specified, and the command line
option to create keys has been specified, new keys will be created.
Otherwise an error will be generated and the tool will exit. This
way, the user may specify certain keys while the tool will create
the remaining ones. This feature is useful for testing purposes
and CI infrastructures.
The OpenSSL directory may be specified using the build option
'OPENSSL_DIR' when building the certificate generation tool.
Default is '/usr'.
Change-Id: I98bcc2bfab28dd7179f17f1177ea7a65698df4e7
The cert_create tool calculates the hash of each BL image and includes
it as an ASN.1 OCTET STRING in the corresponding certificate extension.
Without additional information, the firmware running on the platform
has to know in advance the algorithm used to generate the hash.
This patch modifies the cert_create tool so the certificate extensions
that include an image hash are generated according to the following
ASN.1 structure:
DigestInfo ::= SEQUENCE {
digestAlgorithm AlgorithmIdentifier,
digest OCTET STRING
AlgorithmIdentifier ::= SEQUENCE {
algorithm OBJECT IDENTIFIER,
parameters ANY DEFINED BY algorithm OPTIONAL
The PolarSSL module has been updated to extract the image hash
from the certificate extension according to this structure.
Change-Id: I6d83430f12a8a0eea8447bec7c936e903f644c85
Update the top level makefile to allow platform ports to exist in
subdirectories at any level instead of one level under `plat/`. The
makefile recursively searches for all files called `platform.mk` in
all subdirectories of `plat/`. The directory containing
`platform.mk` is the platform name. Platform names must be unique
across the codebase.
Replace usage of HELP_PLATFORMS in the Makefile with PLATFORMS since
these are both used to report the same information back to the user.
Update the TSP and cert_create tool makefiles in a similar way
to support a deeper platform port directory structure.
Also add PLAT_<plat_name> as a define passed through the top level
makefile to the source files, to allow build time variation in common
platform code.
Change-Id: I213420164808c5ddb99a26144e8e3f141a7417b7
This patch replaces SHA1 by SHA256 in the 'cert_create' tool, so
certificate signatures are generated according to the NSA Suite B
cryptographic algorithm requirements.
Documentation updated accordingly.
Change-Id: I7be79e6b2b62dac8dc78a4f4f5006e37686bccf6
This patch extends the FIP tool to include the certificates
generated by the 'cert_create' tool.
If GENERATE_COT build option is enabled, the Makefile adds the
certificates as dependencies to create the FIP file. Thus, make
target 'fip' will also build the certificates as part of the
Trusted Firmware build process.
Change-Id: I5eee500da7f7be6cfb6e3df0423599739d260074
This patch adds a tool that generates all the necessary elements
to establish the chain of trust (CoT) between the images.
The tool reads the binary images and signing keys and outputs the
corresponding certificates that will be used by the target at run
time to verify the authenticity of the images.
Note: the platform port must provide the file platform_oid.h. This
file will define the OIDs of the x509 extensions that will be added
to the certificates in order to establish the CoT.
Change-Id: I2734d6808b964a2107ab3a4805110698066a04be
If one of the files passed to fip_create on the command line doesn't
exist, it will print an error message but produce an incomplete
fip.bin file and report success. This behaviour could potentially
hide errors made in the command line arguments.
This patch addresses the issue by having the tool bail out if one of
the supplied files can't be processed.
Signed-off-by: Kévin Petit <kevin.petit@arm.com>
Fixes ARM-software/tf-issues#279
Change-Id: I1c7d87d09eb4c063005b7969bdaad1d043c29dec
The 'fiptool' target doesn't depend on fip_create's source files,
neither directly nor indirectly. As a result, the FIP tool is not
rebuilt whenever its source files change.
This patch makes the ${FIPTOOL} target into a phony target so that the
FIP tool's sub-makefile is always called. The sub-makefile correctly
handles the dependencies. It also moves the completion message into
the sub-makefile so that it is only displayed when the tool is
actually recompiled.
Fixes ARM-software/tf-issues#278
Change-Id: Ia027519fe51d3c42be30665d1ad20a7b89fa350f
