Change-Id: If57ec9cc0791f49d9ade83dff9d24ef9047963a8
Co-authored-by: Jean-Paul Etienne <jean-paul.etienne@arm.com>
Signed-off-by: Antonio Nino Diaz <antonio.ninodiaz@arm.com>
Introduce SMCs that open and close handles according to the SPCI
specification.
Change-Id: I65f365f15612e01aa445e783e96e48ae275c39fd
Change-Id: I2ae9b3bb686c41b2e138132a7bed107925ac861e
Change-Id: Ib7c2529b85bb5930d44907edfc8ead13d3b1ef4d
Co-authored-by: Sandrine Bailleux <sandrine.bailleux@arm.com>
Change-Id: I6673a5f8c2f6afa7780483e0ce8d4dad4c8dc8ea
Remove interfaces based on MM_COMMUNICATE.
Change-Id: I628c884b91d9f4758269ea2c4dedc37a66bb93cf
SPM needs to map a number of regions on behalf of the secure partition.
Previously, it used to get a list of them from platform code using the
plat_get_secure_partition_mmap() API. Now it gets them from the resource
description structure.
The SPM<->SP shared buffer is mapped dynamically at EL3. This buffer is
used to pass information between SPM and SP, so it must be mapped at EL3
as well in order to be used by SPM.
Dynamic translation tables have been enabled when the Trusted Firmware
is compiled with SPM support.
Change-Id: I64ad335e931661812a0a60558e60372e1e5e6b72
Read entrypoint of the Secure Partition from the resource description
struct.
Change-Id: Ie693c7b4d4fecafd85b6934d9d8c4232efb1dc55
Load SP and RD from package instead of relying on RD being already
loaded in memory and the SP being loaded as a BL32 image.
Change-Id: I18d4fbf4597656c6a7e878e1d7c01a8a324f3f8a
This information is retrieved from the resource description now.
Change-Id: Iaae23945eb2c45305cdc6442853e42f4e04fe094
This information is defined by the Secure Partition in the resource
description.
Change-Id: Ia7db90c5de8360a596106880d3f6a632a88d3ea8
The current SPM is a prototype that only supports one secure partition
in EL0. The objective of SPM is to have multiple partitions. The current
MM interface isn't adequate for this, so it is needed to modify heavily
the code to add proper support for it.
However, there are platforms which are already using this (like SGI) and
removing the code would break it. For this reason, the current SPM code
has been duplicated in order to temporarily preserve compatibility. All
new improvements/changes to SPM will be done in the non-deprecated copy,
that may change without notice.
The new build option SPM_DEPRECATED has been introduced to select the SPM
implementation. It defaults to 1, that selects the deprecated SPM.
Change-Id: Ic9f80b53b450e97b4d3f47e4ef4a138ee8d87443
The Armv8.5 extensions introduces PSTATE.SSBS (Speculation Store Bypass
Safe) bit to mitigate against Variant 4 vulnerabilities. Although an
Armv8.5 feature, this can be implemented by CPUs implementing earlier
version of the architecture.
With this patch, when both PSTATE.SSBS is implemented and
DYNAMIC_WORKAROUND_CVE_2018_3639 is active, querying for
SMCCC_ARCH_WORKAROUND_2 via. SMCCC_ARCH_FEATURES call would return 1 to
indicate that mitigation on the PE is either permanently enabled or not
required.
When SSBS is implemented, SCTLR_EL3.DSSBS is initialized to 0 at reset
of every BL stage. This means that EL3 always executes with mitigation
applied.
For Cortex A76, if the PE implements SSBS, the existing mitigation (by
using a different vector table, and tweaking CPU ACTLR2) is not used.
Change-Id: Ib0386c5714184144d4747951751c2fc6ba4242b6
Signed-off-by: Jeenu Viswambharan <jeenu.viswambharan@arm.com>
Secure world execution nearly always expect a controlled exit to
Non-secure world. SDEI interrupts, although targets EL3, occur on behalf
of Non-secure world, and may have higher priority than Secure world
interrupts. Therefore they might preempt Secure execution, and yield
execution to Non-secure SDEI handler. Upon completion of SDEI event
handling (regardless of whether it's COPLETE or COMPLETE_AND_RESUME), we
must resume Secure execution if it was preempted.
Change-Id: I6edd991032588588427ba2fe6c3d7668f7080e3d
The current secure partition design mandates that a) at a point, only
a single core can be executing in the secure partition, and b) a core
cannot be preempted by an interrupt while executing in secure
partition.
Ensure this by activating the SPM priority prior to entering the
parition. Deactivate the priority on return from the
partition.
Change-Id: Icb3473496d16b733564592eef06304a1028e4f5c
Signed-off-by: Sughosh Ganu <sughosh.ganu@arm.com>
All identifiers, regardless of use, that start with two underscores are
reserved. This means they can't be used in header guards.
The style that this project is now to use the full name of the file in
capital letters followed by 'H'. For example, for a file called
"uart_example.h", the header guard is UART_EXAMPLE_H.
The exceptions are files that are imported from other projects:
- CryptoCell driver
- dt-bindings folders
- zlib headers
Change-Id: I50561bf6c88b491ec440d0c8385c74650f3c106e
This patch includes context.h from sdei_private.h to fix the
following compilation errors:
<snip>
In file included from services/std_svc/sdei/sdei_event.c:9:0:
services/std_svc/sdei/sdei_private.h: In function 'sdei_client_el':
services/std_svc/sdei/sdei_private.h:164:2: error: unknown type name 'cpu_context_t'
cpu_context_t *ns_ctx = cm_get_context(NON_SECURE);
services/std_svc/sdei/sdei_private.h:165:2: error: unknown type name 'el3_state_t'
el3_state_t *el3_ctx = get_el3state_ctx(ns_ctx);
services/std_svc/sdei/sdei_private.h:165:2: error: implicit declaration of function 'get_el3state_ctx' [-Werror=implicit-function-declaration]
services/std_svc/sdei/sdei_private.h:165:25: error: initialization makes pointer from integer without a cast [-Werror]
services/std_svc/sdei/sdei_private.h:167:2: error: implicit declaration of function 'read_ctx_reg' [-Werror=implicit-function-declaration]
return ((read_ctx_reg(el3_ctx, CTX_SCR_EL3) & SCR_HCE_BIT) != 0U) ?
services/std_svc/sdei/sdei_private.h:167:33: error: 'CTX_SCR_EL3' undeclared (first use in this function)
services/std_svc/sdei/sdei_private.h:167:33: note: each undeclared identifier is reported only once for each function it appears in
cc1: all warnings being treated as errors
<snip>
Change-Id: Id0cad56accf81b19cb0d301784f3f086dd052722
Ensure the flow through switch statements is clear
Change-Id: Icd1cdd42afdc78895a9be6c46b414b0a155cfa63
Ensure case clauses:
* Terminate with an unconditional break, return or goto statement.
* Use conditional break, return or goto statements as long as the end
of the case clause is unreachable; such case clauses must terminate
with assert(0) /* Unreachable */ or an unconditional __dead2 function
call
* Only fallthough when doing otherwise would result in less
readable/maintainable code; such case clauses must terminate with a
/* Fallthrough */ comment to make it clear this is the case and
indicate that a fallthrough is intended.
This reduces the chance of bugs appearing due to unintended flow through a
switch statement
Change-Id: I70fc2d1f4fd679042397dec12fd1982976646168
Signed-off-by: Daniel Boulby <daniel.boulby@arm.com>
The value used to signal failure is 0. It is needed to return a different
value on success.
Change-Id: I2186aa7dfbfc825bfe7b3d5ae3c4de7af10ee44f
The specification requires that, after wakeup from a CPU suspend, the
dispatcher must mask all events on the CPU. This patch adds the feature
to the SDEI dispatcher by subscribing to the PSCI suspend to power down
event, and masking all events on the PE.
Change-Id: I9fe1d1bc2a58379ba7bba953a8d8b275fc18902c
Some platforms might chose to take different actions depending on this
value; this is precisely the case for rcar-gen3.
Signed-off-by: Jorge Ramirez-Ortiz <jramirez@baylibre.com>
tf_printf and tf_snprintf are now called printf and snprintf, so the
code needs to be updated.
Change-Id: Iffeee97afcd6328c4c2d30830d4923b964682d71
The codebase was using non-standard headers. It is needed to replace
them by the correct ones so that we can use the new libc headers.
Change-Id: I530f71d9510cb036e69fe79823c8230afe890b9d
Acked-by: Sumit Garg <sumit.garg@linaro.org>
The event lock for a shared event was being unlocked twice, and the
locking sequence for event complete was misplaced. This patch fixes both
issues.
Change-Id: Ie2fb15c6ec240af132d7d438946ca160bd5c63dc
These changes address most of the required MISRA rules. In the process,
some from generic code is also fixed.
No functional changes.
Change-Id: I6235a355e006f0b1c7c1c4d811b3964a64d0434f
Replace stdio.h functions by TF functions
Functions provided by stdio.h such as printf and sprintf are available
in the codebase, but they add a lot of code to the final image if they
are used:
- AArch64: ~4KB
- AArch32: ~2KB in T32, ~3KB in A32
tf_printf and tf_snprintf are a lot more simple, but it is preferable
to use them when possible because they are also used in common code.
Change-Id: Id09fd2b486198fe3d79276e2c27931595b7ba60e
Acked-by: Haojian Zhuang <haojian.zhuang@linaro.org>
Changed the names for consistency with the rest of the library. Introduced
new helpers that manipulate the active translation tables context.
Change-Id: Icaca56b67fcf6a96e88aa3c7e47411162e8e6856
Fix the types of the arguments of trusty_generic_platform_smc()
to match the expected prototype of a runtime service handler
(see rt_svc_handle_t type).
Change-Id: Ie839d116ca924b4b018ea2abbef72a1073da2a32
Signed-off-by: Sandrine Bailleux <sandrine.bailleux@arm.com>
xlat: More refactoring
Instead of having a different initialization routine than the rest of
the codebase, use the common implementation.
Change-Id: I27c03b9905f3cf0af8810aad9e43092005387a1a
Fix mismatches between the format specifier and the corresponding
variable type.
Change-Id: Ib9004bd9baa9ba24a50000bea4f2418e1bf7e743
Wherever we use 'struct foo' and 'foo_t' interchangeably in a
function's declaration and definition, use 'struct foo' consistently
for both, as per the TF-A coding guidelines [1].
[1] https://github.com/ARM-software/arm-trusted-firmware/wiki/ARM-Trusted-Firmware-Coding-Guidelines#avoid-anonymous-typedefs-of-structsenums-in-header-files
Change-Id: I7998eb24a26746e87e9b6425529926406745b721
Check_vector_size checks if the size of the vector fits
in the size reserved for it. This check creates problems in
the Clang assembler. A new macro, end_vector_entry, is added
and check_vector_size is deprecated.
This new macro fills the current exception vector until the next
exception vector. If the size of the current vector is bigger
than 32 instructions then it gives an error.
Change-Id: Ie8545cf1003a1e31656a1018dd6b4c28a4eaf671
Signed-off-by: Roberto Vargas <roberto.vargas@arm.com>
Make TF UUID RFC 4122 compliant
The function end_sdei_explicit_dispatch() was intended to be
end_sdei_synchronous_dispatch() which does the opposite of
begin_sdei_synchronous_dispatch(). This patch fixes that.
Change-Id: I141bd91eb342ecf4ddfd05b49513eee4549e7a56
commit 2ccfcb2ea555eb86122e7780010cc50fcee08f54 ("SDEI: Determine client
EL from NS context's SCR_EL3") intended to read from SCR_EL3, but
wrongly read from SPSR_EL3 instead. This patch fixes that.
Change-Id: I8ffea39cc98ef59cb8e7a4c6ef4cb12011c58536
The Commit cdb6ac94ecb3c4caa784cd4d7580cf6252146196 introduced a bug
because of which the SDEI dispatcher wrongly panic when an SDEI event
dispatched earlier as a result of interrupt. This patch fixes the check
for a bound interrupt.
Change-Id: If55c8f0422ff781731248bbbc9c1b59fa0d3c4b0
SDEI dispatch changes to enable RAS use cases
SDEI event dispatches currently only sets up the Non-secure context
before returning to the caller. The actual dispatch only happens upon
exiting EL3 next time.
However, for various error handling scenarios, it's beneficial to have
the dispatch happen synchronously. I.e. when receiving SDEI interrupt,
or for a successful sdei_dispatch_event() call, the event handler is
executed; and upon the event completion, dispatcher execution resumes
after the point of dispatch. The jump primitives introduced in the
earlier patch facilitates this feature.
With this patch:
- SDEI interrupts and calls to sdei_dispatch_event prepares the NS
context for event dispatch, then sets a jump point, and immediately
exits EL3. This results in the client handler executing in
Non-secure.
- When the SDEI client completes the dispatched event, the SDEI
dispatcher does a longjmp to the jump pointer created earlier. For
the caller of the sdei_dispatch_event() in particular, this would
appear as if call returned successfully.
The dynamic workaround for CVE_2018_3639 is slightly shifted around as
part of related minor refactoring. It doesn't affect the workaround
functionality.
Documentation updated.
NOTE: This breaks the semantics of the explicit dispatch API, and any
exiting usages should be carefully reviewed.
Change-Id: Ib9c876d27ea2af7fb22de49832e55a0da83da3f9
Currently, the dispatcher reads from SCR_EL3 register directly to
determine the EL of SDEI client. This is with the assumption that
SCR_EL3 is not modified throughout. However, with RAS work flows, it's
possible that SCR_EL3 register contains values corresponding to Secure
world, and therefore EL determination can go wrong. To mitigate this,
always read the register from the saved Non-secure context.
Change-Id: Ic85e4021deb18eb58757f676f9a001174998543a
The current macros only allow to define dynamic and statically-bound
SDEI events. However, there ought be a mechanism to define SDEI events
that are explicitly dispatched; i.e., events that are dispatched as a
result of a previous secure interrupt or other exception
This patch introduces SDEI_EXPLICIT_EVENT() macro to define an explicit
event. They must be placed under private mappings. Only the priority
flags are allowed to be additionally specified.
Change-Id: I2e12f5571381195d6234c9dfbd5904608ad41db3
It may be needed to enter the Secure Partition through other means than
an MM_COMMUNICATE SMC. This patch enables this behaviour by extracting
the necessary code from mm_communicate() and allowing other parts of the
code to use it.
Change-Id: I59f6638d22d9c9d0baff0984f39d056298a8dc8e
Only use synchronous calls to enter the Secure Partition in order to
simplify the SMC handling code.
Change-Id: Ia501a045585ee0836b9151141ad3bd11d0971be2
RFC4122 defines that fields are stored in network order (big endian),
but TF-A stores them in machine order (little endian by default in TF-A).
We cannot change the future UUIDs that are already generated, but we can store
all the bytes using arrays and modify fiptool to generate the UUIDs with
the correct byte order.
Change-Id: I97be2d3168d91f4dee7ccfafc533ea55ff33e46f
Minor fixes to SPM
The function xlat_arch_is_granule_size_supported() can be used to check
if a specific granule size is supported. In Armv8, AArch32 only supports
4 KiB pages. AArch64 supports 4 KiB, 16 KiB or 64 KiB depending on the
implementation, which is detected at runtime.
The function xlat_arch_get_max_supported_granule_size() returns the max
granule size supported by the implementation.
Even though right now they are only used by SPM, they may be useful in
other places in the future. This patch moves the code currently in SPM
to the xlat tables lib so that it can be reused.
Change-Id: If54624a5ecf20b9b9b7f38861b56383a03bbc8a4
In the context management library, cm_setup_context() takes the
information in ep_info to fill the registers x0-x7. This patch replaces
the current code that sets them manually by the correct initialization
code.
Change-Id: Id1fdf4681b154026c2e3af1f9b05b19582b7d16d
