* changes:
Fix Coverity #261967, Infinite loop
Fix Coverity #343017, Missing unlock
Fix Coverity #343008, Side affect in assertion
Fix Coverity #342970, Uninitialized scalar variable
All other returns from this function unlock the responses_lock, so we
also should release the lock in this case.
Change-Id: Ie2cfa8755723fed79e809f9480190d11f373a217
Signed-off-by: Justin Chadwell <justin.chadwell@arm.com>
Enable dispatcher to save/restore unbanked timer registers. So that
both secure (OP-TEE) and non-secure (Linux) worlds can have independent
access control over timer registers.
Signed-off-by: Sumit Garg <sumit.garg@linaro.org>
Change-Id: I4d58d5ff8298587ed478c8433fcbc3aef538d668
NOTE: AARCH32/AARCH64 macros are now deprecated in favor of __aarch64__.
All common C compilers pre-define the same macros to signal which
architecture the code is being compiled for: __arm__ for AArch32 (or
earlier versions) and __aarch64__ for AArch64. There's no need for TF-A
to define its own custom macros for this. In order to unify code with
the export headers (which use __aarch64__ to avoid another dependency),
let's deprecate the AARCH32 and AARCH64 macros and switch the code base
over to the pre-defined standard macro. (Since it is somewhat
unintuitive that __arm__ only means AArch32, let's standardize on only
using __aarch64__.)
Change-Id: Ic77de4b052297d77f38fc95f95f65a8ee70cf200
Signed-off-by: Julius Werner <jwerner@chromium.org>
NOTE: __ASSEMBLY__ macro is now deprecated in favor of __ASSEMBLER__.
All common C compilers predefine a macro called __ASSEMBLER__ when
preprocessing a .S file. There is no reason for TF-A to define it's own
__ASSEMBLY__ macro for this purpose instead. To unify code with the
export headers (which use __ASSEMBLER__ to avoid one extra dependency),
let's deprecate __ASSEMBLY__ and switch the code base over to the
predefined standard.
Change-Id: Id7d0ec8cf330195da80499c68562b65cb5ab7417
The project has been renamed from "Arm Trusted Firmware (ATF)" to
"Trusted Firmware-A (TF-A)" long ago. A few references to the old
project name that still remained in various places have now been
removed.
This change doesn't affect any platform files. Any "ATF" references
inside platform files, still remain.
Change-Id: Id97895faa5b1845e851d4d50f5750de7a55bf99e
Signed-off-by: John Tsichritzis <john.tsichritzis@arm.com>
The spm_sp_get_by_uuid() function is used to look up the secure
partition that provides a given service.
Within this function, memcmp() is used to compare the service
UUIDs but it uses the size of the rdsvc->uuid pointer instead of
the size of its content (missing dereference). This means that only
a partial comparison is performed as UUIDs are 128 bits in length and
rdsvc->uuid is a uint32_t typed pointer.
Instead, use the size of the array pointed to by the svc_uuid parameter,
which will be the full 128 bits, for the comparison.
Change-Id: I258fb0cca3bf19f97b8f2a4c133981647cd050e4
Signed-off-by: Paul Beesley <paul.beesley@arm.com>
Now it is needed to use the full path of the common header files.
Commit 09d40e0e0828 ("Sanitise includes across codebase") provides more
information.
Change-Id: Ifedc79d9f664d208ba565f5736612a3edd94c647
Signed-off-by: Ambroise Vincent <ambroise.vincent@arm.com>
Rather than using a fixed virtual address space size, read all regions
in the resource description of each partition and restrict the virtual
address space size to the one the partition actually needs.
This also allows SPM to take advantage of the extension ARMv8.4-TTST if
the virtual address space size is small enough.
Change-Id: I8646aa95e659136b58b44b040364cdee631f7e82
Signed-off-by: Antonio Nino Diaz <antonio.ninodiaz@arm.com>
Right now the virtual address space is fixed to
PLAT_VIRT_ADDR_SPACE_SIZE, so all base translation tables are the same
size and need the same alignment. The current code allocates the exact
space needed by this initial table.
However, a following patch is going to allow each partition to choose
the size of its address space based on the memory regions defined in
their resource description, so it isn't possible to determine this at
build time. As this optimization no longer applies, it has to be
removed.
Change-Id: Ia8d19f4981e1017e4ffe0ba136de73d701044cb0
This gives each Secure Partition complete freedom on its address space.
Previously, the memory used by the exception vectors was reserved and
couldn't be used. Also, it always had to be mapped, forcing SPM to
generate translation tables that included the exception vectors as well
as the Partition memory regions. With this change, partitions can reduce
their address space size easily.
Change-Id: I67fb5e9bdf2870b73347f23bff702fab0a8f8711
Instead of letting the code run until another error is reached, return
early.
Change-Id: I6277a8c65101d3e39b0540099c2a3063584a7dbd
Fix variable shadowing warnings and prevent code duplication.
Change-Id: Idb29cc95d6b6943bc012d7bd430afa0e4a7cbf8c
Improved support for W=2 compilation flag by solving some nested-extern
and sign-compare warnings.
The libraries are compiling with warnings (which turn into errors with
the Werror flag).
Outside of libraries, some warnings cannot be fixed.
Change-Id: I06b1923857f2a6a50e93d62d0274915b268cef05
Improved support for W=1 compilation flag by solving missing-prototypes
and old-style-definition warnings.
the Werror flag).
Outside of libraries, some warnings cannot be fixed without heavy
structural changes.
Change-Id: I1668cf99123ac4195c2a6a1d48945f7a64c67f16
SSBS support is determined by checking ID_AA64PFR1_EL1 and not
ID_AA64PFR0_EL1.
Fixes ARM-Software/tf-issues#679
Change-Id: I8ecba13b850995ec6a6ede3c2a1e02e69a3a95db
Signed-off-by: Dimitris Papastamos <dimitris.papastamos@arm.com>
The GIC definitions used in this file have to be provided by the platform
but platform_def.h wasn't included.
Change-Id: I858cdf7e60c50577c8e798d64ec2cbc4f067f33b
fvp: trusty: Move dynamic xlat enable to platform
Since commit 01fc1c24b9a0 ("BL31: Use helper function to save registers
in SMC handler") all the general-purpose registers are saved when
entering EL3. It isn't needed to save them here.
Change-Id: Ic540a5441b89b70888da587ab8fc3b2508cef8cc
Rather than letting the Trusty makefile set the option to enable dynamic
translation tables, make platforms do it themselves.
This also allows platforms to replace the implementation of the
translation tables library as long as they use the same function
prototypes.
Change-Id: Ia60904f61709ac323addcb57f7a83391d9e21cd0
Commit 09d40e0e0828 ("Sanitise includes across codebase") modified the
include paths of the TSP includes but it didn't remove the include path
from the makefile or did the same for TLK. This patch does the remaining
work.
Change-Id: Iecee2e88fabcd06989d35568c3a4c1f4e7d93572
Make setjmp/longjmp compliant with the C standard and move them to libc
Instead of having a custom implementation of setjmp() and longjmp() it
is better to follow the C standard.
The comments in setjmp.h are no longer needed as there are no deviations
from the expected one, so they have been removed.
All SDEI code that relied on them has been fixed to use the new function
prototypes and structs.
Change-Id: I6cd2e21cb5a5bcf81ba12283f2e4c067bd5172ca
Trusty requires dynamic translation tables support, so the makefile of
Trusty itself should request it. Not doing so causes platforms such as
FVP to fail to build with Trusty. Other platforms like Tegra still build
because they use dynamic translation tables by default.
Change-Id: Id67d3b9e1f7d0547fa81e81cefa3faf1e0e6f876
This patch dynamically maps the first page of trusty's code memory,
before accessing it to find out if we are running a 32-bit or 64-bit
image.
On Tegra platforms, this means we have to increase the mappings to
accomodate the new memmap entry.
Change-Id: If370d1e6cfcccd69b260134c1b462d8d17bee03d
During System Suspend, the entire system loses its state. To allow Trusty
to save/restore its context and allow its TAs to participate in the suspend
process, it needs to look at the max affinity level being suspended. This
patch passes the max affinity level to Trusty to enable to do so.
Change-Id: If7838dae10c3f5a694baedb15ec56fbad41f2b36
c_rt_ctx is used to store current SP before the system goes
into suspend. The assert for its value being zero is not
really necessary as the value gets over-written eventually.
This patch removes assert(tlk_ctx->c_rt_ctx == 0) from the
System Suspend path, as a result.
Change-Id: If41f15e74ebbbfd82958d8e179114899b2ffb0a7
Signed-off-by: Mihir Joshi <mihirj@nvidia.com>
This patch adds support to handle following TLK SMCs:
{TLK_SS_REGISTER_HANDLER, TLK_REGISTER_NS_DRAM_RANGES, TLK_SET_ROOT_OF_TRUST}
These SMCs need to be supported in ATF in order to forward them to
TLK. Otherwise, these functionalities won't work.
Brief:
TLK_SS_REGISTER_HANDLER: This SMC is issued by TLK Linux Driver to
set up secure storage buffers.
TLK_REGISTER_NS_DRAM_RANGES: Cboot performs this SMC during boot to
pass NS memory ranges to TLK.
TLK_SET_ROOT_OF_TRUST: Cboot performs this SMC during boot to pass
Verified Boot parameters to TLK.
Change-Id: I18af35f6dd6f510dfc22c1d1d1d07f643c7b82bc
Reviewed-on: https://git-master.nvidia.com/r/1643851
This reverts commit 2f370465241c ("Add support for the SMC Calling
Convention 2.0").
SMCCC v2.0 is no longer required for SPM, and won't be needed in the
future. Removing it makes the SMC handling code less complicated.
The SPM implementation based on SPCI and SPRT was using it, but it has
been adapted to SMCCC v1.0.
Change-Id: I36795b91857b2b9c00437cfbfed04b3c1627f578
spd: trusty: trusty_setup should bail on unknown image
When an unknown Trusty image is found, there's no point of still trying
to register the BL32 init handler. Instead, we just should bail out of
the trusty_setup() and allow the system to continue to boot.
Signed-off-by: David Lin <dtwlin@google.com>
Main Fixes:
Use int32_t replace int [Rule 4.6]
Added explicit casts (e.g. 0U) to integers in order for them to be
compatible with whatever operation they're used in [Rule 10.1]
Force operands of an operator to the same type category [Rule 10.4]
Fixed if statement conditional to be essentially boolean [Rule 14.4]
Voided non c-library functions whose return types are not used
[Rule 17.7]
Change-Id: I98caa330c371757eb2dfb9438448cb99115ed907
Signed-off-by: Anthony Zhou <anzhou@nvidia.com>
This implementation is no longer deprecated.
Change-Id: I68552d0fd5ba9f08fad4345e4657e8e3c5362a36
The SPM implementation based on MM is going to be kept for the
foreseeable future.
Change-Id: I11e96778a4f52a1aa803e7e048d9a7cb24a53954
Acked-by: Sumit Garg <sumit.garg@linaro.org>
synquacer: add SPM support
Registered init handlers return a boolean int, not a return code,
so convert the result from the SPM init call before returning it.
Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Permit unaligned accesses while executing the secure partition
payload, so that we don't have to modify existing code that we
will host there. (The UEFI spec explicitly permits unaligned
accesses)
Corrects typos in core code, documentation files, drivers, Arm
platforms and services.
None of the corrections affect code; changes are limited to comments
and other documentation.
Change-Id: I5c1027b06ef149864f315ccc0ea473e2a16bfd1d
Expose the timer registers that are accessible at EL0 per the
architecture to the SPM payload running in secure EL0. Note
that this requires NS_TIMER_SWITCH to be enable for all users
of this code.
Update some asserts that refer to #defines that only occur in
ARM platforms, preventing this code to be used on other platforms.
Instead, use a platform agnostic name, and update all the existing
users.
Enforce full include path for includes. Deprecate old paths.
The following folders inside include/lib have been left unchanged:
- include/lib/cpus/${ARCH}
- include/lib/el3_runtime/${ARCH}
The reason for this change is that having a global namespace for
includes isn't a good idea. It defeats one of the advantages of having
folders and it introduces problems that are sometimes subtle (because
you may not know the header you are actually including if there are two
of them).
For example, this patch had to be created because two headers were
called the same way: e0ea0928d5b7 ("Fix gpio includes of mt8173 platform
to avoid collision."). More recently, this patch has had similar
problems: 46f9b2c3a282 ("drivers: add tzc380 support").
This problem was introduced in commit 4ecca33988b9 ("Move include and
source files to logical locations"). At that time, there weren't too
many headers so it wasn't a real issue. However, time has shown that
this creates problems.
Platforms that want to preserve the way they include headers may add the
removed paths to PLAT_INCLUDES, but this is discouraged.
Change-Id: I39dc53ed98f9e297a5966e723d1936d6ccf2fc8f
AArch64: Use SSBS for CVE_2018_3639 mitigation
Rename files prefixed by sp_ to spm_.
Change-Id: Ie3016a4c4ac5987fe6fdd734c6b470c60954e23d
Also, add a disclaimer to explain that the current implementation of SPM
is a prototype that is going to undergo a lot of rework.
Change-Id: I303c1e61c51d9f286cc599fea565fc9ba5a996bf
The old SMCs SP_MEMORY_ATTRIBUTES_{GET,SET}_AARCH64 have been removed in
favour of SPRT_MEMORY_PERM_ATTR_{GET,SET}_AARCH64.
Change-Id: Idb93cfa5461d0098df941037c5653f7c44b65227
Change-Id: I1fdc2285a3f6517a715ad6159322543fd5a37a37
Note that the arguments passed during the SMC call don't comply with the
SPCI specifications. This will be fixed in following patches, but it is
needed to implement a few more SPCI SMCs to be able to do it. The
current code allows us to start testing it.
Change-Id: Ic13dcc54c40327df03be1b0f52e8a44f468f06b4
Co-authored-by: Jean-Paul Etienne <jean-paul.etienne@arm.com>
This buffer is where all the responses from Secure Partitions are stored
until they are requested.
Change-Id: Iafeb8f0848c5ff6f3e187060cd3a47702484dc45
Blocking calls can only succeed if the target Secure Partition is idle.
Change-Id: Iabeaa0b8d3e653fd8581fa086758936abfc1c772
Change-Id: Ief0e75d072b311737fcdb0c6a60ba5b7406a9ee5
