path: root/services/arm_arch_svc
2019-03-04Ensure proper ID register is checked for feature detectionDimitris Papastamos
SSBS support is determined by checking ID_AA64PFR1_EL1 and not ID_AA64PFR0_EL1. Fixes ARM-Software/tf-issues#679 Change-Id: I8ecba13b850995ec6a6ede3c2a1e02e69a3a95db Signed-off-by: Dimitris Papastamos <dimitris.papastamos@arm.com>
2019-01-04Sanitise includes across codebaseAntonio Nino Diaz
Enforce full include path for includes. Deprecate old paths. The following folders inside include/lib have been left unchanged: - include/lib/cpus/${ARCH} - include/lib/el3_runtime/${ARCH} The reason for this change is that having a global namespace for includes isn't a good idea. It defeats one of the advantages of having folders and it introduces problems that are sometimes subtle (because you may not know the header you are actually including if there are two of them). For example, this patch had to be created because two headers were called the same way: e0ea0928d5b7 ("Fix gpio includes of mt8173 platform to avoid collision."). More recently, this patch has had similar problems: 46f9b2c3a282 ("drivers: add tzc380 support"). This problem was introduced in commit 4ecca33988b9 ("Move include and source files to logical locations"). At that time, there weren't too many headers so it wasn't a real issue. However, time has shown that this creates problems. Platforms that want to preserve the way they include headers may add the removed paths to PLAT_INCLUDES, but this is discouraged. Change-Id: I39dc53ed98f9e297a5966e723d1936d6ccf2fc8f Signed-off-by: Antonio Nino Diaz <antonio.ninodiaz@arm.com>
2018-12-10AArch64: Use SSBS for CVE_2018_3639 mitigationJeenu Viswambharan
The Armv8.5 extensions introduces PSTATE.SSBS (Speculation Store Bypass Safe) bit to mitigate against Variant 4 vulnerabilities. Although an Armv8.5 feature, this can be implemented by CPUs implementing earlier version of the architecture. With this patch, when both PSTATE.SSBS is implemented and DYNAMIC_WORKAROUND_CVE_2018_3639 is active, querying for SMCCC_ARCH_WORKAROUND_2 via. SMCCC_ARCH_FEATURES call would return 1 to indicate that mitigation on the PE is either permanently enabled or not required. When SSBS is implemented, SCTLR_EL3.DSSBS is initialized to 0 at reset of every BL stage. This means that EL3 always executes with mitigation applied. For Cortex A76, if the PE implements SSBS, the existing mitigation (by using a different vector table, and tweaking CPU ACTLR2) is not used. Change-Id: Ib0386c5714184144d4747951751c2fc6ba4242b6 Signed-off-by: Jeenu Viswambharan <jeenu.viswambharan@arm.com>
2018-05-23Add support for dynamic mitigation for CVE-2018-3639Dimitris Papastamos
Some CPUS may benefit from using a dynamic mitigation approach for CVE-2018-3639. A new SMC interface is defined to allow software executing in lower ELs to enable or disable the mitigation for their execution context. It should be noted that regardless of the state of the mitigation for lower ELs, code executing in EL3 is always mitigated against CVE-2018-3639. NOTE: This change is a compatibility break for any platform using the declare_cpu_ops_workaround_cve_2017_5715 macro. Migrate to the declare_cpu_ops_wa macro instead. Change-Id: I3509a9337ad217bbd96de9f380c4ff8bf7917013 Signed-off-by: Dimitris Papastamos <dimitris.papastamos@arm.com>
2018-05-23Implement static workaround for CVE-2018-3639Dimitris Papastamos
For affected CPUs, this approach enables the mitigation during EL3 initialization, following every PE reset. No mechanism is provided to disable the mitigation at runtime. This approach permanently mitigates the entire software stack and no additional mitigation code is required in other software components. TF-A implements this approach for the following affected CPUs: * Cortex-A57 and Cortex-A72, by setting bit 55 (Disable load pass store) of `CPUACTLR_EL1` (`S3_1_C15_C2_0`). * Cortex-A73, by setting bit 3 of `S3_0_C15_C0_0` (not documented in the Technical Reference Manual (TRM)). * Cortex-A75, by setting bit 35 (reserved in TRM) of `CPUACTLR_EL1` (`S3_0_C15_C1_0`). Additionally, a new SMC interface is implemented to allow software executing in lower ELs to discover whether the system is mitigated against CVE-2018-3639. Refer to "Firmware interfaces for mitigating cache speculation vulnerabilities System Software on Arm Systems"[0] for more information. [0] https://developer.arm.com/cache-speculation-vulnerability-firmware-specification Change-Id: I084aa7c3bc7c26bf2df2248301270f77bed22ceb Signed-off-by: Dimitris Papastamos <dimitris.papastamos@arm.com>
2018-05-23Rename symbols and files relating to CVE-2017-5715Dimitris Papastamos
This patch renames symbols and files relating to CVE-2017-5715 to make it easier to introduce new symbols and files for new CVE mitigations. Change-Id: I24c23822862ca73648c772885f1690bed043dbc7 Signed-off-by: Dimitris Papastamos <dimitris.papastamos@arm.com>
2018-04-03Fixup SMCCC_FEATURES return value for SMCCC_ARCH_WORKAROUND_1Dimitris Papastamos
Only return -1 if the workaround for CVE-2017-5715 is not compiled in. Change-Id: I1bd07c57d22b4a13cf51b35be141a1f1ffb065ff Signed-off-by: Dimitris Papastamos <dimitris.papastamos@arm.com>
2018-03-21Rename 'smcc' to 'smccc'Antonio Nino Diaz
When the source code says 'SMCC' it is talking about the SMC Calling Convention. The correct acronym is SMCCC. This affects a few definitions and file names. Some files have been renamed (smcc.h, smcc_helpers.h and smcc_macros.S) but the old files have been kept for compatibility, they include the new ones with an ERROR_DEPRECATED guard. Change-Id: I78f94052a502436fdd97ca32c0fe86bd58173f2f Signed-off-by: Antonio Nino Diaz <antonio.ninodiaz@arm.com>
2018-03-14Fixup `SMCCC_ARCH_FEATURES` semanticsDimitris Papastamos
When querying `SMCCC_ARCH_WORKAROUND_1` through `SMCCC_ARCH_FEATURES`, return either: * -1 to indicate the PE on which `SMCCC_ARCH_FEATURES` is called requires firmware mitigation for CVE-2017-5715 but the mitigation is not compiled in. * 0 to indicate that firmware mitigation is required, or * 1 to indicate that no firmware mitigation is required. This patch complies with v1.2 of the firmware interfaces specification (ARM DEN 0070A). Change-Id: Ibc32d6620efdac6c340758ec502d95554a55f02a Signed-off-by: Dimitris Papastamos <dimitris.papastamos@arm.com>
2018-02-28Fix MISRA rule 8.4 in common codeRoberto Vargas
Rule 8.4: A compatible declaration shall be visible when an object or function with external linkage is defined. Change-Id: I26e042cb251a6f9590afa1340fdac73e42f23979 Signed-off-by: Roberto Vargas <roberto.vargas@arm.com>
2018-01-29Implement support for SMCCC v1.1Dimitris Papastamos
SMCCC v1.1 comes with a relaxed calling convention for AArch64 callers. The caller only needs to save x0-x3 before doing an SMC call. This patch adds support for SMCCC_VERSION and SMCCC_ARCH_FEATURES. Refer to "Firmware Interfaces for mitigating CVE_2017_5715 System Software on Arm Systems"[0] for more information. [0] https://developer.arm.com/-/media/developer/pdf/ARM%20DEN%200070A%20Firmware%20interfaces%20for%20mitigating%20CVE-2017-5715_V1.0.pdf Change-Id: If5b1c55c17d6c5c7cb9c2c3ed355d3a91cdad0a9 Signed-off-by: Dimitris Papastamos <dimitris.papastamos@arm.com>
