Fix assignment error in CSU_SA() and CSU_HPCTRL().
Change-Id: Ia7210745c4e91e33a1ea825ef2678b2d912a066d
Signed-off-by: Ji Luo <ji.luo@nxp.com>
Reviewed-by: Jacky Bai <ping.bai@nxp.com>
In step12, remove the while loop waiting to align
with the ddr4 dvfs flow on imx_2.0.y.
Tested-by: Peng Fan <peng.fan@nxp.com>
Signed-off-by: Jacky Bai <ping.bai@nxp.com>
Fix build break for iMX8MQ.
Signed-off-by: Nitin Garg <nitin.garg@nxp.com>
The bit define for ispdwp & ddrmix is wrong in RM, so correct it.
Reviewed-by: Anson Huang <Anson.Huang@nxp.com>
On i.MX8MP, the SRC GPR9(0x94) is used by memory repair, so choose
SRC GPR10(0x98) as the LPA status sync register. Add use '==' instead
of '&' for LPA active statue check.
Support stop M7 with SIP call.
Per IC team, to rekick M7 need follow steps.
If M7 already in WFI, perform below steps.
a) Set [0x303A_002C].0=0 [ request SLEEPHOLDREQn ]
b) Wait [0x303A_00EC].1 = 0 [ wait SLEEPHOLDACKn ]
c) Set GPR.CPUWAIT=1
d) Set [0x303A_002C].0=1 [ de-assert SLEEPHOLDREQn ]
e) Set SRC_M7_RCR[3:0] = 0xE0 [ reset M7 core/plat ]
f) Wait SRC_M7_RCR[3:0] = 0x8
g) Init TCM or DDR
h) Set GPR.INITVTOR
i) Set GPR.CPUWAIT=0, M7 starting running
Add a timeout check, if timeout, still perform force reset, in this
way no need to rely on M7 team's image wfi support ready.
Return a1,a2 to caller to check timeout or reset fail.
Signed-off-by: Peng Fan <peng.fan@nxp.com>
The number of IMRs for each core is 5, so correct
it and replace with a macro.
The SCFW supports OCRAM retention, so no need to set cpu entry for reboot
to let CPU run from SPL in OCRAM again when reboot, then SPL will reload
images after reboot.
Signed-off-by: Anson Huang <Anson.Huang@nxp.com>
Reviewed-by: Ye Li <ye.li@nxp.com>
This part of code is still needed by uboot, so add
it back.
If the Main NOC is power down before, need to reinit the QoS setting
for A53, GIC & Supermix port.
The common domain suspend callback function is not suitable
for i.MX8MP due to the wait mode workaround. it will be
removed together with the wait mode workaround in the
future.
On i.MX8MN & i.MX8MP, the M core enabled check should
relay on the IOMUX GPR CPU_WAIT bit, when this bit is
cleared, it means M core is active & running, so refine
the m4 enabled check method.
Replace the imr offset magic number with macro defines.
Allow OP-TEE to generate a device-tree overlay binary
that will be applied by u-boot on the regular dtb.
Due to the design requirement, the HSIOMIX need to be RPM
always on, so HSIOMIX need to be boot on by default. There
are no way to manage the clocks when doing domain on/off,
add clock handling in TF-A to resolve this issue.
Add the i.MX8MP workaround for wait mode just for Alpha
release, this patch will be dropped in the future.
Add the basic support for i.MX8MP.
move the gpc reg offset, bit define & macro to a separate header
file for code reuse.
Updating the CPU CORE power up timing to make sure
the RDC reload is done before CPU start to run code
in OCRAM space.
Current reset uses WDOG timeout function and default timeout
value is set to 0.5 second. However, it is better to trigger
reset immediately to speed up reboot process as well as prevent
the scenario of WDOG_B toggling later than CPU reset and PMIC
does NOT reset.
Set the WDE bit when IMX_WDOG_B_RESET is not enabled, or
reboot will fail.
Align code style between 8mq, 8mm and 8mn files.
Signed-off-by: Silvano di Ninno <silvano.dininno@nxp.com>
8DX and 8QX share the same die,
so will reuse the same implementation
(cherry picked from commit bb209a0b4ccca2aa4a3a887f9606dc4a3d294adf)
Port and cleanup OP-TEE support.
i.MX8 SoC with SCU inside support partition reboot, the partition reboot
will NOT reload the bl31.bin, so the data section could have some dirty
data of previous boot up, it will impact the reboot, so need to restore
the data section for partition reboot.
i.MX8DXL ONLY supports up to 12*32 interrupt number, so the
first SPI interrupt offset should be from 0x2c.
(cherry picked from commit cd0519bf70382292768adc1e9c0337808c55f148)
Add support for new SoC i.MX8DXL
Signed-off-by: Teo Hall <teo.hall@nxp.com>
(cherry picked from a7a008da03cd08cae3387c428ad8145fb1fae354)
Add trusty support for imx8mq, default load address
and size for trusty os will be 0xfe000000 and 0x2000000.
(cherry picked from a708794ccde53d8253a74ff578ca9d5258971690)
Add trusty support for imx8mn, default load address and
size of trusty are 0xbe000000 and 0x2000000.
(cherry picked from commit 1566947ab431388906d71a1fb48e802fc9a1eec9)
Add trusty support for imx8mm, default load address
and size of trusty are 0xbe000000 anx 0x2000000.
(cherry picked from commit 28d3f0fa26ff11efb98281ed603b6f44cea3c6c5)
Open the power domain of MU4 and assign it to secure
world so trusty can call the SCFW API.
Test: Get SCFW and SECO-FW by trusty.
Change-Id: I6188f905426fd66072346089505fb1945e4362e3
(cherry-picked from commit 4dd8919a805336c6df8a791f238e8da1830dfe7b)
JR0 and JR1 of CAAM are owned by SECO, only kick the power
of JR2 and JR3 here and assign the resources to be accessed
by secure world.
(cherry picked from commit d82c0e65e74ce8b650ea3237a02249246080840d)
Mapped the BL32 code into MMU due the Trusty
SPD need to check the code status and decide
the CPU executing mode.
To reserve and protect the memory for secure
world, modify the partition code to keep
BL32 spaces in secure_part.
Signed-off-by: Haoran.Wang <elven.wang@nxp.com>
(cherry picked from commit 36ad60e46fd94eac7646218ae2b3e760bcfc33d6)
spd trusty requires memory dynamic mapping feature to be
enabled, so we have to use xlat table library v2 instead
of v1.
Test: builds.
Build break due to result of β1 << 31β requires 33 bits to represent,
but βintβ only has 32 bits [-Werror=shift-overflow=].
Replace the magic number index with enum type to make RDC/CSU config
more clear for user.
Add the M core low power audio support on i.MX8M.
Enable the NOC wrapper power down support for SoC that
have switchable NOC power domain.
Add the NOC QoS setting SiP handler on imx8mq.
Add the SRC SiP handler for M4/M7 boot support on i.MX8M SoC.
Add the HAB secure boot support for the i.MX8M SoC family.
Signed-off-by: Ye Li <ye.li@nxp.com>
Enable DRAM DVFS support on i.MX8MQ.
A53 core's power up ack need to be used when system resume
from DSM mode.
Use non-fast wakeup stop mode for system suspend support, so
the SOC can enter DSM mode by default.
