Replace all GPL with BSD identifier.
Signed-off-by: Anson Huang <Anson.Huang@nxp.com>
As suspend with last CPU power down needs SCFW support,
and it is NOT ready now, in order to enable kernel suspend
function earlier for modules to start debugging suspend
resume function, this patch adds standby suspend for now.
Will add last CPU power down suspend function when SCFW
is ready.
Add a new SIP call FSL_SIP_BUILDINFO to return the current commit id
in 7 hexadecimal digits which are parsed from the version_string.
Signed-off-by: Ye Li <ye.li@nxp.com>
Fix below build error on i.MX8QXP when using poky
tool chain:
CC plat/freescale/common/cpufreq.c
plat/freescale/common/cpufreq.c:27:18:
error: "ap_cluster_index" defined but not used
[-Werror=unused-const-variable=]
Add system_off pcsi callback to avoid below kernel
message when doing power off:
[11613.953711] reboot: Power down
[11613.958318] systemd-shutdow: 8 output lines suppressed due to ratelimiting
[11613.965285] Kernel panic - not syncing: Attempted to kill init! exitcode=0x00
[11613.965285]
[11613.974441] CPU: 0 PID: 1 Comm: systemd-shutdow Not tainted 4.9.11-03354-g0e1
[11613.982369] Hardware name: Freescale i.MX8QXP LPDDR4 ARM2 (DT)
[11613.988216] Call trace:
[11613.990681] [<ffff0000080882bc>] dump_backtrace+0x0/0x1a8
[11613.996092] [<ffff000008088478>] show_stack+0x14/0x1c
[11614.001154] [<ffff0000083aaf98>] dump_stack+0x8c/0xac
[11614.006213] [<ffff000008162aac>] panic+0x124/0x28c
[11614.011016] [<ffff0000080c0b20>] complete_and_exit+0x0/0x20
[11614.016600] [<ffff0000080dc6d8>] SyS_reboot+0x168/0x244
[11614.021829] [<ffff000008082ef0>] el0_svc_naked+0x24/0x28
[11614.027153] Kernel Offset: disabled
[11614.030646] Memory Limit: none
[11614.040755] ---[ end Kernel panic - not syncing: Attempted to kill init! exi0
[11614.040755]
As there is no system power off SCFW API available now, so just
simply do wfi and never return when system_off is called.
The GPC_CPU_PGC_SW_PDN_REQ offset should be 0xfc, previous
offset is incorrect, so actually ARM core is NOT powered
down and the power leakage is very high.
With this fix, each ARM core's leakage is about 25mA@0.9V.
Add SRTC SIP support for i.MX8QM/i.MX8QXP.
Add SCFW timer API support.
Add i.MX8QXP board reset support.
Add i.MX8QM board reboot support.
Signed-off-by: Ranjani Vaidyanathan <Ranjani.Vaidyanathan@nxp.com>
The bits[3:0] of CPU_PGC_PUP/PDN_TRG use core's SW
power up/down. prevous bits assignment is wrong, so
fix it.
Signed-off-by: Bai Ping <ping.bai@nxp.com>
Linux kernel will issue cpu-freq scale via SIP, ATF
calls SCFW API to finish the CPU frequency scale.
Move SIP service code from i.mx8mq to common place for
all i.mx SoCs.
- USB PHY reset bit in SRC needs to be clear before
doing USB PHY power gating in GPC, only needs to
do once;
- Need to handle GPC_PU_PWRHSK during power up/down;
- Enable GPC pu power gate support.
As there are too many difference between each PU's power
on/off flow, here enable all PUs power until all modules'
power on/off function ready and tested, then we will enable
this PU PGC feature.
the PCIE1 and PCIE2 share the same reset signal, if PCIE2 is power down,
PCIE1 will also be power down, so when we need to power up PCIE1, the PCIE2
need to power up too, only PCIE1 is power down, the PCIE2 power domain can
be power down too
No need to enable all PU power during boot up, module driver
will enable their power domain as needed.
Set the MPROTx and OPACRx in AIPS4 configuration registers to allow user mode
and non-supervisor privilege level to access.
Reserve the memory region that is only can access by ATF. ATF is running
in this memory region, while masters in other partitions can't access it.
Change to search the ATF owned memory regions and assign them to non-secure
OS partition. Not allocate new memory region for each one.
The power domain id does NOT equal to the register bit
offset, so need to do a mapping here.
Add hardware power down for all power domains. Make
imx_gpc_set_m_core_pgc usable for all MIX and PU PGC.
Need to mask all M4 IRQ and override all PLLs/OSC
before entering DSM mode, but due to DRAM self-refresh
NOT ready, non-fast wakeup mode is NOT working, so
we still use fast wakeup mode, which means DSM mode
by default is NOT entered.
After DRAM self-refresh is added, we will switch
to non-fast wakeup mode to make DSM work.
Move TZC EN into SPL, and add check in ATF.
Signed-off-by: Peng Fan <peng.fan@nxp.com>
Add SNVS mapping to avoid system off failure.
enable tzc380 for i.mx8mq
Change back BL31_LIMIT to 0x40020000,
because TZC380 could not support 4K aligned address.
Add console init
Add system off support, linux kernel can issue
"poweroff" to power down system.
Add wdog reset support.
Enable the non-privilege access for AIPS address space.
Signed-off-by: Fugang Duan <fugang.duan@nxp.com>
Add basic support for i.MX8MQ.
1. SMP support is ok.
2. basic suspend/resume support is ok.
As we already have control for debug console in platform_def.h,
so no need to un-initialize console in plat runtime setup, just
overwrite the common implementation with blank function.
Signed-off-by: Nitin Garg <nitin.garg@nxp.com>
Not only the resources, but also the memory regions need to assign to
non-secure partition. Otherwise, when the boot partition is secured,
the OS non-secure partition can't access any memory.
This patch currently assign all memory to NS partition, since it is not
isolated, the current secure partition also can access them. In future,
may need to change the regions for reserving some memory in secure
partition for ATF and BL32.
missed bit 31 and 30 which are needed
Disable ATF console output for iMX8QM
Disable debug console by default on i.MX8QXP.
Debug console baudrate should be 115200 for i.MX8QXP real board.
Add necessary resources to secure partition for protection.
Also add in functionality to allow for register access
of some secure-owned peripherals.
These peripherals will still be protected from power or
clk changes.
Signed-off-by: Teo Hall <teo.hall@nxp.com>
Need to add support for booting up A72 cluster only,
so on need to check the cluster ID for primary CPU,
that means if CPU ID is 0, then it can be as primary
CPU.
change MMU mapping to use the address of
the MU currently being used for ATF
add more resources to secure partition for
protection. Also add in functionality to allow
for register access of some secure-owned
peripherals.
power or clk changes.
add rm svc api and set aside separate MU for
secure api calls into SCU
add plat_crash_print_regs macro function to
allow building with debug
UART baudrate is 115200 on i.MX8QM ARM2 board.
