Add i.MX8QXP platform support.
Signed-off-by: Anson Huang <Anson.Huang@nxp.com>
Signed-off-by: Bai Ping <ping.bai@nxp.com>
Signed-off-by: Peng Fan <peng.fan@nxp.com>
Add i.MX8QM platform support.
This patch adds i.MX8 SoCs ATFW support, including below
basic features:
* LPUART
* SCFW RPC
* SMP boot up
Each SoC will have its own platform definition and driver
to support.
This patch implements the platform APIs plat_get_rotpk_info,
plat_get_nv_ctr, plat_set_nv_ctr to invoke CryptoCell SBROM
APIs when ARM_CRYPTOCELL_INT is set.
Change-Id: I693556b3c7f42eceddd527abbe6111e499f55c45
Signed-off-by: Soby Mathew <soby.mathew@arm.com>
This patch makes the necessary changes to enable ARM platform to
successfully integrate CryptoCell during Trusted Board Boot. The
changes are as follows:
* A new build option `ARM_CRYPTOCELL_INTEG` is introduced to select
the CryptoCell crypto driver for Trusted Board boot.
* The TrustZone filter settings for Non Secure DRAM is modified
to allow CryptoCell to read this memory. This is required to
authenticate BL33 which is loaded into the Non Secure DDR.
* The CSS platforms are modified to use coherent stacks in BL1 and BL2
when CryptoCell crypto is selected. This is because CryptoCell makes
use of DMA to transfer data and the CryptoCell SBROM library allocates
buffers on the stack during signature/hash verification.
Change-Id: I1e6f6dcd1899784f1edeabfa2a9f279bbfb90e31
rockchip: enable A53's erratum 855873 for rk3399
Apply workarounds for A53 Cat A Errata 835769 and 843419
Resolve signed-unsigned comparison issues
For rk3399, the L2ACTLR[14] is 0 by default, as ACE CCI-500 doesn't
support WriteEvict. and you will hit the condition L2ACTLR[3] with 0,
as the Evict transactions should propagate to CCI-500 since it has
snoop filters.
Maybe this erratum applies to all Cortex-A53 cores so far, especially
if RK3399's A53 is a r0p4. we should enable it to avoid data corruption,
Change-Id: Ib86933f1fc84f8919c8e43dac41af60fd0c3ce2f
Signed-off-by: Caesar Wang <wxt@rock-chips.com>
juno/aarch32: Fix boot on Cortex A57 and A72
A recent commit 030567e6f51731982a7e71cbd387de93bc0e35fd added U()/ULL()
macro to TF constants. This has caused some signed-unsigned comparison
warnings / errors in the TF static analysis.
This patch addresses these issues by migrating impacted variables from
signed ints to unsigned ints and vice verse where applicable.
Change-Id: I4b4c739a3fa64aaf13b69ad1702c66ec79247e53
Signed-off-by: David Cunado <david.cunado@arm.com>
Fix Tegra CFLAGS usage
On Juno AArch32, the L2 cache may contain garbage after the warm reset
from AArch64 to AArch32. This is all fine until the MMU is configured
and the data caches enabled. To avoid fetching stale data from the L2
unified cache, invalidate it before the warm reset to AArch32 state.
Change-Id: I7d27e810692c02c3e83c9f31de67f6bae59a960a
Signed-off-by: Dimitris Papastamos <dimitris.papastamos@arm.com>
Before BL2 loads the SCP ram firmware, `SCP_BOOT_CFG_ADDR` specifies
the primary core. After the SCP ram firmware has started executing,
`SCP_BOOT_CFG_ADDR` is modified. This is not normally an issue but
the Juno AArch32 boot flow is a special case. BL1 does a warm reset
into AArch32 and the core jumps to the `sp_min` entrypoint. This is
effectively a `RESET_TO_SP_MIN` configuration. `sp_min` has to be
able to determine the primary core and hence we need to restore
`SCP_BOOT_CFG_ADDR` to the cold boot value before `sp_min` runs.
This magically worked when booting on A53 because the core index was
zero and it just so happened to match with the new value in
`SCP_BOOT_CFG_ADDR`.
Change-Id: I105425c680cf6238948625c1d1017b01d3517c01
aarch64: Enable Statistical Profiling Extensions for lower ELs
Use TF_CFLAGS instead of CFLAGS, to allow CFLAGS to be overriden from
the make command line.
Change-Id: I3e5726c04bcd0176f232581b8be2c94413374ac7
Signed-off-by: Douglas Raillard <douglas.raillard@arm.com>
These errata are only applicable to AArch64 state. See the errata notice
for more details:
http://infocenter.arm.com/help/index.jsp?topic=/com.arm.doc.epm048406/index.html
Introduce the build options ERRATA_A53_835769 and ERRATA_A53_843419.
Enable both of them for Juno.
Apply the 835769 workaround as following:
* Compile with -mfix-cortex-a53-835769
* Link with --fix-cortex-a53-835769
Apply the 843419 workaround as following:
* Link with --fix-cortex-a53-843419
The erratum 843419 workaround can lead the linker to create new sections
suffixed with "*.stub*" and 4KB aligned. The erratum 835769 can lead the
linker to create new "*.stub" sections with no particular alignment.
Also add support for LDFLAGS_aarch32 and LDFLAGS_aarch64 in Makefile for
architecture-specific linker options.
Change-Id: Iab3337e338b7a0a16b0d102404d9db98c154f8f8
uniphier: embed ROTPK hash into BL1/BL2
plat: Hikey960: fix the CPU hotplug
SPE is only supported in non-secure state. Accesses to SPE specific
registers from SEL1 will trap to EL3. During a world switch, before
`TTBR` is modified the SPE profiling buffers are drained. This is to
avoid a potential invalid memory access in SEL1.
SPE is architecturally specified only for AArch64.
Change-Id: I04a96427d9f9d586c331913d815fdc726855f6b0
Signed-off-by: dp-arm <dimitris.papastamos@arm.com>
Currently, ROTPK_NOT_DEPLOYED flag is set in plat_get_rotpk_info().
It is up to users how to retrieve ROTPK if the ROT verification is
desired. This is not nice.
This commit improves plat_get_rotpk_info() implementation and automates
the ROTPK deployment. UniPhier platform has no ROTPK storage, so it
should be embedded in BL1/BL2, like ARM_ROTPK_LOCATION=devel_rsa case.
This makes sense because UniPhier platform implements its internal ROM
i.e. BL1 is used as updatable pseudo ROM.
Things work like this:
- ROT_KEY (default: $(BUILD_PLAT)/rot_key.pem) is created if missing.
Users can override ROT_KEY from the command line if they want to
use a specific ROT key.
- ROTPK_HASH is generated based on ROT_KEY.
- ROTPK_HASH is included by uniphier_rotpk.S and compiled into BL1/BL2.
- ROT_KEY is input to cert_create tool.
Commit 6de8b24f52cf2bd74adefbaa86dd2a0676c3eaa2 broke Juno AArch32
build.
Change-Id: Ied70d9becb86e53ccb46a2e3245e2a551d1bf701
On ARM platforms before exiting from SP_MIN ensure that
the default console is switched to the runtime serial port.
Change-Id: I0ca0d42cc47e345d56179eac16aa3d6712767c9b
With GCC 6.2 compiler, more C undefined behaviour is being flagged as
warnings, which result in build errors in ARM TF build.
This patch addresses issue caused by enums with values that exceed
maximum value for an int. For these cases the enum is converted to
a set of defines.
Change-Id: I5114164be10d86d5beef3ea1ed9be5863855144d
hikey960: migrate to use A53 specific defines
The patch fb7d32e5881ef2445e8fe2305005f5590d4a7cfa migrated the CPU
libraries to have unique defines, prefixing them with the CPU name.
This patch migrates the hikey960 platform port to use the A53 specific
defines.
Change-Id: Id76f544b0b236bbd4974ab5ffa1203f073c20021
In CPU off callback function, the old code uses the function
hisi_test_pwrdn_allcores() to check if all CPUs in cluster have been
powered off and if it's valid then power off the whole cluster. But the
function hisi_test_pwrdn_allcores() only maintains the different power
states only for CPU suspend/resume flow, so it cannot return correct
states for CPU on/off flow.
This patch is to change use hisi_test_cpu_down() to check if all CPUs
have been powered off, so that can power off the whole cluster properly
when all CPUs in cluster have been hotplugged off.
Signed-off-by: Tao Wang <kevin.wangtao@hisilicon.com>
Signed-off-by: Leo Yan <leo.yan@linaro.org>
Tegra misra fixes v1
uniphier memory-overrun bug fix
CSS:Fix scpi "get_power_state" when ARM_PLAT_MT is set
Fix coverity error in CSS SCMI driver
The ARM_PLAT_MT bit enables the support for MT bit in
MPIDR format. This means that the level 0 affinity
represents the thread and CPU / Cluster levels are
at affinity level 1 and 2 respectively.
This was not catered for in the scpi 'css_scp_get_power_state, API.
Since the SCPI driver can only cater for single threaded CPUs,
this patch fixes the problem by catering for this shift by
effectively ignoring the Thread (level 0) affinity level.
Change-Id: If44f55c9fb2773c8d3f8a9bbcf5420a6f7409dfe
Signed-off-by: jagadeesh ujja <jagadeesh.ujja@arm.com>
Since this mailbox driver is abandoned, remove it.
Signed-off-by: Haojian Zhuang <haojian.zhuang@linaro.org>
Check the array index before the write. This issue was found by a
static analysis tool.
Main fixes:
* Added explicit casts (e.g. 0U) to integers in order for them to be
compatible with whatever operation they're used in [Rule 10.1]
* Force operands of an operator to the same type category [Rule 10.4]
* Added curly braces ({}) around if/while statements in order to
make them compound [Rule 15.6]
* Added parentheses [Rule 12.1]
* Voided non C-library functions whose return types are not used [Rule 17.7]
Change-Id: I91404edec2e2194b1ce2672d2a3fc6a1f5bf41f1
Signed-off-by: Anthony Zhou <anzhou@nvidia.com>
Main fixes:
* Include header file for function declarations [Rule 8.4]
* Move global object into function [Rule 8.9]
Change-Id: I1bc9f3f0ebd4ffc0b8444ac856cd97b0cb56bda4
Main fixes:
* Use int32_t replace int, use uint32_t replace unsign int [Rule 4.6]
* Fixed assert/if statements conditions to be essentially boolean [Rule 14.4]
* Added curly braces ({}) around if statements in order to
* Convert macros form headers to unsigned ints
Change-Id: I8051cc16499cece2039c9751bd347645f40f0901
Main fixes:
* Convert object type to match the type of function parameters
[Rule 10.3]
* Expressions resulting from the expansion of macro parameters
shall be enclosed in parentheses[Rule 20.7]
Change-Id: I5cf83caafcc1650b545ca731bf3eb8f0bfeb362b
Main fixes:
* Fixed if/while statement conditional to be essentially boolean [Rule 14.4]
* Added curly braces ({}) around if/for/while statements in order to
Change-Id: Ic72b248aeede6cf18bf85051188ea7b8fd8ae829
This patch moves the GPU reset state check, during VideoMem resize, to the
common SiP handler, to reduce code duplication.
Change-Id: I3818c5f104b809da83dc2a61d6a8149606f81c13
This patch fixes the logic to check if the command written to the
MC_CLIENT_HOTRESET_CTRLx registers, was accepted by the hardware module.
Change-Id: If94fff9424555cb4688042eda17b4b20f4eb399a
This patch adds explicit casts (U(x)) to integers in the tegra_def.h
headers, to make them compatible with whatever operation they're used
in [MISRA-C Rule 10.1]
Change-Id: Ic5fc611aad986a2c6e6e6f625e0753ab9b69eb02
This patch makes all the defines in the CPU libraries unique,
by prefixing them with the CPU name.
NOTE: PLATFORMS USING THESE MACROS WILL HAVE TO UPDATE THEIR CODE
TO START USING THE UPDATED NAMES
This patch enables the 'sign-compare' flag, to enable warning/errors
for comparisons between signed/unsigned variables. The warning has
been enabled for all the Tegra platforms, to start with.
UniPhier Initial Support
Since the type of ADC value is always unsigned int, don't
need to check the value with negative value.
Add TSP to test BL32 without relying on external projects.
Initial commit for Socionext UniPhier SoC support. BL1, Bl2, and
BL31 are supported. Refer to docs/plat/socionext-uniphier.md for
more detais.
Change-Id: Ia7d731f429e452e4bc9f9a553d7105b6394c621c
tegra: Fix build errors
