path: root/plat/xilinx
2019-09-10plat: xilinx: zynqmp: Initialize IPI table from zynqmp_config_setup()Jolly Shah
Common ipi_table needs to be initialized before using any IPI command (i.e send/receive). Move zynqmp ipi config table initialization from sip_svc_setup() to zynqmp_config_setup(). Change-Id: Ic8aaa0728a43936cd4c6e1ed590e01ba8f0fbf5b Signed-off-by: Tejas Patel <tejas.patel@xilinx.com> Signed-off-by: Jolly Shah <jolly.shah@xilinx.com>
2019-07-01zynqmp: add support for multi console interfaceAmbroise Vincent
This patch addds multi console interface for ZynqMP platform Change-Id: I508a61412df2b71d04bca6a1139c8f32cbd7dccd Signed-off-by: Ambroise Vincent <ambroise.vincent@arm.com> Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Tested-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com>
2019-06-28Remove MULTI_CONSOLE_API flag and references to itAmbroise Vincent
The new API becomes the default one. Change-Id: Ic1d602da3dff4f4ebbcc158b885295c902a24fec Signed-off-by: Ambroise Vincent <ambroise.vincent@arm.com>
2019-04-03Remove deprecated plat_crash_console_*Ambroise Vincent
The default implementations are defined in crash_console_helpers.S. The platforms have to define plat_crash_console_*. Implemented placeholders for platforms that were missing helpers. Change-Id: Iea60b6f851956916e421dfd8c34a62d96eb9148e Signed-off-by: Ambroise Vincent <ambroise.vincent@arm.com>
2019-03-08zynqmp: pm: Add support for setting PMU configuration objectLuca Ceresoli
Allow EL2 (e.g. U-Boot) to load the configuration object at runtime into the Xilinx ZynqMP PMU firmware. This allows booting with U-Boot and U-Boot SPL with PMU FW without hard-coding the configuration object. Signed-off-by: Luca Ceresoli <luca@lucaceresoli.net>
2019-02-05Merge pull request #1804 from antonio-nino-diaz-arm/an/cleanupAntonio Niño Díaz
Minor cleanup
2019-02-01Remove duplicated definitions of linker symbolsAntonio Nino Diaz
Many parts of the code were duplicating symbols that are defined in include/common/bl_common.h. It is better to only use the definitions in this header. As all the symbols refer to virtual addresses, they have to be uintptr_t, not unsigned long. This has also been fixed in bl_common.h. Change-Id: I204081af78326ced03fb05f69846f229d324c711 Signed-off-by: Antonio Nino Diaz <antonio.ninodiaz@arm.com>
2019-02-01Arm platforms: Rename PLAT_ARM_NS_IMAGE_OFFSETSandrine Bailleux
PLAT_ARM_NS_IMAGE_OFFSET is in fact not an offset relative to some base address, it is an absolute address. Rename it to avoid any confusion. Change-Id: I1f7f5e8553cb267786afe7e5f3cd4d665b610d3f Signed-off-by: Sandrine Bailleux <sandrine.bailleux@arm.com>
2019-01-25plat/arm: Sanitise includesAntonio Nino Diaz
Use full include paths like it is done for common includes. This cleanup was started in commit d40e0e08283a ("Sanitise includes across codebase"), but it only cleaned common files and drivers. This patch does the same to Arm platforms. Change-Id: If982e6450bbe84dceb56d464e282bcf5d6d9ab9b Signed-off-by: Antonio Nino Diaz <antonio.ninodiaz@arm.com>
2019-01-09xilinx: Move IPI functions to common fileJolly Shah
pm_service ipi functions can be used by other xilinx platforms. So move it to common directory. Also change node_id member type in pm_proc structure so it can be used for versal where device IDs are used instead of node IDs. To accommodate this change header files are re-organized. Signed-off-by: Tejas Patel <tejas.patel@xilinx.com> Reviewed-by: Siva Durga Prasad Paladugu <siva.durga.paladugu@xilinx.com> Signed-off-by: Jolly Shah <jollys@xilinx.com>
2019-01-09xilinx: pm_service: Rename macros to use generic macro namesJolly Shah
ZynqMP pm_service ipi file uses platform specific macros names. pm_service ipi functions can be used by other Xilinx platforms also. Make rename macros to use generic names so that it can be used by common file. pm_service ipi functions will be moved to common file in next patch. Signed-off-by: Tejas Patel <tejas.patel@xilinx.com> Reviewed-by: Siva Durga Prasad Paladugu <siva.durga.paladugu@xilinx.com> Signed-off-by: Jolly Shah <jollys@xilinx.com>
2019-01-09xilinx: zynqmp: Rename pm_api members to use generic nameJolly Shah
Use generic name for pm_api structure member, so that pm_api structure can be used other Xilinx platforms. Structure definition will be moved to common file in upcoming patch. Signed-off-by: Tejas Patel <tejas.patel@xilinx.com> Reviewed-by: Siva Durga Prasad Paladugu <siva.durga.paladugu@xilinx.com> Signed-off-by: Jolly Shah <jollys@xilinx.com>
2019-01-09Move generic ipi_mb functions to common filesJolly Shah
ipi_mb functions can be used for other Xilinx platform. Move it to common file from platform specific files. Signed-off-by: Tejas Patel <tejas.patel@xilinx.com> Reviewed-by: Siva Durga Prasad Paladugu <siva.durga.paladugu@xilinx.com> Signed-off-by: Jolly Shah <jollys@xilinx.com>
2019-01-09xilinx: Remove platform specific dependency from IPI functionJolly Shah
ipi_mb function uses platform specific ipi configuration table. These ipi_mb functions can be used for other Xilinx platform. So, instead of using direct data structure, initialize IPI configuration data by passing platform specific ipi table. Macros are updated accordingly for this ipi table change. This change is done so that ipi_mb functions can be moved to common file without major changes. All common functions now would be moved to common file in next patch. Signed-off-by: Tejas Patel <tejas.patel@xilinx.com> Reviewed-by: Siva Durga Prasad Paladugu <siva.durga.paladugu@xilinx.com> Signed-off-by: Jolly Shah <jollys@xilinx.com>
2019-01-09xilinx: Move ipi configuration structure definition to header fileJolly Shah
Move ipi configuration structure definition to common header file and rename it to common name, so it can be used for Xilinx specific other platforms in upcoming changes. Signed-off-by: Tejas Patel <tejas.patel@xilinx.com> Reviewed-by: Siva Durga Prasad Paladugu <siva.durga.paladugu@xilinx.com> Signed-off-by: Jolly Shah <jollys@xilinx.com>
2019-01-09xilinx: zynqmp: Move zynqmp_ipi.h to include directoryJolly Shah
Move zynqmp_ipi.h to platform specific include directory. Rename it to plat_ipi.h instead of platform name. So, it can be used to common source files which needs platform specific data. Signed-off-by: Tejas Patel <tejas.patel@xilinx.com> Reviewed-by: Siva Durga Prasad Paladugu <siva.durga.paladugu@xilinx.com> Signed-off-by: Jolly Shah <jollys@xilinx.com>
2019-01-09plat: xilinx: zynqmp: Move zynqmp_def.h to include directoryJolly Shah
Move zynqmp_def.h to platform specific include directory. Also, update source file to include header file from updated path of zynqmp_def.h Signed-off-by: Tejas Patel <tejas.patel@xilinx.com> Reviewed-by: Siva Durga Prasad Paladugu <siva.durga.paladugu@xilinx.com> Signed-off-by: Jolly Shah <jollys@xilinx.com>
2019-01-09plat: xilinx: zynqmp: Move zynqmp_private.h to include directoryJolly Shah
Move zynqmp_private.h to platform specific include directory. Also, rename it to plat_private.h instead of having platform name. So, it can be used to common source files which needs platform specific data. Signed-off-by: Tejas Patel <tejas.patel@xilinx.com> Reviewed-by: Siva Durga Prasad Paladugu <siva.durga.paladugu@xilinx.com> Signed-off-by: Jolly Shah <jollys@xilinx.com>
2019-01-08Merge pull request #1732 from jollysxilinx/integrationAntonio Niño Díaz
plat: xilinx: Clock and PLL EEMI API Support
2019-01-04zynqmp: pm: Invalidate unused APLL_TO_LPD clockJolly Shah
This clock does not drive any clock in LPD so there is no need for Linux to try to initialize it. Signed-off-by: Mirela Simonovic <mirela.simonovic@aggios.com> Acked-by: Will Wong <WILLW@xilinx.com> Signed-off-by: Jolly Shah <jollys@xilinx.com>
2019-01-04zynqmp: pm: Invalidate several clocks that Linux doesn't need to controlJolly Shah
Linux has no reason to use these system and debug clocks and therefore shouldn't access them. These clocks are marked as invalid in order to prevent Linux from registering and querying them. Note that despite clocks being marked as invalid a security issue still remains in place as there is nothing that prevents the non-secure world from gating these clocks and that way causing damage to the system. Signed-off-by: Mirela Simonovic <mirela.simonovic@aggios.com> Acked-by: Will Wong <WILLW@xilinx.com> Signed-off-by: Jolly Shah <jollys@xilinx.com>
2019-01-04zynqmp: pm: Add ACPU_FULL and ACPU_HALF clocks in the invalid listJolly Shah
These clocks are marked as invalid in order to prevent Linux from registering them. Note that despite clocks being marked as invalid a security issue still remains in place as there is nothing that prevents the non-secure world from gating these clocks and that way halt the whole APU subsystem. Signed-off-by: Mirela Simonovic <mirela.simonovic@aggios.com> Acked-by: Will Wong <WILLW@xilinx.com> Signed-off-by: Jolly Shah <jollys@xilinx.com>
2019-01-04zynqmp: pm: Fix model of ACPU clocksJolly Shah
In the existing model for ACPU clock the mux, divider, and gate were represented as one clock and ACPU_HALF was modelled as child of ACPU clock. This is not correct. ACPU clock model contains only mux and the divider, and it has 2 children: ACPU_FULL and ACPU_HALF clocks which have only gates. The models of ACPU and ACPU_HALF clocks are fixed and ACPU_FULL clock is added. Signed-off-by: Mirela Simonovic <mirela.simonovic@aggios.com> Acked-by: Will Wong <WILLW@xilinx.com> Signed-off-by: Jolly Shah <jollys@xilinx.com>
2019-01-04zynqmp: pm: Reimplement clock get parent EEMI APIJolly Shah
Clock get parent EEMI API is reimplemented to use system-level clock and pll EEMI APIs rather than direct MMIO read/write accesses to clock and pll control registers. Since linux still uses clock set parent API to get pre_src, post_src, div2 and bypasss, in the implementation of pm_clock_get_parent() we need to workaround this by distinguishing two cases: 1) if the given clock ID corresponds to a PLL-related clock ID (*_PRE_SRC, *_POST_SRC, *_INT_MUX or *_PLL clock IDs); or 2) given clock ID is truly an on-chip clock. For case 1) we'll map the call onto PLL-specific EEMI API with the respective parameter ID. For case 2) the call is passed to the PMU. Signed-off-by: Mirela Simonovic <mirela.simonovic@aggios.com> Acked-by: Will Wong <WILLW@xilinx.com> Signed-off-by: Jolly Shah <jollys@xilinx.com>
2019-01-04zynqmp: pm: Reimplement clock set parent EEMI APIJolly Shah
Clock set parent EEMI API is reimplemented to use system-level clock and pll EEMI APIs rather than direct MMIO read/write accesses to clock and pll control registers. Since linux still uses clock set parent API to set pre_src, post_src, div2 and bypass, in the implementation of pm_clock_set_parent() we need to workaround this by distinguishing two cases: 1) if the given clock ID corresponds to a PLL-related clock ID (*_PRE_SRC, *_POST_SRC, *_INT_MUX or *PLL clock IDs); or 2) given clock ID is truly an on-chip clock. For case 1) we'll map the call onto PLL set parameter EEMI API with the respective parameter ID. Since clock set parent interface to EL1/2 receives parent index (mux select value), the value is just passed to PMU. Functions that appear to be unused after this change is made are removed. Setting the parent of *PLL clocks, that actually model bypass, is not possible. This is already ensured by the existing clock model having the CLK_SET_RATE_NO_REPARENT flag. The API also doesn't allow changing the bypass parent. Bypass is controlled only by the PMU firmware. Signed-off-by: Mirela Simonovic <mirela.simonovic@aggios.com> Acked-by: Will Wong <WILLW@xilinx.com> Signed-off-by: Jolly Shah <jollys@xilinx.com>
2019-01-04zynqmp: pm: Cleanup for clock set/get rate EEMI APIJolly Shah
Clock set/get rate are not implemented and will likely never be. Remove empty function stubs. Signed-off-by: Mirela Simonovic <mirela.simonovic@aggios.com> Acked-by: Will Wong <WILLW@xilinx.com> Signed-off-by: Jolly Shah <jollys@xilinx.com>
2019-01-04zynqmp: pm: Reimplement clock get divider EEMI APIJolly Shah
Clock get divider EEMI API is reimplemented to use system-level clock get divider EEMI API rather than direct MMIO read/write accesses to clock control registers. Signed-off-by: Mirela Simonovic <mirela.simonovic@aggios.com> Acked-by: Will Wong <WILLW@xilinx.com> Signed-off-by: Jolly Shah <jollys@xilinx.com>
2019-01-04zynqmp: pm: Reimplement clock set divider EEMI APIJolly Shah
Clock set divider EEMI API is reimplemented to use system-level clock set divider EEMI API rather than direct MMIO read/write accesses to clock control registers. Signed-off-by: Mirela Simonovic <mirela.simonovic@aggios.com> Acked-by: Will Wong <WILLW@xilinx.com> Signed-off-by: Jolly Shah <jollys@xilinx.com>
2019-01-04zynqmp: pm: Reimplement clock get state (status) EEMI APIJolly Shah
Clock get state EEMI API is reimplemented to use system-level clock and pll EEMI APIs rather than direct MMIO read/write accesses to clock and pll control registers. Since linux is_enabled method for PLLs still uses clock get state API get the PLL state, in the implementation of pm_clock_getstate() we need to workaround this by distinguishing two cases: 1) if the given clock ID corresponds to a PLL output clock ID; or 2) given clock ID is truly an on-chip clock whose state of the gate should be returned. For case 1) we'll call pm_api_clock_pll_getstate() implemented in pm_api_clock.h/c. This function will query the PLL state from PMU using the system-level PLL get mode EEMI API. For case 2) we'll call the PMU to query the clock gate state using system-level clock get status EEMI API. Functions that appear to be unused after this change is made are removed. Signed-off-by: Mirela Simonovic <mirela.simonovic@aggios.com> Acked-by: Will Wong <WILLW@xilinx.com> Signed-off-by: Jolly Shah <jollys@xilinx.com>
2019-01-04zynqmp: pm: Reimplement clock disable EEMI APIJolly Shah
Clock disable EEMI API is reimplemented to use system-level clock and pll EEMI APIs rather than direct MMIO read/write accesses to clock and pll control registers. Since linux still uses clock disable API to reset the PLL in the implementation of pm_clock_disable() we need to workaround this by distinguishing two cases: 1) if the given clock ID corresponds to a PLL output clock ID; or 2) given clock ID is truly an on-chip clock that can be gated. For case 1) we'll call pm_api_clock_pll_disable() implemented in pm_api_clock.h/c. This function will reset the PLL using the system-level PLL set mode EEMI API with the reset mode argument. For case 2) we'll call the PMU to configure the clock gate. This is done using system-level clock disable EEMI API. Functions that appear to be unused after this change is made are removed. Signed-off-by: Mirela Simonovic <mirela.simonovic@aggios.com> Acked-by: Will Wong <WILLW@xilinx.com> Signed-off-by: Jolly Shah <jollys@xilinx.com>
2019-01-04zynqmp: pm: Reimplement clock enable EEMI APIJolly Shah
Clock enable EEMI API is reimplemented to use system-level clock and pll EEMI APIs rather than direct MMIO read/write accesses to clock and pll control registers. Since linux still uses clock enable API to trigger locking of the PLLs in the pm_clock_enable() implementation we need to workaround this by distinguishing two cases: 1) if the given clock ID corresponds to a PLL output clock ID; or 2) given clock ID is truly an on-chip clock that can be gated. For case 1) we'll call pm_api_clock_pll_enable() implemented in pm_api_clock.h/c. This function checks what is the buffered PLL mode and calls the system-level PLL set mode EEMI API with the buffered mode value specified as argument. Long term, if linux driver get fixed to use PLL EEMI API to control PLLs, this case could be removed from ATF. For case 2) we'll call the PMU to configure the clock gate. This is done using system-level clock enable EEMI API. Signed-off-by: Mirela Simonovic <mirela.simonovic@aggios.com> Acked-by: Will Wong <WILLW@xilinx.com> Signed-off-by: Jolly Shah <jollys@xilinx.com>
2019-01-04zynqmp: pm: Return the buffered PLL mode through IOCTL PLL get mode APIJolly Shah
When linux calls pm_ioctl_get_pll_frac_mode() it doesn't expect the actual mode to be read from hardware, but the value that it is intending to program. Therefore, we return the buffered value to linux. Signed-off-by: Mirela Simonovic <mirela.simonovic@aggios.com> Acked-by: Will Wong <WILLW@xilinx.com> Signed-off-by: Jolly Shah <jollys@xilinx.com>
2019-01-04zynqmp: pm: Buffer the PLL mode that is set using IOCTL APIJolly Shah
When linux calls pm_ioctl_set_pll_frac_mode() it doesn't expect the fractional mode to be changed in hardware. Furthermore, even before this patch setting the mode which is done by writing into register takes no effect until the PLL reset is deasserted, i.e. until linux "enables" the PLL. To adjust the code to system-level PLL EEMI API and avoid unnecessary IPIs that would otherwise be issued, we buffer the mode value set via IOCTL until the PLL mode really needs to be set. Signed-off-by: Mirela Simonovic <mirela.simonovic@aggios.com> Acked-by: Will Wong <WILLW@xilinx.com> Signed-off-by: Jolly Shah <jollys@xilinx.com>
2019-01-04zynqmp: pm: Set PLL fractional data using PLL set parameter EEMI APIJolly Shah
Fractional data should be set using PLL set parameter EEMI API. This stands for system-level communication (APU to PMU). Since linux already uses a specific IOCTL function to do this and we need to keep it that way, the pll clock ID given by linux has to be mapped to the pll node ID that is communicated at the system-level (argument of PLL set parameter API). With this modification the function pm_api_clk_set_pll_frac_data is removed from pm_api_clock.c/h because it became unused. Signed-off-by: Mirela Simonovic <mirela.simonovic@aggios.com> Acked-by: Will Wong <WILLW@xilinx.com> Signed-off-by: Jolly Shah <jollys@xilinx.com>
2019-01-04zynqmp: pm: Get PLL fractional data using PLL get parameter EEMI APIJolly Shah
Fractional data should be get using PLL get parameter EEMI API. This stands for system-level communication (APU to PMU). Since linux already uses a specific IOCTL function to do this and we need to keep it that way, the pll clock ID given by linux has to be mapped to the pll node ID that is communicated at the system-level (argument of PLL get parameter API). With this modification the function pm_api_clk_get_pll_frac_data is removed from pm_api_clock.c/h because it became unused. The clock enum is defined as 'enum clock_id'. Signed-off-by: Mirela Simonovic <mirela.simonovic@aggios.com> Acked-by: Will Wong <WILLW@xilinx.com> Signed-off-by: Jolly Shah <jollys@xilinx.com>
2019-01-04zynqmp: pm: Implement PLL get mode EEMI APIJolly Shah
This API will be used to get the currently configured PLL mode: reset (bypassed and unlocked), integer or fractional (locked). Signed-off-by: Mirela Simonovic <mirela.simonovic@aggios.com> Acked-by: Will Wong <WILLW@xilinx.com> Signed-off-by: Jolly Shah <jollys@xilinx.com>
2019-01-04zynqmp: pm: Implement PLL set mode EEMI APIJolly Shah
This API will be used to set the PLL mode: reset (unlocked), integer or fractional (locked). If reset mode is set the PM controller will bypass the target PLL prior to asserting the reset. If integer or fractional mode is set the PM controller will program and trigger locking of the PLL. If success status is returned the PLL is locked and its bypass is deasserted. If fractional mode is set the fractional divider (data parameter) has to have a non-zero value prior to issuing pll set fractional mode. The caller need to ensure that the data parameter is properly set using pll get/set parameter EEMI API. Signed-off-by: Mirela Simonovic <mirela.simonovic@aggios.com> Acked-by: Will Wong <WILLW@xilinx.com> Signed-off-by: Jolly Shah <jollys@xilinx.com>
2019-01-04zynqmp: pm: Implement PLL get parameter EEMI APIJolly Shah
This API will be used to get a parameter for the PLL. Parameter values represent the values as defined in the Zynq MPSoC register reference manual ug1087. Signed-off-by: Mirela Simonovic <mirela.simonovic@aggios.com> Acked-by: Will Wong <WILLW@xilinx.com> Signed-off-by: Jolly Shah <jollys@xilinx.com>
2019-01-04zynqmp: pm: Implement PLL set parameter EEMI APIJolly Shah
This API will be used to set a parameter for the PLL. The parameter value that is set will have effect once the PLL mode is set to integer or fractional mode. Parameter values represent the values as defined in the Zynq MPSoC register reference manual ug1087. Signed-off-by: Mirela Simonovic <mirela.simonovic@aggios.com> Acked-by: Will Wong <WILLW@xilinx.com> Signed-off-by: Jolly Shah <jollys@xilinx.com>
2019-01-04Sanitise includes across codebaseAntonio Nino Diaz
Enforce full include path for includes. Deprecate old paths. The following folders inside include/lib have been left unchanged: - include/lib/cpus/${ARCH} - include/lib/el3_runtime/${ARCH} The reason for this change is that having a global namespace for includes isn't a good idea. It defeats one of the advantages of having folders and it introduces problems that are sometimes subtle (because you may not know the header you are actually including if there are two of them). For example, this patch had to be created because two headers were called the same way: e0ea0928d5b7 ("Fix gpio includes of mt8173 platform to avoid collision."). More recently, this patch has had similar problems: 46f9b2c3a282 ("drivers: add tzc380 support"). This problem was introduced in commit 4ecca33988b9 ("Move include and source files to logical locations"). At that time, there weren't too many headers so it wasn't a real issue. However, time has shown that this creates problems. Platforms that want to preserve the way they include headers may add the removed paths to PLAT_INCLUDES, but this is discouraged. Change-Id: I39dc53ed98f9e297a5966e723d1936d6ccf2fc8f Signed-off-by: Antonio Nino Diaz <antonio.ninodiaz@arm.com>
2018-11-12Merge pull request #1605 from sivadur/integrationAntonio Niño Díaz
Add support new Xilinx Versal ACAP platform
2018-11-09arm64: versal: Add support for new Xilinx Versal ACAPsSiva Durga Prasad Paladugu
Xilinx is introducing Versal, an adaptive compute acceleration platform (ACAP), built on 7nm FinFET process technology. Versal ACAPs combine Scalar Processing Engines, Adaptable Hardware Engines, and Intelligent Engines with leading-edge memory and interfacing technologies to deliver powerful heterogeneous acceleration for any application. The Versal AI Core series has five devices, offering 128 to 400 AI Engines. The series includes dual-core Arm Cortex-A72 application processors, dual-core Arm Cortex-R5 real-time processors, 256KB of on-chip memory with ECC, more than 1,900 DSP engines optimized for high-precision floating point with low latency. This patch adds Virtual QEMU platform support for this SoC "versal_virt". Signed-off-by: Siva Durga Prasad Paladugu <siva.durga.paladugu@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-11-08Standardise header guards across codebaseAntonio Nino Diaz
All identifiers, regardless of use, that start with two underscores are reserved. This means they can't be used in header guards. The style that this project is now to use the full name of the file in capital letters followed by 'H'. For example, for a file called "uart_example.h", the header guard is UART_EXAMPLE_H. The exceptions are files that are imported from other projects: - CryptoCell driver - dt-bindings folders - zlib headers Change-Id: I50561bf6c88b491ec440d0c8385c74650f3c106e Signed-off-by: Antonio Nino Diaz <antonio.ninodiaz@arm.com>
2018-10-26Convert arm_setup_page_tables into a generic helperRoberto Vargas
This function is not related to Arm platforms and can be reused by other platforms if needed. Change-Id: Ia9c328ce57ce7e917b825a9e09a42b0abb1a53e8 Co-authored-by: Antonio Nino Diaz <antonio.ninodiaz@arm.com> Signed-off-by: Antonio Nino Diaz <antonio.ninodiaz@arm.com>
2018-10-26xlat: Fix compatibility between v1 and v2Antonio Nino Diaz
There are several platforms using arm_setup_page_tables(), which is supposed to be Arm platform only. This creates several dependency problems between platforms. This patch adds the definition XLAT_TABLES_LIB_V2 to the xlat tables lib v2 makefile. This way it is possible to detect from C code which version is being used and include the correct header. The file arm_xlat_tables.h has been renamed to xlat_tables_compat.h and moved to a common folder. This way, when in doubt, this header can be used to guarantee compatibility, as it includes the correct header based on XLAT_TABLES_LIB_V2. This patch also removes the usage of ARM_XLAT_TABLES_V1 from QEMU (so that is now locked in xlat lib v2) and ZynqMP (where it was added as a workaround). Change-Id: Ie1e22a23b44c549603d1402a237a70d0120d3e04 Signed-off-by: Antonio Nino Diaz <antonio.ninodiaz@arm.com>
2018-10-25zynqmp: Remove dependency on arm_helpers.SAntonio Nino Diaz
Non-Arm platforms shouldn't use Arm platform code. This patch copies the implementation of the functions in arm_helpers.S to zynqmp_helpers.S to remove this dependency of zynqmp on Arm platforms. Change-Id: Ia85f303c4c63bcf0ffa57c7f3ef9d88376729b6b Signed-off-by: Antonio Nino Diaz <antonio.ninodiaz@arm.com>
2018-10-10Replace S-EL3 references by EL3John Tsichritzis
The "Secure" prefix (S-ELx) is valid only for S-EL0 and S-EL1 but is meaningless for EL3, since EL3 is always secure. Hence, the "S" prefix has been removed from wherever it was used as "S-EL3". Change-Id: Icdeac9506d763f9f83d7297c7113aec7b85e9dbe Signed-off-by: John Tsichritzis <john.tsichritzis@arm.com>
2018-10-03Merge pull request #1584 from danielboulby-arm/db/SwitchesSoby Mathew
Ensure the flow through switch statements is clear
2018-09-28zynqmp: Migrate to new interfacesAntonio Nino Diaz
- Remove references to removed build options. - Migrate to bl31_early_platform_setup2(). Change-Id: Ibeb8982a0a841f55ce778c4f09f06b72b47b21d8 Tested-by: Siva Durga Prasad Paladugu <siva.durga.paladugu@xilinx.com> Signed-off-by: Antonio Nino Diaz <antonio.ninodiaz@arm.com>
2018-09-21Ensure the flow through switch statements is clearDaniel Boulby
Ensure case clauses: * Terminate with an unconditional break, return or goto statement. * Use conditional break, return or goto statements as long as the end of the case clause is unreachable; such case clauses must terminate with assert(0) /* Unreachable */ or an unconditional __dead2 function call * Only fallthough when doing otherwise would result in less readable/maintainable code; such case clauses must terminate with a /* Fallthrough */ comment to make it clear this is the case and indicate that a fallthrough is intended. This reduces the chance of bugs appearing due to unintended flow through a switch statement Change-Id: I70fc2d1f4fd679042397dec12fd1982976646168 Signed-off-by: Daniel Boulby <daniel.boulby@arm.com>
