To make software license auditing simpler, use SPDX[0] license
identifiers instead of duplicating the license text in every file.
NOTE: Files that have been imported by FreeBSD have not been modified.
[0]: https://spdx.org/
Change-Id: I80a00e1f641b8cc075ca5a95b10607ed9ed8761a
Signed-off-by: dp-arm <dimitris.papastamos@arm.com>
There are many instances in ARM Trusted Firmware where control is
transferred to functions from which return isn't expected. Such jumps
are made using 'bl' instruction to provide the callee with the location
from which it was jumped to. Additionally, debuggers infer the caller by
examining where 'lr' register points to. If a 'bl' of the nature
described above falls at the end of an assembly function, 'lr' will be
left pointing to a location outside of the function range. This misleads
the debugger back trace.
This patch defines a 'no_ret' macro to be used when jumping to functions
from which return isn't expected. The macro ensures to use 'bl'
instruction for the jump, and also, for debug builds, places a 'nop'
instruction immediately thereafter (unless instructed otherwise) so as
to leave 'lr' pointing within the function range.
Change-Id: Ib34c69fc09197cfd57bc06e147cc8252910e01b0
Co-authored-by: Douglas Raillard <douglas.raillard@arm.com>
Signed-off-by: Jeenu Viswambharan <jeenu.viswambharan@arm.com>
Use the PMUFW get_chipid call to obtain IDCODE and version register.
Cc: Michal Simek <michal.simek@xilinx.com>
Cc: Siva Durga Prasad Paladugu <sivadur@xilinx.com>
Signed-off-by: Soren Brinkmann <soren.brinkmann@xilinx.com>
On ZynqMP the FSBL will configure the system counter. Hence, remove the
initialization of the system counter with hardcoded values from the ATF
and use the setup provided by the bootloader.
Acked-by: Michal Simek <michal.simek@xilinx.com>
The silicon ID does not change at runtime. Skip the IO access if the
ID has been read before.
Add support to provide silicon id to non-secure
software through SMC.
Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com>
[ sb
Move zynqmp_get_silicon_id outside of compile guards to avoid build
errors.
Initialize the generic_delay_timer in the zynqmp port.
Zynqmp updates
The revision field may change between silicon revisions without changing
the mapping to a part. This avoids errors like:
ERROR: Incorrect XILINX IDCODE 0x14738093, maskid 0x4600093
NOTICE: ATF running on XCZUUNKN/EP108 v3/RTL5.1 at 0xfffe5000
on parts with a newer revision.
Reported-by: Love Kumar <love.kumar@xilinx.com>
Acked-by: Alistair Francis <alistair.francis@xilinx.com>
Tested-by: Love Kumar <love.kumar@xilinx.com>
Replaced plat_get_syscnt_freq by plat_get_syscnt_freq2 on all
upstream platforms.
Change-Id: I3248f3f65a16dc5e9720012a05c35b9e3ba6abbe
Provide a function to retrieve the bootmode.
This patch moves the definition for `plat_get_syscnt_freq()`
from arm_bl31_setup.c to arm_common.c. This could be useful
in case a delay timer needs to be installed based on the
generic timer in other BLs.
This patch also modifies the return type for this function
from `uint64_t` to `unsigned long long` within ARM and other
platform files.
Change-Id: Iccdfa811948e660d4fdcaae60ad1d700e4eda80d
The Xilinx Zynq UltraScale+ MPSOC containes a quad A53 cluster. This
patch adds the platform port for that SoC.
