With GCC 6.2 compiler, more C undefined behaviour is being flagged as
warnings, which result in build errors in ARM TF build.
This patch addresses issue caused by enums with values that exceed
maximum value for an int. For these cases the enum is converted to
a set of defines.
Change-Id: I5114164be10d86d5beef3ea1ed9be5863855144d
Signed-off-by: David Cunado <david.cunado@arm.com>
To make software license auditing simpler, use SPDX[0] license
identifiers instead of duplicating the license text in every file.
NOTE: Files that have been imported by FreeBSD have not been modified.
[0]: https://spdx.org/
Change-Id: I80a00e1f641b8cc075ca5a95b10607ed9ed8761a
Signed-off-by: dp-arm <dimitris.papastamos@arm.com>
Move plat/common source file definitions to generic Makefiles
These source file definitions should be defined in generic
Makefiles so that all platforms can benefit. Ensure that the
symbols are properly marked as weak so they can be overridden
by platforms.
NOTE: This change is a potential compatibility break for
non-upstream platforms.
Change-Id: I7b892efa9f2d6d216931360dc6c436e1d10cffed
The Mediatek 8173 SoC contains Cortex-A53 CPUs which are affected by
erratum 855873.
Enable the workaround that TF provides to fix this erratum.
Change-Id: I6e1c7822c320d81bdd46b8942d1d755883dac1f5
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
Now it's possbile to build BL31 for MT8173 with ERROR_DEPRECATED=1.
Signed-off-by: Koan-Sin Tan <koansin.tan@gmail.com>
make 'make ARCH=aarch64 CROSS_COMPILE=aarch64-linux-gnu- PLAT=mt8173
ENABLE_PLAT_COMPAT=0' work.
Change-Id: I13f35d8aef23dfa0e65883fa0be43f1513c9fef5
One nasty part of ATF is some of boolean macros are always defined
as 1 or 0, and the rest of them are only defined under certain
conditions.
For the former group, "#if FOO" or "#if !FOO" must be used because
"#ifdef FOO" is always true. (Options passed by $(call add_define,)
are the cases.)
For the latter, "#ifdef FOO" or "#ifndef FOO" should be used because
checking the value of an undefined macro is strange.
Here, IMAGE_BL* is handled by make_helpers/build_macro.mk like
follows:
$(eval IMAGE := IMAGE_BL$(call uppercase,$(3)))
$(OBJ): $(2)
@echo " CC $$<"
$$(Q)$$(CC) $$(TF_CFLAGS) $$(CFLAGS) -D$(IMAGE) -c $$< -o $$@
This means, IMAGE_BL* is defined when building the corresponding
image, but *undefined* for the other images.
So, IMAGE_BL* belongs to the latter group where we should use #ifdef
or #ifndef.
Macro cleanups
We have lots of duplicated defines (and comment blocks too).
Move them to include/plat/common/common_def.h.
While we are here, suffix the end address with _END instead of
_LIMIT. The _END is a better fit to indicate the linker-derived
real end address.
The actual length of the firmware is 1001 32 bit words.
Signed-off-by: Paul Kocialkowski <contact@paulk.fr>
This patch support single core to boot to Linux kernel
through Trusted Firmware.
It also support 32 bit kernel and 64 bit kernel booting.
This patch migrates the upstream platform makefiles to include the
console drivers from the new location in ARM Trusted Firmware code
base.
Change-Id: I866d6c4951e475de1f836ce8a8c1d5e6da9577e3
This patch introduces a new header file: include/lib/utils.h.
Its purpose is to provide generic macros and helper functions that
are independent of any BL image, architecture, platform and even
not specific to Trusted Firmware.
For now, it contains only 2 macros: ARRAY_SIZE() and
IS_POWER_OF_TWO(). These were previously defined in bl_common.h and
xlat_tables.c respectively.
bl_common.h includes utils.h to retain compatibility for platforms
that relied on bl_common.h for the ARRAY_SIZE() macro. Upstream
platform ports that use this macro have been updated to include
utils.h.
Change-Id: I960450f54134f25d1710bfbdc4184f12c049a9a9
Use the generic delay timer instead of having a specific platform
file for configuring it.
Change-Id: If6b8f60bc04230f4b85b2bcc1b670fc65461214e
Replaced plat_get_syscnt_freq by plat_get_syscnt_freq2 on all
upstream platforms.
Change-Id: I3248f3f65a16dc5e9720012a05c35b9e3ba6abbe
Change-Id: Idc40cc6243e532567ec4334ae37d97c003c90bfa
Signed-off-by: Yi Zheng <yi.zheng@mediatek.com>
Due to the changes in Mediatek platform common code, we need to move
plat related SiP functions to plat folder.
Change-Id: I6b14b988235205a5858b4bf49043bc79d0512b06
Signed-off-by: Jimmy Huang <jimmy.huang@mediatek.com>
Refactor MediaTek platform common code
Refactor MediaTek platform common code for further mt6795 upstream.
This patch moves the definition for `plat_get_syscnt_freq()`
from arm_bl31_setup.c to arm_common.c. This could be useful
in case a delay timer needs to be installed based on the
generic timer in other BLs.
This patch also modifies the return type for this function
from `uint64_t` to `unsigned long long` within ARM and other
platform files.
Change-Id: Iccdfa811948e660d4fdcaae60ad1d700e4eda80d
It is up to the platform to implement the new plat_crash_print_regs macro to
report all relevant platform registers helpful for troubleshooting.
plat_crash_print_regs merges or calls previously defined plat_print_gic_regs
and plat_print_interconnect_regs macros for each existing platforms.
NOTE: THIS COMMIT REQUIRES ALL PLATFORMS THAT ENABLE THE `CRASH_REPORTING`
BUILD FLAG TO MIGRATE TO USE THE NEW `plat_crash_print_regs()` MACRO. BY
DEFAULT, `CRASH_REPORTING` IS ENABLED IN DEBUG BUILDS FOR ALL PLATFORMS.
Fixes: arm-software/tf-issues#373
Signed-off-by: Gerald Lejeune <gerald.lejeune@st.com>
mt8173: Fix timing issue of mfg mtcmos power off
In mt8173, there are totally 10 non-cpu mtcmos, so we cannot tell
if SPM finished the power control flow by 10 status bits of PASR_PDP_3.
So, extend PASR_PDP_3 status bits from 10 to 20 so that we can
make sure if the control action has been done precisely.
Change-Id: Ifd4faaa4173c6e0543aa8471149adb9fe7fadedc
Signed-off-by: Fan Chen <fan.chen@mediatek.com>
This patch modifies the upstream platform port makefiles to use the new
xlat_tables library files. This patch also makes mmap region setup common
between AArch64 and AArch32 for FVP platform port. The file `fvp_common.c`
is moved from the `plat/arm/board/fvp/aarch64` folder to the parent folder
as it is not specific to AArch64.
Change-Id: Id2e9aac45e46227b6f83cccfd1e915404018ea0b
To fix build errors in following build conditions,
DEBUG=1 LOG_LEVEL<40
DEBUG=0 LOG_LEVEL>=40
Change-Id: Ib34aed07b2ae0abd8a3a46948adc9fbeaae715aa
Signed-off-by: yt.lee <yt.lee@mediatek.com>
BL31 usually handles confidential stuff, its memory must not be
read/write accessible from non-secure world. This patch protects
the BL31 memory range from non-secure read/write access.
Change-Id: I442fb92b667bb2f9a62d471a90508b1ba4489911
This patch adds big core ARMPLL control in system suspend flow.
Change-Id: I27a45dbbb360f17ff0b524a125630358ee2277e2
Signed-off-by: Louis Yu <louis.yu@mediatek.com>
We no longer need to control power signal via gpio during system off,
thus remove gpio driver support from platform code.
Change-Id: I6dfec129fa163330951f37b45b71ba5b90355c3b
MT8173 platform code is incompatible with RESET_TO_BL31, add #error
directive to prevent the case.
We also move mt8173_def.h and plat_private.h to include directory, and
remove some unnecessary code.
Change-Id: I47b8d0a506820a4ea1fbe8c8fb0ec6c68d88feb5
All files including plat/mediatek/mt8173/drivers/gpio/gpio.h were
using system includes instead of user includes, which may cause the
wrong version of the header to be included. Said includes have been
changed to user includes to make sure that the included file is the
wanted one.
Change-Id: I29bdfe96fbd9a7900875e2357bbb43f3ea431fa5
Use tf_printf() for debug logs from xlat_tables.c
Disable PL011 UART before configuring it
The debug prints used to debug translation table setup in xlat_tables.c
used the `printf()` standard library function instead of the stack
optimized `tf_printf()` API. DEBUG_XLAT_TABLE option was used to enable
debug logs within xlat_tables.c and it configured a much larger stack
size for the platform in case it was enabled. This patch modifies these
debug prints within xlat_tables.c to use tf_printf() and modifies the format
specifiers to be compatible with tf_printf(). The debug prints are now enabled
if the VERBOSE prints are enabled in Trusted Firmware via LOG_LEVEL build
option.
The much larger stack size definition when DEBUG_XLAT_TABLE is defined
is no longer required and the platform ports are modified to remove this
stack size definition.
Change-Id: I2f7d77ea12a04b827fa15e2adc3125b1175e4c23
We found sometimes mtcmos operation is too long in spm (>1ms),
so update a new version to fix it.
I verified with 5 hours power_LoadTest, every mtcmos control
can finish in 500us (average is 100~200us).
Change-Id: I47b712bf9898870f4abcecbea47e01b9786231d4
1. Set more wakeup source
2. Update PCM code for control logic
Change-Id: I2ad06bd85bd1c75a22c838eab4cf5566c443b89a
Signed-off-by: Weiyi Lu <weiyi.lu@mediatek.com>
1. Add SiP calls for subsystem power on/off and check support
2. Add subsystem power control related initialization in
bl31_plat_setup.c
3. Add subsystem power on/off and power ack waiting functions
4. Update PCM code for subsystem physical power control logic
Change-Id: Ia0ebb1964c8f9758159bcf17c1813d76ef52cf64
1. add power control for both big and Little cluster in MCDI
2. fix incorrect PCM_HOTPLUG_VALID_MASK in spm_hotplug.c
3. check the power status of cpus in cluster before setting the cputop
power control
Change-Id: Ifa85306a8bc218098667247904d281494c2f7bfe
Move SPM related PLL settings to spm_boot_init in ARM TF SPM driver
Change-Id: I414b896caae072570c8de33a25e06db4ae011f57
This patch updates SPM driver settings and PCM code to fix USB remote
wake up problem.
Change-Id: I07a81cc64b1d226d111380580d09ae25879f4285
This patch enables dynamic clock management control to reduce power
consumption in various components.
Change-Id: I8f66d9b72c8b1d70169ffe46cc361b16a0dadb77
The PL011 TRM (ARM DDI 0183G) specifies that the UART must be
disabled before any of the control registers are programmed. The
PL011 driver included in TF does not disable the UART, so the
initialization in BL2 and BL31 is violating this requirement
(and potentially in BL1 if the UART is enabled after reset).
This patch modifies the initialization function in the PL011
console driver to disable the UART before programming the
control registers.
Register clobber list and documentation updated.
Fixes ARM-software/tf-issues#300
Change-Id: I839b2d681d48b03f821ac53663a6a78e8b30a1a1
Migrate all direct usage of __attribute__ to usage of their
corresponding macros from cdefs.h.
e.g.:
- __attribute__((unused)) -> __unused
Signed-off-by: Soren Brinkmann <soren.brinkmann@xilinx.com>
mt8173: Update SPM and fix watchdog setting
This patch corrects the watchdog register setting. To update watchdog
register, the watchdog mode key must be set to make the register
configurable.
Change-Id: I9ca98ea4012f7f220b116013461030de4638ce0b
1. update suspend pcm code (add dummy apb read before mcusys power down)
BRANCH=none
BUG=none
TEST=verified
Change-Id: I2802cf8665fc1c8fe2304fd7d5f3eab9948b0b78
This patch update Mediatek port to use the `DEFINE_BAKERY_LOCK` macro instead of
specifying the exact data structure to use for a bakery lock and the input
linker section that it should be allocated to.
Change-Id: I2116dbe27010bb46d7cc64fafef55c7240c4c721
mt8173: Fix cluster 0 core count
