Some of the platform (ie. Agilex) make use of CCU IPs which will only be
initialized during bl2_el3_early_platform_setup. Any operation to the
cache beforehand will crash the platform. Hence, this will provide an
option to skip the data cache invalidation upon bl2 entry at EL3
Signed-off-by: Hadi Asyrafi <muhammad.hadi.asyrafi.abdul.halim@intel.com>
Change-Id: I2c924ed0589a72d0034714c31be8fe57237d1f06
Disable gic cpu interface for powered down cpu. This patch also removes
core reset during power off as core reset will be done during power on
Change-Id: I2ca96d876b6e71e56d24a9a7e184b6d6226b8673
integration
Driver will calculate DDR size instead of using hardcoded value
Change-Id: I642cf2180929965ef12bd5ae4393b2f3d0dcddde
To provide glitchless clock to downstream logic even if clock toggles
Change-Id: I728d64d0ba3b4492125bea5b0737fc83180356f1
Increase calibration delay, fix ddrio control config & nonsecure region
limit
Change-Id: Ibca3c247a3ad5104176ca9057d29755599f13c9b
Extract clock information for UART, MMC & Watchdog from the clock manager
Change-Id: I42d3d4ceeaf45788d457472f6ddcd3fe099f0133
Extract clock information for UART, MMC & Watchdog from the platform
rather than hard code it
Change-Id: I2582bd34a6da97bd75d5ccba5f93840e65f26b03
* changes:
intel: Platform common code refactor
Pull out common code from aarch64 and include
Change-Id: I4d0f5e1bb01bcdacbedf8e6c359de594239b645f
Previous config blocks ATF runtime service communications with SDM mailbox
Change-Id: Ia857facd0bd0790056df94ed1e016bcf619a161e
Pull out common code from agilex and stratix10
Change-Id: Iddc0a9e6eccb30823d7b15615d5ce9c6bedb2abc
Change-Id: Ic97aa381d3ceb96395595ec192132859d626b8d1
"result of '1 << 31' requires 33 bits to represent, but 'int' only has
32 bits [-Werror=shift-overflow=]"
This is treated as an error since commit 93c690eba8ca ("Enable
-Wshift-overflow=2 to check for undefined shift behavior")
Change-Id: I141827a6711ab7759bfd6357e4ed9c1176da7c7b
Signed-off-by: Ambroise Vincent <ambroise.vincent@arm.com>
Change-Id: Ib2ad2068abdf0b204c5cb021ea919581adaca4ef
* changes:
Enable -Wshift-overflow=2 to check for undefined shift behavior
Update base code to not rely on undefined overflow behaviour
Update hisilicon drivers to not rely on undefined overflow behaviour
Update synopsys drivers to not rely on undefined overflow behaviour
Update imx platform to not rely on undefined overflow behaviour
Update mediatek platform to not rely on undefined overflow behaviour
Update layerscape platform to not rely on undefined overflow behaviour
Update intel platform to not rely on undefined overflow behaviour
Update rockchip platform to not rely on undefined overflow behaviour
Update renesas platform to not rely on undefined overflow behaviour
Update meson platform to not rely on undefined overflow behaviour
Update marvell platform to not rely on undefined overflow behaviour
This consists of ensuring that the left operand of each shift is
unsigned when the operation might overflow into the sign bit.
Change-Id: I4c7a315cb18b3bbe623e7a7a998d2dac869638a7
Signed-off-by: Justin Chadwell <justin.chadwell@arm.com>
MMC sample select needs to be set properly so that DWMMC clock can be
driven to 50Mhz
Signed-off-by: Tien Hock, Loh <tien.hock.loh@intel.com>
Change-Id: I4a1dde4f6a1e78a36940c57a7a5b162be0bd443a
* changes:
qemu: use new console interface in aarch32
warp7: remove old console from makefile
Remove MULTI_CONSOLE_API flag and references to it
Console: removed legacy console API
The new API becomes the default one.
Change-Id: Ic1d602da3dff4f4ebbcc158b885295c902a24fec
Change-Id: I0544315986ee28b23157fdfec3fe5aebae6b860f
Change-Id: I0ffccca7ea83bff35c9f149d7054cd610a59ec01
Change-Id: I5241ed97697b0280b590b47b9173d102d23f305a
Change-Id: Ib79e2c6fe6e66dec5004701133ad6a5f4c78f2fa
Watchdog driver support & enablement during platform setup
Signed-off-by: Muhammad Hadi Asyrafi Abdul Halim <muhammad.hadi.asyrafi.abdul.halim@intel.com>
intel: QSPI boot enablement
Manages QSPI initialization, configuration and IO handling as boot device
To support the enablement of QSPI booting
drivers: mmc: Fix some issues with MMC stack
MMC stack needs OCR voltage information for the platform to initialize
MMC controller correctly.
intel: Mailbox service un-accessible
Change map region for device 2 from non-secure to secure
We should be using zeromem to scrub memory instead of memset. This would
improve the performance by 200x
This adds BL31 support to Intel Stratix10 SoCFPGA platform. BL31 in TF-A
supports:
- PSCI calls to enable 4 CPU cores
- PSCI mailbox calls for FPGA reconfiguration
Signed-off-by: Loh Tien Hock <tien.hock.loh@intel.com>
A DDR calibration value is missing write mask, causing ECC DDR calibration
to fail. This patch addresses the issue. ECC should also be scrubbed before
MMU initializes, thus the scrubbing is moved to ddr intialization phase.
This adds BL2 support for Intel Stratix 10 SoC FPGA.
Functionality includes:
- Release and setup peripherals from reset
- Calibrate DDR
- ECC DDR Scrubbing
- Load FIP (bl31 and bl33)
