setup
Signed-off-by: Olivier Masse <olivier.masse@nxp.com>
Fix Coverity CID 5209712: Uninitialized scalar variable (UNINIT)
issue.
Signed-off-by: Bai Ping <ping.bai@nxp.com>
fix Coverity: CID 5243766: Uninitialized scalar variable (UNINIT)
issue.
If no valid dram info to copy from DRAM, skip
copy the dram info.
remove unused files on i.MX8MQ.
refact the dram low power related code to make it more
friendly for different dram config or different board.
ERR050044: GPU/VPU power domain on/off stress test leads
to unexpected GPU interrupts and hang.
his is caused by no dedicated HW resets for GPU2D/3D.
There is one reset for whole GPUmix and GPU2D/3D has their
own SW reset signals. The SW reset cannot be asserted while
GPU2D/3D is in power off status. So if only GPU2D or GPU3D
has to be powered off and on, unknown status leads to the problem.
VPU has similiar issue. So we need to assert the SW reset before
power up the power domain.
JR0 and JR1 of CAAM are owned by SECO, only kick the power
of JR2 and JR3 here and assign the resources to be accessed
by secure world.
Signed-off-by: Ji Luo <ji.luo@nxp.com>
Due imx8qm_mek's UART0_RTS_B and UART0_CTS_0 pad
reuse to be the UART2 for base bard which operated by
M4_1, so don't touch these two pads in ATF.
Signed-off-by: Haoran.Wang <elven.wang@nxp.com>
Acked-by: Pete Zhang <pete.zhang@nxp.com>
Tee(Trusty Os) will be stored in fit for Android and Android Auto
so we don't need to copy it anymore, this will save some boot time.
Signed-off-by: Luo Ji <ji.luo@nxp.com>
The RFSHCTL3.refresh_mode should be set normal mode if we
want to disable auto refresh mode.
This patch adds support for cpuidle with CPU powerdown,
there will be 3 idle states in Linux kernel:
1: wfi;
2: cpu power down;
3: cluster power down.
As Linux kernel needs a broadcast timer for waking up
CPU when whole CLUSTER is powerdown, GPT is adopted as
broadcast timer, and to make the clock & power management
easy for Linux kernel to avoid many workaround/hake in
Linux kernel, TF-A will handle GPT's power & clock management
as well as registers save/restore when suspend/resume.
Also, psci power states are used to determine CORE/CLUSTER/SYSTEM
power state to distinguish CPU idle and SYSTEM suspend which share
same domain_suspend callback.
The SoC IPs register mmap regions are merged into 1 large
section to cover all the SoC IPs register ranges TF-A needs,
this is to save mmap regions and make it simple.
Signed-off-by: Anson Huang <Anson.Huang@nxp.com>
Update the DDR4 DVFS flow
Add DDR4 DVFS support for i.MX8M. Currently, only tested on i.MX8MM.
A53 cluster cannot be power gated unless the entire
multi-cluster (A53 + A72 + CCI) is gated off. Root cause
still TBD, this patch adds temporary workaround to
ONLY allow A53 power off when system suspend.
Add ddr4 retention flow for imx8m.
Add support for enabling output debug message to SC
console, SC_CONSOLE is used to enable/disable it.
Example log output on SC console as below:
*** Debug Monitor ***
>$ NOTICE: smc_fid is c2000003
imx_pwr_domain_on cluster_id 0, cpu_id 1
cluster:0 core:1 is on
imx_pwr_domain_on cluster_id 0, cpu_id 2
cluster:0 core:2 is on
imx_pwr_domain_on cluster_id 0, cpu_id 3
cluster:0 core:3 is on
imx_pwr_domain_on cluster_id 1, cpu_id 0
cluster:1 core:0 is on
imx_pwr_domain_on cluster_id 1, cpu_id 1
cluster:1 core:1 is on
Add FSL_SIP_MISC_SET_TEMP support for setting thermal
alarm function.
After the SRC bit clear, we must wait for a while to make sure
the operation is finished.
for USB OTG, the limitations are:
1. before system clock configuration. ipg clock runs at 12.5MHz.
delay time should longer than 82us.
2. after system clock configuration. ipg clock runs at 66.5MHz.
delay time should longer than 15.3us.
so add udelay 100 to safely clear the SRC bit 0.
For i.MX8MM low power audio playback, when Linux suspend,
M4 still needs to be active for audio playback, so system
can NOT enter DSM mode but only force A core platform into
STOP mode, PLLs/NoC/DRAM need to be active as well and MU
interrupt wakeup needs to be enabled for waking up Linux
by MU message sent by M4.
The chip revision should ONLY overwrite the lower 16 bits of
soc_id, otherwise, the cpu_is_imx8mq() API in Linux kernel
will be incorrect.
The Trusty OS binary will be installed into
container.img and loaded into 0x84000000.
Due Trusty OS addresss is in 0xfe000000 which
ROM cannot reach, so use ATF to copy it into
the target address.
Mapped the BL32 code into MMU due the Trusty
SPD need to check the code status and decide
the CPU executing mode.
To reserve and protect the memory for secure
world, modify the partition code to keep
BL32 spaces in secure_part.
Reviewed-by: Ye Li <ye.li@nxp.com>
the GPU/VPU mix power off is skip in previous code,
so correct to make sure GPU/VPU mix is actually power
off.
Using sc_pm_set_cpu_resume API instead of sc_pm_set_cpu_resume_addr
to support random CPU resume for system suspend, as Linux kernel
now supports non CPU0 suspend, we have to specify the CPU ID for
SCFW to wake up when system resume.
Read the mode register setting from the DDRC, then we can
make the DVFS flow more indepent from the actual DDR config.
Signed-off-by: Oliver Chen <Oliver.Chen@nxp.com>
On B0.1 chip, the value is 0x1020 not 0x20, due to minor version updated.
So if reading the word and comparing with 0x20, the result is wrong.
Fix the issue by only reading low major version byte for ROM version
Signed-off-by: Ye Li <ye.li@nxp.com>
i.MX8MQ B1's chip revision is identified by reading
OCOTP offset 0x40, the magic number 0xff0055aa is
for B1.
update the ddr controller perf QoS setting on i.MX8MQ.
csu_rdc test in ATF makes use of GPIO 4 and 5. Unfortunatly GPIO5 is
being used by u-boot. This is why u-boot crashes.
Changing the peripherals to protect, instead of gpio4 and 5, use csu
and rdc registers instead.
Signed-off-by: Silvano di Ninno <silvano.dininno@nxp.com>
Signed-off-by: Franck LENORMAND <franck.lenormand@nxp.com>
To support KS1, need to put all resources into OFF mode
instead of STBY when Linux kernel suspend. Here, DRC,
IRQ_STEER and DBLOGIC can be OFF for KS1 mode.
Add NOC configuration entry for all the module.
Kernel can configure the noc priority through this entry.
Signed-off-by: Zhang Bo <bo.zhang@nxp.com>
imx_v2018.03 u-boot uses ROM's APIs: check_target and failsafe. So for iMX8M
platforms, we have to implement the sip calls and use ATF to call them when
u-boot running at non-secure world.
If NOC is power down in DSM mode, the tz380 register config
will be lost, so we must re-init the tz380 after system resume.
the tz380 initialization must be done after DRAM has been out
of retention.
The DRAM APB bus clock rate is wrong before and after DVFS.
The register offset for APB bus clock is wrong, so fix it.
SCFW has supported DDR retention, so now DRC can be
into OFF mode instead of STBY when Linux suspend.
enable NOC power down in DSM mode.
With flash_uboot_cm4ddr in imx-mkimage, the m4 code will access ddr.
However after m4 core moved to non-secure partition, the ddr memory
is still in secure partition. Then m4 core will fault.
So postpone moving resources including m4 core, until other resources,
such as memory/pin moved to non-secure partition.
Signed-off-by: Peng Fan <peng.fan@nxp.com>
(cherry picked from commit 1c8ce0ad5f583ec41026d4ab5bef622f1b45aecd)
Enable the power domain support on imx8mm.
add LPDDR4 DVFS support on imx8mm.
All the DRAM timing related config is saved by SPL in OCRAM_S,
so no need to do save for these configs in ATF anymore.
On i.MX8MM, the OCRAM's last 128K is dedicated for ATF, so move
bl31 to this memory region.
BuildInfo:
- IMX-MKIMAGE: ee5ad91b
The debug version of TF-A has below assert, fix
it by making sure no memory map overlap.
ASSERT: lib/xlat_tables/xlat_tables_common.c:129
Switch to MULTI_CONSOLE_API to make debug UART work.
skip init the dram info if the ddr type is DDR4,
support for it will be added later.
Add SIP service for OTP reading/writing for use
in u-boot
Signed-off-by: Teo Hall <teo.hall@nxp.com>
Update API based on following commit:
commit 24fa33d2f95707e739f01cc04d38a62bec707ceb
Author: Chuck Cannon <chuck.cannon@nxp.com>
Date: Thu Jun 28 15:00:03 2018 -0500
SCF-105: Add disclaimer to docs.
Signed-off-by: Chuck Cannon <chuck.cannon@nxp.com>
For use of the misc otp service
This patch enables necessary erratas for A53 r0p4
according to docs/cpu-specific-build-macros.rst.
SC_R_IRQSTR_SCU2 can be OFF in system suspend if there
is no wakeup irq enabled from non-secure OS partion.
Add wakeup source check to decide if turning off
SC_R_IRQSTR_SCU2 or NOT when suspend.
