Test if a partition reboot has taken place with the MU
interrupt bit. Check before returning the entrypoint
Signed-off-by: Teo Hall <teo.hall@nxp.com>
(cherry picked from commit 627396daa5d9b62e8a0fb118844d1507b94e23f5)
If ATF loads OP-TEE, it will pass OP-TEE base
address and size to the u-boot through boot information.
This will help u-boot update device tree accordingly.
Note that u-boot on i.MX 8QxP does not need this information
to configure memory mapping. Query to the SC Firmware
is used instead
Signed-off-by: Silvano di Ninno <silvano.dininno@nxp.com>
(cherry picked from commit e80fe229192578120a3ba98ae26fd3dbf121538f)
configure OP-TEE Share memory to be accessible by OS.
(cherry picked from commit 0b5eeb7e0dbe50ebd7f3d0ce66047569504e9d52)
fix size of BL32 (currently is 32MB)
(cherry picked from commit f66251dedef31750ff7be4c0e404b77d0a8fb1c4)
reuse Trusty support for OP-TEE
(cherry picked from commit 6e2885a262b94bdeb8face851012f58ed32e86a9)
JR0 and JR1 of CAAM are owned by SECO, only kick the power
of JR2 and JR3 here and assign the resources to be accessed
by secure world.
Signed-off-by: Ji Luo <ji.luo@nxp.com>
Tee(Trusty Os) will be stored in fit for Android and Android Auto
so we don't need to copy it anymore, this will save some boot time.
Signed-off-by: Luo Ji <ji.luo@nxp.com>
This patch adds support for cpuidle with CPU powerdown,
there will be 3 idle states in Linux kernel:
1: wfi;
2: cpu power down;
3: cluster power down.
As Linux kernel needs a broadcast timer for waking up
CPU when whole CLUSTER is powerdown, GPT is adopted as
broadcast timer, and to make the clock & power management
easy for Linux kernel to avoid many workaround/hake in
Linux kernel, TF-A will handle GPT's power & clock management
as well as registers save/restore when suspend/resume.
Also, psci power states are used to determine CORE/CLUSTER/SYSTEM
power state to distinguish CPU idle and SYSTEM suspend which share
same domain_suspend callback.
The SoC IPs register mmap regions are merged into 1 large
section to cover all the SoC IPs register ranges TF-A needs,
this is to save mmap regions and make it simple.
Signed-off-by: Anson Huang <Anson.Huang@nxp.com>
Add support for enabling output debug message to SC
console, SC_CONSOLE is used to enable/disable it.
Example log output on SC console as below:
*** Debug Monitor ***
>$ NOTICE: smc_fid is c2000003
imx_pwr_domain_on cluster_id 0, cpu_id 1
cluster:0 core:1 is on
imx_pwr_domain_on cluster_id 0, cpu_id 2
cluster:0 core:2 is on
imx_pwr_domain_on cluster_id 0, cpu_id 3
cluster:0 core:3 is on
imx_pwr_domain_on cluster_id 1, cpu_id 0
cluster:1 core:0 is on
imx_pwr_domain_on cluster_id 1, cpu_id 1
cluster:1 core:1 is on
Add FSL_SIP_MISC_SET_TEMP support for setting thermal
alarm function.
The Trusty OS binary will be installed into
container.img and loaded into 0x84000000.
Due Trusty OS addresss is in 0xfe000000 which
ROM cannot reach, so use ATF to copy it into
the target address.
Mapped the BL32 code into MMU due the Trusty
SPD need to check the code status and decide
the CPU executing mode.
To reserve and protect the memory for secure
world, modify the partition code to keep
BL32 spaces in secure_part.
Signed-off-by: Haoran.Wang <elven.wang@nxp.com>
Reviewed-by: Ye Li <ye.li@nxp.com>
Using sc_pm_set_cpu_resume API instead of sc_pm_set_cpu_resume_addr
to support random CPU resume for system suspend, as Linux kernel
now supports non CPU0 suspend, we have to specify the CPU ID for
SCFW to wake up when system resume.
SCFW has supported DDR retention, so now DRC can be
into OFF mode instead of STBY when Linux suspend.
With flash_uboot_cm4ddr in imx-mkimage, the m4 code will access ddr.
However after m4 core moved to non-secure partition, the ddr memory
is still in secure partition. Then m4 core will fault.
So postpone moving resources including m4 core, until other resources,
such as memory/pin moved to non-secure partition.
Signed-off-by: Peng Fan <peng.fan@nxp.com>
(cherry picked from commit 1c8ce0ad5f583ec41026d4ab5bef622f1b45aecd)
Switch to MULTI_CONSOLE_API to make debug UART work.
Add SIP service for OTP reading/writing for use
in u-boot
SC_R_IRQSTR_SCU2 can be OFF in system suspend if there
is no wakeup irq enabled from non-secure OS partion.
Add wakeup source check to decide if turning off
SC_R_IRQSTR_SCU2 or NOT when suspend.
DB is NOT necessary for irqsteer on i.MX8QXP,
it can be OFF when linux suspend.
Add MU power off support for suspend, it needs
to be re-initialized after system resume.
With default configuration, M4 and A35 in one partition, M4 is loaded by ROM.
"err = sc_rm_move_all(ipc_handle, secure_part, os_part, true, true);"
M4 core will first be moved to non-secure OS part, then the resource used
by M4 will be moved to non-secure OS part later. But before the resource be
moved to non-secure OS part, M4 core is still running, so a non-secure M4
core access a secure resource will trigger error in M4 side.
First mark M4 core as non-movable, after all other resoures moved to OS
part, move M4 to OS part. No need to check whether M4 is created a new
partition by SCFW, if a partition already created, the call to mark
M4 as non-removable will fail, because it M4 is in its own partition.
make sure to put IRQSTEER SCU into correct power modes.
Signed-off-by: Nitin Garg <nitin.garg@nxp.com>
clean up the license identifier with short SPDX short identifier.
Signed-off-by: Bai Ping <ping.bai@nxp.com>
Use MU0 to comply with boot image usage of MU0
Also power on and pass MU1 for OS/Hypervisor
In order to save power when AP side is suspend,
the DBLOG need to be put into low power mode.
GIC need to be power off to save power. before GIC
power off, we need to save the GIC setting, then
after resume, we need to restore the gic setting.
irqsteer need to be used to wakeup the AP side
when wakeup interrupt is pending for AP side.
The irqstr for scu2 is used for AP wakeup if gic is power off,
so this resource need to be added to the sec rsrc.
Enable USE_COHERENT_MEM feature to make sure no cache
coherence issue and avoid cache operations in many places;
Add return value for cpu kill function.
In worse case, MAX_XLAT_TABLES needs to be equal to
MAX_MMAP_REGIONS, enlarge MAX_XLAT_TABLES to make debug
version ATF can boot up, otherwise, it may fail at below:
ASSERT: lib/xlat_tables/xlat_tables_common.c <362>
1. Request to DRC switch to STBY in low power.
2. Set GIC to LP mode once GIC interface has been disabled in low power flow.
Signed-off-by: Ranjani Vaidyanathan <Ranjani.Vaidyanathan@nxp.com>
Add power off interface for Linux. Currently poweroff the whole board,may
change to poweroff partition if necessary.
sync with the below scfw commit:
commit 0e1f8aa5d6c6a6d9b8c05d5a84bbd613b301d367
Author: Chuck Cannon <chuck.cannon@freescale.com>
Date: Tue Nov 28 13:56:29 2017 -0600
Use SC_R_BOARD_R1 to control the base board reset.
Signed-off-by: Chuck Cannon <chuck.cannon@freescale.com>
Signed-off-by: Robin Gong <yibin.gong@nxp.com>
system interconnect etc.
Request A35 cluster low power mode to off to SCFW,
when suspend, SCFW will turn off A35 cluster.
Add suspend/resume support with all CPUs power down.
Add system_off pcsi callback to avoid below kernel
message when doing power off:
[11613.953711] reboot: Power down
[11613.958318] systemd-shutdow: 8 output lines suppressed due to ratelimiting
[11613.965285] Kernel panic - not syncing: Attempted to kill init! exitcode=0x00
[11613.965285]
[11613.974441] CPU: 0 PID: 1 Comm: systemd-shutdow Not tainted 4.9.11-03354-g0e1
[11613.982369] Hardware name: Freescale i.MX8QXP LPDDR4 ARM2 (DT)
[11613.988216] Call trace:
[11613.990681] [<ffff0000080882bc>] dump_backtrace+0x0/0x1a8
[11613.996092] [<ffff000008088478>] show_stack+0x14/0x1c
[11614.001154] [<ffff0000083aaf98>] dump_stack+0x8c/0xac
[11614.006213] [<ffff000008162aac>] panic+0x124/0x28c
[11614.011016] [<ffff0000080c0b20>] complete_and_exit+0x0/0x20
[11614.016600] [<ffff0000080dc6d8>] SyS_reboot+0x168/0x244
[11614.021829] [<ffff000008082ef0>] el0_svc_naked+0x24/0x28
[11614.027153] Kernel Offset: disabled
[11614.030646] Memory Limit: none
[11614.040755] ---[ end Kernel panic - not syncing: Attempted to kill init! exi0
[11614.040755]
As there is no system power off SCFW API available now, so just
simply do wfi and never return when system_off is called.
Add SRTC SIP support for i.MX8QM/i.MX8QXP.
Add i.MX8QXP board reset support.
Linux kernel will issue cpu-freq scale via SIP, ATF
calls SCFW API to finish the CPU frequency scale.
Move SIP service code from i.mx8mq to common place for
all i.mx SoCs.
Reserve the memory region that is only can access by ATF. ATF is running
in this memory region, while masters in other partitions can't access it.
Signed-off-by: Ye Li <ye.li@nxp.com>
Change to search the ATF owned memory regions and assign them to non-secure
OS partition. Not allocate new memory region for each one.
As we already have control for debug console in platform_def.h,
so no need to un-initialize console in plat runtime setup, just
overwrite the common implementation with blank function.
Not only the resources, but also the memory regions need to assign to
non-secure partition. Otherwise, when the boot partition is secured,
the OS non-secure partition can't access any memory.
This patch currently assign all memory to NS partition, since it is not
isolated, the current secure partition also can access them. In future,
may need to change the regions for reserving some memory in secure
partition for ATF and BL32.
missed bit 31 and 30 which are needed
Disable ATF console output for iMX8QM
Disable debug console by default on i.MX8QXP.
Debug console baudrate should be 115200 for i.MX8QXP real board.
Add necessary resources to secure partition for protection.
Also add in functionality to allow for register access
of some secure-owned peripherals.
These peripherals will still be protected from power or
clk changes.
Add i.MX8QXP platform support.
