Use sc_rm_memreg_frag() instead of sc_rm_memreg_alloc() to avoid memory partition
overlay, sc_rm_memreg_frag() will return non-overlapping regions.
Signed-off-by: Anson Huang <Anson.Huang@nxp.com>
Reviewed-by: Ye Li <ye.li@nxp.com>
In some cases, the bl31 won't be reloaded when spl is not supported,
commit 17de039 adds the save/restore data section to fix boot issues
which is caused by the dirty data in data section of previous boot.
However, sometimes the backup data section in dram won't be erased
totally in board cold reboot, it will be restored and modify the
'correct' data section which will cause the board hang.
This commit uses a global flag 'data_section_restore_flag' which is
initialized as '0x1' and should be stored in data section to indicate
the save/restore behavior.
Test: cold/warm reboot on imx8qm/imx8qxp.
Signed-off-by: Ji Luo <ji.luo@nxp.com>
Port and cleanup OP-TEE support.
Signed-off-by: Silvano di Ninno <silvano.dininno@nxp.com>
i.MX8 SoC with SCU inside support partition reboot, the partition reboot
will NOT reload the bl31.bin, so the data section could have some dirty
data of previous boot up, it will impact the reboot, so need to restore
the data section for partition reboot.
Open the power domain of MU4 and assign it to secure
world so trusty can call the SCFW API.
Test: Get SCFW and SECO-FW by trusty.
Change-Id: I6188f905426fd66072346089505fb1945e4362e3
(cherry-picked from commit 4dd8919a805336c6df8a791f238e8da1830dfe7b)
JR0 and JR1 of CAAM are owned by SECO, only kick the power
of JR2 and JR3 here and assign the resources to be accessed
by secure world.
(cherry picked from commit d82c0e65e74ce8b650ea3237a02249246080840d)
Mapped the BL32 code into MMU due the Trusty
SPD need to check the code status and decide
the CPU executing mode.
To reserve and protect the memory for secure
world, modify the partition code to keep
BL32 spaces in secure_part.
Signed-off-by: Haoran.Wang <elven.wang@nxp.com>
(cherry picked from commit 36ad60e46fd94eac7646218ae2b3e760bcfc33d6)
spd trusty requires memory dynamic mapping feature to be
enabled, so we have to use xlat table library v2 instead
of v1.
Test: builds.
On iMX8 Rev A the OCRAM is used to pass over ROM info, and u-boot
needs to access it. So we can't assign the OCRAM to ATF partition.
This will cause boot hang.
Rev A does not support SPL, so it is ok to not protect the OCRAM.
Signed-off-by: Ye Li <ye.li@nxp.com>
Reviewed-by: Peng Fan <peng.fan@nxp.com>
(cherry picked from commit c9a168bfd16e06b4d6b9f94185910023e4923cf2)
Because the partition reboot won't reload the first level bootloader (SPL),
the SPL won't be authenticated. Users can corrupt the SPL image to break
the boot trust chain in secure boot if we don't protect that OCRAM area.
This patch configures the memory area from 0x0 to 0x118000 only accessed by
secure partition (ATF and OPTEE). Non-secure partitions (u-boot and kernel)
can't access it.
(cherry picked from commit 1eff7d3ef6f121782e56bb1807744ede48b8580b)
(cherry picked from commit 96d33120bb57895db73e669ef0aeccde0d4875d5)
Update flags for expected behavior in ATF
Signed-off-by: Teo Hall <teo.hall@nxp.com>
With partition reboot enabled, console_list variable which is
located in data section is NOT reset, system will be busy looping
in early console operation of flush_loop() if console_list is
NOT 0 while HW console is NOT initialized, so we have to clear
this variable to make partition reboot work.
With flash_uboot_cm4ddr in imx-mkimage, the m4 code will access ddr.
However after m4 core moved to non-secure partition, the ddr memory
is still in secure partition. Then m4 core will fault.
So postpone moving resources including m4 core, until other resources,
such as memory/pin moved to non-secure partition.
Signed-off-by: Peng Fan <peng.fan@nxp.com>
(cherry picked from commit 1c8ce0ad5f583ec41026d4ab5bef622f1b45aecd)
(cherry picked from commit 5b026e05b8f71b3d86da0953c5ca196d5ba5cc66)
With default configuration, M4 and A35 in one partition, M4 is loaded by ROM.
"err = sc_rm_move_all(ipc_handle, secure_part, os_part, true, true);"
M4 core will first be moved to non-secure OS part, then the resource used
by M4 will be moved to non-secure OS part later. But before the resource be
moved to non-secure OS part, M4 core is still running, so a non-secure M4
core access a secure resource will trigger error in M4 side.
First mark M4 core as non-movable, after all other resoures moved to OS
part, move M4 to OS part. No need to check whether M4 is created a new
partition by SCFW, if a partition already created, the call to mark
M4 as non-removable will fail, because it M4 is in its own partition.
(cherry picked from commit 44e209cb87f078abc78839c5e138aae5122ddd78)
Current implementation of i.MX8QX power management related
features does NOT optimize power number, all system resources
like CCI, DDR, and A cluster etc. are kept in STBY mode (powered
ON) when system suspend or CPU hotplug.
To lower the power number, OFF mode should be adopted for those
system resources whenever they can be OFF, A cluster will be OFF
if the CPUs in the cluster are all off line, DDR/MU/DB can be OFF
if system suspend, IRQ steer can be OFF if the wakeup source is
belonged to system controller partition, so wakeup source runtime
check is used to determine if IRQ steer can be OFF before system
suspend.
If resources are powered off for suspend, they should be restored
properly after system resume.
Enforce full include path for includes. Deprecate old paths.
The following folders inside include/lib have been left unchanged:
- include/lib/cpus/${ARCH}
- include/lib/el3_runtime/${ARCH}
The reason for this change is that having a global namespace for
includes isn't a good idea. It defeats one of the advantages of having
folders and it introduces problems that are sometimes subtle (because
you may not know the header you are actually including if there are two
of them).
For example, this patch had to be created because two headers were
called the same way: e0ea0928d5b7 ("Fix gpio includes of mt8173 platform
to avoid collision."). More recently, this patch has had similar
problems: 46f9b2c3a282 ("drivers: add tzc380 support").
This problem was introduced in commit 4ecca33988b9 ("Move include and
source files to logical locations"). At that time, there weren't too
many headers so it wasn't a real issue. However, time has shown that
this creates problems.
Platforms that want to preserve the way they include headers may add the
removed paths to PLAT_INCLUDES, but this is discouraged.
Change-Id: I39dc53ed98f9e297a5966e723d1936d6ccf2fc8f
Signed-off-by: Antonio Nino Diaz <antonio.ninodiaz@arm.com>
- Migrate to new GIC interfaces.
- Migrate to bl31_early_platform_setup2().
- Remove references to removed build options.
Change-Id: Ia7c63f75325ea4b41e32a9de3f01b0007d0ae210
NXP's i.MX8QX is an ARMv8 SoC with 4 Cortex-A35 cores and
system controller (Cortex-M4) inside, documentation can
be found in below link:
https://www.nxp.com/products/processors-and-microcontrollers/
applications-processors/i.mx-applications-processors/i.mx-8-processors:IMX8-SERIES
This patch adds support for booting up SMP linux kernel (v4.9).
