In some cases, the bl31 won't be reloaded when spl is not supported,
commit 17de039 adds the save/restore data section to fix boot issues
which is caused by the dirty data in data section of previous boot.
However, sometimes the backup data section in dram won't be erased
totally in board cold reboot, it will be restored and modify the
'correct' data section which will cause the board hang.
This commit uses a global flag 'data_section_restore_flag' which is
initialized as '0x1' and should be stored in data section to indicate
the save/restore behavior.
Test: cold/warm reboot on imx8qm/imx8qxp.
Signed-off-by: Ji Luo <ji.luo@nxp.com>
The SCFW supports OCRAM retention, so no need to set cpu entry for reboot
to let CPU run from SPL in OCRAM again when reboot, then SPL will reload
images after reboot.
Signed-off-by: Anson Huang <Anson.Huang@nxp.com>
Reviewed-by: Ye Li <ye.li@nxp.com>
Port and cleanup OP-TEE support.
Signed-off-by: Silvano di Ninno <silvano.dininno@nxp.com>
i.MX8 SoC with SCU inside support partition reboot, the partition reboot
will NOT reload the bl31.bin, so the data section could have some dirty
data of previous boot up, it will impact the reboot, so need to restore
the data section for partition reboot.
Open the power domain of MU4 and assign it to secure
world so trusty can call the SCFW API.
Test: Get SCFW and SECO-FW by trusty.
Change-Id: I6188f905426fd66072346089505fb1945e4362e3
(cherry-picked from commit 4dd8919a805336c6df8a791f238e8da1830dfe7b)
JR0 and JR1 of CAAM are owned by SECO, only kick the power
of JR2 and JR3 here and assign the resources to be accessed
by secure world.
(cherry picked from commit d82c0e65e74ce8b650ea3237a02249246080840d)
Mapped the BL32 code into MMU due the Trusty
SPD need to check the code status and decide
the CPU executing mode.
To reserve and protect the memory for secure
world, modify the partition code to keep
BL32 spaces in secure_part.
Signed-off-by: Haoran.Wang <elven.wang@nxp.com>
(cherry picked from commit 36ad60e46fd94eac7646218ae2b3e760bcfc33d6)
spd trusty requires memory dynamic mapping feature to be
enabled, so we have to use xlat table library v2 instead
of v1.
Test: builds.
Signed-off-by: Nitin Garg <nitin.garg@nxp.com>
On iMX8 Rev A the OCRAM is used to pass over ROM info, and u-boot
needs to access it. So we can't assign the OCRAM to ATF partition.
This will cause boot hang.
Rev A does not support SPL, so it is ok to not protect the OCRAM.
Signed-off-by: Ye Li <ye.li@nxp.com>
Reviewed-by: Peng Fan <peng.fan@nxp.com>
(cherry picked from commit c9a168bfd16e06b4d6b9f94185910023e4923cf2)
Because the partition reboot won't reload the first level bootloader (SPL),
the SPL won't be authenticated. Users can corrupt the SPL image to break
the boot trust chain in secure boot if we don't protect that OCRAM area.
This patch configures the memory area from 0x0 to 0x118000 only accessed by
secure partition (ATF and OPTEE). Non-secure partitions (u-boot and kernel)
can't access it.
(cherry picked from commit 1eff7d3ef6f121782e56bb1807744ede48b8580b)
(cherry picked from commit 96d33120bb57895db73e669ef0aeccde0d4875d5)
Update flags for expected behavior in ATF
Signed-off-by: Teo Hall <teo.hall@nxp.com>
With SPL running on OCRAM, when linux suspend, OCRAM
will lose power and if partition reboot is started from
SPL, system will hang as the OCRAM data lost, so for
partition reboot, the CPU boot entry can be set to
be from ATF BL31 entry directly, SCFW exposes such API
for this scenario.
Add pwr_domain_pwr_down_wfi callback for i.MX8QM.
SC_R_GIC_SMMU is a master resource, we can't set peripheral
permission to this resource, otherwise the API will return below error
on latest SCFW, because SCFW has added a resource type check.
On old SCFW, the API does nothing to a master resource. So remove the
resource from ns_access_allowed array.
ERROR: sc_rm_set_peripheral_permissions: rsrc 14, ret 3
Add system_reset2 support for i.MX8QM/i.MX8QX to support
WARM/COLD/BOARD reset.
With partition reboot enabled, console_list variable which is
located in data section is NOT reset, system will be busy looping
in early console operation of flush_loop() if console_list is
NOT 0 while HW console is NOT initialized, so we have to clear
this variable to make partition reboot work.
The issue of A53 cluster runtime power ON/OFF has been
identified as fifo reset issue, and there is software
workaround to avoid such issue and A53 cluster now can
be turned OFF.
Due imx8qm_mek's UART0_RTS_B and UART0_CTS_0 pad
reuse to be the UART2 for base bard which operated by
M4_1, so don't touch these two pads in ATF.
Acked-by: Pete Zhang <pete.zhang@nxp.com>
With flash_uboot_cm4ddr in imx-mkimage, the m4 code will access ddr.
However after m4 core moved to non-secure partition, the ddr memory
is still in secure partition. Then m4 core will fault.
So postpone moving resources including m4 core, until other resources,
such as memory/pin moved to non-secure partition.
Signed-off-by: Peng Fan <peng.fan@nxp.com>
(cherry picked from commit 1c8ce0ad5f583ec41026d4ab5bef622f1b45aecd)
(cherry picked from commit 5b026e05b8f71b3d86da0953c5ca196d5ba5cc66)
Test if a partition reboot has taken place with the MU
interrupt bit. Check before returning the entrypoint
NXP's i.MX8 SoCs with system controller inside support outputting
debug message to system controller's console via calling SCFW API,
since TF-A shares debug console with Linux kernel which will have
confliction if Linux kernel and TF-A's console are both enabled,
this patch adds support for switching TF-A debug console to system
controller to easy TF-A debug.
The new API becomes the default one.
Change-Id: Ic1d602da3dff4f4ebbcc158b885295c902a24fec
Signed-off-by: Ambroise Vincent <ambroise.vincent@arm.com>
Platform defines are already provided by the build system so let's not
duplicate them.
Change-Id: Icf1ea76c3c3213e27b447c95e2b22b961fa7693e
Signed-off-by: Leonard Crestez <leonard.crestez@nxp.com>
Current implementation of i.MX8QM power management related
features does NOT optimize power number, all system resources
like CCI, DDR, and A cluster etc. are kept in STBY mode (powered
ON) when system suspend or CPU hotplug.
To lower the power number, OFF mode should be adopted for those
system resources whenever they can be OFF, A cluster will be OFF
if the CPUs in the cluster are all off line, DDR/MU/DB can be OFF
if system suspend, IRQ steer can be OFF if the wakeup source is
belonged to system controller partition, so wakeup source runtime
check is used to determine if IRQ steer can be OFF before system
suspend.
If resources are powered off for suspend, they should be restored
properly after system resume.
NXP's i.MX8QM uses Cortex-A53 r0p4, enable necessary
erratas for it.
On i.MX8QM/i.MX8QX with system controller inside, the SRTC is
managed by SCFW(system controller firmware) and some functions
like setting SRTC's time etc. can ONLY be requested from secure
world, so SIP runtime service is needed for such kind of operations,
this patch adds SRTC SIP runtime service support for i.MX8QM and
i.MX8QX.
Enforce full include path for includes. Deprecate old paths.
The following folders inside include/lib have been left unchanged:
- include/lib/cpus/${ARCH}
- include/lib/el3_runtime/${ARCH}
The reason for this change is that having a global namespace for
includes isn't a good idea. It defeats one of the advantages of having
folders and it introduces problems that are sometimes subtle (because
you may not know the header you are actually including if there are two
of them).
For example, this patch had to be created because two headers were
called the same way: e0ea0928d5b7 ("Fix gpio includes of mt8173 platform
to avoid collision."). More recently, this patch has had similar
problems: 46f9b2c3a282 ("drivers: add tzc380 support").
This problem was introduced in commit 4ecca33988b9 ("Move include and
source files to logical locations"). At that time, there weren't too
many headers so it wasn't a real issue. However, time has shown that
this creates problems.
Platforms that want to preserve the way they include headers may add the
removed paths to PLAT_INCLUDES, but this is discouraged.
Change-Id: I39dc53ed98f9e297a5966e723d1936d6ccf2fc8f
Signed-off-by: Antonio Nino Diaz <antonio.ninodiaz@arm.com>
This patch makes the build system link the console framework code by
default, like it already does with other common libraries (e.g. cache
helpers). This should not make a difference in practice since TF is
linked with --gc-sections, so the linker will garbage collect all
functions and data that are not referenced by any other code. Thus, if a
platform doesn't want to include console code for size reasons and
doesn't make any references to console functions, the code will not be
included in the final binary.
To avoid compatibility issues with older platform ports, only make this
change for the MULTI_CONSOLE_API.
Change-Id: I153a9dbe680d57aadb860d1c829759ba701130d3
Signed-off-by: Julius Werner <jwerner@chromium.org>
- Migrate to new GIC interfaces.
- Migrate to bl31_early_platform_setup2().
- Remove references to removed build options.
Change-Id: Ia7c63f75325ea4b41e32a9de3f01b0007d0ae210
tf_printf and tf_snprintf are now called printf and snprintf, so the
code needs to be updated.
Change-Id: Iffeee97afcd6328c4c2d30830d4923b964682d71
Also change header guards to fix defects of MISRA C-2012 Rule 21.1.
Change-Id: Ied0d4b0e557ef6119ab669d106d2ac5d99620c57
Acked-by: Sumit Garg <sumit.garg@linaro.org>
Acked-by: Anson Huang <Anson.Huang@nxp.com>
Add domain suspend/resume support, Linux kernel
can "echo mem > /sys/power/state" to put system
into suspend mode, all CPUs and cluster will be
powered off and can be waked up if irq pending
in GIC, tested on i.MX8QM MEK board.
Since the power state has been implemented, switch
to use standard power state for CCI operations
instead of private cpu use count in i.MX8QM.
Add domain off support for Linux kernel's cpu
hot-plug feature, when there are cpu off request
from Linux kernel, TF-A will send command to
system controller to do CPU power gate accordingly,
Add system reset support for i.MX8QM,
when Linux kernel issues "reboot" command,
TF-A will send command to inform system
controller to reset whole board according
to board design, tested on i.MX8QM MEK board.
Add system power off support for i.MX8QM,
when Linux kernel issues "poweroff" command,
controller to power off whole board according
NXP's i.MX8QM is an ARMv8 SoC with 2 clusters, 2 Cortex-A72
cores in one cluster and 4 Cortex-A53 in the other cluster,
and also has system controller (Cortex-M4) inside, documentation
can be found in below link:
https://www.nxp.com/products/processors-and-microcontrollers/
applications-processors/i.mx-applications-processors/i.mx-8-processors:IMX8-SERIES
This patch adds support for booting up SMP linux kernel (v4.9).
