setup
Signed-off-by: Olivier Masse <olivier.masse@nxp.com>
remove unused files on i.MX8MQ.
Signed-off-by: Bai Ping <ping.bai@nxp.com>
refact the dram low power related code to make it more
friendly for different dram config or different board.
After the SRC bit clear, we must wait for a while to make sure
the operation is finished.
for USB OTG, the limitations are:
1. before system clock configuration. ipg clock runs at 12.5MHz.
delay time should longer than 82us.
2. after system clock configuration. ipg clock runs at 66.5MHz.
delay time should longer than 15.3us.
so add udelay 100 to safely clear the SRC bit 0.
The chip revision should ONLY overwrite the lower 16 bits of
soc_id, otherwise, the cpu_is_imx8mq() API in Linux kernel
will be incorrect.
Signed-off-by: Anson Huang <Anson.Huang@nxp.com>
On B0.1 chip, the value is 0x1020 not 0x20, due to minor version updated.
So if reading the word and comparing with 0x20, the result is wrong.
Fix the issue by only reading low major version byte for ROM version
Signed-off-by: Ye Li <ye.li@nxp.com>
i.MX8MQ B1's chip revision is identified by reading
OCOTP offset 0x40, the magic number 0xff0055aa is
for B1.
update the ddr controller perf QoS setting on i.MX8MQ.
Add NOC configuration entry for all the module.
Kernel can configure the noc priority through this entry.
Signed-off-by: Zhang Bo <bo.zhang@nxp.com>
The debug version of TF-A has below assert, fix
it by making sure no memory map overlap.
ASSERT: lib/xlat_tables/xlat_tables_common.c:129
Switch to MULTI_CONSOLE_API to make debug UART work.
This patch enables necessary erratas for A53 r0p4
according to docs/cpu-specific-build-macros.rst.
move CSU and RDC driver to common/i.mx8m folder
and enable the driver for i.mx8mm
Signed-off-by: Silvano di Ninno <silvano.dininno@nxp.com>
Reviewed-by: Aymen Sghaier <aymen.sghaier@nxp.com>
As the i.MX8MM and i.MX8MQ share the same hab file, move it
to common/imx8m, make it reusable for all i.MX8M SOCs.
For the i.MX8 media processor, we have i.MX8MQ and i.MX8MM etc.
so rename the file name of imx8m_bl31_setup.c and imx8m_psci.c
to imx8mq_xxx to make it more clear that these file is specific
to i.MX8MQ.
clean up the license identifier with short SPDX short identifier.
this patch adds some configuration to test CSU and RDC feature
by default this is disable. to enable it add
$(eval $(call add_define,CSU_RDC_TEST)) to the platform.mk file
under plat/freescale/imx8mq/include
this patch configure
- CSU for GPIO5 to be secure only
- RDC for Cortex A to be Domain ID 0
- GPIO4 to be rw by domain ID 2
to test, stops boot at uboot and run following command:
u-boot=> md 0x3024000
03024000:"Synchronous Abort" handler, esr 0x96000210
ELR: 40257504
LR: 402574c0
x0 : 0000000000000009 x1 : 00000000308600b4
x2 : 00000000fdf28804 x3 : 0000000000000000
x4 : 0000000003024000 x5 : 00000000fdf73ad0
x6 : 0000000000000004 x7 : 000000000000000f
x8 : 00000000fc8ff7e0 x9 : 0000000000000000
x10: 00000000fc8ff049 x11: 0000000000000021
x12: 0000000000000008 x13: 00000000ffffffff
x14: 00000000fc8ffb1c x15: 00000000fc8ffc40
x16: 0000000000000000 x17: 0000000000000000
x18: 00000000fc907da0 x19: 0000000000000040
x20: 0000000000000004 x21: 0000000003024000
x22: 0000000003024000 x23: 00000000fdf7348d
x24: 0000000000000008 x25: 0000000000000009
x26: 0000000000000004 x27: 0000000000000004
x28: 00000000fc8ff928 x29: 00000000fc8ff8a0
Resetting CPU ...
resetting ...
CPU tried to acces GPIO 5 registers and crashes
u-boot=> md 0x30230000
30230000:"Synchronous Abort" handler, esr 0x96000210
ELR: 40257504
LR: 402574c0
x4 : 0000000030230000 x5 : 00000000fdf73ad0
x20: 0000000000000004 x21: 0000000030230000
x22: 0000000030230000 x23: 00000000fdf7348d
Resetting CPU ...
resetting ...
CPU tried to acces GPIO 4 registers and crashes
Reviewed-by: Peng Fan <peng.fan@nxp.com>
there is a bug in the CSL assignment.
the CSL(n) and CSL(n+1) configuration were reversed.
correct the ddr type register's offset.
Currently, DDR3L/DDR4 board don't support DDR DVFS,
So skip ddr switch 3200 mts if the DDR is not LPDDR4.
Update the ddr retenton flow and dvfs flow used on imx8mq lpddr4 board.
1. DVFS flow is changed from hwffc to swffc.
2. frequency setpoint is change from 100mts to 667mts.
3. ddr retention flow is updated to compatible with the new lpddr4 training fw.
4. fix the retention failure issue caused by incorrect reset flow in retention exit.
At boot, we reset the Secure Memory configuration for
imx8mq to a default state giving all the job rings to
linux and allowing all accesses from all SDIDs.
NOTE: Checkpatch OK.
Signed-off-by: Franck LENORMAND <franck.lenormand@nxp.com>
Flush the L1 and L2 cache before DDR frequency change to
make sure that no DDR memory access caused by cache activity.
Add an ocram_s mmap entry
Merge mmap entry to use 2MB aligned base and size to shrink the final
mmu table size.
Move stack to ocram_s
Signed-off-by: Peng Fan <peng.fan@nxp.com>
For i.MX8MQ B0 revision the default configuration of JRaMID is not
valid to allow Kernel use CAAM job ring. This patch set the Master ID
of Cortex A in the JRaMID registers.
Signed-off-by: Aymen Sghaier <aymen.sghaier@nxp.com>
On i.MX8MQ, NOC may need different settings for different
use cases, so add SIP for NOC settings.
Update the DDR performance setting when out of retention.
Since the HAB only works in secure mode. The BL33 runs at EL2 non-secure can't
intialize the HAB successfully. So add the SIP call for these HAB interfaces,
BL33 will trap to ATF to run the HAB.
The HAB codes locates in ROM, and need to access OCRAM, CAAM RAM and DDR to
authenticate image. Add these relevant memory region to MMU. Also extend the
stack size of each core to avoid stack overflow by HAB.
Enabling the default csu configuration lead to block boot on
testing boards.
Enable the RDC driver for i.MX8MQ platform with a default settings
as an example.
Enable the CSU driver for i.MX8MQ platform with a default settings
as an example.
the previous stack size is small, the stack will very
easy to overflow, then lead to ATF not work. So increase
the stack size to fix this issue.
When system enter suspend, it should be only wakeup by
specific wakeup source, so non-wakeup source should be
masked before enter suspend.
Refact the PSCI related code. Enable cpuidle support
on i.MX8MQ for CPU idle support.
i.MX8MQ does NOT update revision info in ANATOP_DIGPROG
register, so the revision info needs to read from ROM,
for security reason, this needs to be done in ATF, so
add this SIP support for kernel.
The A0 chip's ROM version is located at 0x800, and B0
chip is located at 0x83c.
Add src sip to handle M4 boot and status check
update the ddrc and phy config info, add more register
config for other frequency point.
When changing the DDR frequency, the DDRC will block
AXI access, so the code for changing the frequency need
to be run on OCRAM not make sure no DDR access at this stage.
the DDR frequency change request is from EL1 linux kernel side,
we use the SiP service call to trap the DDR frequency change operation
from linux kernel to ATF.
Pass TEE address space to BL33 to avoid uboot relocation touch
this space.
Enable the DDR retention support on imx8mq. when
DDR retention is enabled, the non-fast wakeup mode
can be enabled at the same time.
map the whole AIPS1 space, so we don't need
to create map for individual peripheral region.
TEE entry is defined as 0xFE000000. When there is SPD passed to makefile
, TEE_IMX8 will be defined.
Compiling OP-TEE support using "make PLAT=imx8mq bl31 SPD=opteed"
Note:
Since TEE image is located at DRAM 0xFE000000, so need to reserve
this space in UBoot and Kernel, by using gd->dram_size =
PHYS_SDRAM_SIZE - SZ_32M or else.
Change the BL31 load address to ocram so we can
put DDR into low power mode as needed.
On i.MX8MQ, we may need to run ATF in ocram space, but the ocram
space is limited, can NOT put all the sections into it, so move
the xlat_table section into OCRAM_S.
Replace all GPL with BSD identifier.
The GPC_CPU_PGC_SW_PDN_REQ offset should be 0xfc, previous
offset is incorrect, so actually ARM core is NOT powered
down and the power leakage is very high.
With this fix, each ARM core's leakage is about 25mA@0.9V.
The bits[3:0] of CPU_PGC_PUP/PDN_TRG use core's SW
power up/down. prevous bits assignment is wrong, so
fix it.
Linux kernel will issue cpu-freq scale via SIP, ATF
calls SCFW API to finish the CPU frequency scale.
Move SIP service code from i.mx8mq to common place for
all i.mx SoCs.
- USB PHY reset bit in SRC needs to be clear before
doing USB PHY power gating in GPC, only needs to
do once;
- Need to handle GPC_PU_PWRHSK during power up/down;
- Enable GPC pu power gate support.
