path: root/plat/imx/imx8mm
2018-11-13MMIOT-180: ddr address is 33bit width, but rdc memory region register is ↵Olivier Masse
32bit. So we use [32:1] as the configuration value Signed-off-by: Olivier Masse <olivier.masse@nxp.com>
2018-11-13MMIOT-152 + MMIOT-157 : move specific RDC configuration from driver to board ↵Olivier Masse
setup Signed-off-by: Olivier Masse <olivier.masse@nxp.com>
2018-11-13MMIOT-152 Rebase on imx_1.5.y + imx8mm : DRM RDC config addedOlivier Masse
2018-11-01plat: imx: Add sw workaround for the VPU&GPU resetBai Ping
ERR050044: GPU/VPU power domain on/off stress test leads to unexpected GPU interrupts and hang. his is caused by no dedicated HW resets for GPU2D/3D. There is one reset for whole GPUmix and GPU2D/3D has their own SW reset signals. The SW reset cannot be asserted while GPU2D/3D is in power off status. So if only GPU2D or GPU3D has to be powered off and on, unknown status leads to the problem. VPU has similiar issue. So we need to assert the SW reset before power up the power domain. Signed-off-by: Bai Ping <ping.bai@nxp.com>
2018-10-12imx8m: Add DDR4 DVFS supportBai Ping
Add DDR4 DVFS support for i.MX8M. Currently, only tested on i.MX8MM. Signed-off-by: Bai Ping <ping.bai@nxp.com>
2018-10-01imx8mm: Add ddr4 retention support for imx8mBai Ping
Add ddr4 retention flow for imx8m. Signed-off-by: Bai Ping <ping.bai@nxp.com>
2018-09-15plat: imx8mm: Add support for imx8mm lpaAnson Huang
For i.MX8MM low power audio playback, when Linux suspend, M4 still needs to be active for audio playback, so system can NOT enter DSM mode but only force A core platform into STOP mode, PLLs/NoC/DRAM need to be active as well and MU interrupt wakeup needs to be enabled for waking up Linux by MU message sent by M4. Signed-off-by: Anson Huang <Anson.Huang@nxp.com> Signed-off-by: Bai Ping <ping.bai@nxp.com>
2018-09-11plat: imx8mm: fix the gpumix vpumix power downBai Ping
the GPU/VPU mix power off is skip in previous code, so correct to make sure GPU/VPU mix is actually power off. Signed-off-by: Bai Ping <ping.bai@nxp.com>
2018-08-27MLK-18619: [MX8MM-EVK]CSU_RDC: enable csu_rdc test in ATF make the board crashFranck LENORMAND
csu_rdc test in ATF makes use of GPIO 4 and 5. Unfortunatly GPIO5 is being used by u-boot. This is why u-boot crashes. Changing the peripherals to protect, instead of gpio4 and 5, use csu and rdc registers instead. Signed-off-by: Silvano di Ninno <silvano.dininno@nxp.com> Signed-off-by: Franck LENORMAND <franck.lenormand@nxp.com>
2018-08-21plat: imx8mm: fix system resume hang when tz380 is enabledBai Ping
If NOC is power down in DSM mode, the tz380 register config will be lost, so we must re-init the tz380 after system resume. the tz380 initialization must be done after DRAM has been out of retention. Signed-off-by: Bai Ping <ping.bai@nxp.com>
2018-08-02plat: imx8mm: enable noc power down supportBai Ping
enable NOC power down in DSM mode. Signed-off-by: Bai Ping <ping.bai@nxp.com>
2018-07-26plat: imx8mm: enable power domain supportBai Ping
Enable the power domain support on imx8mm. Signed-off-by: Bai Ping <ping.bai@nxp.com>
2018-07-20plat: imx8mm: Add lpddr4 dvfs supportBai Ping
add LPDDR4 DVFS support on imx8mm. Signed-off-by: Bai Ping <ping.bai@nxp.com>
2018-07-20plat: imx: refact the dram retention flow on imx8mmBai Ping
All the DRAM timing related config is saved by SPL in OCRAM_S, so no need to do save for these configs in ATF anymore. Signed-off-by: Bai Ping <ping.bai@nxp.com>
2018-07-20PLAT: imx: Change the bl31 base address to 0x920000 for imx8mmBai Ping
On i.MX8MM, the OCRAM's last 128K is dedicated for ATF, so move bl31 to this memory region. BuildInfo: - IMX-MKIMAGE: ee5ad91b Signed-off-by: Bai Ping <ping.bai@nxp.com>
2018-07-05imx8mq/imx8mm: make sure no overlap during memory mapAnson Huang
The debug version of TF-A has below assert, fix it by making sure no memory map overlap. ASSERT: lib/xlat_tables/xlat_tables_common.c:129 Signed-off-by: Anson Huang <Anson.Huang@nxp.com>
2018-07-05imx8mq/imx8mm: switch to MULTI_CONSOLE_API for debug uart supportAnson Huang
Switch to MULTI_CONSOLE_API to make debug UART work. Signed-off-by: Anson Huang <Anson.Huang@nxp.com>
2018-06-21imx: enable necessary erratas for A53 r0p4Anson Huang
This patch enables necessary erratas for A53 r0p4 according to docs/cpu-specific-build-macros.rst. Signed-off-by: Anson Huang <Anson.Huang@nxp.com>
2018-06-11plat: imx8mm: mask the non-wakeup irq in low power modeBai Ping
Only enable the wakeup irq when system enter DSM mode. Signed-off-by: Bai Ping <ping.bai@nxp.com>
2018-06-11plat: imx8mm: use ARRAY_SIZE instead of magic numberBai Ping
use ARRAY_SIZE to get the array size. Signed-off-by: Bai Ping <ping.bai@nxp.com>
2018-06-11plat: imx8mm: enable DSM mode support on imx8mmBai Ping
enable DSM mode on i.MX8MM. Signed-off-by: Bai Ping <ping.bai@nxp.com>
2018-06-11plat: imx8m: add a common dram PM code for imx8m socBai Ping
re-design the dram power management code to make it more common for all i.MX8M SOCs. code need to refact and optimize to make more better. Using this common code on i.MX8MM first, for i.MX8MQ, will move to this later. Signed-off-by: Bai Ping <ping.bai@nxp.com>
2018-06-11plat: imx8mm: switch the CKIL clock source to 32K OSCBai Ping
Switch the CKIL clock source to 32K OSC. On i.MX8MM, after SOC PoR, the default clock source for CKIL is from divided 24MHz OSC, as 24MHz OSC will be power down when system enters DSM mdoe. So it is better to use 32K OSC as the default clock source after system bootup. Signed-off-by: Bai Ping <ping.bai@nxp.com>
2018-06-11plat: imx8mm: enable PU domains' clocks before power upBai Ping
VPU, GPU and PCIE's clock need to be on before power on these power domains. Signed-off-by: Bai Ping <ping.bai@nxp.com>
2018-06-11MLK-18502-02 plat: imx8mm: keep L2 cache memory power in WAIT modeBai Ping
When system enter deepest cpuilde(WAIT mode), the L2 cache memory can be on for retention to increase the system performance. So the WAIT mode with cluster power down should be defined as rentention power state in PSCI. changing the WAIT_OFF_STATE to WAIT_RET_STATE to make sure the l2 cache memory is not clean & invalidate. Signed-off-by: Bai Ping <ping.bai@nxp.com>
2018-06-11MLK-18502-01 plat: imx8mm: fix audio fifo underrun issueBai Ping
A53 WAIT mode is specific for OS cpuilde. The MASTER1 & MASTER2 mapping in A53 domain should be clear, otherwise the 'noc2supermix' and 'supermix2noc' ADB400 async port will be power down when A53 enters WAIT mode.If the ADB400 is power down in WAIT mode, all the bus request from supermix to noc wrapper will be blocked. Signed-off-by: Bai Ping <ping.bai@nxp.com>
2018-06-11MLK-18343-3: plat: imx8mm: add CAAM supportSilvano di Ninno
- configure Secure memory partition - allocate all CAAM JR to Linux Signed-off-by: Silvano di Ninno <silvano.dininno@nxp.com> Reviewed-by: Aymen Sghaier <aymen.sghaier@nxp.com>
2018-06-11MLK-18343-2: plat: imx8mm: add support for RDC and CSUSilvano di Ninno
move CSU and RDC driver to common/i.mx8m folder and enable the driver for i.mx8mm Signed-off-by: Silvano di Ninno <silvano.dininno@nxp.com> Reviewed-by: Aymen Sghaier <aymen.sghaier@nxp.com>
2018-06-11MLK-18343-1: plat: imx8mm: add BL32 supportSilvano di Ninno
fix entry point for the OP-TEE Signed-off-by: Silvano di Ninno <silvano.dininno@nxp.com> Reviewed-by: Aymen Sghaier <aymen.sghaier@nxp.com>
2018-06-11plat: imx8mm: enable the wait mode support on imx8mmBai Ping
Enable the WAIT mode support in cpuilde to save power. Signed-off-by: Bai Ping <ping.bai@nxp.com>
2018-06-11plat: imx8mm: cleanup platform.mkSilvano di Ninno
cleanup XLAT and STACK defines the OCRAM size for ATF is big enough for i.MX 8mm there is no need to move code to OCRAM_S Signed-off-by: Silvano di Ninno <silvano.dininno@nxp.com> Acked-by: Jacky Bai <ping.bai@nxp.com>
2018-06-11imx8mm: add HAB supportYe Li
Similar to imx8mq, the U-boot calls SIP call for HAB interfaces, and trap to ATF to run the HAB. Since HAB codes locates in ROM, and need to access OCRAM, CAAM RAM and DDR to authenticate image. Add these relevant memory region to MMU. Also extend the stack size of each core to avoid stack overflow, and extend the BL31 limit to OCRAM end 0x940000. Signed-off-by: Ye Li <ye.li@nxp.com>
2018-06-11plat: imx8mm: add basic imx8mm supportBai Ping
i.MX8MM is a new soc of the i.MX8M family, this patch add the basic support for i.MX8MM. further code optimization needed. WAIT mode support is currently disabled, will be enabled later. Signed-off-by: Bai Ping <ping.bai@nxp.com>
