The anamix PLL override setting should be cleared after system resume.
Signed-off-by: Jacky Bai <ping.bai@nxp.com>
Reviewed-by: Anson Huang <anson.huang@nxp.com>
A53 core's power up ack need to be used when system resume
from DSM mode.
Add the anamix PLL override setting for DSM mode support,
so that the PLL can be power down in DSM mode to save power.
This new workaround takes advantage of the per core IMR registers in GPC in
order to unmask the IRQ0, still generated by the 12bit in IOMUX_GPR register
(which now remains always set), so it can only wake up one core at the time.
Also, this entire workaround has now been moved here in TF-A, allowing the
kernel side to be minimal.
Another advantage this workaround brings is the removal of the 50us delay
(which was necessary before in gic_raise_softirq in kernel) by allowing the
core that is waking up to mask his own IRQ0 in the suspend finish callback.
One important change here is the way the cores are woken up in
dram_dvfs_handler. Since the wake up mechanism has changed from asserting the
12th bit in IOMUX_GPR and leaving the IMR1 1st bit on for each core to exactly
the reverse, that is, leaving the IOMUX_GPR 12th bit always set and then
masking/unmasking the IMR1 1st bit for each independent core, we need to use
the imx_gpc_core_wake to wake up the cores.
Also, the 50us udelay is moved to TF-A (inside imx_pwr_domain_off) from kernel
(gic_raise_softirq), since the new cpuidle workaround does not need it in order
to clean the IOMUX_GPC 12bit. For now, the udelay seems to be still needed
in order to delay the affinity info OFF for the dying core. This is something
that needs further investigation.
Signed-off-by: Abel Vesa <abel.vesa@nxp.com>
Add the dram retention support for i.MX8MQ. As there is
no enough ocram space available before entering TF-A,
so the timing info need to be copied from dram into ocram.
for the i.MX8M SOCs, part of the code for gpc
and PSCI implementation can be reused and make it
common for all these SoCs. this patch extracts
the common part for reuse.
Enforce full include path for includes. Deprecate old paths.
The following folders inside include/lib have been left unchanged:
- include/lib/cpus/${ARCH}
- include/lib/el3_runtime/${ARCH}
The reason for this change is that having a global namespace for
includes isn't a good idea. It defeats one of the advantages of having
folders and it introduces problems that are sometimes subtle (because
you may not know the header you are actually including if there are two
of them).
For example, this patch had to be created because two headers were
called the same way: e0ea0928d5b7 ("Fix gpio includes of mt8173 platform
to avoid collision."). More recently, this patch has had similar
problems: 46f9b2c3a282 ("drivers: add tzc380 support").
This problem was introduced in commit 4ecca33988b9 ("Move include and
source files to logical locations"). At that time, there weren't too
many headers so it wasn't a real issue. However, time has shown that
this creates problems.
Platforms that want to preserve the way they include headers may add the
removed paths to PLAT_INCLUDES, but this is discouraged.
Change-Id: I39dc53ed98f9e297a5966e723d1936d6ccf2fc8f
Signed-off-by: Antonio Nino Diaz <antonio.ninodiaz@arm.com>
i.MX8MQ is new SOC of NXP's i.MX8M family based on
A53. It can provide industry-leading audio, voice
and video processing for applications that scale
from consumer home audio to industrial building
automation and mobile computers
this patchset add the basic supoort to boot up
the 4 X A53. more feature will be added later.
Signed-off-by: Bai Ping <ping.bai@nxp.com>
