re-enable csu and rdc test for use of the test team
only enable if CSU_RDC_TEST is defined.
Signed-off-by: Silvano di Ninno <silvano.dininno@nxp.com>
(cherry picked from commit 2eb979f144f1c008f64d4550035ece0ad69a2365)
DRAM MMU settings miss the MT_NS on iMX8MM/MN/MP, this breaks the
HAB function since we load image by u-boot in NS mode and authenticate
it in ATF. Without MT_NS, ATF access secure memory which is different
cacheline with non-secure memory.
Signed-off-by: Ye Li <ye.li@nxp.com>
Reviewed-by: Jacky Bai <ping.bai@nxp.com>
Align code style between 8mq, 8mm and 8mn files.
Port and cleanup OP-TEE support.
Add trusty support for imx8mn, default load address and
size of trusty are 0xbe000000 and 0x2000000.
Signed-off-by: Ji Luo <ji.luo@nxp.com>
(cherry picked from commit 1566947ab431388906d71a1fb48e802fc9a1eec9)
spd trusty requires memory dynamic mapping feature to be
enabled, so we have to use xlat table library v2 instead
of v1.
Test: builds.
Replace the magic number index with enum type to make RDC/CSU config
more clear for user.
Signed-off-by: Jacky Bai <ping.bai@nxp.com>
Add the M core low power audio support on i.MX8M.
Add the SRC SiP handler for M4/M7 boot support on i.MX8M SoC.
Add the HAB secure boot support for the i.MX8M SoC family.
Add the CSU init on i.MX8MN & config the ocram
secure access range. CSU config for specific
system design can be added in the 'csu_cfg' array.
Enable dram retention support on i.MX8MN.
Add imx8mn basic support
