re-enable csu and rdc test for use of the test team
only enable if CSU_RDC_TEST is defined.
Signed-off-by: Silvano di Ninno <silvano.dininno@nxp.com>
(cherry picked from commit 2eb979f144f1c008f64d4550035ece0ad69a2365)
DRAM MMU settings miss the MT_NS on iMX8MM/MN/MP, this breaks the
HAB function since we load image by u-boot in NS mode and authenticate
it in ATF. Without MT_NS, ATF access secure memory which is different
cacheline with non-secure memory.
Signed-off-by: Ye Li <ye.li@nxp.com>
Reviewed-by: Jacky Bai <ping.bai@nxp.com>
On i.MX8MP, the SRC GPR9(0x94) is used by memory repair, so choose
SRC GPR10(0x98) as the LPA status sync register. Add use '==' instead
of '&' for LPA active statue check.
Signed-off-by: Jacky Bai <ping.bai@nxp.com>
Reviewed-by: Anson Huang <Anson.Huang@nxp.com>
Support stop M7 with SIP call.
Per IC team, to rekick M7 need follow steps.
If M7 already in WFI, perform below steps.
a) Set [0x303A_002C].0=0 [ request SLEEPHOLDREQn ]
b) Wait [0x303A_00EC].1 = 0 [ wait SLEEPHOLDACKn ]
c) Set GPR.CPUWAIT=1
d) Set [0x303A_002C].0=1 [ de-assert SLEEPHOLDREQn ]
e) Set SRC_M7_RCR[3:0] = 0xE0 [ reset M7 core/plat ]
f) Wait SRC_M7_RCR[3:0] = 0x8
g) Init TCM or DDR
h) Set GPR.INITVTOR
i) Set GPR.CPUWAIT=0, M7 starting running
Add a timeout check, if timeout, still perform force reset, in this
way no need to rely on M7 team's image wfi support ready.
Return a1,a2 to caller to check timeout or reset fail.
Signed-off-by: Peng Fan <peng.fan@nxp.com>
On i.MX8MN & i.MX8MP, the M core enabled check should
relay on the IOMUX GPR CPU_WAIT bit, when this bit is
cleared, it means M core is active & running, so refine
the m4 enabled check method.
move the gpc reg offset, bit define & macro to a separate header
file for code reuse.
Updating the CPU CORE power up timing to make sure
the RDC reload is done before CPU start to run code
in OCRAM space.
Align code style between 8mq, 8mm and 8mn files.
Port and cleanup OP-TEE support.
Add trusty support for imx8mm, default load address
and size of trusty are 0xbe000000 anx 0x2000000.
Signed-off-by: Ji Luo <ji.luo@nxp.com>
(cherry picked from commit 28d3f0fa26ff11efb98281ed603b6f44cea3c6c5)
spd trusty requires memory dynamic mapping feature to be
enabled, so we have to use xlat table library v2 instead
of v1.
Test: builds.
Replace the magic number index with enum type to make RDC/CSU config
more clear for user.
Add the M core low power audio support on i.MX8M.
Enable the NOC wrapper power down support for SoC that
have switchable NOC power domain.
Add the SRC SiP handler for M4/M7 boot support on i.MX8M SoC.
Add the HAB secure boot support for the i.MX8M SoC family.
Enable the CSU init on imx8mm. The 'csu_cfg' array
is just a placeholder for now as example. In real
use case, user can add the CSU config as needed
based on system design.
No need to keep all PU domains on as the full power domain driver
support has been added.
Add the PU power domain support for imx8mm/mn.
Add the DDR frequency change support.
Change-Id: I84f0ef51b04b84da8ba2cbeca86a07338a4903de
Enable dram retention support on i.MX8MM.
Change-Id: I76ada615d386602e551d572ff4e60ee19bb8e418
Add the basic support for opteed SPD on imx8mq & imx8mm.
Change-Id: I6c4855c89dea78d13d172c3d86cf047f829e51ce
Add the basic support for RDC init/config driver,
this module driver can be enhanced more if necessary.
Change-Id: I290dc378d0d85671435f9de46d5aa790b4e006c8
CAAM module must be initialized in secure world
before it can be used in non-secure world.
Change-Id: I042893667ddef99d8b6fc3902847d516d8591996
The new API becomes the default one.
Change-Id: Ic1d602da3dff4f4ebbcc158b885295c902a24fec
Signed-off-by: Ambroise Vincent <ambroise.vincent@arm.com>
AIPSTZ provide access control for all the peripherals connected
to it. In this patch all the perperals are configured accessible
to all the master. it can be customized based the actual use
case.
Change-Id: I5ef5baa1da6906f13a60923d27ede336c61e319a
The IMX_SIP_BUILDINFO call was implemented for imx8qm and imx8qx but
it's also applicable to imx8m.
This fixes U-Boot not printing commit hash on 8m with upstream TF-A.
Change-Id: Idcfd9729eaaccf329c24e241da325f1f6cd3c880
Signed-off-by: Leonard Crestez <leonard.crestez@nxp.com>
The 'drivers/console/aarch64/console.S' is not needed,
so remove it from build to fix the build error when
'ERROR_DEPRECATED'set.
Change-Id: Id047a355f82fd33298b7e2b49eff289d28eb5b56
The i.MX8M Mini is new SOC of the i.MX8M family. it is
focused on delivering the latest and greatest video and
audio experience combining state-of-the-art media-specific
features with high-performance processing while optimized
for lowest power consumption. The i.MX 8M Mini Media Applications
Processor is 14nm FinFET product of the growing i.MX8M family
targeting the consumer & industrial market. It is built in 14LPP
to achieve both high performance and low power consumption
and relies on a powerful fully coherent core complex based on
a quad Cortex-A53 cluster with video and graphics accelerators
this patch add the basic support for i.MX8MM.
