The i.MX8MP A0 silicon will not be supported anymore, remove the
wait mode workaround to make the cpuidle support more robust & simplify
the code logic.
Signed-off-by: Jacky Bai <ping.bai@nxp.com>
Reviewed-by: Jian Li <jian.li@nxp.com>
Fix the out of bound access to the rank setting array.
Reviewed-by: Ye Li <ye.li@nxp.com>
The dfimisc reg value should be shift right 8 bit to
get the current fsp.
Reviewed-by: Anson Huang <Anson.Huang@nxp.com>
update umctl2's setting based on phy training CDD value
to workaround the rank-to-rank space issue.
Reviewed-by: Anson Huang <anson.huang@nxp.com>
the DDR3L & DDR4 can share same piece of code of DVFS, so update
the ddr4 dvfs to support DDR3L too.
the bitfield of active_ranks in MSTR is defined as below.
Correct the rank num get in dram_info.
0x01: one rank;
0x11: two rank;
Add the i.MX8MP workaround for wait mode just for Alpha
release, this patch will be dropped in the future.
Enable DRAM DVFS support on i.MX8MQ.
Add the dram retention support for i.MX8MQ. As there is
no enough ocram space available before entering TF-A,
so the timing info need to be copied from dram into ocram.
Add the DDR frequency change support.
Change-Id: I84f0ef51b04b84da8ba2cbeca86a07338a4903de
Add the dram retention flow for i.MX8M SoC family.
Change-Id: Ifb8ba5b2f6f002133cf47c07fef73df29c51c890
