update umctl2's setting based on phy training CDD value
to workaround the rank-to-rank space issue.
Signed-off-by: Jacky Bai <ping.bai@nxp.com>
Reviewed-by: Anson Huang <anson.huang@nxp.com>
(cherry picked from commit 8cd4fa6dfff74b190294141bdc22634a7cb40a30)
the DDR3L & DDR4 can share same piece of code of DVFS, so update
the ddr4 dvfs to support DDR3L too.
(cherry picked from commit 57bf8a00a74f12671cb38863bbc3606b3834f195)
the bitfield of active_ranks in MSTR is defined as below.
Correct the rank num get in dram_info.
0x01: one rank;
0x11: two rank;
(cherry picked from commit bc9bc03f38fecbf5a2e4d938ed6f45fb3ec0b574)
Add the i.MX8MP workaround for wait mode just for Alpha
release, this patch will be dropped in the future.
Enable DRAM DVFS support on i.MX8MQ.
Add the dram retention support for i.MX8MQ. As there is
no enough ocram space available before entering TF-A,
so the timing info need to be copied from dram into ocram.
Add the DDR frequency change support.
Change-Id: I84f0ef51b04b84da8ba2cbeca86a07338a4903de
Add the dram retention flow for i.MX8M SoC family.
Change-Id: Ifb8ba5b2f6f002133cf47c07fef73df29c51c890
