Handle corner cases of early of wakeup interrupts.
Monitor the status of OS MU interrupt in the IRQSTR as the last step
in the suspend process. If an MU interrupt is pending, switch the
wakeup source to be irqsteer so that the core can woken up by the SCFW
after wfi is executed.
Signed-off-by: Ranjani Vaidyanathan <ranjani.vaidyanathan@nxp.com>
(cherry picked from commit c3acc399cfd8db878d6078456092ca3f63fd070b)
The SCFW supports OCRAM retention, so no need to set cpu entry for reboot
to let CPU run from SPL in OCRAM again when reboot, then SPL will reload
images after reboot.
Signed-off-by: Anson Huang <Anson.Huang@nxp.com>
Reviewed-by: Ye Li <ye.li@nxp.com>
i.MX8DXL ONLY supports up to 12*32 interrupt number, so the
first SPI interrupt offset should be from 0x2c.
(cherry picked from commit cd0519bf70382292768adc1e9c0337808c55f148)
Add support for new SoC i.MX8DXL
Signed-off-by: Teo Hall <teo.hall@nxp.com>
(cherry picked from a7a008da03cd08cae3387c428ad8145fb1fae354)
