Avoid to load FIP by hacking address. Load it by partition table instead.
Signed-off-by: Haojian Zhuang <haojian.zhuang@linaro.org>
Change-Id: I0283fc2e6e459bff14de19d92db4158e05106ee4
Change-Id: Ib476d024a51e4b9705441a0007d78f9fdf0ca078
NOTE: AARCH32/AARCH64 macros are now deprecated in favor of __aarch64__.
All common C compilers pre-define the same macros to signal which
architecture the code is being compiled for: __arm__ for AArch32 (or
earlier versions) and __aarch64__ for AArch64. There's no need for TF-A
to define its own custom macros for this. In order to unify code with
the export headers (which use __aarch64__ to avoid another dependency),
let's deprecate the AARCH32 and AARCH64 macros and switch the code base
over to the pre-defined standard macro. (Since it is somewhat
unintuitive that __arm__ only means AArch32, let's standardize on only
using __aarch64__.)
Change-Id: Ic77de4b052297d77f38fc95f95f65a8ee70cf200
Signed-off-by: Julius Werner <jwerner@chromium.org>
NOTE: __ASSEMBLY__ macro is now deprecated in favor of __ASSEMBLER__.
All common C compilers predefine a macro called __ASSEMBLER__ when
preprocessing a .S file. There is no reason for TF-A to define it's own
__ASSEMBLY__ macro for this purpose instead. To unify code with the
export headers (which use __ASSEMBLER__ to avoid one extra dependency),
let's deprecate __ASSEMBLY__ and switch the code base over to the
predefined standard.
Change-Id: Id7d0ec8cf330195da80499c68562b65cb5ab7417
It's not a good idea to use u_register_t for the members of
aapcs64_params_t and aapcs32_params_t, since the width of that type
always depends on the current execution environment. This would cause
problems if e.g. we used this structure to set up the entry point of an
AArch32 program from within an AArch64 program. (It doesn't seem like
any code is doing that today, but it's probably still a good idea to
write this defensively. Also, it helps with my next patch.)
Change-Id: I12c04a85611f2b6702589f3362bea3e6a7c9f776
This consists of ensuring that the left operand of each shift is
unsigned when the operation might overflow into the sign bit.
Change-Id: I67984b6c48c08af61e95a4dbd18047e2c3151f9a
Signed-off-by: Justin Chadwell <justin.chadwell@arm.com>
The new API becomes the default one.
Change-Id: Ic1d602da3dff4f4ebbcc158b885295c902a24fec
Signed-off-by: Ambroise Vincent <ambroise.vincent@arm.com>
Change-Id: I54869151bfc434df66933bd418c70cca9c3d0861
Signed-off-by: Michalis Pappas <mpappas@fastmail.fm>
* changes:
Mbed TLS: Remove weak heap implementation
sgm: Fix bl2 sources
The implementation of the heap function plat_get_mbedtls_heap() becomes
mandatory for platforms supporting TRUSTED_BOARD_BOOT.
The shared Mbed TLS heap default weak function implementation is
converted to a helper function get_mbedtls_heap_helper() which can be
used by the platforms for their own function implementation.
Change-Id: Ic8f2994e25e3d9fcd371a21ac459fdcafe07433e
From the hotplug testing on Hikey960, in some case cores fail to become
online in the system. When some cores are hotplugged off, if other
cores in the same cluster enter into CPU idle states at the meantime,
the cluster will be powered off. This introduces the state machine
malfunction in the power controller, thus when hotplug on the core
afterwards, it fails to boot up the core because the power controller
thinks the cluster is powered on.
This patch is to avoid race condition between hotplug and idles by
preventing cluster power off when some of cores in the cluster are
hotplugged off, if all cores in the same cluster are hotplugged off,
the cluster can be powered off.
Change-Id: Ib2feeb093357c70409a3536cb4f9da9b504fdcbe
Signed-off-by: Wei Yu <yuwei3@hisilicon.com>
Signed-off-by: Leo Yan <leo.yan@linaro.org>
There exists a third DMA controller on the hi3660
SoC called the IOMCU DMAC. This controller is used by
peripherals like SPI2 and UART3. Initialize channels 4-7
as non-secure, while 0-3 remain reserved and secure.
Signed-off-by: Ryan Grachek <ryan@edited.us>
Minor cleanup
Also, update platform_def.h guidelines about includes in the porting
guide.
Change-Id: I1ae338c9dd3242b309f6d53687ba2cb755d488c3
Signed-off-by: Antonio Nino Diaz <antonio.ninodiaz@arm.com>
Many parts of the code were duplicating symbols that are defined in
include/common/bl_common.h. It is better to only use the definitions in
this header.
As all the symbols refer to virtual addresses, they have to be
uintptr_t, not unsigned long. This has also been fixed in bl_common.h.
Change-Id: I204081af78326ced03fb05f69846f229d324c711
Channel 0 is used to communicate with LPM3, a coprocessor
for power management. Leave it as secure.
The definitions in bl1/bl1_private.h and bl2/bl2_private.h are useful for
platforms that may need to access them.
Change-Id: Ifd1880f855ddafcb3bfcaf1ed4a4e0f121eda174
Change-Id: I7194a9a5f0e41308eb3242d20c0d3434f72da591
Signed-off-by: Joel Hutton <Joel.Hutton@Arm.com>
It is cleaner to use the same number of tables regardless of whether
OP-TEE is used or not. This doesn't result in a significant memory
usage increase.
Change-Id: I38bcaa3f2f197c0a352153117592749f189a265c
Enforce full include path for includes. Deprecate old paths.
The following folders inside include/lib have been left unchanged:
- include/lib/cpus/${ARCH}
- include/lib/el3_runtime/${ARCH}
The reason for this change is that having a global namespace for
includes isn't a good idea. It defeats one of the advantages of having
folders and it introduces problems that are sometimes subtle (because
you may not know the header you are actually including if there are two
of them).
For example, this patch had to be created because two headers were
called the same way: e0ea0928d5b7 ("Fix gpio includes of mt8173 platform
to avoid collision."). More recently, this patch has had similar
problems: 46f9b2c3a282 ("drivers: add tzc380 support").
This problem was introduced in commit 4ecca33988b9 ("Move include and
source files to logical locations"). At that time, there weren't too
many headers so it wasn't a real issue. However, time has shown that
this creates problems.
Platforms that want to preserve the way they include headers may add the
removed paths to PLAT_INCLUDES, but this is discouraged.
Change-Id: I39dc53ed98f9e297a5966e723d1936d6ccf2fc8f
This is used as a table index, and already compared with an unsigned int:
block_dev_count.
Signed-off-by: Yann Gautier <yann.gautier@st.com>
This is needed to utilize the DMA controller on the hikey960
commit 386b14bf64124ebf0368eab33ef07603e0c3138a
Author: Haojian Zhuang <haojian.zhuang@linaro.org>
Date: Wed Nov 21 09:19:49 2018 +0800
mmc: poll eMMC status after EXT_CSD command
EXT_CSD command needs to access data from eMMC device. Add the
operation of polling eMMC device status. Make sure the command is
finished.
A hacked delay time can't fit each eMMC device. Since the above commit
enables the polling operation, remove the hacked delay time now.
Some eMMC chips require a longer delay. After testing
different chips, 20ms appears to work reliably.
hikey, hikey960, poplar: use new console APIs
Switch to the new console APIs enabled by setting MULTI_CONSOLE_API=1.
Enables building with ERROR_DEPRECATED=1.
Signed-off-by: Jerome Forissier <jerome.forissier@linaro.org>
All identifiers, regardless of use, that start with two underscores are
reserved. This means they can't be used in header guards.
The style that this project is now to use the full name of the file in
capital letters followed by 'H'. For example, for a file called
"uart_example.h", the header guard is UART_EXAMPLE_H.
The exceptions are files that are imported from other projects:
- CryptoCell driver
- dt-bindings folders
- zlib headers
Change-Id: I50561bf6c88b491ec440d0c8385c74650f3c106e
hikey: add delay after eMMC initialized
The macro EL_IMPLEMENTED() has been deprecated in favour of the new
function el_implemented().
Change-Id: Ic9b1b81480b5e019b50a050e8c1a199991bf0ca9
It boots failure on CircuitCo HiKey board. The delay could fix the
hang issue.
plat/arm files should only be used by Arm platforms. If other platforms
use them, they create dependencies that can introduce problems when
updating Arm platforms.
This patch copies the needed code from Arm platforms so that poplar can
be independent from them.
Change-Id: I0b194f5bdb0377b8ccacbd400e021614c026c7fe
Tested-by: Shawn Guo <shawn.guo@linaro.org>
Even though at this point plat_crash_console_flush is optional, it will
stop being optional in a following patch.
The console driver of warp7 doesn't support flush, so the implementation
is a placeholder.
TI had ``plat_crash_console_init`` and ``plat_crash_console_putc``, but
they weren't global so they weren't actually used. Also, they were
calling the wrong functions.
imx8_helpers.S only has placeholders for all of the functions.
Change-Id: I8d17bbf37c7dad74e134c61ceb92acb9af497718
The "Secure" prefix (S-ELx) is valid only for S-EL0 and S-EL1 but is
meaningless for EL3, since EL3 is always secure. Hence, the "S" prefix
has been removed from wherever it was used as "S-EL3".
Change-Id: Icdeac9506d763f9f83d7297c7113aec7b85e9dbe
Signed-off-by: John Tsichritzis <john.tsichritzis@arm.com>
Remove deprecated interfaces for all platforms
Topic/fix clang
- Remove support for LOAD_IMAGE_V2=0.
- Replace deprecated bl1_init_bl2_mem_layout().
- Migrate to bl2_early_platform_setup2().
- Migrate to bl31_early_platform_setup2().
- Use PLAT_VIRT_ADDR_SPACE_SIZE and PLAT_PHY_ADDR_SPACE_SIZE.
- Remove references to removed build options.
- Update Makefile paths.
Change-Id: I52e02633365b3db4244f7ff0f99a6446eae619f0
- Migrate to new GIC interfaces.
- Remove unused bl1_init_bl2_mem_layout().
Change-Id: I583fd893555e6535f32d87ed67bbae430b8e6afe
Tested-by: Haojian Zhuang <haojian.zhuang@linaro.org>
Change-Id: Idd1e99b4864b2a72e9e12ff1fcd73d8285bc1c94
Commit eba1b6b3c724 ("plat/poplar: migrate to mmc framework") defines
variable 'info' without !POPLAR_RECOVERY protection, and hence causes
the following unused variable error with POPLAR_RECOVERY=1 build.
plat/hisilicon/poplar/bl1_plat_setup.c: In function ‘bl1_platform_setup’:
plat/hisilicon/poplar/bl1_plat_setup.c:95:25: error: unused variable ‘info’ [-Werror=unused-variable]
struct mmc_device_info info;
The patches fixes the build error with POPLAR_RECOVERY=1.
plat/hisilicon/hikey960/include/plat_macros.S:19:55: error: unexpected token in
'.asciz' directive
.asciz "gicd_ispendr regs (Offsets 0x200 - 0x278)\n" " Offset:\t\t\tvalue\n"
Makefile:720: recipe for target 'build/hikey960/debug/bl1/cortex_a53.o' failed
make: *** [build/hikey960/debug/bl1/cortex_a53.o] Error 1
Merge the two lines into one.
plat/hisilicon/hikey/include/plat_macros.S:19:55: error: unexpected token in '.asciz' directive
Makefile:720: recipe for target 'build/hikey/debug/bl1/cortex_a53.o' failed
make: *** [build/hikey/debug/bl1/cortex_a53.o] Error 1
Merge two lines into one line.
This patch adds experimental support for TBB to the HiKey960 board. To
build and test with TBB modify the uefi-tools project platforms.config
+ATF_BUILDFLAGS=TRUSTED_BOARD_BOOT=1 GENERATE_COT=1 SAVE_KEYS=1 \
MBEDTLS_DIR=./mbedtls
Signed-off-by: Teddy Reed <teddy@casualhacking.io>
tf_printf and tf_snprintf are now called printf and snprintf, so the
code needs to be updated.
Change-Id: Iffeee97afcd6328c4c2d30830d4923b964682d71
The codebase was using non-standard headers. It is needed to replace
them by the correct ones so that we can use the new libc headers.
Change-Id: I530f71d9510cb036e69fe79823c8230afe890b9d
Acked-by: Sumit Garg <sumit.garg@linaro.org>
Replace stdio.h functions by TF functions
Migrate from emmc framework to mmc framework.
Migrate to mmc framework.
Functions provided by stdio.h such as printf and sprintf are available
in the codebase, but they add a lot of code to the final image if they
are used:
- AArch64: ~4KB
- AArch32: ~2KB in T32, ~3KB in A32
tf_printf and tf_snprintf are a lot more simple, but it is preferable
to use them when possible because they are also used in common code.
Change-Id: Id09fd2b486198fe3d79276e2c27931595b7ba60e
Acked-by: Haojian Zhuang <haojian.zhuang@linaro.org>
