As suspend with last CPU power down needs SCFW support,
and it is NOT ready now, in order to enable kernel suspend
function earlier for modules to start debugging suspend
resume function, this patch adds standby suspend for now.
Will add last CPU power down suspend function when SCFW
is ready.
Signed-off-by: Anson Huang <Anson.Huang@nxp.com>
Add system_off pcsi callback to avoid below kernel
message when doing power off:
[11613.953711] reboot: Power down
[11613.958318] systemd-shutdow: 8 output lines suppressed due to ratelimiting
[11613.965285] Kernel panic - not syncing: Attempted to kill init! exitcode=0x00
[11613.965285]
[11613.974441] CPU: 0 PID: 1 Comm: systemd-shutdow Not tainted 4.9.11-03354-g0e1
[11613.982369] Hardware name: Freescale i.MX8QXP LPDDR4 ARM2 (DT)
[11613.988216] Call trace:
[11613.990681] [<ffff0000080882bc>] dump_backtrace+0x0/0x1a8
[11613.996092] [<ffff000008088478>] show_stack+0x14/0x1c
[11614.001154] [<ffff0000083aaf98>] dump_stack+0x8c/0xac
[11614.006213] [<ffff000008162aac>] panic+0x124/0x28c
[11614.011016] [<ffff0000080c0b20>] complete_and_exit+0x0/0x20
[11614.016600] [<ffff0000080dc6d8>] SyS_reboot+0x168/0x244
[11614.021829] [<ffff000008082ef0>] el0_svc_naked+0x24/0x28
[11614.027153] Kernel Offset: disabled
[11614.030646] Memory Limit: none
[11614.040755] ---[ end Kernel panic - not syncing: Attempted to kill init! exi0
[11614.040755]
As there is no system power off SCFW API available now, so just
simply do wfi and never return when system_off is called.
Add SRTC SIP support for i.MX8QM/i.MX8QXP.
Add i.MX8QM board reboot support.
Linux kernel will issue cpu-freq scale via SIP, ATF
calls SCFW API to finish the CPU frequency scale.
Move SIP service code from i.mx8mq to common place for
all i.mx SoCs.
Reserve the memory region that is only can access by ATF. ATF is running
in this memory region, while masters in other partitions can't access it.
Signed-off-by: Ye Li <ye.li@nxp.com>
Change to search the ATF owned memory regions and assign them to non-secure
OS partition. Not allocate new memory region for each one.
As we already have control for debug console in platform_def.h,
so no need to un-initialize console in plat runtime setup, just
overwrite the common implementation with blank function.
Signed-off-by: Nitin Garg <nitin.garg@nxp.com>
Not only the resources, but also the memory regions need to assign to
non-secure partition. Otherwise, when the boot partition is secured,
the OS non-secure partition can't access any memory.
This patch currently assign all memory to NS partition, since it is not
isolated, the current secure partition also can access them. In future,
may need to change the regions for reserving some memory in secure
partition for ATF and BL32.
missed bit 31 and 30 which are needed
Disable ATF console output for iMX8QM
Need to add support for booting up A72 cluster only,
so on need to check the cluster ID for primary CPU,
that means if CPU ID is 0, then it can be as primary
CPU.
change MMU mapping to use the address of
the MU currently being used for ATF
Signed-off-by: Teo Hall <teo.hall@nxp.com>
add more resources to secure partition for
protection. Also add in functionality to allow
for register access of some secure-owned
peripherals.
These peripherals will still be protected from
power or clk changes.
add rm svc api and set aside separate MU for
secure api calls into SCU
UART baudrate is 115200 on i.MX8QM ARM2 board.
Add i.MX8QM platform support.
Signed-off-by: Bai Ping <ping.bai@nxp.com>
