Replace all GPL with BSD identifier.
Signed-off-by: Anson Huang <Anson.Huang@nxp.com>
Add a new SIP call FSL_SIP_BUILDINFO to return the current commit id
in 7 hexadecimal digits which are parsed from the version_string.
Signed-off-by: Ye Li <ye.li@nxp.com>
Fix below build error on i.MX8QXP when using poky
tool chain:
CC plat/freescale/common/cpufreq.c
plat/freescale/common/cpufreq.c:27:18:
error: "ap_cluster_index" defined but not used
[-Werror=unused-const-variable=]
Add SRTC SIP support for i.MX8QM/i.MX8QXP.
Add SCFW timer API support.
Signed-off-by: Ranjani Vaidyanathan <Ranjani.Vaidyanathan@nxp.com>
Linux kernel will issue cpu-freq scale via SIP, ATF
calls SCFW API to finish the CPU frequency scale.
Move SIP service code from i.mx8mq to common place for
all i.mx SoCs.
Add basic support for i.MX8MQ.
1. SMP support is ok.
2. basic suspend/resume support is ok.
Signed-off-by: Bai Ping <ping.bai@nxp.com>
Signed-off-by: Nitin Garg <nitin.garg@nxp.com>
Need to add support for booting up A72 cluster only,
so on need to check the cluster ID for primary CPU,
that means if CPU ID is 0, then it can be as primary
CPU.
add rm svc api and set aside separate MU for
secure api calls into SCU
Signed-off-by: Teo Hall <teo.hall@nxp.com>
add plat_crash_print_regs macro function to
allow building with debug
This patch adds i.MX8 SoCs ATFW support, including below
basic features:
* LPUART
* SCFW RPC
* SMP boot up
Each SoC will have its own platform definition and driver
to support.
