path: root/plat/compat
2017-11-30Do not enable SVE on pre-v8.2 platformsDavid Cunado
Pre-v8.2 platforms such as the Juno platform does not have the Scalable Vector Extensions implemented and so the build option ENABLE_SVE is set to zero. This has a minor performance improvement with no functional impact. Change-Id: Ib072735db7a0247406f8b60e325b7e28b1e04ad1 Signed-off-by: David Cunado <david.cunado@arm.com>
2017-06-27Resolve signed-unsigned comparison issuesDavid Cunado
A recent commit 030567e6f51731982a7e71cbd387de93bc0e35fd added U()/ULL() macro to TF constants. This has caused some signed-unsigned comparison warnings / errors in the TF static analysis. This patch addresses these issues by migrating impacted variables from signed ints to unsigned ints and vice verse where applicable. Change-Id: I4b4c739a3fa64aaf13b69ad1702c66ec79247e53 Signed-off-by: David Cunado <david.cunado@arm.com>
2017-05-03Use SPDX license identifiersdp-arm
To make software license auditing simpler, use SPDX[0] license identifiers instead of duplicating the license text in every file. NOTE: Files that have been imported by FreeBSD have not been modified. [0]: https://spdx.org/ Change-Id: I80a00e1f641b8cc075ca5a95b10607ed9ed8761a Signed-off-by: dp-arm <dimitris.papastamos@arm.com>
2016-08-10AArch32: Add essential ARM platform and FVP supportSoby Mathew
This patch adds AArch32 support for FVP and implements common platform APIs like `plat_get_my_stack`, `plat_set_my_stack`, `plat_my_core_cos` for AArch32. Only Multi Processor(MP) implementations of these functions are considered in this patch. The ARM Standard platform layer helpers are implemented for AArch32 and the common makefiles are modified to cater for both AArch64 and AArch32 builds. Compatibility with the deprecated platform API is not supported for AArch32. Change-Id: Iad228400613eec91abf731b49e21a15bcf2833ea
2016-07-19Include `plat_psci_common.c` from the new locationSoby Mathew
The `plat_psci_common.c` was moved to the new location `plat/common` and a stub file was retained at previous location for compatibility. This patch modifies the platform makefiles to include the file from the new location. Change-Id: Iabddeeb824e9a5d72d176d7c644735966c8c0699
2015-08-13PSCI: Implement platform compatibility layerSoby Mathew
The new PSCI topology framework and PSCI extended State framework introduces a breaking change in the platform port APIs. To ease the migration of the platform ports to the new porting interface, a compatibility layer is introduced which essentially defines the new platform API in terms of the old API. The old PSCI helpers to retrieve the power-state, its associated fields and the highest coordinated physical OFF affinity level of a core are also implemented for compatibility. This allows the existing platform ports to work with the new PSCI framework without significant rework. This layer will be enabled by default once the switch to the new PSCI framework is done and is controlled by the build flag ENABLE_PLAT_COMPAT. Change-Id: I4b17cac3a4f3375910a36dba6b03d8f1700d07e3
