Pre-v8.2 platforms such as the Juno platform does not have
the Scalable Vector Extensions implemented and so the build
option ENABLE_SVE is set to zero.
This has a minor performance improvement with no functional
impact.
Change-Id: Ib072735db7a0247406f8b60e325b7e28b1e04ad1
Signed-off-by: David Cunado <david.cunado@arm.com>
A recent commit 030567e6f51731982a7e71cbd387de93bc0e35fd added U()/ULL()
macro to TF constants. This has caused some signed-unsigned comparison
warnings / errors in the TF static analysis.
This patch addresses these issues by migrating impacted variables from
signed ints to unsigned ints and vice verse where applicable.
Change-Id: I4b4c739a3fa64aaf13b69ad1702c66ec79247e53
To make software license auditing simpler, use SPDX[0] license
identifiers instead of duplicating the license text in every file.
NOTE: Files that have been imported by FreeBSD have not been modified.
[0]: https://spdx.org/
Change-Id: I80a00e1f641b8cc075ca5a95b10607ed9ed8761a
Signed-off-by: dp-arm <dimitris.papastamos@arm.com>
This patch adds AArch32 support for FVP and implements common platform APIs
like `plat_get_my_stack`, `plat_set_my_stack`, `plat_my_core_cos` for AArch32.
Only Multi Processor(MP) implementations of these functions are considered in
this patch. The ARM Standard platform layer helpers are implemented for
AArch32 and the common makefiles are modified to cater for both AArch64 and
AArch32 builds. Compatibility with the deprecated platform API is not
supported for AArch32.
Change-Id: Iad228400613eec91abf731b49e21a15bcf2833ea
The `plat_psci_common.c` was moved to the new location `plat/common`
and a stub file was retained at previous location for compatibility. This
patch modifies the platform makefiles to include the file from the new
location.
Change-Id: Iabddeeb824e9a5d72d176d7c644735966c8c0699
The new PSCI topology framework and PSCI extended State framework introduces
a breaking change in the platform port APIs. To ease the migration of the
platform ports to the new porting interface, a compatibility layer is
introduced which essentially defines the new platform API in terms of the
old API. The old PSCI helpers to retrieve the power-state, its associated
fields and the highest coordinated physical OFF affinity level of a core
are also implemented for compatibility. This allows the existing
platform ports to work with the new PSCI framework without significant
rework. This layer will be enabled by default once the switch to the new
PSCI framework is done and is controlled by the build flag ENABLE_PLAT_COMPAT.
Change-Id: I4b17cac3a4f3375910a36dba6b03d8f1700d07e3
