Refactor the FVP gic code in plat/fvp/fvp_gic.c to be a generic ARM
GIC driver in drivers/arm/gic/arm_gic.c. Provide the platform
specific inputs in the arm_gic_setup() function so that the driver
has no explicit dependency on platform code.
Provide weak implementations of the platform interrupt controller
API in a new file, plat/common/plat_gic.c. These simply call through
to the ARM GIC driver.
Move the only remaining FVP GIC function, fvp_gic_init() to
plat/fvp/aarch64/fvp_common.c and remove plat/fvp/fvp_gic.c
Fixes ARM-software/tf-issues#182
Change-Id: Iea82fe095fad62dd33ba9efbddd48c57717edd21
