* changes:
amlogic: g12a: Add support for the S905X2 (G12A) platform
amlogic: makefile: Use PLAT variable when possible
amlogic: sha_dma: Move register mappings to platform header
Introduce the preliminary support for the Amlogic S905X2 (G12A) SoC.
This port is a minimal implementation of BL31 capable of booting
mainline U-Boot and Linux. Tested on a SEI510 board.
Signed-off-by: Carlo Caione <ccaione@baylibre.com>
Change-Id: Ife958f10e815a4530292c45446adb71239f3367f
To address the file names.
Change-Id: Ib79b8dfa032a1db012c5031d47de61e1a16b5f9a
The registers location for the SHA DMA driver is not unique for the
different platforms. Move the mapping out of the driver and into the
platform-specific header.
Change-Id: Ice64637844a3cb384b01e466cb8c1cea5f764129
Both kernel and U-Boot use a SMC call to the secure monitor to get the
chip ID. This call is translated by BL31 to a call to the SCP to
retrieve the ID. Add a new SiP call and the backing SCPI command.
Change-Id: Ib128f5645ee92866e7ebbcd550dacd33f573524b
The code managing the console is the same for all the platforms
currently supported. Since it is unlikely to change in the future move
the code to an external file in the common directory.
Change-Id: I6df555ea82d483b4f08a4a1e2cb0a7488fbaa015
As part of the code refactoring fix the order of the include files
across all the source files.
Change-Id: Ice72f687cc26ee881a9051168149467688100cfb
Make the header guards more generic and contextually remove the
GXBB_BL31_PLAT_PARAM_VAL value that is unused on the GXL platform.
Change-Id: I842fa2e084e71280ae17b39c67877e844821a171
Remove the GXBB prefix where needed and add SoC specific prefixes for
GXBB/GXL.
Change-Id: Ic3eb3a77ca2d9c779a9dee5cee786e9c16ecdb27
Remove the GXBB prefix from the code in the common directory and add
SoC-specific prefixes in the SoC specific code.
Change-Id: Ic983ef70b0ef23f95088dd8df488d8c42c3bc030
Add a new aml_* prefix to the SCPI related function calls.
Change-Id: I697812ac1c0df28cbb639a1dc3e838f1107fb739
Make the MHU code AML specific adding a new aml_* prefix and remove the
GXBB prefix from the register names.
Change-Id: I8f20918e29f08542bd71bd679f88e65b4efaa7d2
All the SIP/SVC related code is currently the same between GXL and GXBB.
Rename function names and register names to avoid hardcoding the GXBB
prefix.
Change-Id: I7e58ab68489df8d4762663fc01fb64e6899cc8bf
No need to have a special SoC-specific prefix.
Change-Id: I0da543e7d92d56604e79440a98027ffd9a2eaa59
The header file is shared between all the SoCs. Better avoiding
hardcoding the SoC name in the function names.
Change-Id: I9074871bd1ed8a702c1a656e0f50f2d3c6cb0425
The efuse driver is hardcoding the GXBB prefix. No need to do that since
the driver is shared between multiple SoCs.
Change-Id: I97691b0bbd55170d8216d301a3fc04feb8c2af2e
Fixing at the same time the related register names.
Change-Id: Ib1130d50abe6088f1c0826878d1ae454a0f23008
The code is the common directory is now generic, no need to have the SoC
prefix hardcoded in the function names.
Change-Id: Ied3a5e506b9abd4c2d6f893bafef50019bff24f1
Now that every piece is in place, the makefiles can be refactored and
slightly beautified removing useless and redundant parts.
Change-Id: If74e1909df52d475cf4b0dfed819d07d3a4c85b9
The code is the same between GXBB and GXL. Move it to the common source
directory.
Change-Id: I875689a6fd029971aa755fc2725217e90ed06b6c
As done already for multiple files, move the topology file to the common
directory.
Change-Id: Iaca357a089593ad58c35c05c929239132249dcda
As for most of the Amlogic code, this is common between the Amlogic
SoCs. Move the code to the common directory.
Change-Id: Id3f0073ff1f0b9ddbe964f80303323ee4a2f27b0
The MHU code is shared between all the supported platforms. Move it to
the common directory instead.
Change-Id: Iaf53122866eae85c13f772927d16836dcfa877a3
The efuse code is the same between GXL and GXBB. Move the code to common
directory.
Change-Id: Ie37f21d1907a36292724f1fb645a78041fe4a6b3
The platform macros are shared between all the SoCs. Move it to common
directory.
Change-Id: Ia04c3ffe4d7b068aa701268ed99f69995d8db92b
Now that also the SHA256 DMA driver is shared between all the SoCs, we
can have one single private platform header file.
Change-Id: I77d51915f9d8233aeceeed66ed1f491573402cfc
The SCPI code is the same between GXBB and GXL. No need to have it
replicated for each SoCs. Move it to the common directory.
Change-Id: I7e416caf1e9538b3ce7702c0363ee00a054e2451
The SHA256 DMA driver can be used by multiple SoCs. Move it to the
common directory.
Change-Id: I96319eeeeeebd503ef0dcb07c0e4ff6a67afeaa5
The assembly helpers are common to all the amlogic SoCs. Move the .S
file to the common directory.
Change-Id: I0d8616a7ae22dbcb14848cefd0149b6bb5814ea6
Make the platform name a parameter for the source directories. Besides a
cosmetic fix, this is going to be helpful when reusing the same Makefile
for different SoCs.
Change-Id: I307897a21800cca8ad68a5ab8972d27e9356ff2a
Meson is the internal code name for the SoC family. The correct name for
the platform should be Amlogic. Change the name of the platform
directory.
Change-Id: Icc140e1ea137f12117acbf64c7dcb1a8b66b345d
