path: root/plat/amlogic
2019-09-27Merge changes from topic "amlogic-g12a" into integrationSoby Mathew
* changes: amlogic: g12a: Add support for the S905X2 (G12A) platform amlogic: makefile: Use PLAT variable when possible amlogic: sha_dma: Move register mappings to platform header
2019-09-26amlogic: g12a: Add support for the S905X2 (G12A) platformCarlo Caione
Introduce the preliminary support for the Amlogic S905X2 (G12A) SoC. This port is a minimal implementation of BL31 capable of booting mainline U-Boot and Linux. Tested on a SEI510 board. Signed-off-by: Carlo Caione <ccaione@baylibre.com> Change-Id: Ife958f10e815a4530292c45446adb71239f3367f
2019-09-18amlogic: makefile: Use PLAT variable when possibleCarlo Caione
To address the file names. Signed-off-by: Carlo Caione <ccaione@baylibre.com> Change-Id: Ib79b8dfa032a1db012c5031d47de61e1a16b5f9a
2019-09-18amlogic: sha_dma: Move register mappings to platform headerCarlo Caione
The registers location for the SHA DMA driver is not unique for the different platforms. Move the mapping out of the driver and into the platform-specific header. Signed-off-by: Carlo Caione <ccaione@baylibre.com> Change-Id: Ice64637844a3cb384b01e466cb8c1cea5f764129
2019-09-17amlogic: scpi: Add support to retrieve chip IDCarlo Caione
Both kernel and U-Boot use a SMC call to the secure monitor to get the chip ID. This call is translated by BL31 to a call to the SCP to retrieve the ID. Add a new SiP call and the backing SCPI command. Signed-off-by: Carlo Caione <ccaione@baylibre.com> Change-Id: Ib128f5645ee92866e7ebbcd550dacd33f573524b
2019-09-12amlogic: console: Move console driver to common directoryCarlo Caione
The code managing the console is the same for all the platforms currently supported. Since it is unlikely to change in the future move the code to an external file in the common directory. Signed-off-by: Carlo Caione <ccaione@baylibre.com> Change-Id: I6df555ea82d483b4f08a4a1e2cb0a7488fbaa015
2019-09-11amlogic: Fix includes orderCarlo Caione
As part of the code refactoring fix the order of the include files across all the source files. Signed-off-by: Carlo Caione <ccaione@baylibre.com> Change-Id: Ice72f687cc26ee881a9051168149467688100cfb
2019-09-11amlogic: Fix header guardsCarlo Caione
Make the header guards more generic and contextually remove the GXBB_BL31_PLAT_PARAM_VAL value that is unused on the GXL platform. Signed-off-by: Carlo Caione <ccaione@baylibre.com> Change-Id: I842fa2e084e71280ae17b39c67877e844821a171
2019-09-05amlogic: Fix prefixes in the SoC specific filesCarlo Caione
Remove the GXBB prefix where needed and add SoC specific prefixes for GXBB/GXL. Signed-off-by: Carlo Caione <ccaione@baylibre.com> Change-Id: Ic3eb3a77ca2d9c779a9dee5cee786e9c16ecdb27
2019-09-05amlogic: Fix prefixes in the PM codeCarlo Caione
Remove the GXBB prefix from the code in the common directory and add SoC-specific prefixes in the SoC specific code. Signed-off-by: Carlo Caione <ccaione@baylibre.com> Change-Id: Ic983ef70b0ef23f95088dd8df488d8c42c3bc030
2019-09-05amlogic: Fix prefixes in the SCPI related codeCarlo Caione
Add a new aml_* prefix to the SCPI related function calls. Signed-off-by: Carlo Caione <ccaione@baylibre.com> Change-Id: I697812ac1c0df28cbb639a1dc3e838f1107fb739
2019-09-05amlogic: Fix prefixes in the MHU codeCarlo Caione
Make the MHU code AML specific adding a new aml_* prefix and remove the GXBB prefix from the register names. Signed-off-by: Carlo Caione <ccaione@baylibre.com> Change-Id: I8f20918e29f08542bd71bd679f88e65b4efaa7d2
2019-09-05amlogic: Fix prefixes in the SIP/SVC codeCarlo Caione
All the SIP/SVC related code is currently the same between GXL and GXBB. Rename function names and register names to avoid hardcoding the GXBB prefix. Signed-off-by: Carlo Caione <ccaione@baylibre.com> Change-Id: I7e58ab68489df8d4762663fc01fb64e6899cc8bf
2019-09-05amlogic: Fix prefixes in the thermal driverCarlo Caione
No need to have a special SoC-specific prefix. Signed-off-by: Carlo Caione <ccaione@baylibre.com> Change-Id: I0da543e7d92d56604e79440a98027ffd9a2eaa59
2019-09-05amlogic: Fix prefixes in the private header fileCarlo Caione
The header file is shared between all the SoCs. Better avoiding hardcoding the SoC name in the function names. Signed-off-by: Carlo Caione <ccaione@baylibre.com> Change-Id: I9074871bd1ed8a702c1a656e0f50f2d3c6cb0425
2019-09-05amlogic: Fix prefixes in the efuse driverCarlo Caione
The efuse driver is hardcoding the GXBB prefix. No need to do that since the driver is shared between multiple SoCs. Signed-off-by: Carlo Caione <ccaione@baylibre.com> Change-Id: I97691b0bbd55170d8216d301a3fc04feb8c2af2e
2019-09-05amlogic: Fix prefixes in the platform macros fileCarlo Caione
Fixing at the same time the related register names. Signed-off-by: Carlo Caione <ccaione@baylibre.com> Change-Id: Ib1130d50abe6088f1c0826878d1ae454a0f23008
2019-09-05amlogic: Fix prefixes in the helpers fileCarlo Caione
The code is the common directory is now generic, no need to have the SoC prefix hardcoded in the function names. Signed-off-by: Carlo Caione <ccaione@baylibre.com> Change-Id: Ied3a5e506b9abd4c2d6f893bafef50019bff24f1
2019-09-05amlogic: Rework MakefilesCarlo Caione
Now that every piece is in place, the makefiles can be refactored and slightly beautified removing useless and redundant parts. Signed-off-by: Carlo Caione <ccaione@baylibre.com> Change-Id: If74e1909df52d475cf4b0dfed819d07d3a4c85b9
2019-09-05amlogic: Move the SIP SVC code to common directoryCarlo Caione
The code is the same between GXBB and GXL. Move it to the common source directory. Signed-off-by: Carlo Caione <ccaione@baylibre.com> Change-Id: I875689a6fd029971aa755fc2725217e90ed06b6c
2019-09-05amlogic: Move topology file to common directoryCarlo Caione
As done already for multiple files, move the topology file to the common directory. Signed-off-by: Carlo Caione <ccaione@baylibre.com> Change-Id: Iaca357a089593ad58c35c05c929239132249dcda
2019-09-05amlogic: Move thermal code to common directoryCarlo Caione
As for most of the Amlogic code, this is common between the Amlogic SoCs. Move the code to the common directory. Signed-off-by: Carlo Caione <ccaione@baylibre.com> Change-Id: Id3f0073ff1f0b9ddbe964f80303323ee4a2f27b0
2019-09-05amlogic: Move MHU code to common directoryCarlo Caione
The MHU code is shared between all the supported platforms. Move it to the common directory instead. Signed-off-by: Carlo Caione <ccaione@baylibre.com> Change-Id: Iaf53122866eae85c13f772927d16836dcfa877a3
2019-09-05amlogic: Move efuse code to common directoryCarlo Caione
The efuse code is the same between GXL and GXBB. Move the code to common directory. Signed-off-by: Carlo Caione <ccaione@baylibre.com> Change-Id: Ie37f21d1907a36292724f1fb645a78041fe4a6b3
2019-09-05amlogic: Move platform macros assembly file to common directoryCarlo Caione
The platform macros are shared between all the SoCs. Move it to common directory. Signed-off-by: Carlo Caione <ccaione@baylibre.com> Change-Id: Ia04c3ffe4d7b068aa701268ed99f69995d8db92b
2019-09-05amlogic: Introduce unified private header fileCarlo Caione
Now that also the SHA256 DMA driver is shared between all the SoCs, we can have one single private platform header file. Signed-off-by: Carlo Caione <ccaione@baylibre.com> Change-Id: I77d51915f9d8233aeceeed66ed1f491573402cfc
2019-09-05amlogic: Move SCPI code to common directoryCarlo Caione
The SCPI code is the same between GXBB and GXL. No need to have it replicated for each SoCs. Move it to the common directory. Signed-off-by: Carlo Caione <ccaione@baylibre.com> Change-Id: I7e416caf1e9538b3ce7702c0363ee00a054e2451
2019-09-05amlogic: Move the SHA256 DMA driver to common directoryCarlo Caione
The SHA256 DMA driver can be used by multiple SoCs. Move it to the common directory. Signed-off-by: Carlo Caione <ccaione@baylibre.com> Change-Id: I96319eeeeeebd503ef0dcb07c0e4ff6a67afeaa5
2019-09-05amlogic: Move assembly helpers to common directoryCarlo Caione
The assembly helpers are common to all the amlogic SoCs. Move the .S file to the common directory. Signed-off-by: Carlo Caione <ccaione@baylibre.com> Change-Id: I0d8616a7ae22dbcb14848cefd0149b6bb5814ea6
2019-09-05amlogic: Introduce directory parameters in the makefilesCarlo Caione
Make the platform name a parameter for the source directories. Besides a cosmetic fix, this is going to be helpful when reusing the same Makefile for different SoCs. Signed-off-by: Carlo Caione <ccaione@baylibre.com> Change-Id: I307897a21800cca8ad68a5ab8972d27e9356ff2a
2019-09-05meson: Rename platform directory to amlogicCarlo Caione
Meson is the internal code name for the SoC family. The correct name for the platform should be Amlogic. Change the name of the platform directory. Signed-off-by: Carlo Caione <ccaione@baylibre.com> Change-Id: Icc140e1ea137f12117acbf64c7dcb1a8b66b345d
