path: root/make_helpers/windows.mk
2017-05-08Merge pull request #926 from EvanLloyd/win_make_4davidcunado-arm
Minor makefile fixes
2017-05-03Use SPDX license identifiersdp-arm
To make software license auditing simpler, use SPDX[0] license identifiers instead of duplicating the license text in every file. NOTE: Files that have been imported by FreeBSD have not been modified. [0]: https://spdx.org/ Change-Id: I80a00e1f641b8cc075ca5a95b10607ed9ed8761a Signed-off-by: dp-arm <dimitris.papastamos@arm.com>
2017-05-02Build: Fix parallel buildEvan Lloyd
2 problems were found, but are in one change to avoid submitting a patch that might fail to build. The problems were: 1. The macro MAKE_PREREQ_DIR has a minor bug, in that it is capable of generating recursive dependencies. 2. The inclusion of BUILD_DIR in TEMP_OBJ_DIRS left no explicit dependency, BUILD_DIR might not exist when subdirectories are created by a thread on another CPU. This fix corrects these with the following changes: 1. MAKE_PREREQ_DIR does nothing for a direct self dependency. 2. BUILD_DIR is built using MAKE_PREREQ_DIR. 3. BUILD_DIR is an explicit prerequisite of all OBJ_DIRS. Change-Id: I938cddea4a006df225c02a47b9cf759212f27fb7 Signed-off-by: Evan Lloyd <evan.lloyd@arm.com>
2017-01-05Build: exclude -c flag from TF_CFLAGSMasahiro Yamada
The -c flag should not be included in the global variable TF_CFLAGS; it should be specified in the build rule only when its target is a *.o file. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-04-14Give user's compiler flags precedence over default onesSandrine Bailleux
The user can provide additional CFLAGS to use when building TF. However, these custom CFLAGS are currently prepended to the standard CFLAGS that are hardcoded in the TF build system. This is an issue because when providing conflicting compiler flags (e.g. different optimisations levels like -O1 and -O0), the last one on the command line usually takes precedence. This means that the user flags get overriden. To address this problem, this patch separates the TF CFLAGS from the user CFLAGS. The former are now stored in the TF_CFLAGS make variable, whereas the CFLAGS make variable is untouched and reserved for the user. The order of the 2 sets of flags is enforced when invoking the compiler. Fixes ARM-Software/tf-issues#350 Change-Id: Ib189f44555b885f1dffbec6015092f381600e560
2016-04-01Make:Improve version string generation portabilityEvan Lloyd
To get round problems encountered when building in a DOS build environment the generation of the .o file containing build identifier strings is modified. The problems encounterred were: 1. DOS echo doesn't strip ' characters from the output text. 2. git is not available from CMD.EXE so the BUILD_STRING value needs some other origin. A BUILD_STRING value of "development build" is used for now. MAKE_BUILD_STRINGS is used to customise build string generation in a DOS environment. This variable is not defined in the UNIX build environment make file helper, and so the existing build string generation behaviour is retained in these build environments. NOTE: This commit completes a cumulative series aimed at improving build portability across development environments. This enables the build to run on several new build environments, if the relevant tools are available. At this point the build is tested on Windows 7 Enterprise SP1, using CMD.EXE, Cygwin and Msys (MinGW),as well as a native Linux envionment". The Windows platform builds used aarch64-none-elf-gcc.exe 4.9.1. CMD.EXE and Msys used Gnu Make 3.81, cygwin used Gnu Make 4.1. CAVEAT: The cert_create tool build is not tested on the Windows platforms (openssl-for-windows has a GPL license). Change-Id: Iaa4fc89dbe2a9ebae87e2600c9eef10a6af30251
2016-04-01Make:Allow for extension in tool names.Evan Lloyd
In some build environments executable programs have a specific file extension. The value of BIN_EXT is appended to the relevant tool file names to allow for this. The value of BIN_EXT is set, where appropriate, by the build environment specific make helper (to .exe for Windows build environments). .gitignore is updated to hide the new (.exe) files. Change-Id: Icc32f64b750e425265075ad4e0dea18129640b86
2016-04-01Make:Use environment variables for OS detection.Evan Lloyd
Add make helper files to select the appropriate settings for the build environment. Selection is made in make_helpers/build_env.mk, which selects other files to include using generic build environment settings. The Trusted Firmware Makefile and supporting tool Makefiles are updated to include build_env.mk instead of unix.mk. NOTE: This change does not fully enable builds in other build environments. It facilitates this without compromising the existing build environments. Change-Id: Ic4064ffe6ce158bbd16d7cc9f27dd4655a3580f6
