path: root/make_helpers/unix.mk
2018-10-19Makefile: Fix verbose builds on WindowsAntonio Nino Diaz
Commit <ee1ba6d4ddf1> ("Makefile: Support totally quiet output with -s") broke verbose (V=1) builds on Windows. This patch fixes it by adding helpers to silence echo prints in a OS-dependent way. Change-Id: I24669150457516e9fb34fa32fa103398efe8082d Signed-off-by: Antonio Nino Diaz <antonio.ninodiaz@arm.com>
2017-05-08Merge pull request #926 from EvanLloyd/win_make_4davidcunado-arm
Minor makefile fixes
2017-05-03Use SPDX license identifiersdp-arm
To make software license auditing simpler, use SPDX[0] license identifiers instead of duplicating the license text in every file. NOTE: Files that have been imported by FreeBSD have not been modified. [0]: https://spdx.org/ Change-Id: I80a00e1f641b8cc075ca5a95b10607ed9ed8761a Signed-off-by: dp-arm <dimitris.papastamos@arm.com>
2017-05-02Build: Fix parallel buildEvan Lloyd
2 problems were found, but are in one change to avoid submitting a patch that might fail to build. The problems were: 1. The macro MAKE_PREREQ_DIR has a minor bug, in that it is capable of generating recursive dependencies. 2. The inclusion of BUILD_DIR in TEMP_OBJ_DIRS left no explicit dependency, BUILD_DIR might not exist when subdirectories are created by a thread on another CPU. This fix corrects these with the following changes: 1. MAKE_PREREQ_DIR does nothing for a direct self dependency. 2. BUILD_DIR is built using MAKE_PREREQ_DIR. 3. BUILD_DIR is an explicit prerequisite of all OBJ_DIRS. Change-Id: I938cddea4a006df225c02a47b9cf759212f27fb7 Signed-off-by: Evan Lloyd <evan.lloyd@arm.com>
2016-04-01Make:Make shell commands more portableEvan Lloyd
Macros are inserted to replace direct invocations of commands that are problematic on some build environments. (e.g. Some environments expect \ in paths instead of /.) The changes take into account mismatched command mappings across environments. The new helper file unix.mk retains existing makefile behaviour on unix like build environments by providing the following macro definitions: SHELL_COPY cp -f SHELL_COPY_TREE cp -rf SHELL_DELETE rm -f SHELL_DELETE_ALL rm -rf MAKE_PREREQ_DIR mkdir -p (As make target) SHELL_REMOVE_DIR rm -rf Change-Id: I1b5ca5e1208e78230b15284c4af00c1c006cffcb
