2017-05-03 | Use SPDX license identifiers | dp-arm | |
To make software license auditing simpler, use SPDX[0] license identifiers instead of duplicating the license text in every file. NOTE: Files that have been imported by FreeBSD have not been modified. [0]: https://spdx.org/ Change-Id: I80a00e1f641b8cc075ca5a95b10607ed9ed8761a Signed-off-by: dp-arm <dimitris.papastamos@arm.com> | |||
2016-04-01 | Make:Remove calls to shell from makefiles. | Evan Lloyd | |
As an initial stage of making Trusted Firmware build environment more portable, we remove most uses of the $(shell ) function and replace them with more portable make function based solutions. Note that the setting of BUILD_STRING still uses $(shell ) since it's not possible to reimplement this as a make function. Avoiding invocation of this on incompatible host platforms will be implemented separately. Change-Id: I768e2f9a265c78814a4adf2edee4cc46cda0f5b8 |
