path: root/make_helpers/build_env.mk
2017-05-03Use SPDX license identifiersdp-arm
To make software license auditing simpler, use SPDX[0] license identifiers instead of duplicating the license text in every file. NOTE: Files that have been imported by FreeBSD have not been modified. [0]: https://spdx.org/ Change-Id: I80a00e1f641b8cc075ca5a95b10607ed9ed8761a Signed-off-by: dp-arm <dimitris.papastamos@arm.com>
2016-12-14Fix incorrect copyright noticesAntonio Nino Diaz
Some files have incorrect copyright notices, this patch fixes all files with deviations from the standard notice. Change-Id: I66b73e78a50a235acb55f1e2ec2052a42c0570d2 Signed-off-by: Antonio Nino Diaz <antonio.ninodiaz@arm.com>
2016-04-01Make:Use environment variables for OS detection.Evan Lloyd
Add make helper files to select the appropriate settings for the build environment. Selection is made in make_helpers/build_env.mk, which selects other files to include using generic build environment settings. The Trusted Firmware Makefile and supporting tool Makefiles are updated to include build_env.mk instead of unix.mk. NOTE: This change does not fully enable builds in other build environments. It facilitates this without compromising the existing build environments. Change-Id: Ic4064ffe6ce158bbd16d7cc9f27dd4655a3580f6
