Update Arm Trusted Firmware references in the upstream documents to
Trusted Firmware-A (TF-A). This is for consistency with and
disambiguation from Trusted Firmware-M (TF-M).
Also update other Arm trademarks, e.g. ARM->Arm, ARMv8->Armv8-A.
Change-Id: I8bb0e18af29c6744eeea2dc6c08f2c10b20ede22
Signed-off-by: Dan Handley <dan.handley@arm.com>
Signed-off-by: David Cunado <david.cunado@arm.com>
Signed-off-by: Victor Chong <victor.chong@linaro.org>
* Update the RockChip sub-maintainer from rkchrome to rockchip-linux
in maintainers.rst.
* Add missing documentation files and change extensions from `md` to `rst`.
* Add sub-maintainer for Socionext UniPhier platform.
Change-Id: I7f498316acb0f7947c6432dbe14988e61a8903fe
Co-Authored-By: Antonio Nino Diaz <antonio.ninodiaz@arm.com>
Update Xilinx maintainer details
This port can be compiled to boot an AArch64 or AArch32 payload with the
build option `RPI3_BL33_AARCH32`.
Note: This is not a secure port of the Trusted Firmware. This port is
only meant to be a reference implementation to experiment with an
inexpensive board in real hardware.
Change-Id: Ide58114299289bf765ef1366199eb05c46f81903
Co-authored-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Signed-off-by: Antonio Nino Diaz <antonio.ninodiaz@arm.com>
This patch updates Xilinx maintainers details
as sorenb is no more the maintainer for xilinx
and the email id is invalid now.
Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com>
External build environment shall sets directive ARM_ARCH_MAJOR to 7
to specify a target ARMv7-A core.
As ARM-TF expects AARCH to be set, ARM_ARCH_MAJOR==7 mandates
AARCH=aarch32.
The toolchain target architecture/cpu is delegated after the platform
configuration is parsed. Platform shall define target core through
ARM_CORTEX_A<x>=yes, <x> being 5, 7, 9, 12, 15 and/or 17.
Platform can bypass ARM_CORTEX_A<x>=yes directive and provide straight
the toolchain target directive through MARCH32_DIRECTIVE.
Signed-off-by: Etienne Carriere <etienne.carriere@linaro.org>
Due to recent issues in the rendering of the documentation on GitHub and
some long-standing issues like the lack of automatic table of content in
Markdown, the documentation has been converted to reStructuredText.
Basic constructs looks pretty similar to Markdown.
Automatically convert GitHub markdown documentation to reStructuredText
using pandoc.
Change-Id: If20b695acedc6d1b49c8d9fb64efd6b6ba23f4a9
Signed-off-by: Douglas Raillard <douglas.raillard@arm.com>
